RTEMS
6.3
Toggle main menu visibility
include
score
userextdata.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
13
14
15
* COPYRIGHT (c) 1989-2009.
16
* On-Line Applications Research Corporation (OAR).
17
18
19
* modification, are permitted provided that the following conditions
20
* are met:
21
* 1. Redistributions of source code must retain the above copyright
22
* notice, this list of conditions and the following disclaimer.
23
* 2. Redistributions in binary form must reproduce the above copyright
24
* notice, this list of conditions and the following disclaimer in the
25
* documentation and/or other materials provided with the distribution.
26
27
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37
* POSSIBILITY OF SUCH DAMAGE.
38
39
40
#ifndef _RTEMS_SCORE_USEREXTDATA_H
41
#define _RTEMS_SCORE_USEREXTDATA_H
42
43
rtems/score/userext.h
44
rtems/score/chain.h
45
46
#ifdef __cplusplus
47
extern
"C"
48
#endif
49
55
61
typedef
struct
62
Chain_Node
Node;
63
User_extensions_thread_switch_extension
thread_switch;
64
User_extensions_Switch_control
65
72
typedef
struct
73
Chain_Node
Node;
74
Switch;
75
User_extensions_Table
Callouts;
76
User_extensions_Control
77
83
extern
const
size_t
_User_extensions_Initial_count
84
90
extern
const
_User_extensions_Initial_extensions
91
97
extern
98
_User_extensions_Initial_switch_controls
99
101
102
#ifdef __cplusplus
103
104
#endif
105
106
#endif
107
/* end of include file */
void(*) User_extensions_thread_switch_extension(struct _Thread_Control *executing, struct _Thread_Control *heir)
Task switch extension.
Definition
userext.h:177
User_extensions_Switch_control _User_extensions_Initial_switch_controls[]
A spare switch control for each initial user extension.
const size_t _User_extensions_Initial_count
The count of initial user extensions.
const User_extensions_Table _User_extensions_Initial_extensions[]
The table of initial user extensions.
chain.h
This header file provides interfaces of the Chain Handler which are used by the implementation and th...
Chain_Node
This structure represents a chain node.
Definition
chain.h:78
Manages each user extension set.
Definition
userextdata.h:72
Manages the switch callouts.
Definition
userextdata.h:61
User extension table.
Definition
userext.h:253
userext.h
This header file provides interfaces of the User Extensions Handler which are used by the implementat...
