RTEMS
6.3
Toggle main menu visibility
include
score
sysstate.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* COPYRIGHT (c) 1989-2011.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_SCORE_SYSSTATE_H
39
#define _RTEMS_SCORE_SYSSTATE_H
40
41
rtems/score/basedefs.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
56
60
typedef
enum
64
SYSTEM_STATE_BEFORE_INITIALIZATION
65
70
SYSTEM_STATE_BEFORE_MULTITASKING
71
75
SYSTEM_STATE_UP
76
80
SYSTEM_STATE_TERMINATED
81
System_state_Codes
82
83
#define SYSTEM_STATE_CODES_FIRST SYSTEM_STATE_BEFORE_INITIALIZATION
84
85
#define SYSTEM_STATE_CODES_LAST SYSTEM_STATE_TERMINATED
86
87
#if defined(RTEMS_MULTIPROCESSING)
88
extern
bool
_System_state_Is_multiprocessing;
89
#endif
90
91
extern
System_state_Codes
_System_state_Current;
92
98
static
inline
void
_System_state_Set (
99
System_state_Codes
state
100
101
102
_System_state_Current = state;
103
104
110
static
inline
System_state_Codes
_System_state_Get (
void
111
112
return
113
114
123
static
inline
bool
_System_state_Is_before_initialization (
124
System_state_Codes
state
125
126
127
return
(state ==
128
129
138
static
inline
bool
_System_state_Is_before_multitasking (
139
System_state_Codes
state
140
141
142
return
(state ==
143
144
153
static
inline
bool
_System_state_Is_up (
154
System_state_Codes
state
155
156
157
return
(state ==
SYSTEM_STATE_UP
158
159
168
static
inline
bool
_System_state_Is_terminated (
169
System_state_Codes
state
170
171
172
return
(state ==
173
174
176
177
#ifdef __cplusplus
178
179
#endif
180
181
#endif
182
/* end of include file */
basedefs.h
This header file provides basic definitions used by the API and the implementation.
System_state_Codes
System_state_Codes
System states.
Definition
sysstate.h:60
@ SYSTEM_STATE_TERMINATED
The system reached its terminal state.
Definition
sysstate.h:80
SYSTEM_STATE_UP
@ SYSTEM_STATE_UP
The system is up and operating normally.
Definition
sysstate.h:75
@ SYSTEM_STATE_BEFORE_MULTITASKING
The system is between end of the first phase of initialization but before multitasking is started.
Definition
sysstate.h:70
@ SYSTEM_STATE_BEFORE_INITIALIZATION
The system is before the end of the first phase of initialization.
Definition
sysstate.h:64
