RTEMS 6.3
This group contains the implementation to execute a routine only once. More...
Files | |
| file | cpukit/include/rtems/score/onceimpl.h |
| This header file provides the interfaces of the Execute Once Support. | |
| file | cpukit/score/src/once.c |
| This source file contains the implementation of _Once(), _Once_Lock(), and _Once_Unlock(). | |
| int | _Once (unsigned char *once_state, void(*init_routine)(void)) |
| Reacts according to the state of once_state. | |
| int _Once | ( | unsigned char * | once_state, |
| void(* | init_routine )(void) ) |
If once_state is ONCE_STATE_INIT, then the once state is set first to ONCE_STATE_RUNNING and after calling the init routine it is set to ONCE_STATE_COMPLETED. If once_state is ONCE_STATE_COMPLETED, nothing happens. If once_state is not either one, this method waits for the Once_Information_Mutex.
| once_state | The once state. |
| init_routine | The initialization routine called if once_state is ONCE_STATE_INIT. |
