RTEMS 6.3
This group contains the implementation of the per-CPU information. More...
Topics | |
| Flexible Per-CPU Data | |
| This group contains the implementation to support flexible per-CPU data. | |
Files | |
| file | cpukit/include/rtems/score/percpu.h |
| This header file provides the interfaces of the Per-CPU Information. | |
| file | cpukit/score/src/percpu.c |
| This source file contains the uniprocessor definition of _Per_CPU_Information and some static assertions. | |
| file | cpukit/score/src/percpuasm.c |
| This source file contains the static assertions for defines used in assembler files. | |
| file | cpukit/score/src/percpujobs.c |
| This source file contains the implementation of _Per_CPU_Add_job(), _Per_CPU_Perform_jobs(), _Per_CPU_Submit_job(), and _Per_CPU_Wait_for_job(). | |
| struct | Per_CPU_Stats |
| Per-CPU statistics. More... | |
| struct | Per_CPU_Control |
| Per CPU Core Structure. More... | |
| struct | Per_CPU_Control_envelope |
| struct | Per_CPU_Control::[struct].Watchdog |
| Watchdog state for this processor. More... | |
| #define | _Per_CPU_Acquire(cpu, lock_context) |
| #define | _Per_CPU_Release(cpu, lock_context) |
| #define | _Per_CPU_Get_snapshot() |
| #define | _Per_CPU_Get() |
| #define | _Thread_Dispatch_disable_level _Per_CPU_Get()->thread_dispatch_disable_level |
| #define | _Thread_Heir _Per_CPU_Get()->heir |
| #define | _Thread_Executing _Per_CPU_Get_executing( _Per_CPU_Get() ) |
| #define | _ISR_Nest_level _Per_CPU_Get()->isr_nest_level |
| #define | _CPU_Interrupt_stack_low _Per_CPU_Get()->interrupt_stack_low |
| #define | _CPU_Interrupt_stack_high _Per_CPU_Get()->interrupt_stack_high |
| #define | _Thread_Dispatch_necessary _Per_CPU_Get()->dispatch_necessary |
Typedefs | |
| typedef struct Per_CPU_Control | Per_CPU_Control |
| Per CPU Core Structure. | |
Enumerations | |
| enum | Per_CPU_Watchdog_index { PER_CPU_WATCHDOG_TICKS , PER_CPU_WATCHDOG_REALTIME , PER_CPU_WATCHDOG_MONOTONIC , PER_CPU_WATCHDOG_COUNT } |
| Per-CPU watchdog header index. More... | |
| CPU_STRUCTURE_ALIGNMENT Per_CPU_Control_envelope | _Per_CPU_Information [] |
| Set of Per CPU Core Information. | |
The per-CPU information encapsulates state which is maintained for each configured processor in the system. There will be one instance of a Per_CPU_Control in the _Per_CPU_Information table for each configured processor in the system.
| #define _Per_CPU_Acquire | ( | cpu, | |
| lock_context ) |
| #define _Per_CPU_Get | ( | ) |
| #define _Per_CPU_Get_snapshot | ( | ) |
| #define _Per_CPU_Release | ( | cpu, | |
| lock_context ) |
| typedef struct Per_CPU_Control Per_CPU_Control |
This structure is used to hold per core state information.
extern |
This is an array of per CPU core information.
