RTEMS 6.1-rc1
Test context for spec:/rtems/ratemon/req/get-status test case. More...
Data Fields | |
rtems_id | period_id |
This member contains a valid identifier of a period. | |
GetTimecountHandler | previous_timecounter_handler |
This member contains the previous timecounter handler to restore. | |
rtems_rate_monotonic_period_status | period_status |
This member is used to receive the rtems_rate_monotonic_period_status from the action. | |
rtems_id | id_param |
This member specifies the id parameter for the action. | |
rtems_rate_monotonic_period_status * | status_param |
This member specifies the status parameter for the action. | |
rtems_status_code | status |
This member contains the returned status code of the action. | |
rtems_id | task_id |
This member contains the task identifier of the owner task. | |
rtems_rate_monotonic_period_states | previous_state |
This member contains the state before the action. | |
void(* | do_reset )(void) |
If the rtems_cpu_usage_reset() directive should be called before rtems_rate_monotonic_get_status(), this member contains a pointer to it. | |
struct timespec | elapsed |
This member contains the CLOCK_MONOTONIC time elapsed. | |
struct timespec | consumed |
This member contains the CPU time consumed by the owner task. | |
uint32_t | postponed_jobs_count |
This member contains the number of postponed jobs. | |
struct { | |
size_t pci [6] | |
This member defines the pre-condition indices for the next action. | |
size_t pcs [6] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsRatemonReqGetStatus_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
