_Scheduler_default_Pin_or_unpin_not_supported, \
_Scheduler_SMP_Start_idle \
SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION \
void _Scheduler_simple_SMP_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes the node with the given attributes.
Definition schedulersimplesmp.c:74
void _Scheduler_simple_SMP_Make_sticky(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Makes the node sticky.
Definition schedulersimplesmp.c:392
bool _Scheduler_simple_SMP_Ask_for_help(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Asks for help.
Definition schedulersimplesmp.c:342
void _Scheduler_simple_SMP_Yield(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Definition schedulersimplesmp.c:461
void _Scheduler_simple_SMP_Block(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Blocks a thread.
Definition schedulersimplesmp.c:218
Thread_Control * _Scheduler_simple_SMP_Remove_processor(const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
Removes an idle thread from the given cpu.
Definition schedulersimplesmp.c:443
void _Scheduler_simple_SMP_Reconsider_help_request(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Reconsiders help.
Definition schedulersimplesmp.c:353
void _Scheduler_simple_SMP_Clean_sticky(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Cleans the sticky property from the node.
Definition schedulersimplesmp.c:407
void _Scheduler_simple_SMP_Withdraw_node(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
Withdraws node.
Definition schedulersimplesmp.c:369
void _Scheduler_simple_SMP_Unblock(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Unblocks a thread.
Definition schedulersimplesmp.c:283
void _Scheduler_simple_SMP_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Updates the priority of the node.
Definition schedulersimplesmp.c:321
void _Scheduler_simple_SMP_Initialize(const Scheduler_Control *scheduler)
Initializes the scheduler's context.
Definition schedulersimplesmp.c:65
void _Scheduler_simple_SMP_Add_processor(const Scheduler_Control *scheduler, Thread_Control *idle)
Adds idle to scheduler.
Definition schedulersimplesmp.c:427
void _Scheduler_default_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Does nothing.
Definition schedulerdefaultreleasejob.c:44
void _Scheduler_default_Node_destroy(const Scheduler_Control *scheduler, Scheduler_Node *node)
Does nothing.
Definition schedulerdefaultnodedestroy.c:45
Priority_Control _Scheduler_default_Map_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Returns the scheduler internal thread priority mapped by SCHEDULER_PRIORITY_MAP().
Definition schedulerdefaultmappriority.c:43
void _Scheduler_default_Schedule(const Scheduler_Control *scheduler, Thread_Control *the_thread)
Does nothing.
Definition schedulerdefaultschedule.c:43
Priority_Control _Scheduler_default_Unmap_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Returns the user visible thread priority unmapped by SCHEDULER_PRIORITY_UNMAP().
Definition schedulerdefaultmappriority.c:51
void _Scheduler_default_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Does nothing.
Definition schedulerdefaultreleasejob.c:59
Entry points for the Simple SMP Scheduler.
