RTEMS
6.3
Toggle main menu visibility
include
score
isrlevel.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
13
14
15
* COPYRIGHT (c) 1989-2011.
16
* On-Line Applications Research Corporation (OAR).
17
18
19
* modification, are permitted provided that the following conditions
20
* are met:
21
* 1. Redistributions of source code must retain the above copyright
22
* notice, this list of conditions and the following disclaimer.
23
* 2. Redistributions in binary form must reproduce the above copyright
24
* notice, this list of conditions and the following disclaimer in the
25
* documentation and/or other materials provided with the distribution.
26
27
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37
* POSSIBILITY OF SUCH DAMAGE.
38
39
40
#ifndef _RTEMS_SCORE_ISR_LEVEL_h
41
#define _RTEMS_SCORE_ISR_LEVEL_h
42
43
#include <rtems/score/cpu.h>
44
rtems/score/assert.h
45
46
#ifdef __cplusplus
47
extern
"C"
48
#endif
49
55
60
typedef
uint32_t
ISR_Level
61
76
#define _ISR_Local_disable( _level ) \
77
do { \
78
_CPU_ISR_Disable( _level ); \
79
RTEMS_COMPILER_MEMORY_BARRIER(); \
80
} while (0)
81
93
#define _ISR_Local_enable( _level ) \
94
do { \
95
96
_CPU_ISR_Enable( _level ); \
97
} while (0)
98
118
#define _ISR_Local_flash( _level ) \
119
do { \
120
121
_CPU_ISR_Flash( _level ); \
122
123
} while (0)
124
134
#define _ISR_Is_enabled( _level ) \
135
_CPU_ISR_Is_enabled( _level )
136
147
#define _ISR_Get_level() \
148
_CPU_ISR_Get_level()
149
159
#define _ISR_Set_level( _new_level ) \
160
do { \
161
162
_CPU_ISR_Set_level( _new_level ); \
163
164
} while (0)
165
175
bool
_ISR_Is_in_progress
void
176
178
179
#ifdef __cplusplus
180
181
#endif
182
#endif
assert.h
This header file provides the interfaces of the Assert Handler.
_ISR_Is_in_progress
bool _ISR_Is_in_progress(void)
Checks if an ISR in progress.
Definition
nios2-isr-is-in-progress.c:36
ISR_Level
uint32_t ISR_Level
Definition
isrlevel.h:60
