RTEMS 6.1-rc1
- d -
- D0TCM_ECC_MULTI_ERROR_ADDR : FLEXRAM_Type
- D0TCM_ECC_MULTI_ERROR_DATA : FLEXRAM_Type
- D0TCM_ECC_MULTI_ERROR_INFO : FLEXRAM_Type
- D0TCM_ECC_SINGLE_ERROR_ADDR : FLEXRAM_Type
- D0TCM_ECC_SINGLE_ERROR_DATA : FLEXRAM_Type
- D0TCM_ECC_SINGLE_ERROR_INFO : FLEXRAM_Type
- D1 : _pxp_csc2_config
- D1CCIPR : RCC_TypeDef
- D1CFGR : RCC_TypeDef
- D1TCM_ECC_MULTI_ERROR_ADDR : FLEXRAM_Type
- D1TCM_ECC_MULTI_ERROR_DATA : FLEXRAM_Type
- D1TCM_ECC_MULTI_ERROR_INFO : FLEXRAM_Type
- D1TCM_ECC_SINGLE_ERROR_ADDR : FLEXRAM_Type
- D1TCM_ECC_SINGLE_ERROR_DATA : FLEXRAM_Type
- D1TCM_ECC_SINGLE_ERROR_INFO : FLEXRAM_Type
- D2 : _pxp_csc2_config
- D2CCIP1R : RCC_TypeDef
- D2CCIP2R : RCC_TypeDef
- D2CFGR : RCC_TypeDef
- D3 : _pxp_csc2_config
- D3AMR : RCC_TypeDef
- D3CCIPR : RCC_TypeDef
- D3CFGR : RCC_TypeDef
- D3CR : PWR_TypeDef
- D3PCR1H : EXTI_TypeDef
- D3PCR1L : EXTI_TypeDef
- D3PCR2H : EXTI_TypeDef
- D3PCR2L : EXTI_TypeDef
- D3PCR3H : EXTI_TypeDef
- D3PCR3L : EXTI_TypeDef
- D3PMR1 : EXTI_TypeDef
- D3PMR2 : EXTI_TypeDef
- D3PMR3 : EXTI_TypeDef
- d_lockdown_0 : L2CC
- d_lockdown_1 : L2CC
- d_lockdown_2 : L2CC
- d_lockdown_3 : L2CC
- d_lockdown_4 : L2CC
- d_lockdown_5 : L2CC
- d_lockdown_6 : L2CC
- d_lockdown_7 : L2CC
- da_name : ofw_tree_node
- DACC_ACR : Dacc
- DACC_CDR : Dacc
- DACC_CHDR : Dacc
- DACC_CHER : Dacc
- DACC_CHSR : Dacc
- DACC_CR : Dacc
- DACC_IDR : Dacc
- DACC_IER : Dacc
- DACC_IMR : Dacc
- DACC_ISR : Dacc
- DACC_MR : Dacc
- DACC_TRIGR : Dacc
- DACC_VERSION : Dacc
- DACC_WPMR : Dacc
- DACC_WPSR : Dacc
- dacChannel : DacCmd
- DACCR : CMP_Type
- dacId : DacDma
- DACValue : _acmp_dac_config, _cmp_dac_config
- DADDR : _edma_tcd, DMA_Type
- DAINT : USB_OTG_DeviceTypeDef
- DAINTMSK : USB_OTG_DeviceTypeDef
- DAR : CAAM_Type
- dasi : dsu4
- data : _flexio_i2c_master_transfer, _flexio_i2s_transfer, _flexio_uart_transfer, _flexspi_handle, _flexspi_transfer, _lpi2c_master_transfer, _lpi2c_slave_transfer, _lpuart_transfer, _pdm_edma_transfer, _pdm_transfer, _rtems_rfs_inode, _sai_transfer, _spdif_transfer, _ssarc_descriptor_config, _usdhc_handle, _usdhc_scatter_gather_transfer, _usdhc_transfer, ALT_GPIO_CONFIG_RECORD_s, apbuart, atsam_power_control
- DATA : DAC_Type
- data : grgpio
- DATA : LPUART_Type, OCOTP_Type
- data : rtems_rtl_archive_chain_data, rtems_rtl_obj_sym
- Data24BitAlignment : I2S_InitTypeDef
- data_11_8 : _pxp_dither_final_lut_data
- data_15_12 : _pxp_dither_final_lut_data
- data_3_0 : _pxp_dither_final_lut_data
- data_7_4 : _pxp_dither_final_lut_data
- data_a : RtemsTimerReqReset_Context
- data_b : RtemsTimerReqReset_Context
- data_base : rtems_rtl_obj
- data_begin : TLS_Configuration
- DATA_BUFF_ACC_PORT : USDHC_Type
- data_ram_ctrl : L2CC
- data_size : rtems_rtl_obj, TLS_Configuration
- data_socket : rtems_ftpfs_entry
- data_xfer_type : ALT_QSPI_DEV_INST_CONFIG_s
- dataAddress : _flexio_camera_transfer
- DataAddressMux : FMC_NORSRAM_InitTypeDef
- dataAddrOrSameValue : _flexio_mculcd_edma_handle, _flexio_mculcd_handle, _flexio_mculcd_smartdma_handle, _flexio_mculcd_transfer
- DataAlignment : MDMA_InitTypeDef
- dataBitsCount : _lpuart_config
- DataBlockSize : SDMMC_DataInitTypeDef
- dataBus : _csi_config, _elcdif_rgb_mode_config
- DataBusWidth : HAL_SD_CardStatusTypeDef
- dataByte0 : _flexcan_frame
- dataByte1 : _flexcan_frame
- dataByte2 : _flexcan_frame
- dataByte3 : _flexcan_frame
- dataByte4 : _flexcan_frame
- dataByte5 : _flexcan_frame
- dataByte6 : _flexcan_frame
- dataByte7 : _flexcan_frame
- DATACH : PDM_Type
- dataCount : _flexio_mculcd_edma_handle, _flexio_mculcd_handle, _flexio_mculcd_smartdma_handle
- dataCountUsingEzh : _flexio_mculcd_smartdma_handle
- dataDirection : _usdhc_scatter_gather_data
- dataFirstBitShifted : _sai_serial_data
- DataFormat : I2S_InitTypeDef
- DataInvert : SMARTCARD_AdvFeatureInitTypeDef, UART_AdvFeatureInitTypeDef
- DataLatency : FMC_NORSRAM_TimingTypeDef
- DataLength : SDMMC_DataInitTypeDef
- dataMaskedWord : _sai_serial_data
- dataMode : _flexio_spi_master_config, _flexio_spi_slave_config
- dataNum : _flexio_camera_transfer
- dataOrder : _sai_serial_data
- dataOutConfig : _lpspi_master_config, _lpspi_slave_config
- DataPacking : DFSDM_Channel_InputTypeDef
- dataPadSettingOverride : _flexspi_mem_config, _FlexSPIConfig
- dataPin : _smartcard_interface_config
- dataPinMux : _smartcard_interface_config
- dataPinStartIndex : _flexio_mculcd_type
- dataPort : _smartcard_interface_config
- DataPtr : TaskBD1_t, TaskBD2_t
- DataSetupTime : FMC_NORSRAM_TimingTypeDef
- dataSize : _flexio_i2c_master_transfer, _flexio_i2s_transfer, _flexio_mculcd_transfer, _flexio_spi_transfer, _flexio_uart_transfer, _flexspi_handle, _flexspi_transfer, _lpi2c_master_transfer, _lpi2c_slave_transfer, _lpspi_transfer, _lpuart_transfer, _pdm_edma_transfer, _pdm_transfer, _sai_transfer, _spdif_edma_transfer, _spdif_transfer
- DataSize : SAI_InitTypeDef, SPI_InitTypeDef
- DataSource : DFSDM_Filter_AwdParamTypeDef
- dataTimeout : _usdhc_config
- DataTimeOut : SDMMC_DataInitTypeDef
- dataType : _usdhc_data, _usdhc_scatter_gather_data
- datatype : rtems_rtl_rap
- dataValidDelay_ns : _lpi2c_slave_config
- dataValidTime : _flexspi_device_config, _flexspi_mem_config, _FlexSPIConfig
- dataWord0 : _flexcan_frame
- dataWord0Length : _sai_serial_data
- dataWord1 : _flexcan_frame
- dataWordLength : _sai_serial_data
- dataWordNLength : _sai_serial_data
- dataWordNum : _sai_serial_data
- Date : RTC_DateTypeDef
- DateCode : __attribute__
- datPinStartIdx : _flexio_camera_type
- day : _snvs_hp_rtc_datetime, _snvs_lp_srtc_datetime, rtems_time_of_day
- DayLightSaving : RTC_TimeTypeDef
- DBG1 : CAN_Type
- DBG2 : CAN_Type
- DBGDATA : DCP_Type
- dbgm : dsu4
- DBGSELECT : DCP_Type
- DBICR0 : SEMC_Type
- DBICR1 : SEMC_Type
- DBICR2 : SEMC_Type
- DBTP : FDCAN_GlobalTypeDef
- dc : spwtdp
- DC_CTRL : PDM_Type
- DCCIMVAC : SCB_Type
- DCCISW : SCB_Type
- DCCMVAC : SCB_Type
- DCCMVAU : SCB_Type
- DCCPARAMS : USB_Type
- DCCR : LTDC_Layer_TypeDef, SEMC_Type
- DCCSW : SCB_Type
- dcd : _ivt_
- DCFG : USB_OTG_DeviceTypeDef
- DCHPRI0 : DMA_Type
- DCHPRI1 : DMA_Type
- DCHPRI10 : DMA_Type
- DCHPRI11 : DMA_Type
- DCHPRI12 : DMA_Type
- DCHPRI13 : DMA_Type
- DCHPRI14 : DMA_Type
- DCHPRI15 : DMA_Type
- DCHPRI16 : DMA_Type
- DCHPRI17 : DMA_Type
- DCHPRI18 : DMA_Type
- DCHPRI19 : DMA_Type
- DCHPRI2 : DMA_Type
- DCHPRI20 : DMA_Type
- DCHPRI21 : DMA_Type
- DCHPRI22 : DMA_Type
- DCHPRI23 : DMA_Type
- DCHPRI24 : DMA_Type
- DCHPRI25 : DMA_Type
- DCHPRI26 : DMA_Type
- DCHPRI27 : DMA_Type
- DCHPRI28 : DMA_Type
- DCHPRI29 : DMA_Type
- DCHPRI3 : DMA_Type
- DCHPRI30 : DMA_Type
- DCHPRI31 : DMA_Type
- DCHPRI4 : DMA_Type
- DCHPRI5 : DMA_Type
- DCHPRI6 : DMA_Type
- DCHPRI7 : DMA_Type
- DCHPRI8 : DMA_Type
- DCHPRI9 : DMA_Type
- DCICC : DCIC_Type
- DCICIC : DCIC_Type
- DCICRC : DCIC_Type
- DCICRCS : DCIC_Type
- DCICRRS : DCIC_Type
- DCICRS : DCIC_Type
- DCICS : DCIC_Type
- DCIMVAC : SCB_Type
- DCISW : SCB_Type
- DCIVERSION : USB_Type
- DCOUNT : SDMMC_TypeDef
- DCR : QUADSPI_TypeDef, TIM_TypeDef
- DCR1 : OCTOSPI_TypeDef
- DCR2 : OCTOSPI_TypeDef
- DCR3 : OCTOSPI_TypeDef
- DCR4 : OCTOSPI_TypeDef
- DCRDR : CoreDebug_Type
- DCRSR : CoreDebug_Type
- DCTL : USB_OTG_DeviceTypeDef
- DCTRL : SDMMC_TypeDef
- dd : rtems_bdbuf_buffer, rtems_bdbuf_swapout_transfer
- DDAR : CAAM_Type
- DDDR : CAAM_Type
- DDDR_LS : CAAM_Type
- DDDR_MS : CAAM_Type
- DDESB : CAAM_Type
- DDJP : CAAM_Type
- DDJR : CAAM_Type
- DE : ADC_Type
- DEACHINT : USB_OTG_DeviceTypeDef
- DEACHMSK : USB_OTG_DeviceTypeDef
- deadline : Scheduler_CBS_Parameters
- deadlock : ScoreMtxReqSeizeWait_Context, TQContext
- deadlock_callout : Thread_queue_Context
- DeadTime : TIM_BreakDeadTimeConfigTypeDef
- deadtimeValue : _pwm_signal_param
- deallocate : Objects_Information
- debounce : ALT_GPIO_CONFIG_RECORD_s
- DEBUG0_STATUS : USBPHY_Type
- DEBUG1 : USBPHY_Type
- DEBUG1_CLR : USBPHY_Type
- DEBUG1_SET : USBPHY_Type
- DEBUG1_TOG : USBPHY_Type
- DEBUG_CLR : USBPHY_Type
- debug_ctrl : L2CC
- DEBUG_MODE : TSC_Type
- DEBUG_MODE2 : TSC_Type
- DEBUG_SET : USBPHY_Type
- DEBUG_TOG : USBPHY_Type
- DEBUGCTL : CAAM_Type
- debugEnable : _lpi2c_master_config
- debugMode : _qtmr_config
- DEBUGr : USBPHY_Type
- decoderWorkMode : _enc_config
- DECODID_LS : CAAM_Type
- DECODID_MS : CAAM_Type
- decomp : rtems_rtl_data, rtems_rtl_rap
- decompress : rtems_jffs2_compressor_control
- DECORR : CAAM_Type
- DECORSR : CAAM_Type
- defaddr : grspw2
- default_address : i2c_bus
- default_handler_calls : RtemsSignalReqCatch_Context
- default_timeout : MPCI_Control
- DefaultInitValueUse : CRC_InitTypeDef
- DefaultPolynomialUse : CRC_InitTypeDef
- deferred_released_count : rtems_filesystem_global_location_t
- deferred_released_next : rtems_filesystem_global_location_t
- DELAY : PGMC_MIF_SIGNAL_Type
- delay_cells : flexspi_dll_time_t
- delay_usecs : spi_bus, spi_ioc_transfer
- delayed_write_priority : rtems_jffs2_config
- delayModulus : _acmp_round_robin_config
- delayPower : lpadc_conv_trigger_config_t
- delete_extension_calls : RtemsTaskReqExit_Context
- delete_status : RtemsSemReqDelete_Context
- delete_worker_expected : RtemsTaskReqDelete_Context, RtemsTaskReqExit_Context, RtemsTaskReqRestart_Context
- deleted : rtems_disk_device
- deleter_2_id : RtemsTaskReqDelete_Context
- deleter_2_tcb : RtemsTaskReqDelete_Context
- deleter_id : RtemsTaskReqDelete_Context, RtemsTaskReqExit_Context, RtemsTaskReqRestart_Context
- deleter_tcb : RtemsTaskReqDelete_Context, RtemsTaskReqRestart_Context
- delivered : _Regulator_Statistics, rtems_regulator_statistics
- deliverer : rtems_regulator_attributes
- deliverer_context : rtems_regulator_attributes
- delivery_thread_has_exited : _Regulator_Control
- delivery_thread_id : _Regulator_Control
- delivery_thread_is_running : _Regulator_Control
- delivery_thread_period : rtems_regulator_attributes
- delivery_thread_period_id : _Regulator_Control
- delivery_thread_priority : rtems_regulator_attributes
- delivery_thread_request_exit : _Regulator_Control
- delivery_thread_stack_size : rtems_regulator_attributes
- DEMCR : CoreDebug_Type
- denominator : _clock_audio_pll_config, _clock_audio_pll_gpc_config, _clock_sys_pll_config, _clock_video_pll_config
- dependencies : rtems_rtl_obj_print
- dependents : rtems_rtl_elf_reloc_data, rtems_rtl_obj, rtems_rtl_obj_depends
- depends : rtems_rtl_obj_depends
- depth : drvmgr_bus
- DER : LPSPI_Type
- derri : griommu
- DESC_ADDR_DOWN : SSARC_LP_Type
- DESC_ADDR_UP : SSARC_LP_Type
- DESC_CTRL0 : SSARC_LP_Type
- DESC_CTRL1 : SSARC_LP_Type
- descriptor : rtems_fdisk_device_ctl, rtems_fdisk_segment_ctl, rtems_nvdisk_device_ctl
- destAddr : _edma_transfer_config
- DestBlockAddressOffset : MDMA_InitTypeDef
- DestBurst : MDMA_InitTypeDef
- DestDataSize : MDMA_InitTypeDef
- destination_offset : Thread_Control_add_on
- DestinationInc : MDMA_InitTypeDef
- destOffset : _edma_transfer_config
- destOffsetX : _pxp_pic_copy_config
- destOffsetY : _pxp_pic_copy_config
- destPicBaseAddr : _pxp_pic_copy_config
- destPitchBytes : _pxp_pic_copy_config
- destroy : i2c_bus, i2c_dev, rtems_flashdev, rtems_interrupt_server_config, rtems_interrupt_server_control, rtems_jffs2_compressor_control, rtems_jffs2_flash_control, spi_bus
- destructor : POSIX_Keys_Control
- destTransferSize : _edma_transfer_config
- det0 : spwtdp
- det1 : spwtdp
- det2 : spwtdp
- det3 : spwtdp
- det4 : spwtdp
- DetectErrorCallback : __RAMECC_HandleTypeDef
- dev : drvmgr_bus, drvmgr_drv, rtems_disk_device
- dev_cnt : drvmgr_bus, drvmgr_drv
- dev_prefix : drvmgr_bus_params
- dev_priv_size : drvmgr_drv
- Devaddress : __I2C_HandleTypeDef
- device : _rtems_rfs_file_system, lpc176x_timer, ofw_tree_node, rtems_fdisk_segment_ctl, rtems_nvdisk_device_ctl
- Device_Code3 : NOR_IDTypeDef
- device_context : rtems_termios_tty
- device_count : rtems_flashdisk, rtems_flashdisk_config, rtems_nvdisk, rtems_nvdisk_config
- device_file : console_device
- device_identifier : rtems_jffs2_flash_control
- device_node : rtems_termios_tty
- device_path : atsam_sc16is752_spi_config
- device_type : _serial_nor_config_option
- DEVICEADDR : USB_Type
- deviceAddress : _flexspi_transfer
- DeviceId : XNandPsu_Config, XQspiPsu_Config
- DeviceManufacturer : __attribute__
- deviceModeArg : _flexspi_mem_config, _FlexSPIConfig
- deviceModeCfgEnable : _flexspi_mem_config, _FlexSPIConfig
- DeviceModel : __attribute__
- deviceModeSeq : _flexspi_mem_config, _FlexSPIConfig
- deviceModeType : _flexspi_mem_config, _FlexSPIConfig
- deviceProbe : _console_tbl
- devices : drvmgr, rtems_flashdisk, rtems_flashdisk_config, rtems_nvdisk, rtems_nvdisk_config
- DeviceSize : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef, XNandPsu_Geometry
- DeviceSizeMul : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- deviceType : _console_tbl, _flexspi_mem_config, _FlexSPIConfig
- DEVID : TPI_Type
- DEVTYPE : TPI_Type
- DFR : SCB_Type
- Dfsdm1ClockSelection : RCC_PeriphCLKInitTypeDef
- DFSR : SCB_Type
- DGTR_0 : CAAM_Type
- DGTR_1 : CAAM_Type
- DGTR_2 : CAAM_Type
- DGTR_3 : CAAM_Type
- DHCSR : CoreDebug_Type
- DHR12L1 : DAC_TypeDef
- DHR12L2 : DAC_TypeDef
- DHR12LD : DAC_TypeDef
- DHR12R1 : DAC_TypeDef
- DHR12R2 : DAC_TypeDef
- DHR12RD : DAC_TypeDef
- DHR8R1 : DAC_TypeDef
- DHR8R2 : DAC_TypeDef
- DHR8RD : DAC_TypeDef
- DHTMEM : JPEG_TypeDef
- Di : _smartcard_card_params
- diagctrl : griommu
- diagd_0 : griommu
- diagd_1 : griommu
- diagt : griommu
- DIEPCTL : USB_OTG_INEndpointTypeDef
- DIEPDMA : USB_OTG_INEndpointTypeDef
- DIEPEMPMSK : USB_OTG_DeviceTypeDef
- DIEPINT : USB_OTG_INEndpointTypeDef
- DIEPMSK : USB_OTG_DeviceTypeDef
- DIEPTSIZ : USB_OTG_INEndpointTypeDef
- DIEPTXF : USB_OTG_GlobalTypeDef
- DIEPTXF0_HNPTXFSIZ : USB_OTG_GlobalTypeDef
- DIER : TIM_TypeDef
- DIFSEL : ADC_TypeDef
- DIFSEL_RES12 : ADC_TypeDef
- DIGPROG : USB_ANALOG_Type
- DIN : CRYP_TypeDef, HASH_TypeDef
- DINEP1MSK : USB_OTG_DeviceTypeDef
- DIR : JPEG_TypeDef
- dir : lpc176x_fio
- DIR : SPDIFRX_TypeDef
- DIRECT : CCM_Type
- DirectColorModeInfo : RTEMS_PACKED
- direction : _flexio_i2c_master_transfer, _flexio_spi_master_handle, _gpio_pin_config, _lpi2c_master_transfer, _lpspi_master_config, _lpspi_slave_config, _smartcard_context, _smartcard_xfer, ALT_GPIO_CONFIG_RECORD_s, Chain_Iterator
- Direction : DMA_InitTypeDef
- direction : grgpio
- Direction : SPI_InitTypeDef
- dirty : rtems_rfs_block_map_s, rtems_rfs_buffer_handle_t
- dirty_blocks : rtems_jffs2_info
- dirty_size : rtems_jffs2_info
- disableAdaptiveFreq : _pmu_well_bias_option
- disableSelfReception : _flexcan_config
- dischargeResistorValue : _pmu_snvs_dig_config
- discipline : TQContext
- DiscontinuousConvMode : ADC_InitTypeDef
- disk_id : rtems_bdpart_format
- DISMAP : PWM_Type
- DISP_PARA : LCDIFV2_Type
- DISP_SIZE : LCDIFV2_Type
- dispatch_disabled : RtemsTaskReqDelete_Context, RtemsTaskReqExit_Context, RtemsTaskReqRestart_Context
- dispatch_necessary : Per_CPU_Control
- DisplayCodec : ISI_Descriptors
- ditherMode0 : _pxp_dither_config
- ditherMode1 : _pxp_dither_config
- ditherMode2 : _pxp_dither_config
- div : _clock_root_config_t, _clock_root_setpoint_config_t, ALT_CLK_PLL_CFG_s
- div0 : _clock_group_config
- divider : _gpt_init_config
- Divider : DFSDM_Channel_OutputClockTypeDef
- DIVISOR : EMVSIM_Type
- DJQCR_LS : CAAM_Type
- DJQCR_MS : CAAM_Type
- dkey : grspw2
- DLAST_SGA : _edma_tcd, DMA_Type
- DLEN : SDMMC_TypeDef
- DLL_CTRL : USDHC_Type
- DLL_STATUS : USDHC_Type
- DLLCR : FLEXSPI_Type, SEMC_Type
- DLR : OCTOSPI_TypeDef, QUADSPI_TypeDef
- DLTCR : DSI_TypeDef
- dma : grspw2
- DMA : TMR_Type
- DMA0_AID_ENB : CAAM_Type
- DMA0_ARD_LAT : CAAM_Type
- DMA0_ARD_TC : CAAM_Type
- DMA0_AWR_LAT : CAAM_Type
- DMA0_AWR_TC : CAAM_Type
- DMA_AIDL_MAP_LS : CAAM_Type
- DMA_AIDL_MAP_MS : CAAM_Type
- DMA_AIDM_MAP_LS : CAAM_Type
- DMA_AIDM_MAP_MS : CAAM_Type
- DMA_CTRL : ADC_ETC_Type
- DMA_Handle : ADC_HandleTypeDef
- DMA_STA : CAAM_Type
- DMA_X_AID_11_8_MAP : CAAM_Type
- DMA_X_AID_15_0_EN : CAAM_Type
- DMA_X_AID_15_12_MAP : CAAM_Type
- DMA_X_AID_3_0_MAP : CAAM_Type
- DMA_X_AID_7_4_MAP : CAAM_Type
- DMA_X_ARTC_CTL : CAAM_Type
- DMA_X_ARTC_LAT : CAAM_Type
- DMA_X_ARTC_LC : CAAM_Type
- DMA_X_ARTC_SC : CAAM_Type
- DMA_X_AWTC_CTL : CAAM_Type
- DMA_X_AWTC_LAT : CAAM_Type
- DMA_X_AWTC_LC : CAAM_Type
- DMA_X_AWTC_SC : CAAM_Type
- dmaaddr : grspw2_dma
- dmabase : grpci2
- DMABurstState : TIM_HandleTypeDef
- DMACFG : ENET_Type
- dmachan : grpci2
- DMACR : CRYP_TypeDef
- dmactrl : grpci2, grspw2_dma
- DMADisableonRxError : SMARTCARD_AdvFeatureInitTypeDef, UART_AdvFeatureInitTypeDef
- DMAEN : PWM_Type
- dmaHandle : _flexio_i2s_dma_handle, _flexio_i2s_edma_handle, _pdm_edma_handle, _pdm_sdma_handle, _sai_sdma_handle, sai_edma_handle
- dmaLeftHandle : _spdif_edma_handle
- dmamaxlen : grspw2_dma
- dmaMode : _usdhc_adma_config
- DmaMode : DFSDM_Filter_InjectedParamTypeDef, DFSDM_Filter_RegularParamTypeDef, XNandPsu
- DMAmuxChannel : __DMA_HandleTypeDef
- DMAmuxChannelStatus : __DMA_HandleTypeDef
- DMAmuxChannelStatusMask : __DMA_HandleTypeDef
- DMAmuxRequestGen : __DMA_HandleTypeDef
- DMAmuxRequestGenStatus : __DMA_HandleTypeDef
- DMAmuxRequestGenStatusMask : __DMA_HandleTypeDef
- dmaProgress : UsartChannel
- DMAR : TIM_TypeDef
- dmaRightHandle : _spdif_edma_handle
- dmarxdesc : grspw2_dma
- DMASA_FB1 : CSI_Type
- DMASA_FB2 : CSI_Type
- DMASA_STATFIFO : CSI_Type
- DMATS_STATFIFO : CSI_Type
- dmatxdesc : grspw2_dma
- DMR0 : LPSPI_Type
- DMR1 : LPSPI_Type
- DMTH_LS : CAAM_Type
- DMTH_MS : CAAM_Type
- do_action : RtemsRatemonReqCancel_Context, RtemsRatemonReqPeriod_Context
- do_clear : RtemsIntrReqClear_Context, RtemsIntrReqIsPending_Context, RtemsIntrReqRaise_Context, RtemsIntrReqRaiseOn_Context
- do_reset : RtemsRatemonReqGetStatus_Context
- do_size_command : rtems_ftpfs_entry
- DODIDSR : CAAM_Type
- DOEPCTL : USB_OTG_OUTEndpointTypeDef
- DOEPDMA : USB_OTG_OUTEndpointTypeDef
- DOEPINT : USB_OTG_OUTEndpointTypeDef
- DOEPMSK : USB_OTG_DeviceTypeDef
- DOEPTSIZ : USB_OTG_OUTEndpointTypeDef
- DOFF : _edma_tcd, DMA_Type
- DOMAIN_DISPLAY : SRC_Type
- DOMAIN_M4CORE : SRC_Type
- DOMAIN_M4DEBUG : SRC_Type
- DOMAIN_M7CORE : SRC_Type
- DOMAIN_M7DEBUG : SRC_Type
- DOMAIN_MEGA : SRC_Type
- DOMAIN_USBPHY1 : SRC_Type
- DOMAIN_USBPHY2 : SRC_Type
- DOMAIN_WAKEUP : SRC_Type
- domainId : _rdc_domain_assignment
- domainID : _rdc_mem_status
- domainId : _xrdc2_master_domain_assignment
- domainNumber : _rdc_hardware_config
- DOMAINr : CCM_Type
- done : rtems_blkdev_request, RtemsSemValSmp_Context, TQContext
- DONE0_1_IRQ : ADC_ETC_Type
- DONE2_3_ERR_IRQ : ADC_ETC_Type
- done_2 : RtemsSemValSmp_Context
- done_arg : rtems_blkdev_request
- done_bytes : Untar_ChunkContext
- DOPSTA_LS : CAAM_Type
- DOPSTA_MS : CAAM_Type
- DOR : JPEG_TypeDef
- DOR1 : DAC_TypeDef
- DOR2 : DAC_TypeDef
- dormant : RtemsTaskReqDelete_Context, RtemsTaskReqRestart_Context
- dos_compatibility : rtems_bdpart_format
- doubly_buffer : rtems_rfs_block_map_s
- DOUT : CRYP_TypeDef
- DOUTEP1MSK : USB_OTG_DeviceTypeDef
- DPAMS : IEE_Type
- dPDCsize : _SpioCaptureInit
- DPDIDSR : CAAM_Type
- dpf : spwtdp
- dphy : MIPI_DSI_Type
- dpi : MIPI_DSI_Type
- dpiColorCoding : _dsi_dpi_config
- DPLLClkSource : _spdif_config
- DPOVRD : CAAM_Type
- DPSM : SDMMC_DataInitTypeDef
- dqs_pinmux_group : _serial_nor_config_option
- dqsMode : _semc_config_t
- dqsPadSettingOverride : _flexspi_mem_config, _FlexSPIConfig
- DR : ADC_TypeDef, CRC_TypeDef, DCMI_TypeDef, DTS_TypeDef, GPIO_Type, OCTOSPI_TypeDef, PSSI_TypeDef, QUADSPI_TypeDef, RNG_TypeDef, RTC_TypeDef, SAI_Block_TypeDef, SPDIFRX_TypeDef
- DR_CLEAR : GPIO_Type
- DR_SET : GPIO_Type
- DR_TOGGLE : GPIO_Type
- drive_strength : _serial_nor_config_option
- driver : rtems_flashdev
- driver_data : rtems_disk_device
- DRR : CAAM_Type
- drv : drvmgr_dev
- drv_id : drvmgr_drv, drvmgr_drv_res
- drvstr1 : gr740_iopll
- drvstr2 : gr740_iopll
- DrvStrength : __attribute__
- ds : spwtdp
- DS_ADDR : USDHC_Type
- ds_bkp : RTEMS_PACKED
- dscCmd : _dsi_transfer
- DSDP : CAAM_Type
- dsi : _dsi_handle
- dsize : _SpioCaptureInit
- DSRImpl : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- DstAddress : MDMA_LinkNodeConfTypeDef
- dstAlphaMode : pxp_porter_duff_config_t
- dstColorMode : pxp_porter_duff_config_t
- dstFactorMode : pxp_porter_duff_config_t
- dstGlobalAlpha : pxp_porter_duff_config_t
- dstGlobalAlphaMode : pxp_porter_duff_config_t
- DSTR_0 : CAAM_Type
- DSTR_1 : CAAM_Type
- DSTR_2 : CAAM_Type
- DSTR_3 : CAAM_Type
- DSTS : USB_OTG_DeviceTypeDef
- DTCM_MAGIC_ADDR : FLEXRAM_Type
- dtcmBankNum : _flexram_allocate_ram
- DTCMCR : SCB_Type
- DTCNT0 : PWM_Type
- DTCNT1 : PWM_Type
- DTHRCTL : USB_OTG_DeviceTypeDef
- DTIMER : SDMMC_TypeDef
- dtr : dsu4
- DTSRCSEL : PWM_Type
- dttc : dsu4
- DTXFSTS : USB_OTG_INEndpointTypeDef
- DTxR : HRTIM_Timerx_TypeDef
- DualAddressMode : I2C_InitTypeDef, SMBUS_InitTypeDef
- DualFlashMode : BSP_QSPI_Ctx_t, BSP_QSPI_Init_t
- DualModeData : ADC_MultiModeTypeDef
- dummy_cache_sync_reg : L2CC
- dummy_cycles : _serial_nor_config_option, ALT_QSPI_DEV_INST_CONFIG_s
- dutyCyclePercent : _pwm_signal_param
- DVBUSDIS : USB_OTG_DeviceTypeDef
- DVBUSPULSE : USB_OTG_DeviceTypeDef
- DVR : GFXMMU_TypeDef
- dwDmaCh : _Mcid
- dwMck : _Mcid
- dwXfrNdx : _Mcid
- dwXSize : _Mcid
