RTEMS
6.3
Toggle main menu visibility
include
score
apimutex.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* COPYRIGHT (c) 1989-2008.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_SCORE_APIMUTEX_H
39
#define _RTEMS_SCORE_APIMUTEX_H
40
41
rtems/score/thread.h
42
43
#include <sys/lock.h>
44
57
58
#ifdef __cplusplus
59
extern
"C"
60
#endif
61
65
typedef
struct
69
struct
_Mutex_recursive_Control
Mutex
70
75
Thread_Life_state
previous_thread_life_state
76
API_Mutex_Control
77
81
#define API_MUTEX_INITIALIZER( name ) \
82
{ _MUTEX_RECURSIVE_NAMED_INITIALIZER( name ), 0 }
83
89
void
_API_Mutex_Lock
API_Mutex_Control
mutex
90
96
void
_API_Mutex_Unlock
API_Mutex_Control
mutex
97
103
bool
_API_Mutex_Is_owner
const
API_Mutex_Control
mutex
104
106
120
121
void
_RTEMS_Lock_allocator(
void
122
123
void
_RTEMS_Unlock_allocator(
void
124
125
bool
_RTEMS_Allocator_is_owner(
void
126
128
129
#ifdef __cplusplus
130
131
#endif
132
133
#endif
134
/* end of include file */
_API_Mutex_Is_owner
bool _API_Mutex_Is_owner(const API_Mutex_Control *mutex)
Checks if the specified API mutex is owned by the executing thread.
Definition
apimutexisowner.c:45
_API_Mutex_Lock
void _API_Mutex_Lock(API_Mutex_Control *mutex)
Acquires the specified API mutex.
Definition
apimutexlock.c:45
_API_Mutex_Unlock
void _API_Mutex_Unlock(API_Mutex_Control *mutex)
Releases the specified API mutex.
Definition
apimutexunlock.c:45
Thread_Life_state
unsigned int Thread_Life_state
This type represents the thread life state.
Definition
thread.h:747
thread.h
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
API_Mutex_Control
Control block used to manage each API mutex.
Definition
apimutex.h:65
API_Mutex_Control::previous_thread_life_state
Thread_Life_state previous_thread_life_state
The thread life protection state before the outer-most mutex obtain.
Definition
apimutex.h:75
API_Mutex_Control::Mutex
struct _Mutex_recursive_Control Mutex
Definition
apimutex.h:69
mutex
Definition
mutex.h:4
