RTEMS 6.1-rc1
JFFS2 flash device control. More...
#include <jffs2.h>
uint32_t block_size
 The size in bytes of the erasable unit of the flash device.
uint32_t flash_size
 The size in bytes of the flash device. More...
uint32_t write_size
 The size in bytes of the minimum write size for the flash device. More...
rtems_jffs2_flash_read read
 Read from flash operation.
rtems_jffs2_flash_write write
 Write to flash operation.
rtems_jffs2_flash_erase erase
 Flash erase operation.
rtems_jffs2_flash_block_is_bad block_is_bad
 Flash bad block check operation.
rtems_jffs2_flash_block_mark_bad block_mark_bad
 Flash bad block mark operation.
rtems_jffs2_flash_oob_write oob_write
 Flash oob bytes write operation.
rtems_jffs2_flash_oob_read oob_read
 Flash oob bytes read operation.
rtems_jffs2_flash_get_oob_size get_oob_size
 Flash get oob bytes per page operation.
rtems_jffs2_flash_destroy destroy
 Flash destroy operation. More...
dev_t device_identifier
 The device identifier of the flash device. More...
rtems_jffs2_trigger_garbage_collection trigger_garbage_collection
 Trigger garbage collection operation. More...
Field Documentation
◆ destroy
rtems_jffs2_flash_destroy rtems_jffs2_flash_control::destroy
This operation is optional and the pointer may be NULL.
◆ device_identifier
dev_t rtems_jffs2_flash_control::device_identifier
It is used in combination with the inode number to uniquely identify a file system node in the system.
◆ flash_size
uint32_t rtems_jffs2_flash_control::flash_size
It must be an integral multiple of the block size. The flash device must have at least five blocks.
◆ trigger_garbage_collection
rtems_jffs2_trigger_garbage_collection rtems_jffs2_flash_control::trigger_garbage_collection
This operation is optional and may be NULL. This operation should wake up a garbage collection thread. The garbage collection thread should use the RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION IO control to carry out the work.
◆ write_size
uint32_t rtems_jffs2_flash_control::write_size
It must be an integral divisor into the block size. This is only applicable for NAND devices.
