RTEMS 6.3
This group contains the SMP Scheduler implementation. More...
Topics | |
| Deterministic Priority SMP Scheduler | |
| This group contains the Deterministic Priority SMP Scheduler implementation. | |
| Earliest Deadline First (EDF) Priority SMP Scheduler | |
| This group contains the Earliest Deadline First (EDF) Priority SMP Scheduler implementation. | |
| Simple Priority SMP Scheduler | |
| This group contains the Simple Priority SMP Scheduler implementation. | |
| Strong APA Scheduler | |
| This group contains the Strong APA Scheduler implementation. | |
Files | |
| file | cpukit/include/rtems/score/schedulersmp.h |
| This header file provides interfaces of the SMP Scheduler which are used by the implementation and the Application Configuration. | |
| file | cpukit/include/rtems/score/schedulersmpimpl.h |
| This header file provides interfaces of the SMP Scheduler which are only used by the implementation. | |
| struct | Scheduler_SMP_Context |
| Scheduler context specialization for SMP schedulers. More... | |
| struct | Scheduler_SMP_Node |
| Scheduler node specialization for SMP schedulers. More... | |
Typedefs | |
| typedef bool(*) | Scheduler_SMP_Has_ready(Scheduler_Context *context) |
| typedef Scheduler_Node *(*) | Scheduler_SMP_Get_highest_ready(Scheduler_Context *context, Scheduler_Node *filter) |
| typedef Scheduler_Node *(*) | Scheduler_SMP_Get_lowest_ready(Scheduler_Context *context) |
| typedef Scheduler_Node *(*) | Scheduler_SMP_Get_lowest_scheduled(Scheduler_Context *context, Scheduler_Node *filter) |
| typedef void(*) | Scheduler_SMP_Extract(Scheduler_Context *context, Scheduler_Node *node_to_extract) |
| typedef void(*) | Scheduler_SMP_Insert(Scheduler_Context *context, Scheduler_Node *node_to_insert, Priority_Control insert_priority) |
| typedef void(*) | Scheduler_SMP_Move(Scheduler_Context *context, Scheduler_Node *node_to_move) |
| typedef bool(*) | Scheduler_SMP_Ask_for_help(Scheduler_Context *context, Thread_Control *thread, Scheduler_Node *node) |
| typedef void(*) | Scheduler_SMP_Update(Scheduler_Context *context, Scheduler_Node *node_to_update, Priority_Control new_priority) |
| typedef void(*) | Scheduler_SMP_Set_affinity(Scheduler_Context *context, Scheduler_Node *node, void *arg) |
| typedef bool(*) | Scheduler_SMP_Enqueue(Scheduler_Context *context, Scheduler_Node *node_to_enqueue, Priority_Control priority) |
| typedef void(*) | Scheduler_SMP_Enqueue_scheduled(Scheduler_Context *context, Scheduler_Node *node_to_enqueue, Priority_Control priority) |
| typedef void(*) | Scheduler_SMP_Allocate_processor(Scheduler_Context *context, Scheduler_Node *scheduled, Per_CPU_Control *cpu) |
| typedef void(*) | Scheduler_SMP_Register_idle(Scheduler_Context *context, Scheduler_Node *idle, Per_CPU_Control *cpu) |
Enumerations | |
| enum | Scheduler_SMP_Node_state { SCHEDULER_SMP_NODE_BLOCKED , SCHEDULER_SMP_NODE_SCHEDULED , SCHEDULER_SMP_NODE_READY } |
| SMP scheduler node states. More... | |
| enum | Scheduler_SMP_Action { SCHEDULER_SMP_DO_SCHEDULE , SCHEDULER_SMP_DO_NOT_SCHEDULE } |
| This enumeration defines what a scheduler should do with a node which could be scheduled. | |
| void | _Scheduler_SMP_Start_idle (const Scheduler_Control *scheduler, Thread_Control *idle, struct Per_CPU_Control *cpu) |
| Starts an idle thread on the specified cpu. | |
| void | _Scheduler_SMP_Remove_ask_for_help_from_processor (Thread_Control *thread, Per_CPU_Control *cpu) |
| Removes the thread's ask for help request from the processor. | |
The scheduler nodes can be in four states
State transitions are triggered via basic operations
During system initialization each processor of the scheduler instance starts with an idle thread assigned to it. Lets have a look at an example with two idle threads I and J with priority 5. We also have blocked threads A, B and C with priorities 1, 2 and 3 respectively. The scheduler nodes are ordered with respect to the thread priority from left to right in the below diagrams. The highest priority node (lowest priority number) is the leftmost node. Since the processor assignment is independent of the thread priority the processor indices may move from one state to the other.
Lets start A. For this an enqueue operation is performed.
Lets start C.
Lets start B.
Lets change the priority of thread A to 4.
Now perform a blocking operation with thread B. Please note that thread A migrated now from processor 0 to processor 1 and thread C still executes on processor 1.
| void _Scheduler_SMP_Remove_ask_for_help_from_processor | ( | Thread_Control * | thread, |
| Per_CPU_Control * | cpu ) |
The caller must be the owner of the thread's scheduler lock.
| [in,out] | thread | is the thread of the ask for help request. |
| [in,out] | cpu | is the processor from which the ask for help request should be removed. |
| void _Scheduler_SMP_Start_idle | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | idle, | ||
| struct Per_CPU_Control * | cpu ) |
| scheduler | The scheduler instance. | |
| [in,out] | idle | The idle thread to schedule. |
| [out] | cpu | The cpu to run the idle thread on. |
