RTEMS 6.1-rc1
Data Structures | Enumerator | Variables
Lpuart_driver
struct  _lpuart_config
 LPUART configuration structure. More...
struct  _lpuart_transfer
 LPUART transfer structure. More...
struct  _lpuart_handle
 LPUART handle structure. More...
uint32_t _lpuart_config::baudRate_Bps
lpuart_parity_mode_t _lpuart_config::parityMode
lpuart_data_bits_t _lpuart_config::dataBitsCount
bool _lpuart_config::isMsb
lpuart_idle_type_select_t _lpuart_config::rxIdleType
lpuart_idle_config_t _lpuart_config::rxIdleConfig
bool _lpuart_config::enableTx
bool _lpuart_config::enableRx
uint8_t *   _lpuart_transfer::data
uint8_t *   _lpuart_transfer::rxData
const uint8_t *   _lpuart_transfer::txData
union {
size_t _lpuart_transfer::dataSize
const uint8_t *volatile _lpuart_handle::txData
volatile size_t _lpuart_handle::txDataSize
size_t _lpuart_handle::txDataSizeAll
uint8_t *volatile _lpuart_handle::rxData
volatile size_t _lpuart_handle::rxDataSize
size_t _lpuart_handle::rxDataSizeAll
uint8_t * _lpuart_handle::rxRingBuffer
size_t _lpuart_handle::rxRingBufferSize
volatile uint16_t _lpuart_handle::rxRingBufferHead
volatile uint16_t _lpuart_handle::rxRingBufferTail
lpuart_transfer_callback_t _lpuart_handle::callback
void * _lpuart_handle::userData
volatile uint8_t _lpuart_handle::txState
volatile uint8_t _lpuart_handle::rxState
Driver version
enum  {
  kStatus_LPUART_TxBusy = MAKE_STATUS(kStatusGroup_LPUART, 0) , kStatus_LPUART_RxBusy = MAKE_STATUS(kStatusGroup_LPUART, 1) , kStatus_LPUART_TxIdle = MAKE_STATUS(kStatusGroup_LPUART, 2) , kStatus_LPUART_RxIdle = MAKE_STATUS(kStatusGroup_LPUART, 3) ,
  kStatus_LPUART_TxWatermarkTooLarge = MAKE_STATUS(kStatusGroup_LPUART, 4) , kStatus_LPUART_RxWatermarkTooLarge = MAKE_STATUS(kStatusGroup_LPUART, 5) , kStatus_LPUART_FlagCannotClearManually = MAKE_STATUS(kStatusGroup_LPUART, 6) , kStatus_LPUART_Error = MAKE_STATUS(kStatusGroup_LPUART, 7) ,
  kStatus_LPUART_RxRingBufferOverrun , kStatus_LPUART_RxHardwareOverrun = MAKE_STATUS(kStatusGroup_LPUART, 9) , kStatus_LPUART_NoiseError = MAKE_STATUS(kStatusGroup_LPUART, 10) , kStatus_LPUART_FramingError = MAKE_STATUS(kStatusGroup_LPUART, 11) ,
  kStatus_LPUART_ParityError = MAKE_STATUS(kStatusGroup_LPUART, 12) , kStatus_LPUART_BaudrateNotSupport , kStatus_LPUART_IdleLineDetected = MAKE_STATUS(kStatusGroup_LPUART, 14) , kStatus_LPUART_Timeout = MAKE_STATUS(kStatusGroup_LPUART, 15)
 Error codes for the LPUART driver. More...
enum  _lpuart_parity_mode { kLPUART_ParityDisabled = 0x0U , kLPUART_ParityEven = 0x2U , kLPUART_ParityOdd = 0x3U }
 LPUART parity mode. More...
enum  _lpuart_data_bits { kLPUART_EightDataBits = 0x0U }
 LPUART data bits count. More...
enum  _lpuart_stop_bit_count { kLPUART_OneStopBit = 0U , kLPUART_TwoStopBit = 1U }
 LPUART stop bit count. More...
enum  _lpuart_idle_type_select { kLPUART_IdleTypeStartBit = 0U , kLPUART_IdleTypeStopBit = 1U }
 LPUART idle flag type defines when the receiver starts counting. More...
enum  _lpuart_idle_config {
  kLPUART_IdleCharacter1 = 0U , kLPUART_IdleCharacter2 = 1U , kLPUART_IdleCharacter4 = 2U , kLPUART_IdleCharacter8 = 3U ,
  kLPUART_IdleCharacter16 = 4U , kLPUART_IdleCharacter32 = 5U , kLPUART_IdleCharacter64 = 6U , kLPUART_IdleCharacter128 = 7U
 LPUART idle detected configuration. This structure defines the number of idle characters that must be received before the IDLE flag is set. More...
enum  _lpuart_interrupt_enable {
  kLPUART_RxActiveEdgeInterruptEnable = (LPUART_BAUD_RXEDGIE_MASK >> 8U) , kLPUART_TxDataRegEmptyInterruptEnable = (LPUART_CTRL_TIE_MASK) , kLPUART_TransmissionCompleteInterruptEnable = (LPUART_CTRL_TCIE_MASK) , kLPUART_RxDataRegFullInterruptEnable = (LPUART_CTRL_RIE_MASK) ,
  kLPUART_IdleLineInterruptEnable = (LPUART_CTRL_ILIE_MASK) , kLPUART_RxOverrunInterruptEnable = (LPUART_CTRL_ORIE_MASK) , kLPUART_NoiseErrorInterruptEnable = (LPUART_CTRL_NEIE_MASK) , kLPUART_FramingErrorInterruptEnable = (LPUART_CTRL_FEIE_MASK) ,
  kLPUART_ParityErrorInterruptEnable = (LPUART_CTRL_PEIE_MASK) , kLPUART_AllInterruptEnable
 LPUART interrupt configuration structure, default settings all disabled. More...
enum  _lpuart_flags {
  kLPUART_TxDataRegEmptyFlag , kLPUART_TransmissionCompleteFlag , kLPUART_RxDataRegFullFlag = (LPUART_STAT_RDRF_MASK) , kLPUART_IdleLineFlag = (LPUART_STAT_IDLE_MASK) ,
  kLPUART_RxOverrunFlag = (LPUART_STAT_OR_MASK) , kLPUART_NoiseErrorFlag = (LPUART_STAT_NF_MASK) , kLPUART_FramingErrorFlag , kLPUART_ParityErrorFlag = (LPUART_STAT_PF_MASK) ,
  kLPUART_RxActiveEdgeFlag = (LPUART_STAT_RXEDGIF_MASK) , kLPUART_RxActiveFlag , kLPUART_AllClearFlags , kLPUART_AllFlags
 LPUART status flags. More...
typedef enum _lpuart_parity_mode lpuart_parity_mode_t
 LPUART parity mode.
typedef enum _lpuart_data_bits lpuart_data_bits_t
typedef enum _lpuart_stop_bit_count lpuart_stop_bit_count_t
typedef enum _lpuart_idle_type_select lpuart_idle_type_select_t
typedef enum _lpuart_idle_config lpuart_idle_config_t
typedef struct _lpuart_config lpuart_config_t
typedef struct _lpuart_transfer lpuart_transfer_t
typedef struct _lpuart_handle lpuart_handle_t
typedef void(* lpuart_transfer_callback_t) (LPUART_Type *base, lpuart_handle_t *handle, status_t status, void *userData)
 LPUART transfer callback function.
typedef void(* lpuart_isr_t) (LPUART_Type *base, void *handle)
void * s_lpuartHandle []
const IRQn_Type s_lpuartIRQ []
lpuart_isr_t s_lpuartIsr []
#define FSL_LPUART_DRIVER_VERSION   (MAKE_VERSION(2, 7, 0))
 LPUART driver version.
#define UART_RETRY_TIMES   0U /* Defining to zero means to keep waiting for the flag until it is assert/deassert. */
 Retry times for waiting flag.
Initialization and deinitialization
status_t LPUART_Init (LPUART_Type *base, const lpuart_config_t *config, uint32_t srcClock_Hz)
 Initializes an LPUART instance with the user configuration structure and the peripheral clock. More...
void LPUART_Deinit (LPUART_Type *base)
 Deinitializes a LPUART instance. More...
void LPUART_GetDefaultConfig (lpuart_config_t *config)
 Gets the default configuration structure. More...
Module configuration
status_t LPUART_SetBaudRate (LPUART_Type *base, uint32_t baudRate_Bps, uint32_t srcClock_Hz)
 Sets the LPUART instance baudrate. More...
void LPUART_Enable9bitMode (LPUART_Type *base, bool enable)
 Enable 9-bit data mode for LPUART. More...
Status
uint32_t LPUART_GetStatusFlags (LPUART_Type *base)
 Gets LPUART status flags. More...
status_t LPUART_ClearStatusFlags (LPUART_Type *base, uint32_t mask)
 Clears status flags with a provided mask. More...
Interrupts
void LPUART_EnableInterrupts (LPUART_Type *base, uint32_t mask)
 Enables LPUART interrupts according to a provided mask. More...
void LPUART_DisableInterrupts (LPUART_Type *base, uint32_t mask)
 Disables LPUART interrupts according to a provided mask. More...
uint32_t LPUART_GetEnabledInterrupts (LPUART_Type *base)
 Gets enabled LPUART interrupts. More...
Bus Operations
uint32_t LPUART_GetInstance (LPUART_Type *base)
 Get the LPUART instance from peripheral base address. More...
void LPUART_SendAddress (LPUART_Type *base, uint8_t address)
 Transmit an address frame in 9-bit data mode. More...
status_t LPUART_WriteBlocking (LPUART_Type *base, const uint8_t *data, size_t length)
 Writes to the transmitter register using a blocking method. More...
status_t LPUART_ReadBlocking (LPUART_Type *base, uint8_t *data, size_t length)
 Reads the receiver data register using a blocking method. More...
Transactional
void LPUART_TransferCreateHandle (LPUART_Type *base, lpuart_handle_t *handle, lpuart_transfer_callback_t callback, void *userData)
 Initializes the LPUART handle. More...
status_t LPUART_TransferSendNonBlocking (LPUART_Type *base, lpuart_handle_t *handle, lpuart_transfer_t *xfer)
 Transmits a buffer of data using the interrupt method. More...
void LPUART_TransferStartRingBuffer (LPUART_Type *base, lpuart_handle_t *handle, uint8_t *ringBuffer, size_t ringBufferSize)
 Sets up the RX ring buffer. More...
void LPUART_TransferStopRingBuffer (LPUART_Type *base, lpuart_handle_t *handle)
 Aborts the background transfer and uninstalls the ring buffer. More...
size_t LPUART_TransferGetRxRingBufferLength (LPUART_Type *base, lpuart_handle_t *handle)
 Get the length of received data in RX ring buffer. More...
void LPUART_TransferAbortSend (LPUART_Type *base, lpuart_handle_t *handle)
 Aborts the interrupt-driven data transmit. More...
status_t LPUART_TransferGetSendCount (LPUART_Type *base, lpuart_handle_t *handle, uint32_t *count)
 Gets the number of bytes that have been sent out to bus. More...
status_t LPUART_TransferReceiveNonBlocking (LPUART_Type *base, lpuart_handle_t *handle, lpuart_transfer_t *xfer, size_t *receivedBytes)
 Receives a buffer of data using the interrupt method. More...
void LPUART_TransferAbortReceive (LPUART_Type *base, lpuart_handle_t *handle)
 Aborts the interrupt-driven data receiving. More...
status_t LPUART_TransferGetReceiveCount (LPUART_Type *base, lpuart_handle_t *handle, uint32_t *count)
 Gets the number of bytes that have been received. More...
void LPUART_TransferHandleIRQ (LPUART_Type *base, void *irqHandle)
 LPUART IRQ handle function. More...
void LPUART_TransferHandleErrorIRQ (LPUART_Type *base, void *irqHandle)
 LPUART Error IRQ handle function. More...
◆ anonymous enum
anonymous enum
TX busy
RX busy
LPUART transmitter is idle.
LPUART receiver is idle.
TX FIFO watermark too large
RX FIFO watermark too large
Some flag can't manually clear
Error happens on LPUART.
LPUART RX software ring buffer overrun.
LPUART RX receiver overrun.
LPUART noise error.
LPUART framing error.
LPUART parity error.
Baudrate is not support in current clock source
IDLE flag.
LPUART times out.
◆ _lpuart_data_bits
Eight data bit
◆ _lpuart_flags
This provides constants for the LPUART status flags for use in the LPUART functions.
Transmit data register empty flag, sets when transmit buffer is empty. bit 23
Transmission complete flag, sets when transmission activity complete. bit 22
Receive data register full flag, sets when the receive data buffer is full. bit 21
Idle line detect flag, sets when idle line detected. bit 20
Receive Overrun, sets when new data is received before data is read from receive register. bit 19
Receive takes 3 samples of each received bit. If any of these samples differ, noise flag sets. bit 18
Frame error flag, sets if logic 0 was detected where stop bit expected. bit 17
If parity enabled, sets upon parity error detection. bit 16
Receive pin active edge interrupt flag, sets when active edge detected. bit 30
Receiver Active Flag (RAF), sets at beginning of valid start. bit 24
◆ _lpuart_idle_config
the number of idle characters.
◆ _lpuart_idle_type_select
Start counting after a valid start bit.
Start counting after a stop bit.
◆ _lpuart_interrupt_enable
This structure contains the settings for all LPUART interrupt configurations.
Receive Active Edge. bit 6
Transmit data register empty. bit 23
Transmission complete. bit 22
Receiver data register full. bit 21
Idle line. bit 20
Receiver Overrun. bit 27
Noise error flag. bit 26
Framing error flag. bit 25
Parity error flag. bit 24
◆ _lpuart_parity_mode
LPUART parity mode.
Parity disabled
kLPUART_ParityEven
Parity enabled, type even, bit setting: PE|PT = 10
kLPUART_ParityOdd
Parity enabled, type odd, bit setting: PE|PT = 11
◆ _lpuart_stop_bit_count
kLPUART_OneStopBit
One stop bit
kLPUART_TwoStopBit
Two stop bits
◆ LPUART_ClearStatusFlags()
status_t LPUART_ClearStatusFlags ( LPUART_Type base,
uint32_t  mask
This function clears LPUART status flags with a provided mask. Automatically cleared flags can't be cleared by this function. Flags that can only cleared or set by hardware are: kLPUART_TxDataRegEmptyFlag, kLPUART_TransmissionCompleteFlag, kLPUART_RxDataRegFullFlag, kLPUART_RxActiveFlag, kLPUART_NoiseErrorFlag, kLPUART_ParityErrorFlag, kLPUART_TxFifoEmptyFlag,kLPUART_RxFifoEmptyFlag Note: This API should be called when the Tx/Rx is idle, otherwise it takes no effects.
Parameters
baseLPUART peripheral base address.
maskthe status flags to be cleared. The user can use the enumerators in the _lpuart_status_flag_t to do the OR operation and get the mask.
Returns
0 succeed, others failed.
Return values
kStatus_LPUART_FlagCannotClearManuallyThe flag can't be cleared by this function but it is cleared automatically by hardware.
kStatus_SuccessStatus in the mask are cleared.
brief Clears status flags with a provided mask.
param base LPUART peripheral base address. param mask the status flags to be cleared. The user can use the enumerators in the _lpuart_status_flag_t to do the OR operation and get the mask. return 0 succeed, others failed. retval kStatus_LPUART_FlagCannotClearManually The flag can't be cleared by this function but it is cleared automatically by hardware. retval kStatus_Success Status in the mask are cleared.
◆ LPUART_Deinit()
void LPUART_Deinit ( LPUART_Type base)
This function waits for transmit to complete, disables TX and RX, and disables the LPUART clock.
Parameters
brief Deinitializes a LPUART instance.
◆ LPUART_DisableInterrupts()
void LPUART_DisableInterrupts ( LPUART_Type base,
uint32_t  mask
This function disables the LPUART interrupts according to a provided mask. The mask is a logical OR of enumeration members. See _lpuart_interrupt_enable. This example shows how to disable the TX empty interrupt and RX full interrupt:
#define LPUART1
Definition: MIMXRT1052.h:32133
void LPUART_DisableInterrupts(LPUART_Type *base, uint32_t mask)
Definition: fsl_lpuart.c:801
@ kLPUART_TxDataRegEmptyInterruptEnable
Definition: fsl_lpuart.h:130
@ kLPUART_RxDataRegFullInterruptEnable
Definition: fsl_lpuart.h:132
Parameters
maskThe interrupts to disable. Logical OR of _lpuart_interrupt_enable.
brief Disables LPUART interrupts according to a provided mask.
This function disables the LPUART interrupts according to a provided mask. The mask is a logical OR of enumeration members. See ref _lpuart_interrupt_enable. This example shows how to disable the TX empty interrupt and RX full interrupt: code LPUART_DisableInterrupts(LPUART1,kLPUART_TxDataRegEmptyInterruptEnable | kLPUART_RxDataRegFullInterruptEnable); endcode
param base LPUART peripheral base address. param mask The interrupts to disable. Logical OR of ref _lpuart_interrupt_enable.
◆ LPUART_Enable9bitMode()
void LPUART_Enable9bitMode ( LPUART_Type base,
bool  enable
This function set the 9-bit mode for LPUART module. The 9th bit is not used for parity thus can be modified by user.
Parameters
enabletrue to enable, flase to disable.
brief Enable 9-bit data mode for LPUART.
param base LPUART peripheral base address. param enable true to enable, flase to disable.
◆ LPUART_EnableInterrupts()
void LPUART_EnableInterrupts ( LPUART_Type base,
uint32_t  mask
This function enables the LPUART interrupts according to a provided mask. The mask is a logical OR of enumeration members. See the _lpuart_interrupt_enable. This examples shows how to enable TX empty interrupt and RX full interrupt:
void LPUART_EnableInterrupts(LPUART_Type *base, uint32_t mask)
Definition: fsl_lpuart.c:759
Parameters
maskThe interrupts to enable. Logical OR of _lpuart_interrupt_enable.
brief Enables LPUART interrupts according to a provided mask.
This function enables the LPUART interrupts according to a provided mask. The mask is a logical OR of enumeration members. See the ref _lpuart_interrupt_enable. This examples shows how to enable TX empty interrupt and RX full interrupt: code LPUART_EnableInterrupts(LPUART1,kLPUART_TxDataRegEmptyInterruptEnable | kLPUART_RxDataRegFullInterruptEnable); endcode
param base LPUART peripheral base address. param mask The interrupts to enable. Logical OR of ref _lpuart_interrupt_enable.
◆ LPUART_GetDefaultConfig()
void LPUART_GetDefaultConfig ( lpuart_config_t config)
This function initializes the LPUART configuration structure to a default value. The default values are: lpuartConfig->baudRate_Bps = 115200U; lpuartConfig->parityMode = kLPUART_ParityDisabled; lpuartConfig->dataBitsCount = kLPUART_EightDataBits; lpuartConfig->isMsb = false; lpuartConfig->stopBitCount = kLPUART_OneStopBit; lpuartConfig->txFifoWatermark = 0; lpuartConfig->rxFifoWatermark = 1; lpuartConfig->rxIdleType = kLPUART_IdleTypeStartBit; lpuartConfig->rxIdleConfig = kLPUART_IdleCharacter1; lpuartConfig->enableTx = false; lpuartConfig->enableRx = false;
Parameters
configPointer to a configuration structure.
brief Gets the default configuration structure.
param config Pointer to a configuration structure.
◆ LPUART_GetEnabledInterrupts()
uint32_t LPUART_GetEnabledInterrupts ( LPUART_Type base)
This function gets the enabled LPUART interrupts. The enabled interrupts are returned as the logical OR value of the enumerators _lpuart_interrupt_enable. To check a specific interrupt enable status, compare the return value with enumerators in _lpuart_interrupt_enable. For example, to check whether the TX empty interrupt is enabled:
uint32_t enabledInterrupts = LPUART_GetEnabledInterrupts(LPUART1);
if (kLPUART_TxDataRegEmptyInterruptEnable & enabledInterrupts)
uint32_t LPUART_GetEnabledInterrupts(LPUART_Type *base)
Definition: fsl_lpuart.c:849
Parameters
Returns
LPUART interrupt flags which are logical OR of the enumerators in _lpuart_interrupt_enable.
brief Gets enabled LPUART interrupts.
This function gets the enabled LPUART interrupts. The enabled interrupts are returned as the logical OR value of the enumerators ref _lpuart_interrupt_enable. To check a specific interrupt enable status, compare the return value with enumerators in ref _lpuart_interrupt_enable. For example, to check whether the TX empty interrupt is enabled: code uint32_t enabledInterrupts = LPUART_GetEnabledInterrupts(LPUART1);
if (kLPUART_TxDataRegEmptyInterruptEnable & enabledInterrupts) { ... } endcode
param base LPUART peripheral base address. return LPUART interrupt flags which are logical OR of the enumerators in ref _lpuart_interrupt_enable.
◆ LPUART_GetInstance()
uint32_t LPUART_GetInstance ( LPUART_Type base)
Parameters
Returns
LPUART instance.
brief Get the LPUART instance from peripheral base address.
param base LPUART peripheral base address. return LPUART instance.
◆ LPUART_GetStatusFlags()
uint32_t LPUART_GetStatusFlags ( LPUART_Type base)
This function gets all LPUART status flags. The flags are returned as the logical OR value of the enumerators _lpuart_flags. To check for a specific status, compare the return value with enumerators in the _lpuart_flags. For example, to check whether the TX is empty:
uint32_t LPUART_GetStatusFlags(LPUART_Type *base)
Definition: fsl_lpuart.c:887
@ kLPUART_TxDataRegEmptyFlag
Definition: fsl_lpuart.h:171
Parameters
Returns
LPUART status flags which are ORed by the enumerators in the _lpuart_flags.
brief Gets LPUART status flags.
This function gets all LPUART status flags. The flags are returned as the logical OR value of the enumerators ref _lpuart_flags. To check for a specific status, compare the return value with enumerators in the ref _lpuart_flags. For example, to check whether the TX is empty: code if (kLPUART_TxDataRegEmptyFlag & LPUART_GetStatusFlags(LPUART1)) { ... } endcode
param base LPUART peripheral base address. return LPUART status flags which are ORed by the enumerators in the _lpuart_flags.
◆ LPUART_Init()
status_t LPUART_Init ( LPUART_Type base,
const lpuart_config_t config,
This function configures the LPUART module with user-defined settings. Call the LPUART_GetDefaultConfig() function to configure the configuration structure and get the default configuration. The example below shows how to use this API to configure the LPUART.
lpuart_config_t lpuartConfig;
lpuartConfig.baudRate_Bps = 115200U;
lpuartConfig.isMsb = false;
lpuartConfig.stopBitCount = kLPUART_OneStopBit;
lpuartConfig.txFifoWatermark = 0;
lpuartConfig.rxFifoWatermark = 1;
LPUART_Init(LPUART1, &lpuartConfig, 20000000U);
bool isMsb
Definition: fsl_lpuart.h:245
status_t LPUART_Init(LPUART_Type *base, const lpuart_config_t *config, uint32_t srcClock_Hz)
Definition: fsl_lpuart.c:278
lpuart_parity_mode_t parityMode
Definition: fsl_lpuart.h:243
Definition: fsl_lpuart.h:242
lpuart_data_bits_t dataBitsCount
Definition: fsl_lpuart.h:244
@ kLPUART_ParityDisabled
Definition: fsl_lpuart.h:59
@ kLPUART_EightDataBits
Definition: fsl_lpuart.h:67
@ kLPUART_OneStopBit
Definition: fsl_lpuart.h:76
Definition: fsl_lpuart.h:241
Parameters
configPointer to a user-defined configuration structure.
srcClock_HzLPUART clock source frequency in HZ.
Return values
kStatus_LPUART_BaudrateNotSupportBaudrate is not support in current clock source.
kStatus_SuccessLPUART initialize succeed
brief Initializes an LPUART instance with the user configuration structure and the peripheral clock.
This function configures the LPUART module with user-defined settings. Call the LPUART_GetDefaultConfig() function to configure the configuration structure and get the default configuration. The example below shows how to use this API to configure the LPUART. code lpuart_config_t lpuartConfig; lpuartConfig.baudRate_Bps = 115200U; lpuartConfig.parityMode = kLPUART_ParityDisabled; lpuartConfig.dataBitsCount = kLPUART_EightDataBits; lpuartConfig.isMsb = false; lpuartConfig.stopBitCount = kLPUART_OneStopBit; lpuartConfig.txFifoWatermark = 0; lpuartConfig.rxFifoWatermark = 1; LPUART_Init(LPUART1, &lpuartConfig, 20000000U); endcode
param base LPUART peripheral base address. param config Pointer to a user-defined configuration structure. param srcClock_Hz LPUART clock source frequency in HZ. retval kStatus_LPUART_BaudrateNotSupport Baudrate is not support in current clock source. retval kStatus_Success LPUART initialize succeed
◆ LPUART_ReadBlocking()
status_t LPUART_ReadBlocking ( LPUART_Type base,
uint8_t *  data,
size_t  length
This function polls the receiver register, waits for the receiver register full or receiver FIFO has data, and reads data from the TX register.
Parameters
dataStart address of the buffer to store the received data.
lengthSize of the buffer.
Return values
kStatus_LPUART_RxHardwareOverrunReceiver overrun happened while receiving data.
kStatus_LPUART_NoiseErrorNoise error happened while receiving data.
kStatus_LPUART_FramingErrorFraming error happened while receiving data.
kStatus_LPUART_ParityErrorParity error happened while receiving data.
kStatus_LPUART_TimeoutTransmission timed out and was aborted.
kStatus_SuccessSuccessfully received all data.
brief Reads the receiver data register using a blocking method.
param base LPUART peripheral base address. param data Start address of the buffer to store the received data. param length Size of the buffer. retval kStatus_LPUART_RxHardwareOverrun Receiver overrun happened while receiving data. retval kStatus_LPUART_NoiseError Noise error happened while receiving data. retval kStatus_LPUART_FramingError Framing error happened while receiving data. retval kStatus_LPUART_ParityError Parity error happened while receiving data. retval kStatus_LPUART_Timeout Transmission timed out and was aborted. retval kStatus_Success Successfully received all data.
◆ LPUART_SendAddress()
void LPUART_SendAddress ( LPUART_Type base,
uint8_t  address
Parameters
addressLPUART slave address.
brief Transmit an address frame in 9-bit data mode.
param base LPUART peripheral base address. param address LPUART slave address.
◆ LPUART_SetBaudRate()
status_t LPUART_SetBaudRate ( LPUART_Type base,
This function configures the LPUART module baudrate. This function is used to update the LPUART module baudrate after the LPUART module is initialized by the LPUART_Init.
LPUART_SetBaudRate(LPUART1, 115200U, 20000000U);
status_t LPUART_SetBaudRate(LPUART_Type *base, uint32_t baudRate_Bps, uint32_t srcClock_Hz)
Definition: fsl_lpuart.c:615
Parameters
baudRate_BpsLPUART baudrate to be set.
Return values
kStatus_LPUART_BaudrateNotSupportBaudrate is not supported in the current clock source.
kStatus_SuccessSet baudrate succeeded.
brief Sets the LPUART instance baudrate.
This function configures the LPUART module baudrate. This function is used to update the LPUART module baudrate after the LPUART module is initialized by the LPUART_Init. code LPUART_SetBaudRate(LPUART1, 115200U, 20000000U); endcode
param base LPUART peripheral base address. param baudRate_Bps LPUART baudrate to be set. param srcClock_Hz LPUART clock source frequency in HZ. retval kStatus_LPUART_BaudrateNotSupport Baudrate is not supported in the current clock source. retval kStatus_Success Set baudrate succeeded.
◆ LPUART_TransferAbortReceive()
void LPUART_TransferAbortReceive ( LPUART_Type base,
lpuart_handle_t handle
This function aborts the interrupt-driven data receiving. The user can get the remainBytes to find out how many bytes not received yet.
Parameters
handleLPUART handle pointer.
brief Aborts the interrupt-driven data receiving.
param base LPUART peripheral base address. param handle LPUART handle pointer.
◆ LPUART_TransferAbortSend()
void LPUART_TransferAbortSend ( LPUART_Type base,
This function aborts the interrupt driven data sending. The user can get the remainBtyes to find out how many bytes are not sent out.
Parameters
brief Aborts the interrupt-driven data transmit.
◆ LPUART_TransferCreateHandle()
void LPUART_TransferCreateHandle ( LPUART_Type base,
lpuart_handle_t handle,
void *  userData
This function initializes the LPUART handle, which can be used for other LPUART transactional APIs. Usually, for a specified LPUART instance, call this API once to get the initialized handle.
The LPUART driver supports the "background" receiving, which means that user can set up an RX ring buffer optionally. Data received is stored into the ring buffer even when the user doesn't call the LPUART_TransferReceiveNonBlocking() API. If there is already data received in the ring buffer, the user can get the received data from the ring buffer directly. The ring buffer is disabled if passing NULL as ringBuffer.
Parameters
callbackCallback function.
userDataUser data.
brief Initializes the LPUART handle.
The LPUART driver supports the "background" receiving, which means that user can set up an RX ring buffer optionally. Data received is stored into the ring buffer even when the user doesn't call the LPUART_TransferReceiveNonBlocking() API. If there is already data received in the ring buffer, the user can get the received data from the ring buffer directly. The ring buffer is disabled if passing NULL as p ringBuffer.
param base LPUART peripheral base address. param handle LPUART handle pointer. param callback Callback function. param userData User data.
◆ LPUART_TransferGetReceiveCount()
status_t LPUART_TransferGetReceiveCount ( LPUART_Type base,
uint32_t *  count
This function gets the number of bytes that have been received.
Parameters
countReceive bytes count.
Return values
kStatus_NoTransferInProgressNo receive in progress.
kStatus_InvalidArgumentParameter is invalid.
kStatus_SuccessGet successfully through the parameter count;
brief Gets the number of bytes that have been received.
param base LPUART peripheral base address. param handle LPUART handle pointer. param count Receive bytes count. retval kStatus_NoTransferInProgress No receive in progress. retval kStatus_InvalidArgument Parameter is invalid. retval kStatus_Success Get successfully through the parameter count;
◆ LPUART_TransferGetRxRingBufferLength()
size_t LPUART_TransferGetRxRingBufferLength ( LPUART_Type base,
Parameters
Returns
Length of received data in RX ring buffer.
brief Get the length of received data in RX ring buffer.
userData handle LPUART handle pointer. return Length of received data in RX ring buffer.
◆ LPUART_TransferGetSendCount()
status_t LPUART_TransferGetSendCount ( LPUART_Type base,
uint32_t *  count
This function gets the number of bytes that have been sent out to bus by an interrupt method.
Parameters
countSend bytes count.
Return values
kStatus_NoTransferInProgressNo send in progress.
brief Gets the number of bytes that have been sent out to bus.
param base LPUART peripheral base address. param handle LPUART handle pointer. param count Send bytes count. retval kStatus_NoTransferInProgress No send in progress. retval kStatus_InvalidArgument Parameter is invalid. retval kStatus_Success Get successfully through the parameter count;
◆ LPUART_TransferHandleErrorIRQ()
void LPUART_TransferHandleErrorIRQ ( LPUART_Type base,
void *  irqHandle
This function handles the LPUART error IRQ request.
Parameters
irqHandleLPUART handle pointer.
brief LPUART Error IRQ handle function.
param base LPUART peripheral base address. param irqHandle LPUART handle pointer.
◆ LPUART_TransferHandleIRQ()
void LPUART_TransferHandleIRQ ( LPUART_Type base,
void *  irqHandle
This function handles the LPUART transmit and receive IRQ request.
Parameters
brief LPUART IRQ handle function.
◆ LPUART_TransferReceiveNonBlocking()
status_t LPUART_TransferReceiveNonBlocking ( LPUART_Type base,
lpuart_transfer_t xfer,
size_t *  receivedBytes
This function receives data using an interrupt method. This is a non-blocking function which returns without waiting to ensure that all data are received. If the RX ring buffer is used and not empty, the data in the ring buffer is copied and the parameter receivedBytes shows how many bytes are copied from the ring buffer. After copying, if the data in the ring buffer is not enough for read, the receive request is saved by the LPUART driver. When the new data arrives, the receive request is serviced first. When all data is received, the LPUART driver notifies the upper layer through a callback function and passes a status parameter kStatus_UART_RxIdle. For example, the upper layer needs 10 bytes but there are only 5 bytes in ring buffer. The 5 bytes are copied to xfer->data, which returns with the parameter receivedBytes set to 5. For the remaining 5 bytes, the newly arrived data is saved from xfer->data[5]. When 5 bytes are received, the LPUART driver notifies the upper layer. If the RX ring buffer is not enabled, this function enables the RX and RX interrupt to receive data to xfer->data. When all data is received, the upper layer is notified.
Parameters
xferLPUART transfer structure, see uart_transfer_t.
receivedBytesBytes received from the ring buffer directly.
Return values
kStatus_SuccessSuccessfully queue the transfer into the transmit queue.
kStatus_LPUART_RxBusyPrevious receive request is not finished.
kStatus_InvalidArgumentInvalid argument.
brief Receives a buffer of data using the interrupt method.
This function receives data using an interrupt method. This is a non-blocking function which returns without waiting to ensure that all data are received. If the RX ring buffer is used and not empty, the data in the ring buffer is copied and the parameter p receivedBytes shows how many bytes are copied from the ring buffer. After copying, if the data in the ring buffer is not enough for read, the receive request is saved by the LPUART driver. When the new data arrives, the receive request is serviced first. When all data is received, the LPUART driver notifies the upper layer through a callback function and passes a status parameter ref kStatus_UART_RxIdle. For example, the upper layer needs 10 bytes but there are only 5 bytes in ring buffer. The 5 bytes are copied to xfer->data, which returns with the parameter p receivedBytes set to 5. For the remaining 5 bytes, the newly arrived data is saved from xfer->data[5]. When 5 bytes are received, the LPUART driver notifies the upper layer. If the RX ring buffer is not enabled, this function enables the RX and RX interrupt to receive data to xfer->data. When all data is received, the upper layer is notified.
param base LPUART peripheral base address. param handle LPUART handle pointer. param xfer LPUART transfer structure, see #uart_transfer_t. param receivedBytes Bytes received from the ring buffer directly. retval kStatus_Success Successfully queue the transfer into the transmit queue. retval kStatus_LPUART_RxBusy Previous receive request is not finished. retval kStatus_InvalidArgument Invalid argument.
◆ LPUART_TransferSendNonBlocking()
status_t LPUART_TransferSendNonBlocking ( LPUART_Type base,
This function send data using an interrupt method. This is a non-blocking function, which returns directly without waiting for all data written to the transmitter register. When all data is written to the TX register in the ISR, the LPUART driver calls the callback function and passes the kStatus_LPUART_TxIdle as status parameter.
Note
The kStatus_LPUART_TxIdle is passed to the upper layer when all data are written to the TX register. However, there is no check to ensure that all the data sent out. Before disabling the TX, check the kLPUART_TransmissionCompleteFlag to ensure that the transmit is finished.
Parameters
xferLPUART transfer structure, see lpuart_transfer_t.
Return values
kStatus_SuccessSuccessfully start the data transmission.
kStatus_LPUART_TxBusyPrevious transmission still not finished, data not all written to the TX register.
brief Transmits a buffer of data using the interrupt method.
This function send data using an interrupt method. This is a non-blocking function, which returns directly without waiting for all data written to the transmitter register. When all data is written to the TX register in the ISR, the LPUART driver calls the callback function and passes the ref kStatus_LPUART_TxIdle as status parameter.
note The kStatus_LPUART_TxIdle is passed to the upper layer when all data are written to the TX register. However, there is no check to ensure that all the data sent out. Before disabling the TX, check the kLPUART_TransmissionCompleteFlag to ensure that the transmit is finished.
param base LPUART peripheral base address. param handle LPUART handle pointer. param xfer LPUART transfer structure, see lpuart_transfer_t. retval kStatus_Success Successfully start the data transmission. retval kStatus_LPUART_TxBusy Previous transmission still not finished, data not all written to the TX register. retval kStatus_InvalidArgument Invalid argument.
◆ LPUART_TransferStartRingBuffer()
void LPUART_TransferStartRingBuffer ( LPUART_Type base,
uint8_t *  ringBuffer,
This function sets up the RX ring buffer to a specific UART handle.
When the RX ring buffer is used, data received is stored into the ring buffer even when the user doesn't call the UART_TransferReceiveNonBlocking() API. If there is already data received in the ring buffer, the user can get the received data from the ring buffer directly.
Note
When using RX ring buffer, one byte is reserved for internal use. In other words, if ringBufferSize is 32, then only 31 bytes are used for saving data.
Parameters
ringBufferStart address of ring buffer for background receiving. Pass NULL to disable the ring buffer.
ringBufferSizesize of the ring buffer.
brief Sets up the RX ring buffer.
note When using RX ring buffer, one byte is reserved for internal use. In other words, if p ringBufferSize is 32, then only 31 bytes are used for saving data.
param base LPUART peripheral base address. param handle LPUART handle pointer. param ringBuffer Start address of ring buffer for background receiving. Pass NULL to disable the ring buffer. param ringBufferSize size of the ring buffer.
◆ LPUART_TransferStopRingBuffer()
void LPUART_TransferStopRingBuffer ( LPUART_Type base,
This function aborts the background transfer and uninstalls the ring buffer.
Parameters
brief Aborts the background transfer and uninstalls the ring buffer.
◆ LPUART_WriteBlocking()
status_t LPUART_WriteBlocking ( LPUART_Type base,
const uint8_t *  data,
size_t  length
This function polls the transmitter register, first waits for the register to be empty or TX FIFO to have room, and writes data to the transmitter buffer, then waits for the dat to be sent out to the bus.
Parameters
dataStart address of the data to write.
lengthSize of the data to write.
Return values
kStatus_SuccessSuccessfully wrote all data.
brief Writes to the transmitter register using a blocking method.
This function polls the transmitter register, first waits for the register to be empty or TX FIFO to have room, and writes data to the transmitter buffer, then waits for the data to be sent out to bus.
param base LPUART peripheral base address. param data Start address of the data to write. param length Size of the data to write. retval kStatus_LPUART_Timeout Transmission timed out and was aborted. retval kStatus_Success Successfully wrote all data.
Variable Documentation
◆ baudRate_Bps
LPUART baud rate
◆ callback
Callback function.
◆ data [1/2]
uint8_t* _lpuart_transfer::data
The buffer of data to be transfer.
◆  [2/2]
uint8_t* { ... } ::data
◆ dataBitsCount
Data bits count, eight (default), seven
◆ dataSize
The byte count to be transfer.
◆ enableRx
Enable RX
◆ enableTx
Enable TX
◆ isMsb
Data bits order, LSB (default), MSB
◆ parityMode
Parity mode, disabled (default), even, odd
◆ rxData [1/3]
uint8_t* _lpuart_transfer::rxData
The buffer to receive data.
◆  [2/3]
uint8_t* { ... } ::rxData
◆ rxData [3/3]
uint8_t* volatile _lpuart_handle::rxData
Address of remaining data to receive.
◆ rxDataSize
Size of the remaining data to receive.
◆ rxDataSizeAll
Size of the data to receive.
◆ rxIdleConfig
RX IDLE configuration.
◆ rxIdleType
RX IDLE type.
◆ rxRingBuffer
uint8_t* _lpuart_handle::rxRingBuffer
Start address of the receiver ring buffer.
◆ rxRingBufferHead
Index for the driver to store received data into ring buffer.
◆ rxRingBufferSize
Size of the ring buffer.
◆ rxRingBufferTail
Index for the user to get data from the ring buffer.
◆ rxState
RX transfer state.
◆  [1/3]
const uint8_t* { ... } ::txData
The buffer of data to be sent.
◆ txData [2/3]
const uint8_t* _lpuart_transfer::txData
◆ txData [3/3]
const uint8_t* volatile _lpuart_handle::txData
Address of remaining data to send.
◆ txDataSize
Size of the remaining data to send.
◆ txDataSizeAll
Size of the data to send out.
◆ txState
TX transfer state.
◆ userData
void* _lpuart_handle::userData
LPUART callback function parameter.
