RTEMS 6.1-rc1
_flexio_mculcd_edma_handle Struct Reference
FlexIO MCULCD eDMA transfer handle, users should not touch the content of the handle. More...
#include <fsl_flexio_mculcd_edma.h>
FLEXIO_MCULCD_Typebase
uint8_t txShifterNum
uint8_t rxShifterNum
uint32_t minorLoopBytes
edma_modulo_t txEdmaModulo
edma_modulo_t rxEdmaModulo
uint32_t dataAddrOrSameValue
size_t dataCount
volatile size_t remainingCount
volatile uint32_t state
edma_handle_ttxDmaHandle
edma_handle_trxDmaHandle
flexio_mculcd_edma_transfer_callback_t completionCallback
void * userData
Field Documentation
◆ base
FLEXIO_MCULCD_Type* _flexio_mculcd_edma_handle::base
Pointer to the FLEXIO_MCULCD_Type.
◆ completionCallback
flexio_mculcd_edma_transfer_callback_t _flexio_mculcd_edma_handle::completionCallback
Callback for MCULCD DMA transfer
◆ dataAddrOrSameValue
uint32_t _flexio_mculcd_edma_handle::dataAddrOrSameValue
When sending the same value for many times, this is the value to send. When writing or reading array, this is the address of the data array.
◆ dataCount
size_t _flexio_mculcd_edma_handle::dataCount
Total count to be transferred.
◆ minorLoopBytes
uint32_t _flexio_mculcd_edma_handle::minorLoopBytes
eDMA transfer minor loop bytes.
◆ remainingCount
volatile size_t _flexio_mculcd_edma_handle::remainingCount
Remaining count still not transfered.
◆ rxDmaHandle
edma_handle_t* _flexio_mculcd_edma_handle::rxDmaHandle
DMA handle for MCULCD RX
◆ rxEdmaModulo
edma_modulo_t _flexio_mculcd_edma_handle::rxEdmaModulo
Modulo value for the FlexIO shifter buffer access.
◆ rxShifterNum
uint8_t _flexio_mculcd_edma_handle::rxShifterNum
Number of shifters used for RX.
◆ state
volatile uint32_t _flexio_mculcd_edma_handle::state
FlexIO MCULCD driver internal state.
◆ txDmaHandle
edma_handle_t* _flexio_mculcd_edma_handle::txDmaHandle
DMA handle for MCULCD TX
◆ txEdmaModulo
edma_modulo_t _flexio_mculcd_edma_handle::txEdmaModulo
◆ txShifterNum
uint8_t _flexio_mculcd_edma_handle::txShifterNum
Number of shifters used for TX.
◆ userData
void* _flexio_mculcd_edma_handle::userData
User Data for MCULCD DMA callback
