RTEMS 6.3
This group contains the EDF Scheduler implementation. More...
file  cpukit/include/rtems/score/scheduleredf.h
 This header file provides interfaces of the EDF Scheduler which are used by the implementation and the Application Configuration.
file  cpukit/include/rtems/score/scheduleredfimpl.h
 This header file provides interfaces of the EDF Scheduler which are only used by the implementation.
file  cpukit/score/src/scheduleredf.c
 This source file contains the implementation of _Scheduler_EDF_Initialize().
file  cpukit/score/src/scheduleredfblock.c
 This source file contains the implementation of _Scheduler_EDF_Block().
file  cpukit/score/src/scheduleredfchangepriority.c
 This source file contains the implementation of _Scheduler_EDF_Update_priority().
file  cpukit/score/src/scheduleredfnodeinit.c
 This source file contains the implementation of _Scheduler_EDF_Node_initialize().
file  cpukit/score/src/scheduleredfreleasejob.c
 This source file contains the implementation of _Scheduler_EDF_Map_priority(), _Scheduler_EDF_Unmap_priority(), _Scheduler_EDF_Release_job(), and _Scheduler_EDF_Cancel_job().
file  cpukit/score/src/scheduleredfschedule.c
 This source file contains the implementation of _Scheduler_EDF_Schedule().
file  cpukit/score/src/scheduleredfunblock.c
 This source file contains the implementation of _Scheduler_EDF_Unblock().
file  cpukit/score/src/scheduleredfyield.c
 This source file contains the implementation of _Scheduler_EDF_Yield().
struct  Scheduler_EDF_Context
struct  Scheduler_EDF_Node
 Scheduler node specialization for EDF schedulers. More...
#define SCHEDULER_EDF_MAXIMUM_PRIORITY   INT_MAX
#define SCHEDULER_EDF_ENTRY_POINTS
#define SCHEDULER_EDF_PRIO_MSB   0x8000000000000000
void _Scheduler_EDF_Initialize (const Scheduler_Control *scheduler)
 Initializes EDF scheduler.
void _Scheduler_EDF_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Removes the blocking thread from the ready queue and schedules is only again if the thread is executing or the heir thread.
void _Scheduler_EDF_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Sets the heir thread to be the next ready thread in the rbtree ready queue.
void _Scheduler_EDF_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes an EDF specific scheduler node of the_thread.
void _Scheduler_EDF_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Performs an unblocking of the thread.
void _Scheduler_EDF_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Updates the priority of the scheduler node.
Priority_Control _Scheduler_EDF_Map_priority (const Scheduler_Control *scheduler, Priority_Control priority)
 Gets the mapped priority map of the priority control.
Priority_Control _Scheduler_EDF_Unmap_priority (const Scheduler_Control *scheduler, Priority_Control priority)
 Gets the unmapped priority map of the priority control.
void _Scheduler_EDF_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Executes a thread yield for the thread.
void _Scheduler_EDF_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
 Releases a EDF job.
void _Scheduler_EDF_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
 Cancels a job and removes the thread from the queue context.
◆ SCHEDULER_EDF_ENTRY_POINTS
Value:
SCHEDULER_DEFAULT_SMP_OPERATIONS \
_Scheduler_EDF_Node_initialize, \
_Scheduler_default_Start_idle \
SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION \
void _Scheduler_EDF_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition scheduleredfunblock.c:46
void _Scheduler_EDF_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition scheduleredfyield.c:44
void _Scheduler_EDF_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Definition scheduleredfreleasejob.c:98
void _Scheduler_EDF_Initialize(const Scheduler_Control *scheduler)
Definition scheduleredf.c:44
void _Scheduler_EDF_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Releases a EDF job.
Definition scheduleredfreleasejob.c:61
void _Scheduler_EDF_Block(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Removes the blocking thread from the ready queue and schedules is only again if the thread is executi...
Definition scheduleredfblock.c:44
Priority_Control _Scheduler_EDF_Map_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Definition scheduleredfreleasejob.c:45
Priority_Control _Scheduler_EDF_Unmap_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Definition scheduleredfreleasejob.c:53
void _Scheduler_EDF_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition scheduleredfchangepriority.c:44
void _Scheduler_EDF_Schedule(const Scheduler_Control *scheduler, Thread_Control *the_thread)
Definition scheduleredfschedule.c:44
void _Scheduler_default_Node_destroy(const Scheduler_Control *scheduler, Scheduler_Node *node)
Does nothing.
Definition schedulerdefaultnodedestroy.c:45
Entry points for the Earliest Deadline First Scheduler.
◆ SCHEDULER_EDF_PRIO_MSB
This is just a most significant bit of Priority_Control type. It distinguishes threads which are deadline driven (priority represented by a lower number than SCHEDULER_EDF_PRIO_MSB) from those ones who do not have any deadlines and thus are considered background tasks.
◆ _Scheduler_EDF_Block()
void _Scheduler_EDF_Block ( const Scheduler_Control * scheduler,
Thread_Control * the_thread,
Scheduler_Node * node )
Parameters
[in,out]schedulerThe scheduler for the operation.
the_threadThe thread to operate upon.
[in,out]nodeThe scheduler node for this thread.
◆ _Scheduler_EDF_Cancel_job()
void _Scheduler_EDF_Cancel_job ( const Scheduler_Control * scheduler,
Priority_Node * priority_node,
Thread_queue_Context * queue_context )
Parameters
schedulerThe scheduler instance.
the_threadThe thread for the operation.
[in,out]priority_nodeThe corresponding priority node.
[in,out]queue_contextThe thread queue context.
◆ _Scheduler_EDF_Initialize()
void _Scheduler_EDF_Initialize ( const Scheduler_Control * scheduler)
This routine initializes the EDF scheduler.
Parameters
[in,out]schedulerThe scheduler instance.
◆ _Scheduler_EDF_Map_priority()
Priority_Control _Scheduler_EDF_Map_priority ( const Scheduler_Control * scheduler,
Priority_Control priority )
Parameters
schedulerNot used in this operation.
priorityThe priority control to get the priority map of.
Returns
The mapped priority map of priority.
◆ _Scheduler_EDF_Node_initialize()
void _Scheduler_EDF_Node_initialize ( const Scheduler_Control * scheduler,
Scheduler_Node * node,
Parameters
nodeThe node being initialized.
the_threadThe thread of the node.
priorityThe thread priority.
◆ _Scheduler_EDF_Release_job()
void _Scheduler_EDF_Release_job ( const Scheduler_Control * scheduler,
uint64_t deadline,
Releases a EDF job.
Parameters
[in,out]priority_nodeThe priority node for the operation.
deadlineThe deadline for the job.
◆ _Scheduler_EDF_Schedule()
void _Scheduler_EDF_Schedule ( const Scheduler_Control * scheduler,
Thread_Control * the_thread )
This kernel routine sets the heir thread to be the next ready thread in the rbtree ready queue.
Parameters
the_threadThe thread being scheduled.
◆ _Scheduler_EDF_Unblock()
void _Scheduler_EDF_Unblock ( const Scheduler_Control * scheduler,
Parameters
the_threadThe unblocking thread. May be set as new heir.
[in,out]nodeThe scheduler node for the thread.
◆ _Scheduler_EDF_Unmap_priority()
Priority_Control _Scheduler_EDF_Unmap_priority ( const Scheduler_Control * scheduler,
Parameters
Returns
The unmapped priority map of priority.
◆ _Scheduler_EDF_Update_priority()
void _Scheduler_EDF_Update_priority ( const Scheduler_Control * scheduler,
Parameters
[in,out]nodeThe priority node to update the priority of.
◆ _Scheduler_EDF_Yield()
void _Scheduler_EDF_Yield ( const Scheduler_Control * scheduler,
Parameters
the_threadThe thread that performs the yield.
