RTEMS 6.3
This header file provides interfaces of the Deterministic Priority SMP Scheduler which are used by the implementation and the Application Configuration. More...
#include <rtems/score/scheduler.h>#include <rtems/score/schedulerpriority.h>#include <rtems/score/schedulersmp.h>Go to the source code of this file.
| struct | Scheduler_priority_SMP_Context |
| Scheduler context specialization for Deterministic Priority SMP schedulers. More... | |
| struct | Scheduler_priority_SMP_Node |
| Scheduler node specialization for Deterministic Priority SMP schedulers. More... | |
| #define | SCHEDULER_PRIORITY_SMP_ENTRY_POINTS |
| Entry points for the Priority SMP Scheduler. | |
| void | _Scheduler_priority_SMP_Initialize (const Scheduler_Control *scheduler) |
| Initializes the priority SMP scheduler. | |
| void | _Scheduler_priority_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes the node with the given priority. | |
| void | _Scheduler_priority_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Blocks the thread. | |
| void | _Scheduler_priority_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Unblocks the thread. | |
| void | _Scheduler_priority_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Updates the priority of the node. | |
| bool | _Scheduler_priority_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Asks for help operation. | |
| void | _Scheduler_priority_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Reconsiders help operation. | |
| void | _Scheduler_priority_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state) |
| Withdraws node operation. | |
| void | _Scheduler_priority_SMP_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Makes the node sticky. | |
| void | _Scheduler_priority_SMP_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Cleans the sticky property from the node. | |
| void | _Scheduler_priority_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle) |
| Adds idle to scheduler. | |
| Thread_Control * | _Scheduler_priority_SMP_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu) |
| Removes an idle thread from the given cpu. | |
| void | _Scheduler_priority_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Performs the yield of a thread. | |
