RTEMS 6.1-rc1
Files | Data Structures | Macros | Enumerator | Variables
Clock
file  fsl_clock.h
file  fsl_clock.h
struct  _clock_arm_pll_config
 PLL configuration for ARM. More...
struct  _clock_usb_pll_config
 PLL configuration for USB. More...
struct  _clock_sys_pll_config
 PLL configuration for System. More...
struct  _clock_audio_pll_config
 PLL configuration for AUDIO and VIDEO. More...
struct  _clock_video_pll_config
struct  _clock_enet_pll_config
 PLL configuration for ENET. More...
struct  _clock_group_config
 The structure used to configure clock group. More...
struct  _clock_pll_ss_config
 Spread specturm configure Pll. More...
struct  _clock_sys_pll2_config
 PLL configure for Sys Pll2. More...
struct  _clock_sys_pll1_config
 PLL configure for Sys Pll1. More...
struct  _clock_audio_pll_gpc_config
 PLL configuration fro AUDIO PLL, SYSTEM PLL1 and VIDEO PLL. More...
struct  _clock_root_config_t
 Clock root configuration. More...
struct  _clock_root_setpoint_config_t
 Clock root configuration in SetPoint Mode. More...
#define FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL   0
 Configure whether driver controls clock. More...
bool _clock_group_config::clockOff
uint16_t _clock_group_config::resetDiv
uint8_t _clock_group_config::div0
clock_pll_post_div_t _clock_arm_pll_config::postDivider
uint32_t _clock_arm_pll_config::loopDivider
uint8_t _clock_usb_pll_config::loopDivider
uint8_t _clock_usb_pll_config::src
uint16_t _clock_pll_ss_config::stop
uint16_t _clock_pll_ss_config::step
uint32_t _clock_sys_pll2_config::mfd
clock_pll_ss_config_t_clock_sys_pll2_config::ss
bool _clock_sys_pll2_config::ssEnable
bool _clock_sys_pll1_config::pllDiv2En
bool _clock_sys_pll1_config::pllDiv5En
clock_pll_ss_config_t_clock_sys_pll1_config::ss
bool _clock_sys_pll1_config::ssEnable
uint8_t _clock_audio_pll_config::loopDivider
uint8_t _clock_audio_pll_config::postDivider
uint32_t _clock_audio_pll_config::numerator
uint32_t _clock_audio_pll_config::denominator
clock_pll_ss_config_t_clock_audio_pll_config::ss
bool _clock_audio_pll_config::ssEnable
uint8_t _clock_audio_pll_gpc_config::loopDivider
uint32_t _clock_audio_pll_gpc_config::numerator
uint32_t _clock_audio_pll_gpc_config::denominator
clock_pll_ss_config_t_clock_audio_pll_gpc_config::ss
bool _clock_audio_pll_gpc_config::ssEnable
bool _clock_enet_pll_config::enableClkOutput
bool _clock_enet_pll_config::enableClkOutput25M
uint8_t _clock_enet_pll_config::loopDivider
uint8_t _clock_enet_pll_config::src
bool _clock_enet_pll_config::enableClkOutput1
uint8_t _clock_enet_pll_config::loopDivider1
bool _clock_root_config_t::clockOff
uint8_t _clock_root_config_t::mux
uint8_t _clock_root_config_t::div
uint8_t _clock_root_setpoint_config_t::grade
bool _clock_root_setpoint_config_t::clockOff
uint8_t _clock_root_setpoint_config_t::mux
uint8_t _clock_root_setpoint_config_t::div
Driver version
enum  _clock_name {
  kCLOCK_CpuClk = 0x0U , kCLOCK_AhbClk = 0x1U , kCLOCK_SemcClk = 0x2U , kCLOCK_IpgClk = 0x3U ,
  kCLOCK_PerClk = 0x4U , kCLOCK_OscClk = 0x5U , kCLOCK_RtcClk = 0x6U , kCLOCK_ArmPllClk = 0x7U ,
  kCLOCK_Usb1PllClk = 0x8U , kCLOCK_Usb1PllPfd0Clk = 0x9U , kCLOCK_Usb1PllPfd1Clk = 0xAU , kCLOCK_Usb1PllPfd2Clk = 0xBU ,
  kCLOCK_Usb1PllPfd3Clk = 0xCU , kCLOCK_Usb1SwClk = 0x17U , kCLOCK_Usb1Sw120MClk = 0x18U , kCLOCK_Usb1Sw60MClk = 0x19U ,
  kCLOCK_Usb1Sw80MClk = 0x1AU , kCLOCK_Usb2PllClk = 0xDU , kCLOCK_SysPllClk = 0xEU , kCLOCK_SysPllPfd0Clk = 0xFU ,
  kCLOCK_SysPllPfd1Clk = 0x10U , kCLOCK_SysPllPfd2Clk = 0x11U , kCLOCK_SysPllPfd3Clk = 0x12U , kCLOCK_EnetPll0Clk = 0x13U ,
  kCLOCK_EnetPll1Clk = 0x14U , kCLOCK_AudioPllClk = 0x15U , kCLOCK_VideoPllClk = 0x16U , kCLOCK_NoneName = CLOCK_SOURCE_NONE ,
  kCLOCK_OscRc16M = 0 , kCLOCK_OscRc48M = 1 , kCLOCK_OscRc48MDiv2 = 2 , kCLOCK_OscRc400M = 3 ,
  kCLOCK_Osc24M = 4 , kCLOCK_Osc24MOut = 5 , kCLOCK_ArmPll = 6 , kCLOCK_ArmPllOut = 7 ,
  kCLOCK_SysPll2 = 8 , kCLOCK_SysPll2Out = 9 , kCLOCK_SysPll2Pfd0 = 10 , kCLOCK_SysPll2Pfd1 = 11 ,
  kCLOCK_SysPll2Pfd2 = 12 , kCLOCK_SysPll2Pfd3 = 13 , kCLOCK_SysPll3 = 14 , kCLOCK_SysPll3Out = 15 ,
  kCLOCK_SysPll3Div2 = 16 , kCLOCK_SysPll3Pfd0 = 17 , kCLOCK_SysPll3Pfd1 = 18 , kCLOCK_SysPll3Pfd2 = 19 ,
  kCLOCK_SysPll3Pfd3 = 20 , kCLOCK_SysPll1 = 21 , kCLOCK_SysPll1Out = 22 , kCLOCK_SysPll1Div2 = 23 ,
  kCLOCK_SysPll1Div5 = 24 , kCLOCK_AudioPll = 25 , kCLOCK_AudioPllOut = 26 , kCLOCK_VideoPll = 27 ,
  kCLOCK_VideoPllOut = 28 , kCLOCK_CpuClk , kCLOCK_CoreSysClk , kCLOCK_Reserved = 0xFFU
 Clock name used to get clock frequency. More...
enum  _clock_ip_name {
  kCLOCK_IpInvalid = -1 , kCLOCK_Aips_tz1 = (0U << 8U) | CCM_CCGR0_CG0_SHIFT , kCLOCK_Aips_tz2 = (0U << 8U) | CCM_CCGR0_CG1_SHIFT , kCLOCK_Mqs = (0U << 8U) | CCM_CCGR0_CG2_SHIFT ,
  kCLOCK_FlexSpiExsc = (0U << 8U) | CCM_CCGR0_CG3_SHIFT , kCLOCK_Sim_M_Main = (0U << 8U) | CCM_CCGR0_CG4_SHIFT , kCLOCK_Dcp = (0U << 8U) | CCM_CCGR0_CG5_SHIFT , kCLOCK_Lpuart3 = (0U << 8U) | CCM_CCGR0_CG6_SHIFT ,
  kCLOCK_Can1 = (0U << 8U) | CCM_CCGR0_CG7_SHIFT , kCLOCK_Can1S = (0U << 8U) | CCM_CCGR0_CG8_SHIFT , kCLOCK_Can2 = (0U << 8U) | CCM_CCGR0_CG9_SHIFT , kCLOCK_Can2S = (0U << 8U) | CCM_CCGR0_CG10_SHIFT ,
  kCLOCK_Trace = (0U << 8U) | CCM_CCGR0_CG11_SHIFT , kCLOCK_Gpt2 = (0U << 8U) | CCM_CCGR0_CG12_SHIFT , kCLOCK_Gpt2S = (0U << 8U) | CCM_CCGR0_CG13_SHIFT , kCLOCK_Lpuart2 = (0U << 8U) | CCM_CCGR0_CG14_SHIFT ,
  kCLOCK_Gpio2 = (0U << 8U) | CCM_CCGR0_CG15_SHIFT , kCLOCK_Lpspi1 = (1U << 8U) | CCM_CCGR1_CG0_SHIFT , kCLOCK_Lpspi2 = (1U << 8U) | CCM_CCGR1_CG1_SHIFT , kCLOCK_Lpspi3 = (1U << 8U) | CCM_CCGR1_CG2_SHIFT ,
  kCLOCK_Lpspi4 = (1U << 8U) | CCM_CCGR1_CG3_SHIFT , kCLOCK_Adc2 = (1U << 8U) | CCM_CCGR1_CG4_SHIFT , kCLOCK_Enet = (1U << 8U) | CCM_CCGR1_CG5_SHIFT , kCLOCK_Pit = (1U << 8U) | CCM_CCGR1_CG6_SHIFT ,
  kCLOCK_Aoi2 = (1U << 8U) | CCM_CCGR1_CG7_SHIFT , kCLOCK_Adc1 = (1U << 8U) | CCM_CCGR1_CG8_SHIFT , kCLOCK_SemcExsc = (1U << 8U) | CCM_CCGR1_CG9_SHIFT , kCLOCK_Gpt1 = (1U << 8U) | CCM_CCGR1_CG10_SHIFT ,
  kCLOCK_Gpt1S = (1U << 8U) | CCM_CCGR1_CG11_SHIFT , kCLOCK_Lpuart4 = (1U << 8U) | CCM_CCGR1_CG12_SHIFT , kCLOCK_Gpio1 = (1U << 8U) | CCM_CCGR1_CG13_SHIFT , kCLOCK_Csu = (1U << 8U) | CCM_CCGR1_CG14_SHIFT ,
  kCLOCK_Gpio5 = (1U << 8U) | CCM_CCGR1_CG15_SHIFT , kCLOCK_OcramExsc = (2U << 8U) | CCM_CCGR2_CG0_SHIFT , kCLOCK_Csi = (2U << 8U) | CCM_CCGR2_CG1_SHIFT , kCLOCK_IomuxcSnvs = (2U << 8U) | CCM_CCGR2_CG2_SHIFT ,
  kCLOCK_Lpi2c1 = (2U << 8U) | CCM_CCGR2_CG3_SHIFT , kCLOCK_Lpi2c2 = (2U << 8U) | CCM_CCGR2_CG4_SHIFT , kCLOCK_Lpi2c3 = (2U << 8U) | CCM_CCGR2_CG5_SHIFT , kCLOCK_Ocotp = (2U << 8U) | CCM_CCGR2_CG6_SHIFT ,
  kCLOCK_Xbar3 = (2U << 8U) | CCM_CCGR2_CG7_SHIFT , kCLOCK_Ipmux1 = (2U << 8U) | CCM_CCGR2_CG8_SHIFT , kCLOCK_Ipmux2 = (2U << 8U) | CCM_CCGR2_CG9_SHIFT , kCLOCK_Ipmux3 = (2U << 8U) | CCM_CCGR2_CG10_SHIFT ,
  kCLOCK_Xbar1 = (2U << 8U) | CCM_CCGR2_CG11_SHIFT , kCLOCK_Xbar2 = (2U << 8U) | CCM_CCGR2_CG12_SHIFT , kCLOCK_Gpio3 = (2U << 8U) | CCM_CCGR2_CG13_SHIFT , kCLOCK_Lcd = (2U << 8U) | CCM_CCGR2_CG14_SHIFT ,
  kCLOCK_Pxp = (2U << 8U) | CCM_CCGR2_CG15_SHIFT , kCLOCK_Flexio2 = (3U << 8U) | CCM_CCGR3_CG0_SHIFT , kCLOCK_Lpuart5 = (3U << 8U) | CCM_CCGR3_CG1_SHIFT , kCLOCK_Semc = (3U << 8U) | CCM_CCGR3_CG2_SHIFT ,
  kCLOCK_Lpuart6 = (3U << 8U) | CCM_CCGR3_CG3_SHIFT , kCLOCK_Aoi1 = (3U << 8U) | CCM_CCGR3_CG4_SHIFT , kCLOCK_LcdPixel = (3U << 8U) | CCM_CCGR3_CG5_SHIFT , kCLOCK_Gpio4 = (3U << 8U) | CCM_CCGR3_CG6_SHIFT ,
  kCLOCK_Ewm0 = (3U << 8U) | CCM_CCGR3_CG7_SHIFT , kCLOCK_Wdog1 = (3U << 8U) | CCM_CCGR3_CG8_SHIFT , kCLOCK_FlexRam = (3U << 8U) | CCM_CCGR3_CG9_SHIFT , kCLOCK_Acmp1 = (3U << 8U) | CCM_CCGR3_CG10_SHIFT ,
  kCLOCK_Acmp2 = (3U << 8U) | CCM_CCGR3_CG11_SHIFT , kCLOCK_Acmp3 = (3U << 8U) | CCM_CCGR3_CG12_SHIFT , kCLOCK_Acmp4 = (3U << 8U) | CCM_CCGR3_CG13_SHIFT , kCLOCK_Ocram = (3U << 8U) | CCM_CCGR3_CG14_SHIFT ,
  kCLOCK_IomuxcSnvsGpr = (3U << 8U) | CCM_CCGR3_CG15_SHIFT , kCLOCK_Sim_m7_clk_r = (4U << 8U) | CCM_CCGR4_CG0_SHIFT , kCLOCK_Iomuxc = (4U << 8U) | CCM_CCGR4_CG1_SHIFT , kCLOCK_IomuxcGpr = (4U << 8U) | CCM_CCGR4_CG2_SHIFT ,
  kCLOCK_Bee = (4U << 8U) | CCM_CCGR4_CG3_SHIFT , kCLOCK_SimM7 = (4U << 8U) | CCM_CCGR4_CG4_SHIFT , kCLOCK_Tsc = (4U << 8U) | CCM_CCGR4_CG5_SHIFT , kCLOCK_SimM = (4U << 8U) | CCM_CCGR4_CG6_SHIFT ,
  kCLOCK_SimEms = (4U << 8U) | CCM_CCGR4_CG7_SHIFT , kCLOCK_Pwm1 = (4U << 8U) | CCM_CCGR4_CG8_SHIFT , kCLOCK_Pwm2 = (4U << 8U) | CCM_CCGR4_CG9_SHIFT , kCLOCK_Pwm3 = (4U << 8U) | CCM_CCGR4_CG10_SHIFT ,
  kCLOCK_Pwm4 = (4U << 8U) | CCM_CCGR4_CG11_SHIFT , kCLOCK_Enc1 = (4U << 8U) | CCM_CCGR4_CG12_SHIFT , kCLOCK_Enc2 = (4U << 8U) | CCM_CCGR4_CG13_SHIFT , kCLOCK_Enc3 = (4U << 8U) | CCM_CCGR4_CG14_SHIFT ,
  kCLOCK_Enc4 = (4U << 8U) | CCM_CCGR4_CG15_SHIFT , kCLOCK_Rom = (5U << 8U) | CCM_CCGR5_CG0_SHIFT , kCLOCK_Flexio1 = (5U << 8U) | CCM_CCGR5_CG1_SHIFT , kCLOCK_Wdog3 = (5U << 8U) | CCM_CCGR5_CG2_SHIFT ,
  kCLOCK_Dma = (5U << 8U) | CCM_CCGR5_CG3_SHIFT , kCLOCK_Kpp = (5U << 8U) | CCM_CCGR5_CG4_SHIFT , kCLOCK_Wdog2 = (5U << 8U) | CCM_CCGR5_CG5_SHIFT , kCLOCK_Aips_tz4 = (5U << 8U) | CCM_CCGR5_CG6_SHIFT ,
  kCLOCK_Spdif = (5U << 8U) | CCM_CCGR5_CG7_SHIFT , kCLOCK_SimMain = (5U << 8U) | CCM_CCGR5_CG8_SHIFT , kCLOCK_Sai1 = (5U << 8U) | CCM_CCGR5_CG9_SHIFT , kCLOCK_Sai2 = (5U << 8U) | CCM_CCGR5_CG10_SHIFT ,
  kCLOCK_Sai3 = (5U << 8U) | CCM_CCGR5_CG11_SHIFT , kCLOCK_Lpuart1 = (5U << 8U) | CCM_CCGR5_CG12_SHIFT , kCLOCK_Lpuart7 = (5U << 8U) | CCM_CCGR5_CG13_SHIFT , kCLOCK_SnvsHp = (5U << 8U) | CCM_CCGR5_CG14_SHIFT ,
  kCLOCK_SnvsLp = (5U << 8U) | CCM_CCGR5_CG15_SHIFT , kCLOCK_UsbOh3 = (6U << 8U) | CCM_CCGR6_CG0_SHIFT , kCLOCK_Usdhc1 = (6U << 8U) | CCM_CCGR6_CG1_SHIFT , kCLOCK_Usdhc2 = (6U << 8U) | CCM_CCGR6_CG2_SHIFT ,
  kCLOCK_Dcdc = (6U << 8U) | CCM_CCGR6_CG3_SHIFT , kCLOCK_Ipmux4 = (6U << 8U) | CCM_CCGR6_CG4_SHIFT , kCLOCK_FlexSpi = (6U << 8U) | CCM_CCGR6_CG5_SHIFT , kCLOCK_Trng = (6U << 8U) | CCM_CCGR6_CG6_SHIFT ,
  kCLOCK_Lpuart8 = (6U << 8U) | CCM_CCGR6_CG7_SHIFT , kCLOCK_Timer4 = (6U << 8U) | CCM_CCGR6_CG8_SHIFT , kCLOCK_Aips_tz3 = (6U << 8U) | CCM_CCGR6_CG9_SHIFT , kCLOCK_SimPer = (6U << 8U) | CCM_CCGR6_CG10_SHIFT ,
  kCLOCK_Anadig = (6U << 8U) | CCM_CCGR6_CG11_SHIFT , kCLOCK_Lpi2c4 = (6U << 8U) | CCM_CCGR6_CG12_SHIFT , kCLOCK_Timer1 = (6U << 8U) | CCM_CCGR6_CG13_SHIFT , kCLOCK_Timer2 = (6U << 8U) | CCM_CCGR6_CG14_SHIFT ,
  kCLOCK_Timer3 = (6U << 8U) | CCM_CCGR6_CG15_SHIFT
 CCM CCGR gate control for each module independently. More...
enum  _clock_osc { kCLOCK_RcOsc = 0U , kCLOCK_XtalOsc = 1U , kCLOCK_RcOsc = 0U , kCLOCK_XtalOsc = 1U }
 OSC 24M sorce select. More...
enum  _clock_gate_value {
  kCLOCK_ClockNotNeeded = 0U , kCLOCK_ClockNeededRun = 1U , kCLOCK_ClockNeededRunWait = 3U , kCLOCK_Off = (int)~CCM_LPCG_DIRECT_ON_MASK ,
  kCLOCK_On = CCM_LPCG_DIRECT_ON_MASK
 Clock gate value. More...
enum  _clock_mode_t {
  kCLOCK_ModeRun = 0U , kCLOCK_ModeWait = 1U , kCLOCK_ModeStop = 2U , kCLOCK_ModeRun = 0U ,
 System clock mode. More...
enum  _clock_mux {
  kCLOCK_Pll3SwMux , kCLOCK_PeriphMux , kCLOCK_SemcAltMux , kCLOCK_SemcMux ,
  kCLOCK_PrePeriphMux , kCLOCK_TraceMux , kCLOCK_PeriphClk2Mux , kCLOCK_LpspiMux ,
  kCLOCK_FlexspiMux , kCLOCK_Usdhc2Mux , kCLOCK_Usdhc1Mux , kCLOCK_Sai3Mux ,
  kCLOCK_Sai2Mux , kCLOCK_Sai1Mux , kCLOCK_PerclkMux , kCLOCK_Flexio2Mux ,
  kCLOCK_CanMux , kCLOCK_UartMux , kCLOCK_SpdifMux , kCLOCK_Flexio1Mux ,
  kCLOCK_Lpi2cMux , kCLOCK_LcdifPreMux , kCLOCK_CsiMux
 MUX control names for clock mux setting. More...
enum  _clock_div {
  kCLOCK_ArmDiv , kCLOCK_PeriphClk2Div , kCLOCK_SemcDiv , kCLOCK_AhbDiv ,
  kCLOCK_IpgDiv , kCLOCK_LpspiDiv , kCLOCK_LcdifDiv , kCLOCK_FlexspiDiv ,
  kCLOCK_PerclkDiv , kCLOCK_CanDiv , kCLOCK_TraceDiv , kCLOCK_Usdhc2Div ,
  kCLOCK_Usdhc1Div , kCLOCK_UartDiv , kCLOCK_Flexio2Div , kCLOCK_Sai3PreDiv ,
  kCLOCK_Sai3Div , kCLOCK_Flexio2PreDiv , kCLOCK_Sai1PreDiv , kCLOCK_Sai1Div ,
  kCLOCK_Sai2PreDiv , kCLOCK_Sai2Div , kCLOCK_Spdif0PreDiv , kCLOCK_Spdif0Div ,
  kCLOCK_Flexio1PreDiv , kCLOCK_Flexio1Div , kCLOCK_Lpi2cDiv , kCLOCK_LcdifPreDiv ,
  kCLOCK_CsiDiv , kCLOCK_NonePreDiv = CLOCK_ROOT_NONE_PRE_DIV
 DIV control names for clock div setting. More...
enum  _clock_div_value {
  kCLOCK_ArmDivBy1 = 0 , kCLOCK_ArmDivBy2 = 1 , kCLOCK_ArmDivBy3 = 2 , kCLOCK_ArmDivBy4 = 3 ,
  kCLOCK_ArmDivBy5 = 4 , kCLOCK_ArmDivBy6 = 5 , kCLOCK_ArmDivBy7 = 6 , kCLOCK_ArmDivBy8 = 7 ,
  kCLOCK_PeriphClk2DivBy1 = 0 , kCLOCK_PeriphClk2DivBy2 = 1 , kCLOCK_PeriphClk2DivBy3 = 2 , kCLOCK_PeriphClk2DivBy4 = 3 ,
  kCLOCK_PeriphClk2DivBy5 = 4 , kCLOCK_PeriphClk2DivBy6 = 5 , kCLOCK_PeriphClk2DivBy7 = 6 , kCLOCK_PeriphClk2DivBy8 = 7 ,
  kCLOCK_SemcDivBy1 = 0 , kCLOCK_SemcDivBy2 = 1 , kCLOCK_SemcDivBy3 = 2 , kCLOCK_SemcDivBy4 = 3 ,
  kCLOCK_SemcDivBy5 = 4 , kCLOCK_SemcDivBy6 = 5 , kCLOCK_SemcDivBy7 = 6 , kCLOCK_SemcDivBy8 = 7 ,
  kCLOCK_AhbDivBy1 = 0 , kCLOCK_AhbDivBy2 = 1 , kCLOCK_AhbDivBy3 = 2 , kCLOCK_AhbDivBy4 = 3 ,
  kCLOCK_AhbDivBy5 = 4 , kCLOCK_AhbDivBy6 = 5 , kCLOCK_AhbDivBy7 = 6 , kCLOCK_AhbDivBy8 = 7 ,
  kCLOCK_IpgDivBy1 = 0 , kCLOCK_IpgDivBy2 = 1 , kCLOCK_IpgDivBy3 = 2 , kCLOCK_IpgDivBy4 = 3 ,
  kCLOCK_LpspiDivBy1 = 0 , kCLOCK_LpspiDivBy2 = 1 , kCLOCK_LpspiDivBy3 = 2 , kCLOCK_LpspiDivBy4 = 3 ,
  kCLOCK_LpspiDivBy5 = 4 , kCLOCK_LpspiDivBy6 = 5 , kCLOCK_LpspiDivBy7 = 6 , kCLOCK_LpspiDivBy8 = 7 ,
  kCLOCK_LcdifDivBy1 = 0 , kCLOCK_LcdifDivBy2 = 1 , kCLOCK_LcdifDivBy3 = 2 , kCLOCK_LcdifDivBy4 = 3 ,
  kCLOCK_LcdifDivBy5 = 4 , kCLOCK_LcdifDivBy6 = 5 , kCLOCK_LcdifDivBy7 = 6 , kCLOCK_LcdifDivBy8 = 7 ,
  kCLOCK_FlexspiDivBy1 = 0 , kCLOCK_FlexspiDivBy2 = 1 , kCLOCK_FlexspiDivBy3 = 2 , kCLOCK_FlexspiDivBy4 = 3 ,
  kCLOCK_FlexspiDivBy5 = 4 , kCLOCK_FlexspiDivBy6 = 5 , kCLOCK_FlexspiDivBy7 = 6 , kCLOCK_FlexspiDivBy8 = 7 ,
  kCLOCK_TraceDivBy1 = 0 , kCLOCK_TraceDivBy2 = 1 , kCLOCK_TraceDivBy3 = 2 , kCLOCK_TraceDivBy4 = 3 ,
  kCLOCK_Usdhc2DivBy1 = 0 , kCLOCK_Usdhc2DivBy2 = 1 , kCLOCK_Usdhc2DivBy3 = 2 , kCLOCK_Usdhc2DivBy4 = 3 ,
  kCLOCK_Usdhc2DivBy5 = 4 , kCLOCK_Usdhc2DivBy6 = 5 , kCLOCK_Usdhc2DivBy7 = 6 , kCLOCK_Usdhc2DivBy8 = 7 ,
  kCLOCK_Usdhc1DivBy1 = 0 , kCLOCK_Usdhc1DivBy2 = 1 , kCLOCK_Usdhc1DivBy3 = 2 , kCLOCK_Usdhc1DivBy4 = 3 ,
  kCLOCK_Usdhc1DivBy5 = 4 , kCLOCK_Usdhc1DivBy6 = 5 , kCLOCK_Usdhc1DivBy7 = 6 , kCLOCK_Usdhc1DivBy8 = 7 ,
  kCLOCK_Flexio2DivBy1 = 0 , kCLOCK_Flexio2DivBy2 = 1 , kCLOCK_Flexio2DivBy3 = 2 , kCLOCK_Flexio2DivBy4 = 3 ,
  kCLOCK_Flexio2DivBy5 = 4 , kCLOCK_Flexio2DivBy6 = 5 , kCLOCK_Flexio2DivBy7 = 6 , kCLOCK_Flexio2DivBy8 = 7 ,
  kCLOCK_Sai3PreDivBy1 = 0 , kCLOCK_Sai3PreDivBy2 = 1 , kCLOCK_Sai3PreDivBy3 = 2 , kCLOCK_Sai3PreDivBy4 = 3 ,
  kCLOCK_Sai3PreDivBy5 = 4 , kCLOCK_Sai3PreDivBy6 = 5 , kCLOCK_Sai3PreDivBy7 = 6 , kCLOCK_Sai3PreDivBy8 = 7 ,
  kCLOCK_Flexio2PreDivBy1 = 0 , kCLOCK_Flexio2PreDivBy2 = 1 , kCLOCK_Flexio2PreDivBy3 = 2 , kCLOCK_Flexio2PreDivBy4 = 3 ,
  kCLOCK_Flexio2PreDivBy5 = 4 , kCLOCK_Flexio2PreDivBy6 = 5 , kCLOCK_Flexio2PreDivBy7 = 6 , kCLOCK_Flexio2PreDivBy8 = 7 ,
  kCLOCK_Sai1PreDivBy1 = 0 , kCLOCK_Sai1PreDivBy2 = 1 , kCLOCK_Sai1PreDivBy3 = 2 , kCLOCK_Sai1PreDivBy4 = 3 ,
  kCLOCK_Sai1PreDivBy5 = 4 , kCLOCK_Sai1PreDivBy6 = 5 , kCLOCK_Sai1PreDivBy7 = 6 , kCLOCK_Sai1PreDivBy8 = 7 ,
  kCLOCK_Sai2PreDivBy1 = 0 , kCLOCK_Sai2PreDivBy2 = 1 , kCLOCK_Sai2PreDivBy3 = 2 , kCLOCK_Sai2PreDivBy4 = 3 ,
  kCLOCK_Sai2PreDivBy5 = 4 , kCLOCK_Sai2PreDivBy6 = 5 , kCLOCK_Sai2PreDivBy7 = 6 , kCLOCK_Sai2PreDivBy8 = 7 ,
  kCLOCK_Spdif0PreDivBy1 = 0 , kCLOCK_Spdif0PreDivBy2 = 1 , kCLOCK_Spdif0PreDivBy3 = 2 , kCLOCK_Spdif0PreDivBy4 = 3 ,
  kCLOCK_Spdif0PreDivBy5 = 4 , kCLOCK_Spdif0PreDivBy6 = 5 , kCLOCK_Spdif0PreDivBy7 = 6 , kCLOCK_Spdif0PreDivBy8 = 7 ,
  kCLOCK_Spdif0DivBy1 = 0 , kCLOCK_Spdif0DivBy2 = 1 , kCLOCK_Spdif0DivBy3 = 2 , kCLOCK_Spdif0DivBy4 = 3 ,
  kCLOCK_Spdif0DivBy5 = 4 , kCLOCK_Spdif0DivBy6 = 5 , kCLOCK_Spdif0DivBy7 = 6 , kCLOCK_Spdif0DivBy8 = 7 ,
  kCLOCK_Flexio1PreDivBy1 = 0 , kCLOCK_Flexio1PreDivBy2 = 1 , kCLOCK_Flexio1PreDivBy3 = 2 , kCLOCK_Flexio1PreDivBy4 = 3 ,
  kCLOCK_Flexio1PreDivBy5 = 4 , kCLOCK_Flexio1PreDivBy6 = 5 , kCLOCK_Flexio1PreDivBy7 = 6 , kCLOCK_Flexio1PreDivBy8 = 7 ,
  kCLOCK_Flexio1DivBy1 = 0 , kCLOCK_Flexio1DivBy2 = 1 , kCLOCK_Flexio1DivBy3 = 2 , kCLOCK_Flexio1DivBy4 = 3 ,
  kCLOCK_Flexio1DivBy5 = 4 , kCLOCK_Flexio1DivBy6 = 5 , kCLOCK_Flexio1DivBy7 = 6 , kCLOCK_Flexio1DivBy8 = 7 ,
  kCLOCK_LcdifPreDivBy1 = 0 , kCLOCK_LcdifPreDivBy2 = 1 , kCLOCK_LcdifPreDivBy3 = 2 , kCLOCK_LcdifPreDivBy4 = 3 ,
  kCLOCK_LcdifPreDivBy5 = 4 , kCLOCK_LcdifPreDivBy6 = 5 , kCLOCK_LcdifPreDivBy7 = 6 , kCLOCK_LcdifPreDivBy8 = 7 ,
  kCLOCK_CsiDivBy1 = 0 , kCLOCK_CsiDivBy2 = 1 , kCLOCK_CsiDivBy3 = 2 , kCLOCK_CsiDivBy4 = 3 ,
  kCLOCK_CsiDivBy5 = 4 , kCLOCK_CsiDivBy6 = 5 , kCLOCK_CsiDivBy7 = 6 , kCLOCK_CsiDivBy8 = 7 ,
  kCLOCK_MiscDivBy1 = 0 , kCLOCK_MiscDivBy2 = 1 , kCLOCK_MiscDivBy3 = 2 , kCLOCK_MiscDivBy4 = 3 ,
  kCLOCK_MiscDivBy5 = 4 , kCLOCK_MiscDivBy6 = 5 , kCLOCK_MiscDivBy7 = 6 , kCLOCK_MiscDivBy8 = 7 ,
  kCLOCK_MiscDivBy9 = 8 , kCLOCK_MiscDivBy10 = 9 , kCLOCK_MiscDivBy11 = 10 , kCLOCK_MiscDivBy12 = 11 ,
  kCLOCK_MiscDivBy13 = 12 , kCLOCK_MiscDivBy14 = 13 , kCLOCK_MiscDivBy15 = 14 , kCLOCK_MiscDivBy16 = 15 ,
  kCLOCK_MiscDivBy17 = 16 , kCLOCK_MiscDivBy18 = 17 , kCLOCK_MiscDivBy19 = 18 , kCLOCK_MiscDivBy20 = 19 ,
  kCLOCK_MiscDivBy21 = 20 , kCLOCK_MiscDivBy22 = 21 , kCLOCK_MiscDivBy23 = 22 , kCLOCK_MiscDivBy24 = 23 ,
  kCLOCK_MiscDivBy25 = 24 , kCLOCK_MiscDivBy26 = 25 , kCLOCK_MiscDivBy27 = 26 , kCLOCK_MiscDivBy28 = 27 ,
  kCLOCK_MiscDivBy29 = 28 , kCLOCK_MiscDivBy30 = 29 , kCLOCK_MiscDivBy31 = 30 , kCLOCK_MiscDivBy32 = 31 ,
  kCLOCK_MiscDivBy33 = 32 , kCLOCK_MiscDivBy34 = 33 , kCLOCK_MiscDivBy35 = 34 , kCLOCK_MiscDivBy36 = 35 ,
  kCLOCK_MiscDivBy37 = 36 , kCLOCK_MiscDivBy38 = 37 , kCLOCK_MiscDivBy39 = 38 , kCLOCK_MiscDivBy40 = 39 ,
  kCLOCK_MiscDivBy41 = 40 , kCLOCK_MiscDivBy42 = 41 , kCLOCK_MiscDivBy43 = 42 , kCLOCK_MiscDivBy44 = 43 ,
  kCLOCK_MiscDivBy45 = 44 , kCLOCK_MiscDivBy46 = 45 , kCLOCK_MiscDivBy47 = 46 , kCLOCK_MiscDivBy48 = 47 ,
  kCLOCK_MiscDivBy49 = 48 , kCLOCK_MiscDivBy50 = 49 , kCLOCK_MiscDivBy51 = 50 , kCLOCK_MiscDivBy52 = 51 ,
  kCLOCK_MiscDivBy53 = 52 , kCLOCK_MiscDivBy54 = 53 , kCLOCK_MiscDivBy55 = 54 , kCLOCK_MiscDivBy56 = 55 ,
  kCLOCK_MiscDivBy57 = 56 , kCLOCK_MiscDivBy58 = 57 , kCLOCK_MiscDivBy59 = 58 , kCLOCK_MiscDivBy60 = 59 ,
  kCLOCK_MiscDivBy61 = 60 , kCLOCK_MiscDivBy62 = 61 , kCLOCK_MiscDivBy63 = 62 , kCLOCK_MiscDivBy64 = 63
 Clock divider value. More...
enum  _clock_usb_src { kCLOCK_Usb480M = 0 , kCLOCK_UsbSrcUnused = (int)0xFFFFFFFFU , kCLOCK_Usb480M = 0 , kCLOCK_UsbSrcUnused = (int)0xFFFFFFFFU }
 USB clock source definition. More...
enum  _clock_usb_phy_src { kCLOCK_Usbphy480M = 0 , kCLOCK_Usbphy480M = 0 }
 Source of the USB HS PHY. More...
enum  _clock_pll_clk_src { kCLOCK_PllClkSrc24M = 0U , kCLOCK_PllSrcClkPN = 1U , kCLOCK_PllClkSrc24M = 0U , kCLOCK_PllSrcClkPN = 1U }
 PLL clock source, bypass cloco source also. More...
enum  _clock_pll {
  kCLOCK_PllArm = CCM_ANALOG_TUPLE(PLL_ARM_OFFSET, CCM_ANALOG_PLL_ARM_ENABLE_SHIFT) , kCLOCK_PllSys = CCM_ANALOG_TUPLE(PLL_SYS_OFFSET, CCM_ANALOG_PLL_SYS_ENABLE_SHIFT) , kCLOCK_PllUsb1 = CCM_ANALOG_TUPLE(PLL_USB1_OFFSET, CCM_ANALOG_PLL_USB1_ENABLE_SHIFT) , kCLOCK_PllAudio = CCM_ANALOG_TUPLE(PLL_AUDIO_OFFSET, CCM_ANALOG_PLL_AUDIO_ENABLE_SHIFT) ,
  kCLOCK_PllVideo = CCM_ANALOG_TUPLE(PLL_VIDEO_OFFSET, CCM_ANALOG_PLL_VIDEO_ENABLE_SHIFT) , kCLOCK_PllEnet = CCM_ANALOG_TUPLE(PLL_ENET_OFFSET, CCM_ANALOG_PLL_ENET_ENABLE_SHIFT) , kCLOCK_PllEnet25M = CCM_ANALOG_TUPLE(PLL_ENET_OFFSET, CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN_SHIFT) , kCLOCK_PllUsb2 = CCM_ANALOG_TUPLE(PLL_USB2_OFFSET, CCM_ANALOG_PLL_USB2_ENABLE_SHIFT) ,
  kCLOCK_PllArm , kCLOCK_PllSys1 , kCLOCK_PllSys2 , kCLOCK_PllSys3 ,
  kCLOCK_PllAudio , kCLOCK_PllVideo , kCLOCK_PllInvalid = -1
 PLL name. More...
enum  _clock_pfd {
  kCLOCK_Pfd0 = 0U , kCLOCK_Pfd1 = 1U , kCLOCK_Pfd2 = 2U , kCLOCK_Pfd3 = 3U ,
 PLL PFD name. More...
enum  _clock_output1_selection {
  kCLOCK_OutputPllUsb1 = 0U , kCLOCK_OutputPllSys = 1U , kCLOCK_OutputPllVideo = 3U , kCLOCK_OutputSemcClk = 5U ,
  kCLOCK_OutputLcdifPixClk = 0xAU , kCLOCK_OutputAhbClk = 0xBU , kCLOCK_OutputIpgClk = 0xCU , kCLOCK_OutputPerClk = 0xDU ,
  kCLOCK_OutputCkilSyncClk = 0xEU , kCLOCK_OutputPll4MainClk = 0xFU , kCLOCK_DisableClockOutput1 = 0x10U
 The enumerater of clock output1's clock source, such as USB1 PLL, SYS PLL and so on. More...
enum  _clock_output2_selection {
  kCLOCK_OutputUsdhc1Clk = 3U , kCLOCK_OutputLpi2cClk = 6U , kCLOCK_OutputCsiClk = 0xBU , kCLOCK_OutputOscClk = 0xEU ,
  kCLOCK_OutputUsdhc2Clk = 0x11U , kCLOCK_OutputSai1Clk = 0x12U , kCLOCK_OutputSai2Clk = 0x13U , kCLOCK_OutputSai3Clk = 0x14U ,
  kCLOCK_OutputCanClk = 0x17U , kCLOCK_OutputFlexspiClk = 0x1BU , kCLOCK_OutputUartClk = 0x1CU , kCLOCK_OutputSpdif0Clk = 0x1DU ,
  kCLOCK_DisableClockOutput2 = 0x1FU
 The enumerater of clock output2's clock source, such as USDHC1 clock root, LPI2C clock root and so on. More...
enum  _clock_output_divider {
  kCLOCK_DivideBy1 = 0U , kCLOCK_DivideBy2 , kCLOCK_DivideBy3 , kCLOCK_DivideBy4 ,
  kCLOCK_DivideBy5 , kCLOCK_DivideBy6 , kCLOCK_DivideBy7 , kCLOCK_DivideBy8
 The enumerator of clock output's divider. More...
enum  _clock_root {
  kCLOCK_Usdhc1ClkRoot = 0U , kCLOCK_Usdhc2ClkRoot , kCLOCK_FlexspiClkRoot , kCLOCK_CsiClkRoot ,
  kCLOCK_LpspiClkRoot , kCLOCK_TraceClkRoot , kCLOCK_Sai1ClkRoot , kCLOCK_Sai2ClkRoot ,
  kCLOCK_Sai3ClkRoot , kCLOCK_Lpi2cClkRoot , kCLOCK_CanClkRoot , kCLOCK_UartClkRoot ,
  kCLOCK_LcdifClkRoot , kCLOCK_SpdifClkRoot , kCLOCK_Flexio1ClkRoot , kCLOCK_Flexio2ClkRoot ,
  kCLOCK_Root_M7 = 0 , kCLOCK_Root_M4 = 1 , kCLOCK_Root_Bus = 2 , kCLOCK_Root_Bus_Lpsr = 3 ,
  kCLOCK_Root_Semc = 4 , kCLOCK_Root_Cssys = 5 , kCLOCK_Root_Cstrace = 6 , kCLOCK_Root_M4_Systick = 7 ,
  kCLOCK_Root_M7_Systick = 8 , kCLOCK_Root_Adc1 = 9 , kCLOCK_Root_Adc2 = 10 , kCLOCK_Root_Acmp = 11 ,
  kCLOCK_Root_Flexio1 = 12 , kCLOCK_Root_Flexio2 = 13 , kCLOCK_Root_Gpt1 = 14 , kCLOCK_Root_Gpt2 = 15 ,
  kCLOCK_Root_Gpt3 = 16 , kCLOCK_Root_Gpt4 = 17 , kCLOCK_Root_Gpt5 = 18 , kCLOCK_Root_Gpt6 = 19 ,
  kCLOCK_Root_Flexspi1 = 20 , kCLOCK_Root_Flexspi2 = 21 , kCLOCK_Root_Can1 = 22 , kCLOCK_Root_Can2 = 23 ,
  kCLOCK_Root_Can3 = 24 , kCLOCK_Root_Lpuart1 = 25 , kCLOCK_Root_Lpuart2 = 26 , kCLOCK_Root_Lpuart3 = 27 ,
  kCLOCK_Root_Lpuart4 = 28 , kCLOCK_Root_Lpuart5 = 29 , kCLOCK_Root_Lpuart6 = 30 , kCLOCK_Root_Lpuart7 = 31 ,
  kCLOCK_Root_Lpuart8 = 32 , kCLOCK_Root_Lpuart9 = 33 , kCLOCK_Root_Lpuart10 = 34 , kCLOCK_Root_Lpuart11 = 35 ,
  kCLOCK_Root_Lpuart12 = 36 , kCLOCK_Root_Lpi2c1 = 37 , kCLOCK_Root_Lpi2c2 = 38 , kCLOCK_Root_Lpi2c3 = 39 ,
  kCLOCK_Root_Lpi2c4 = 40 , kCLOCK_Root_Lpi2c5 = 41 , kCLOCK_Root_Lpi2c6 = 42 , kCLOCK_Root_Lpspi1 = 43 ,
  kCLOCK_Root_Lpspi2 = 44 , kCLOCK_Root_Lpspi3 = 45 , kCLOCK_Root_Lpspi4 = 46 , kCLOCK_Root_Lpspi5 = 47 ,
  kCLOCK_Root_Lpspi6 = 48 , kCLOCK_Root_Emv1 = 49 , kCLOCK_Root_Emv2 = 50 , kCLOCK_Root_Enet1 = 51 ,
  kCLOCK_Root_Enet2 = 52 , kCLOCK_Root_Enet_25m = 54 , kCLOCK_Root_Enet_Timer1 = 55 , kCLOCK_Root_Enet_Timer2 = 56 ,
  kCLOCK_Root_Usdhc1 = 58 , kCLOCK_Root_Usdhc2 = 59 , kCLOCK_Root_Asrc = 60 , kCLOCK_Root_Mqs = 61 ,
  kCLOCK_Root_Mic = 62 , kCLOCK_Root_Spdif = 63 , kCLOCK_Root_Sai1 = 64 , kCLOCK_Root_Sai2 = 65 ,
  kCLOCK_Root_Sai3 = 66 , kCLOCK_Root_Sai4 = 67 , kCLOCK_Root_Gc355 = 68 , kCLOCK_Root_Lcdif = 69 ,
  kCLOCK_Root_Lcdifv2 = 70 , kCLOCK_Root_Mipi_Ref = 71 , kCLOCK_Root_Mipi_Esc = 72 , kCLOCK_Root_Csi2 = 73 ,
  kCLOCK_Root_Csi2_Esc = 74 , kCLOCK_Root_Csi2_Ui = 75 , kCLOCK_Root_Csi = 76 , kCLOCK_Root_Cko1 = 77 ,
  kCLOCK_Root_Cko2 = 78
 The enumerator of clock root. More...
typedef enum _clock_name clock_name_t
typedef enum _clock_ip_name clock_ip_name_t
typedef enum _clock_osc clock_osc_t
typedef enum _clock_gate_value clock_gate_value_t
 Clock gate value.
typedef enum _clock_mode_t clock_mode_t
 System clock mode.
typedef enum _clock_mux clock_mux_t
typedef enum _clock_div clock_div_t
typedef enum _clock_div_value clock_div_value_t
typedef enum _clock_usb_src clock_usb_src_t
typedef enum _clock_usb_phy_src clock_usb_phy_src_t
typedef struct _clock_arm_pll_config clock_arm_pll_config_t
typedef struct _clock_usb_pll_config clock_usb_pll_config_t
typedef struct _clock_sys_pll_config clock_sys_pll_config_t
typedef struct _clock_audio_pll_config clock_audio_pll_config_t
typedef struct _clock_video_pll_config clock_video_pll_config_t
typedef struct _clock_enet_pll_config clock_enet_pll_config_t
typedef enum _clock_pll clock_pll_t
 PLL name.
typedef enum _clock_pfd clock_pfd_t
 PLL PFD name.
typedef enum _clock_output1_selection clock_output1_selection_t
typedef enum _clock_output2_selection clock_output2_selection_t
typedef enum _clock_output_divider clock_output_divider_t
typedef enum _clock_root clock_root_t
volatile uint32_t g_xtalFreq
 External XTAL (24M OSC/SYSOSC) clock frequency. More...
volatile uint32_t g_rtcXtalFreq
 External RTC XTAL (32K OSC) clock frequency. More...
uint32_t CLOCK_GetAhbFreq (void)
 Gets the AHB clock frequency. More...
uint32_t CLOCK_GetSemcFreq (void)
 Gets the SEMC clock frequency. More...
uint32_t CLOCK_GetIpgFreq (void)
 Gets the IPG clock frequency. More...
uint32_t CLOCK_GetPerClkFreq (void)
 Gets the PER clock frequency. More...
uint32_t CLOCK_GetFreq (clock_name_t name)
 Gets the clock frequency for a specific clock name. More...
uint32_t CLOCK_GetClockRootFreq (clock_root_t clockRoot)
 Gets the frequency of selected clock root. More...
#define FSL_CLOCK_DRIVER_VERSION   (MAKE_VERSION(2, 5, 1))
 CLOCK driver version 2.5.1.
#define SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY   (600000000UL)
#define CCM_ANALOG_PLL_BYPASS_SHIFT   (16U)
#define CCM_ANALOG_PLL_BYPASS_CLK_SRC_MASK   (0xC000U)
#define CCM_ANALOG_PLL_BYPASS_CLK_SRC_SHIFT   (14U)
#define CCSR_OFFSET   0x0C
 CCM registers offset.
#define CBCDR_OFFSET   0x14
#define CBCMR_OFFSET   0x18
#define CSCMR1_OFFSET   0x1C
#define CSCMR2_OFFSET   0x20
#define CSCDR1_OFFSET   0x24
#define CDCDR_OFFSET   0x30
#define CSCDR2_OFFSET   0x38
#define CSCDR3_OFFSET   0x3C
#define CACRR_OFFSET   0x10
#define CS1CDR_OFFSET   0x28
#define CS2CDR_OFFSET   0x2C
#define PLL_ARM_OFFSET   0x00
 CCM Analog registers offset.
#define PLL_SYS_OFFSET   0x30
#define PLL_USB1_OFFSET   0x10
#define PLL_AUDIO_OFFSET   0x70
#define PLL_VIDEO_OFFSET   0xA0
#define PLL_ENET_OFFSET   0xE0
#define PLL_USB2_OFFSET   0x20
#define CCM_TUPLE(reg, shift, mask, busyShift)    (int)(((reg)&0xFFU) | ((shift) << 8U) | ((((mask) >> (shift)) & 0x1FFFU) << 13U) | ((busyShift) << 26U))
#define CCM_TUPLE_REG(base, tuple)   (*((volatile uint32_t *)(((uint32_t)(base)) + ((uint32_t)(tuple)&0xFFU))))
#define CCM_TUPLE_SHIFT(tuple)   ((((uint32_t)tuple) >> 8U) & 0x1FU)
#define CCM_TUPLE_MASK(tuple)    ((uint32_t)((((uint32_t)(tuple) >> 13U) & 0x1FFFU) << (((((uint32_t)tuple) >> 8U) & 0x1FU))))
#define CCM_TUPLE_BUSY_SHIFT(tuple)   ((((uint32_t)tuple) >> 26U) & 0x3FU)
#define CCM_NO_BUSY_WAIT   (0x20U)
#define CCM_ANALOG_TUPLE(reg, shift)   ((((reg)&0xFFFU) << 16U) | (shift))
 CCM ANALOG tuple macros to map corresponding registers and bit fields.
#define CCM_ANALOG_TUPLE_SHIFT(tuple)   (((uint32_t)tuple) & 0x1FU)
#define CCM_ANALOG_TUPLE_REG_OFF(base, tuple, off)    (*((volatile uint32_t *)((uint32_t)(base) + (((uint32_t)(tuple) >> 16U) & 0xFFFU) + (off))))
#define CCM_ANALOG_TUPLE_REG(base, tuple)   CCM_ANALOG_TUPLE_REG_OFF(base, tuple, 0U)
#define CLKPN_FREQ   0U
 clock1PN frequency.
#define CLOCK_SetXtal0Freq   CLOCK_SetXtalFreq
#define CLOCK_SetXtal32Freq   CLOCK_SetRtcXtalFreq
#define ADC_CLOCKS
 Clock ip name array for ADC. More...
#define AOI_CLOCKS
 Clock ip name array for AOI. More...
#define BEE_CLOCKS
 Clock ip name array for BEE. More...
#define CMP_CLOCKS
 Clock ip name array for CMP. More...
#define CSI_CLOCKS
 Clock ip name array for CSI. More...
#define DCDC_CLOCKS
 Clock ip name array for DCDC. More...
#define DCP_CLOCKS
 Clock ip name array for DCP. More...
#define DMAMUX_CLOCKS
 Clock ip name array for DMAMUX_CLOCKS. More...
#define EDMA_CLOCKS
 Clock ip name array for DMA. More...
#define ENC_CLOCKS
 Clock ip name array for ENC. More...
#define ENET_CLOCKS
 Clock ip name array for ENET. More...
#define EWM_CLOCKS
 Clock ip name array for EWM. More...
#define FLEXCAN_CLOCKS
 Clock ip name array for FLEXCAN. More...
#define FLEXCAN_PERIPH_CLOCKS
 Clock ip name array for FLEXCAN Peripheral clock. More...
#define FLEXIO_CLOCKS
 Clock ip name array for FLEXIO. More...
#define FLEXRAM_CLOCKS
 Clock ip name array for FLEXRAM. More...
#define FLEXSPI_CLOCKS
 Clock ip name array for FLEXSPI. More...
#define FLEXSPI_EXSC_CLOCKS
 Clock ip name array for FLEXSPI EXSC. More...
#define GPIO_CLOCKS
 Clock ip name array for GPIO. More...
#define GPT_CLOCKS
 Clock ip name array for GPT. More...
#define KPP_CLOCKS
 Clock ip name array for KPP. More...
#define LCDIF_CLOCKS
 Clock ip name array for LCDIF. More...
#define LCDIF_PERIPH_CLOCKS
 Clock ip name array for LCDIF PIXEL. More...
#define LPI2C_CLOCKS
 Clock ip name array for LPI2C. More...
#define LPSPI_CLOCKS
 Clock ip name array for LPSPI. More...
#define LPUART_CLOCKS
 Clock ip name array for LPUART. More...
#define MQS_CLOCKS
 Clock ip name array for MQS. More...
#define OCRAM_EXSC_CLOCKS
 Clock ip name array for OCRAM EXSC. More...
#define PIT_CLOCKS
 Clock ip name array for PIT. More...
#define PWM_CLOCKS
 Clock ip name array for PWM. More...
#define PXP_CLOCKS
 Clock ip name array for PXP. More...
#define RTWDOG_CLOCKS
 Clock ip name array for RTWDOG. More...
#define SAI_CLOCKS
 Clock ip name array for SAI. More...
#define SEMC_CLOCKS
 Clock ip name array for SEMC. More...
#define SEMC_EXSC_CLOCKS
 Clock ip name array for SEMC EXSC. More...
#define TMR_CLOCKS
 Clock ip name array for QTIMER. More...
#define TRNG_CLOCKS
 Clock ip name array for TRNG. More...
#define TSC_CLOCKS
 Clock ip name array for TSC. More...
#define WDOG_CLOCKS
 Clock ip name array for WDOG. More...
#define USDHC_CLOCKS
 Clock ip name array for USDHC. More...
#define SPDIF_CLOCKS
 Clock ip name array for SPDIF. More...
#define XBARA_CLOCKS
 Clock ip name array for XBARA. More...
#define XBARB_CLOCKS
 Clock ip name array for XBARB. More...
#define CLOCK_SOURCE_NONE   (0xFFU)
#define CLOCK_ROOT_SOUCE
#define CLOCK_ROOT_MUX_TUPLE
#define CLOCK_ROOT_NONE_PRE_DIV   0UL
#define CLOCK_ROOT_DIV_TUPLE
#define kCLOCK_CoreSysClk   kCLOCK_CpuClk
#define CLOCK_GetCoreSysClkFreq   CLOCK_GetCpuClkFreq
Driver version
enum  _clock_lpcg {
  kCLOCK_M7 = 0 , kCLOCK_M4 = 1 , kCLOCK_Sim_M7 = 2 , kCLOCK_Sim_M = 3 ,
  kCLOCK_Sim_Disp = 4 , kCLOCK_Sim_Per = 5 , kCLOCK_Sim_Lpsr = 6 , kCLOCK_Anadig = 7 ,
  kCLOCK_Dcdc = 8 , kCLOCK_Src = 9 , kCLOCK_Ccm = 10 , kCLOCK_Gpc = 11 ,
  kCLOCK_Ssarc = 12 , kCLOCK_Sim_R = 13 , kCLOCK_Wdog1 = 14 , kCLOCK_Wdog2 = 15 ,
  kCLOCK_Wdog3 = 16 , kCLOCK_Wdog4 = 17 , kCLOCK_Ewm0 = 18 , kCLOCK_Sema = 19 ,
  kCLOCK_Mu_A = 20 , kCLOCK_Mu_B = 21 , kCLOCK_Edma = 22 , kCLOCK_Edma_Lpsr = 23 ,
  kCLOCK_Romcp = 24 , kCLOCK_Ocram = 25 , kCLOCK_Flexram = 26 , kCLOCK_Lmem = 27 ,
  kCLOCK_Flexspi1 = 28 , kCLOCK_Flexspi2 = 29 , kCLOCK_Rdc = 30 , kCLOCK_M7_Xrdc = 31 ,
  kCLOCK_M4_Xrdc = 32 , kCLOCK_Semc = 33 , kCLOCK_Xecc = 34 , kCLOCK_Iee = 35 ,
  kCLOCK_Key_Manager = 36 , kCLOCK_Puf = 36 , kCLOCK_Ocotp = 37 , kCLOCK_Snvs_Hp = 38 ,
  kCLOCK_Snvs = 39 , kCLOCK_Caam = 40 , kCLOCK_Jtag_Mux = 41 , kCLOCK_Cstrace = 42 ,
  kCLOCK_Xbar1 = 43 , kCLOCK_Xbar2 = 44 , kCLOCK_Xbar3 = 45 , kCLOCK_Aoi1 = 46 ,
  kCLOCK_Aoi2 = 47 , kCLOCK_Adc_Etc = 48 , kCLOCK_Iomuxc = 49 , kCLOCK_Iomuxc_Lpsr = 50 ,
  kCLOCK_Gpio = 51 , kCLOCK_Kpp = 52 , kCLOCK_Flexio1 = 53 , kCLOCK_Flexio2 = 54 ,
  kCLOCK_Lpadc1 = 55 , kCLOCK_Lpadc2 = 56 , kCLOCK_Dac = 57 , kCLOCK_Acmp1 = 58 ,
  kCLOCK_Acmp2 = 59 , kCLOCK_Acmp3 = 60 , kCLOCK_Acmp4 = 61 , kCLOCK_Pit1 = 62 ,
  kCLOCK_Pit2 = 63 , kCLOCK_Gpt1 = 64 , kCLOCK_Gpt2 = 65 , kCLOCK_Gpt3 = 66 ,
  kCLOCK_Gpt4 = 67 , kCLOCK_Gpt5 = 68 , kCLOCK_Gpt6 = 69 , kCLOCK_Qtimer1 = 70 ,
  kCLOCK_Qtimer2 = 71 , kCLOCK_Qtimer3 = 72 , kCLOCK_Qtimer4 = 73 , kCLOCK_Enc1 = 74 ,
  kCLOCK_Enc2 = 75 , kCLOCK_Enc3 = 76 , kCLOCK_Enc4 = 77 , kCLOCK_Hrtimer = 78 ,
  kCLOCK_Pwm1 = 79 , kCLOCK_Pwm2 = 80 , kCLOCK_Pwm3 = 81 , kCLOCK_Pwm4 = 82 ,
  kCLOCK_Can1 = 83 , kCLOCK_Can2 = 84 , kCLOCK_Can3 = 85 , kCLOCK_Lpuart1 = 86 ,
  kCLOCK_Lpuart2 = 87 , kCLOCK_Lpuart3 = 88 , kCLOCK_Lpuart4 = 89 , kCLOCK_Lpuart5 = 90 ,
  kCLOCK_Lpuart6 = 91 , kCLOCK_Lpuart7 = 92 , kCLOCK_Lpuart8 = 93 , kCLOCK_Lpuart9 = 94 ,
  kCLOCK_Lpuart10 = 95 , kCLOCK_Lpuart11 = 96 , kCLOCK_Lpuart12 = 97 , kCLOCK_Lpi2c1 = 98 ,
  kCLOCK_Lpi2c2 = 99 , kCLOCK_Lpi2c3 = 100 , kCLOCK_Lpi2c4 = 101 , kCLOCK_Lpi2c5 = 102 ,
  kCLOCK_Lpi2c6 = 103 , kCLOCK_Lpspi1 = 104 , kCLOCK_Lpspi2 = 105 , kCLOCK_Lpspi3 = 106 ,
  kCLOCK_Lpspi4 = 107 , kCLOCK_Lpspi5 = 108 , kCLOCK_Lpspi6 = 109 , kCLOCK_Sim1 = 110 ,
  kCLOCK_Sim2 = 111 , kCLOCK_Enet = 112 , kCLOCK_Enet_1g = 113 , kCLOCK_Usb = 115 ,
  kCLOCK_Cdog = 116 , kCLOCK_Usdhc1 = 117 , kCLOCK_Usdhc2 = 118 , kCLOCK_Asrc = 119 ,
  kCLOCK_Mqs = 120 , kCLOCK_Pdm = 121 , kCLOCK_Spdif = 122 , kCLOCK_Sai1 = 123 ,
  kCLOCK_Sai2 = 124 , kCLOCK_Sai3 = 125 , kCLOCK_Sai4 = 126 , kCLOCK_Pxp = 127 ,
  kCLOCK_Gpu2d = 128 , kCLOCK_Lcdif = 129 , kCLOCK_Lcdifv2 = 130 , kCLOCK_Mipi_Dsi = 131 ,
  kCLOCK_Mipi_Csi = 132 , kCLOCK_Csi = 133 , kCLOCK_Dcic_Mipi = 134 , kCLOCK_Dcic_Lcd = 135 ,
  kCLOCK_Video_Mux = 136 , kCLOCK_Uniq_Edt_I = 137 , kCLOCK_IpInvalid
 Clock LPCG index. More...
enum  _clock_name {
 Clock name. More...
enum  _clock_root {
 Root clock index. More...
enum  _clock_root_mux_source {
  kCLOCK_M7_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_M7_ClockRoot_MuxOsc24MOut = 1U , kCLOCK_M7_ClockRoot_MuxOscRc400M = 2U , kCLOCK_M7_ClockRoot_MuxOscRc16M = 3U ,
  kCLOCK_M7_ClockRoot_MuxArmPllOut = 4U , kCLOCK_M7_ClockRoot_MuxSysPll3Out = 6U , kCLOCK_M4_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_M4_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_M4_ClockRoot_MuxOscRc400M = 2U , kCLOCK_M4_ClockRoot_MuxOscRc16M = 3U , kCLOCK_M4_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_M4_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_M4_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_M4_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_BUS_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_BUS_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_BUS_ClockRoot_MuxOscRc400M = 2U , kCLOCK_BUS_ClockRoot_MuxOscRc16M = 3U , kCLOCK_BUS_ClockRoot_MuxSysPll3Out = 4U , kCLOCK_BUS_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_BUS_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_BUS_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_BUS_LPSR_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc400M = 2U , kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc16M = 3U , kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_SEMC_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_SEMC_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_SEMC_ClockRoot_MuxOscRc400M = 2U , kCLOCK_SEMC_ClockRoot_MuxOscRc16M = 3U , kCLOCK_SEMC_ClockRoot_MuxSysPll1Div5 = 4U , kCLOCK_SEMC_ClockRoot_MuxSysPll2Out = 5U ,
  kCLOCK_SEMC_ClockRoot_MuxSysPll2Pfd1 = 6U , kCLOCK_SEMC_ClockRoot_MuxSysPll3Pfd0 = 7U , kCLOCK_CSSYS_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CSSYS_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CSSYS_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CSSYS_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CSSYS_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_CSSYS_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_CSSYS_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_CSSYS_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_CSTRACE_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CSTRACE_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CSTRACE_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CSTRACE_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CSTRACE_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_CSTRACE_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_CSTRACE_ClockRoot_MuxSysPll2Pfd1 = 6U , kCLOCK_CSTRACE_ClockRoot_MuxSysPll2Out = 7U , kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_M4_SYSTICK_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc400M = 2U , kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc16M = 3U , kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll2Pfd0 = 6U , kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_M7_SYSTICK_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc400M = 2U , kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc16M = 3U , kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll2Out = 4U , kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll3Div2 = 5U ,
  kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll2Pfd0 = 7U , kCLOCK_ADC1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ADC1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ADC1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ADC1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ADC1_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_ADC1_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_ADC1_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_ADC1_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_ADC2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ADC2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ADC2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ADC2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ADC2_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_ADC2_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_ADC2_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_ADC2_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_ACMP_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ACMP_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ACMP_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ACMP_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ACMP_ClockRoot_MuxSysPll3Out = 4U , kCLOCK_ACMP_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_ACMP_ClockRoot_MuxAudioPllOut = 6U , kCLOCK_ACMP_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_FLEXIO1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_FLEXIO1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_FLEXIO1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_FLEXIO1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_FLEXIO1_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_FLEXIO1_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_FLEXIO1_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_FLEXIO1_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_FLEXIO2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_FLEXIO2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_FLEXIO2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_FLEXIO2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_FLEXIO2_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_FLEXIO2_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_FLEXIO2_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_FLEXIO2_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_GPT1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_GPT1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_GPT1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_GPT1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_GPT1_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_GPT1_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_GPT1_ClockRoot_MuxSysPll3Pfd2 = 6U , kCLOCK_GPT1_ClockRoot_MuxSysPll3Pfd3 = 7U , kCLOCK_GPT2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_GPT2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_GPT2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_GPT2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_GPT2_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_GPT2_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_GPT2_ClockRoot_MuxAudioPllOut = 6U , kCLOCK_GPT2_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_GPT3_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_GPT3_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_GPT3_ClockRoot_MuxOscRc400M = 2U , kCLOCK_GPT3_ClockRoot_MuxOscRc16M = 3U , kCLOCK_GPT3_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_GPT3_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_GPT3_ClockRoot_MuxAudioPllOut = 6U , kCLOCK_GPT3_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_GPT4_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_GPT4_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_GPT4_ClockRoot_MuxOscRc400M = 2U , kCLOCK_GPT4_ClockRoot_MuxOscRc16M = 3U , kCLOCK_GPT4_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_GPT4_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_GPT4_ClockRoot_MuxSysPll3Pfd2 = 6U , kCLOCK_GPT4_ClockRoot_MuxSysPll3Pfd3 = 7U , kCLOCK_GPT5_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_GPT5_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_GPT5_ClockRoot_MuxOscRc400M = 2U , kCLOCK_GPT5_ClockRoot_MuxOscRc16M = 3U , kCLOCK_GPT5_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_GPT5_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_GPT5_ClockRoot_MuxSysPll3Pfd2 = 6U , kCLOCK_GPT5_ClockRoot_MuxSysPll3Pfd3 = 7U , kCLOCK_GPT6_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_GPT6_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_GPT6_ClockRoot_MuxOscRc400M = 2U , kCLOCK_GPT6_ClockRoot_MuxOscRc16M = 3U , kCLOCK_GPT6_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_GPT6_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_GPT6_ClockRoot_MuxSysPll3Pfd2 = 6U , kCLOCK_GPT6_ClockRoot_MuxSysPll3Pfd3 = 7U , kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_FLEXSPI1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll3Pfd0 = 4U , kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll2Out = 5U ,
  kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll2Pfd2 = 6U , kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll3Out = 7U , kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_FLEXSPI2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll3Pfd0 = 4U , kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll2Out = 5U ,
  kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll2Pfd2 = 6U , kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll3Out = 7U , kCLOCK_CAN1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CAN1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CAN1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CAN1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CAN1_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_CAN1_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_CAN1_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_CAN1_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_CAN2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CAN2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CAN2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CAN2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CAN2_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_CAN2_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_CAN2_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_CAN2_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_CAN3_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CAN3_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CAN3_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CAN3_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CAN3_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_CAN3_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_CAN3_ClockRoot_MuxSysPll2Pfd3 = 6U , kCLOCK_CAN3_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_LPUART1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART1_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART1_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART1_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART1_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART2_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART2_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART2_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART2_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART3_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART3_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART3_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART3_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART3_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART3_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART3_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART3_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART4_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART4_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART4_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART4_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART4_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART4_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART4_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART4_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART5_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART5_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART5_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART5_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART5_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART5_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART5_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART5_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART6_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART6_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART6_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART6_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART6_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART6_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART6_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART6_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART7_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART7_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART7_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART7_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART7_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART7_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART7_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART7_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART8_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART8_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART8_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART8_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART8_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART8_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART8_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART8_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART9_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART9_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART9_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART9_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART9_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART9_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART9_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART9_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART10_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART10_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART10_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART10_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART10_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPUART10_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPUART10_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPUART10_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPUART11_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART11_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART11_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART11_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART11_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_LPUART11_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_LPUART11_ClockRoot_MuxSysPll2Pfd3 = 6U , kCLOCK_LPUART11_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_LPUART12_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPUART12_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPUART12_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPUART12_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPUART12_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_LPUART12_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_LPUART12_ClockRoot_MuxSysPll2Pfd3 = 6U , kCLOCK_LPUART12_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_LPI2C1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPI2C1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPI2C1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPI2C1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPI2C1_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPI2C1_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPI2C1_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPI2C1_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPI2C2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPI2C2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPI2C2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPI2C2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPI2C2_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPI2C2_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPI2C2_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPI2C2_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPI2C3_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPI2C3_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPI2C3_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPI2C3_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPI2C3_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPI2C3_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPI2C3_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPI2C3_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPI2C4_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPI2C4_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPI2C4_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPI2C4_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPI2C4_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_LPI2C4_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPI2C4_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPI2C4_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPI2C5_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPI2C5_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPI2C5_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPI2C5_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPI2C5_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_LPI2C5_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_LPI2C5_ClockRoot_MuxSysPll2Pfd3 = 6U , kCLOCK_LPI2C5_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_LPI2C6_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPI2C6_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPI2C6_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPI2C6_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPI2C6_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_LPI2C6_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_LPI2C6_ClockRoot_MuxSysPll2Pfd3 = 6U , kCLOCK_LPI2C6_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_LPSPI1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPSPI1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPSPI1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPSPI1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPSPI1_ClockRoot_MuxSysPll3Pfd2 = 4U , kCLOCK_LPSPI1_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPSPI1_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPSPI1_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPSPI2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPSPI2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPSPI2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPSPI2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPSPI2_ClockRoot_MuxSysPll3Pfd2 = 4U , kCLOCK_LPSPI2_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPSPI2_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPSPI2_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPSPI3_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPSPI3_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPSPI3_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPSPI3_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPSPI3_ClockRoot_MuxSysPll3Pfd2 = 4U , kCLOCK_LPSPI3_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPSPI3_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPSPI3_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPSPI4_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPSPI4_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPSPI4_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPSPI4_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPSPI4_ClockRoot_MuxSysPll3Pfd2 = 4U , kCLOCK_LPSPI4_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_LPSPI4_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_LPSPI4_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_LPSPI5_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPSPI5_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPSPI5_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPSPI5_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Pfd2 = 6U , kCLOCK_LPSPI5_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_LPSPI6_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LPSPI6_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LPSPI6_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LPSPI6_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Pfd2 = 6U , kCLOCK_LPSPI6_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_EMV1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_EMV1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_EMV1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_EMV1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_EMV1_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_EMV1_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_EMV1_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_EMV1_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_EMV2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_EMV2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_EMV2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_EMV2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_EMV2_ClockRoot_MuxSysPll3Div2 = 4U , kCLOCK_EMV2_ClockRoot_MuxSysPll1Div5 = 5U ,
  kCLOCK_EMV2_ClockRoot_MuxSysPll2Out = 6U , kCLOCK_EMV2_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_ENET1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ENET1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ENET1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ENET1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ENET1_ClockRoot_MuxSysPll1Div2 = 4U , kCLOCK_ENET1_ClockRoot_MuxAudioPllOut = 5U ,
  kCLOCK_ENET1_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_ENET1_ClockRoot_MuxSysPll2Pfd1 = 7U , kCLOCK_ENET2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ENET2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ENET2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ENET2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ENET2_ClockRoot_MuxSysPll1Div2 = 4U , kCLOCK_ENET2_ClockRoot_MuxAudioPllOut = 5U ,
  kCLOCK_ENET2_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_ENET2_ClockRoot_MuxSysPll2Pfd1 = 7U , kCLOCK_ENET_25M_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ENET_25M_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ENET_25M_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ENET_25M_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ENET_25M_ClockRoot_MuxSysPll1Div2 = 4U , kCLOCK_ENET_25M_ClockRoot_MuxAudioPllOut = 5U ,
  kCLOCK_ENET_25M_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_ENET_25M_ClockRoot_MuxSysPll2Pfd1 = 7U , kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ENET_TIMER1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll1Div2 = 4U , kCLOCK_ENET_TIMER1_ClockRoot_MuxAudioPllOut = 5U ,
  kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll2Pfd1 = 7U , kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ENET_TIMER2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll1Div2 = 4U , kCLOCK_ENET_TIMER2_ClockRoot_MuxAudioPllOut = 5U ,
  kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll2Pfd1 = 7U , kCLOCK_USDHC1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_USDHC1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_USDHC1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_USDHC1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_USDHC1_ClockRoot_MuxSysPll2Pfd2 = 4U , kCLOCK_USDHC1_ClockRoot_MuxSysPll2Pfd0 = 5U ,
  kCLOCK_USDHC1_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_USDHC1_ClockRoot_MuxArmPllOut = 7U , kCLOCK_USDHC2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_USDHC2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_USDHC2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_USDHC2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_USDHC2_ClockRoot_MuxSysPll2Pfd2 = 4U , kCLOCK_USDHC2_ClockRoot_MuxSysPll2Pfd0 = 5U ,
  kCLOCK_USDHC2_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_USDHC2_ClockRoot_MuxArmPllOut = 7U , kCLOCK_ASRC_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_ASRC_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_ASRC_ClockRoot_MuxOscRc400M = 2U , kCLOCK_ASRC_ClockRoot_MuxOscRc16M = 3U , kCLOCK_ASRC_ClockRoot_MuxSysPll1Div5 = 4U , kCLOCK_ASRC_ClockRoot_MuxSysPll3Div2 = 5U ,
  kCLOCK_ASRC_ClockRoot_MuxAudioPllOut = 6U , kCLOCK_ASRC_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_MQS_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_MQS_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_MQS_ClockRoot_MuxOscRc400M = 2U , kCLOCK_MQS_ClockRoot_MuxOscRc16M = 3U , kCLOCK_MQS_ClockRoot_MuxSysPll1Div5 = 4U , kCLOCK_MQS_ClockRoot_MuxSysPll3Div2 = 5U ,
  kCLOCK_MQS_ClockRoot_MuxAudioPllOut = 6U , kCLOCK_MQS_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_MIC_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_MIC_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_MIC_ClockRoot_MuxOscRc400M = 2U , kCLOCK_MIC_ClockRoot_MuxOscRc16M = 3U , kCLOCK_MIC_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_MIC_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_MIC_ClockRoot_MuxAudioPllOut = 6U , kCLOCK_MIC_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_SPDIF_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_SPDIF_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_SPDIF_ClockRoot_MuxOscRc400M = 2U , kCLOCK_SPDIF_ClockRoot_MuxOscRc16M = 3U , kCLOCK_SPDIF_ClockRoot_MuxAudioPllOut = 4U , kCLOCK_SPDIF_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_SPDIF_ClockRoot_MuxSysPll3Pfd2 = 6U , kCLOCK_SPDIF_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_SAI1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_SAI1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_SAI1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_SAI1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_SAI1_ClockRoot_MuxAudioPllOut = 4U , kCLOCK_SAI1_ClockRoot_MuxSysPll3Pfd2 = 5U ,
  kCLOCK_SAI1_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_SAI1_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_SAI2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_SAI2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_SAI2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_SAI2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_SAI2_ClockRoot_MuxAudioPllOut = 4U , kCLOCK_SAI2_ClockRoot_MuxSysPll3Pfd2 = 5U ,
  kCLOCK_SAI2_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_SAI2_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_SAI3_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_SAI3_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_SAI3_ClockRoot_MuxOscRc400M = 2U , kCLOCK_SAI3_ClockRoot_MuxOscRc16M = 3U , kCLOCK_SAI3_ClockRoot_MuxAudioPllOut = 4U , kCLOCK_SAI3_ClockRoot_MuxSysPll3Pfd2 = 5U ,
  kCLOCK_SAI3_ClockRoot_MuxSysPll1Div5 = 6U , kCLOCK_SAI3_ClockRoot_MuxSysPll2Pfd3 = 7U , kCLOCK_SAI4_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_SAI4_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_SAI4_ClockRoot_MuxOscRc400M = 2U , kCLOCK_SAI4_ClockRoot_MuxOscRc16M = 3U , kCLOCK_SAI4_ClockRoot_MuxSysPll3Pfd3 = 4U , kCLOCK_SAI4_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_SAI4_ClockRoot_MuxAudioPllOut = 6U , kCLOCK_SAI4_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_GC355_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_GC355_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_GC355_ClockRoot_MuxOscRc400M = 2U , kCLOCK_GC355_ClockRoot_MuxOscRc16M = 3U , kCLOCK_GC355_ClockRoot_MuxSysPll2Out = 4U , kCLOCK_GC355_ClockRoot_MuxSysPll2Pfd1 = 5U ,
  kCLOCK_GC355_ClockRoot_MuxSysPll3Out = 6U , kCLOCK_GC355_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_LCDIF_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LCDIF_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LCDIF_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LCDIF_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LCDIF_ClockRoot_MuxSysPll2Out = 4U , kCLOCK_LCDIF_ClockRoot_MuxSysPll2Pfd2 = 5U ,
  kCLOCK_LCDIF_ClockRoot_MuxSysPll3Pfd0 = 6U , kCLOCK_LCDIF_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_LCDIFV2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_LCDIFV2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_LCDIFV2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_LCDIFV2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_LCDIFV2_ClockRoot_MuxSysPll2Out = 4U , kCLOCK_LCDIFV2_ClockRoot_MuxSysPll2Pfd2 = 5U ,
  kCLOCK_LCDIFV2_ClockRoot_MuxSysPll3Pfd0 = 6U , kCLOCK_LCDIFV2_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_MIPI_REF_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_MIPI_REF_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_MIPI_REF_ClockRoot_MuxOscRc400M = 2U , kCLOCK_MIPI_REF_ClockRoot_MuxOscRc16M = 3U , kCLOCK_MIPI_REF_ClockRoot_MuxSysPll2Out = 4U , kCLOCK_MIPI_REF_ClockRoot_MuxSysPll2Pfd0 = 5U ,
  kCLOCK_MIPI_REF_ClockRoot_MuxSysPll3Pfd0 = 6U , kCLOCK_MIPI_REF_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_MIPI_ESC_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc400M = 2U , kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc16M = 3U , kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll2Out = 4U , kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll2Pfd0 = 5U ,
  kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll3Pfd0 = 6U , kCLOCK_MIPI_ESC_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_CSI2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CSI2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CSI2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CSI2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CSI2_ClockRoot_MuxSysPll2Pfd2 = 4U , kCLOCK_CSI2_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_CSI2_ClockRoot_MuxSysPll2Pfd0 = 6U , kCLOCK_CSI2_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CSI2_ESC_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll2Pfd2 = 4U , kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll2Pfd0 = 6U , kCLOCK_CSI2_ESC_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_CSI2_UI_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CSI2_UI_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CSI2_UI_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CSI2_UI_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CSI2_UI_ClockRoot_MuxSysPll2Pfd2 = 4U , kCLOCK_CSI2_UI_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_CSI2_UI_ClockRoot_MuxSysPll2Pfd0 = 6U , kCLOCK_CSI2_UI_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_CSI_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CSI_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CSI_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CSI_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CSI_ClockRoot_MuxSysPll2Pfd2 = 4U , kCLOCK_CSI_ClockRoot_MuxSysPll3Out = 5U ,
  kCLOCK_CSI_ClockRoot_MuxSysPll3Pfd1 = 6U , kCLOCK_CSI_ClockRoot_MuxVideoPllOut = 7U , kCLOCK_CKO1_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CKO1_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CKO1_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CKO1_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CKO1_ClockRoot_MuxSysPll2Pfd2 = 4U , kCLOCK_CKO1_ClockRoot_MuxSysPll2Out = 5U ,
  kCLOCK_CKO1_ClockRoot_MuxSysPll3Pfd1 = 6U , kCLOCK_CKO1_ClockRoot_MuxSysPll1Div5 = 7U , kCLOCK_CKO2_ClockRoot_MuxOscRc48MDiv2 = 0U , kCLOCK_CKO2_ClockRoot_MuxOsc24MOut = 1U ,
  kCLOCK_CKO2_ClockRoot_MuxOscRc400M = 2U , kCLOCK_CKO2_ClockRoot_MuxOscRc16M = 3U , kCLOCK_CKO2_ClockRoot_MuxSysPll2Pfd3 = 4U , kCLOCK_CKO2_ClockRoot_MuxOscRc48M = 5U ,
  kCLOCK_CKO2_ClockRoot_MuxSysPll3Pfd1 = 6U , kCLOCK_CKO2_ClockRoot_MuxAudioPllOut = 7U
 The enumerator of clock roots' clock source mux value. More...
enum  _clock_group { kCLOCK_Group_FlexRAM = 0 , kCLOCK_Group_MipiDsi = 1 , kCLOCK_Group_Last }
 Clock group enumeration. More...
enum  _clock_pll_post_div { kCLOCK_PllPostDiv8 = 0U , kCLOCK_PllPostDiv4 = 1U }
 PLL post divider enumeration. More...
enum  _clock_pll {
 PLL name. More...
enum  _clock_pfd {
enum  _clock_control_mode { kCLOCK_SoftwareMode = 0U , kCLOCK_GpcMode }
 The enumeration of control mode. More...
enum  _clock_24MOsc_mode { kCLOCK_24MOscHighGainMode = 0U , kCLOCK_24MOscBypassMode = 1U , kCLOCK_24MOscLowPowerMode = 2U }
 The enumeration of 24MHz crystal oscillator mode. More...
enum  _clock_16MOsc_source { kCLOCK_16MOscSourceFrom16MOsc = 0U , kCLOCK_16MOscSourceFrom24MOsc = 1U }
 The enumeration of 16MHz RC oscillator clock source. More...
enum  _clock_1MHzOut_behavior { kCLOCK_1MHzOutDisable = 0U , kCLOCK_1MHzOutEnableLocked1Mhz = 1U , kCLOCK_1MHzOutEnableFreeRunning1Mhz = 2U }
 The enumeration of 1MHz output clock behavior, including disabling 1MHz output, enabling locked 1MHz clock output, and enabling free-running 1MHz clock output. More...
enum  _clock_level {
  kCLOCK_Level0 = 0x0UL , kCLOCK_Level1 = 0x1UL , kCLOCK_Level2 = 0x2UL , kCLOCK_Level3 = 0x3UL ,
  kCLOCK_Level4 = 0x4UL
 The clock dependence level. More...
typedef enum _clock_lpcg clock_lpcg_t
 Clock LPCG index.
 Clock name.
 Root clock index.
typedef enum _clock_root_mux_source clock_root_mux_source_t
typedef enum _clock_group clock_group_t
typedef struct _clock_group_config clock_group_config_t
 The structure used to configure clock group.
 Clock gate value.
 System clock mode.
typedef enum _clock_pll_post_div clock_pll_post_div_t
 PLL configuration for ARM. More...
 PLL configuration for USB.
typedef struct _clock_pll_ss_config clock_pll_ss_config_t
 Spread specturm configure Pll.
typedef struct _clock_sys_pll2_config clock_sys_pll2_config_t
 PLL configure for Sys Pll2.
typedef struct _clock_sys_pll1_config clock_sys_pll1_config_t
 PLL configure for Sys Pll1.
typedef struct _clock_audio_pll_config clock_av_pll_config_t
 PLL configuration for AUDIO and VIDEO.
typedef struct _clock_audio_pll_config clock_video_pll_config_t
typedef struct _clock_audio_pll_gpc_config clock_audio_pll_gpc_config_t
 PLL configuration fro AUDIO PLL, SYSTEM PLL1 and VIDEO PLL.
typedef struct _clock_audio_pll_gpc_config clock_video_pll_gpc_config_t
typedef struct _clock_audio_pll_gpc_config clock_sys_pll1_gpc_config_t
 PLL configuration for ENET.
typedef struct _clock_root_config_t clock_root_config_t
 Clock root configuration.
typedef struct _clock_root_setpoint_config_t clock_root_setpoint_config_t
 Clock root configuration in SetPoint Mode.
 PLL name.
 PLL PFD name.
typedef enum _clock_control_mode clock_control_mode_t
typedef enum _clock_24MOsc_mode clock_24MOsc_mode_t
typedef enum _clock_16MOsc_source clock_16MOsc_source_t
typedef enum _clock_1MHzOut_behavior clock_1MHzOut_behavior_t
typedef enum _clock_level clock_level_t
void CLOCK_SetGroupConfig (clock_group_t group, const clock_group_config_t *config)
 Set the clock group configuration. More...
#define FSL_CLOCK_DRIVER_VERSION   (MAKE_VERSION(2, 1, 2))
 CLOCK driver version.
#define SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY   (240000000UL)
#define ARM_PLL_OFFSET   0x00
#define CCM_TUPLE(reg, shift, mask, busyShift)    (int)((reg & 0xFFU) | ((shift) << 8U) | ((((mask) >> (shift)) & 0x1FFFU) << 13U) | ((busyShift) << 26U))
#define CCM_TUPLE_REG(base, tuple)   (*((volatile uint32_t *)(((uint32_t)(base)) + ((tuple)&0xFFU))))
#define CCM_TUPLE_SHIFT(tuple)   (((tuple) >> 8U) & 0x1FU)
#define CCM_TUPLE_MASK(tuple)   ((uint32_t)((((tuple) >> 13U) & 0x1FFFU) << ((((tuple) >> 8U) & 0x1FU))))
#define CCM_TUPLE_BUSY_SHIFT(tuple)   (((tuple) >> 26U) & 0x3FU)
#define CCM_BUSY_WAIT   (0x20U)
#define CCM_ANALOG_TUPLE(reg, shift)   (((reg & 0xFFFU) << 16U) | (shift))
#define CCM_ANALOG_TUPLE_REG_OFF(base, tuple, off)    (*((volatile uint32_t *)((uint32_t)base + (((uint32_t)tuple >> 16U) & 0xFFFU) + off)))
#define SYS_PLL1_FREQ   (1000000000UL)
 SYS_PLL_FREQ frequency in Hz.
#define SYS_PLL2_MFI   (22UL)
#define SYS_PLL2_FREQ   (XTAL_FREQ * SYS_PLL2_MFI)
#define SYS_PLL3_MFI   (20UL)
#define SYS_PLL3_FREQ   (XTAL_FREQ * SYS_PLL3_MFI)
#define XTAL_FREQ   (24000000UL)
#define LPADC_CLOCKS
 Clock gate name array for ADC. More...
#define ADC_ETC_CLOCKS
#define AOI_CLOCKS
 Clock gate name array for AOI. More...
#define DCDC_CLOCKS
 Clock gate name array for DCDC. More...
#define DCDC_CLOCKS
#define SRC_CLOCKS
 Clock gate name array for SRC. More...
#define GPC_CLOCKS
 Clock gate name array for GPC. More...
#define SSARC_CLOCKS
 Clock gate name array for SSARC. More...
#define WDOG_CLOCKS
 Clock gate name array for WDOG. More...
#define EWM_CLOCKS
 Clock gate name array for EWM. More...
#define SEMA_CLOCKS
 Clock gate name array for Sema. More...
#define MU_CLOCKS
 Clock gate name array for MU. More...
#define EDMA_CLOCKS
 Clock gate name array for EDMA. More...
 Clock gate name array for FLEXRAM. More...
#define LMEM_CLOCKS
 Clock gate name array for LMEM. More...
 Clock gate name array for FLEXSPI. More...
#define RDC_CLOCKS
 Clock gate name array for RDC. More...
#define SEMC_CLOCKS
#define XECC_CLOCKS
 Clock ip name array for XECC. More...
#define IEE_CLOCKS
 Clock ip name array for IEE. More...
#define KEYMANAGER_CLOCKS
 Clock ip name array for KEY_MANAGER. More...
#define PUF_CLOCKS
 Clock ip name array for PUF. More...
#define OCOTP_CLOCKS
 Clock ip name array for OCOTP. More...
#define CAAM_CLOCKS
 Clock ip name array for CAAM. More...
#define XBAR_CLOCKS
 Clock ip name array for XBAR. More...
#define IOMUXC_CLOCKS
 Clock ip name array for IOMUXC. More...
#define GPIO_CLOCKS
#define KPP_CLOCKS
#define DAC_CLOCKS
 Clock ip name array for DAC. More...
#define CMP_CLOCKS
#define PIT_CLOCKS
#define GPT_CLOCKS
#define TMR_CLOCKS
#define ENC_CLOCKS
#define PWM_CLOCKS
#define EMVSIM_CLOCKS
 Clock ip name array for EMVSIM. More...
#define ENET_CLOCKS
#define USB_CLOCKS
 Clock ip name array for USB. More...
#define CDOG_CLOCKS
 Clock ip name array for CDOG. More...
#define ASRC_CLOCKS
 Clock ip name array for ASRC. More...
#define MQS_CLOCKS
#define PDM_CLOCKS
 Clock ip name array for PDM. More...
#define SAI_CLOCKS
#define PXP_CLOCKS
#define GPU2D_CLOCKS
 Clock ip name array for GPU2d. More...
#define LCDIFV2_CLOCKS
 Clock ip name array for LCDIFV2. More...
#define MIPI_DSI_HOST_CLOCKS
 Clock ip name array for MIPI_DSI. More...
#define MIPI_CSI2RX_CLOCKS
 Clock ip name array for MIPI_CSI. More...
#define CSI_CLOCKS
#define DCIC_CLOCKS
 Clock ip name array for DCIC. More...
#define CCM_OBS_M7_CLK_ROOT   128, 4
#define CCM_OBS_M4_CLK_ROOT   129, 0
#define CCM_OBS_BUS_CLK_ROOT   130, 2
#define CCM_OBS_BUS_LPSR_CLK_ROOT   131, 0
#define CCM_OBS_SEMC_CLK_ROOT   132, 2
#define CCM_OBS_CSSYS_CLK_ROOT   133, 2
#define CCM_OBS_CSTRACE_CLK_ROOT   134, 2
#define CCM_OBS_M4_SYSTICK_CLK_ROOT   135, 0
#define CCM_OBS_M7_SYSTICK_CLK_ROOT   136, 2
#define CCM_OBS_ADC1_CLK_ROOT   137, 2
#define CCM_OBS_ADC2_CLK_ROOT   138, 2
#define CCM_OBS_ACMP_CLK_ROOT   139, 2
#define CCM_OBS_FLEXIO1_CLK_ROOT   140, 2
#define CCM_OBS_FLEXIO2_CLK_ROOT   141, 2
#define CCM_OBS_GPT1_CLK_ROOT   142, 2
#define CCM_OBS_GPT2_CLK_ROOT   143, 2
#define CCM_OBS_GPT3_CLK_ROOT   144, 2
#define CCM_OBS_GPT4_CLK_ROOT   145, 2
#define CCM_OBS_GPT5_CLK_ROOT   146, 2
#define CCM_OBS_GPT6_CLK_ROOT   147, 2
#define CCM_OBS_FLEXSPI1_CLK_ROOT   148, 2
#define CCM_OBS_FLEXSPI2_CLK_ROOT   149, 2
#define CCM_OBS_CAN1_CLK_ROOT   150, 2
#define CCM_OBS_CAN2_CLK_ROOT   151, 2
#define CCM_OBS_CAN3_CLK_ROOT   152, 0
#define CCM_OBS_LPUART1_CLK_ROOT   153, 2
#define CCM_OBS_LPUART2_CLK_ROOT   154, 2
#define CCM_OBS_LPUART3_CLK_ROOT   155, 2
#define CCM_OBS_LPUART4_CLK_ROOT   156, 2
#define CCM_OBS_LPUART5_CLK_ROOT   157, 2
#define CCM_OBS_LPUART6_CLK_ROOT   158, 2
#define CCM_OBS_LPUART7_CLK_ROOT   159, 2
#define CCM_OBS_LPUART8_CLK_ROOT   160, 2
#define CCM_OBS_LPUART9_CLK_ROOT   161, 2
#define CCM_OBS_LPUART10_CLK_ROOT   162, 2
#define CCM_OBS_LPUART11_CLK_ROOT   163, 0
#define CCM_OBS_LPUART12_CLK_ROOT   164, 0
#define CCM_OBS_LPI2C1_CLK_ROOT   165, 2
#define CCM_OBS_LPI2C2_CLK_ROOT   166, 2
#define CCM_OBS_LPI2C3_CLK_ROOT   167, 2
#define CCM_OBS_LPI2C4_CLK_ROOT   168, 2
#define CCM_OBS_LPI2C5_CLK_ROOT   169, 0
#define CCM_OBS_LPI2C6_CLK_ROOT   170, 0
#define CCM_OBS_LPSPI1_CLK_ROOT   171, 2
#define CCM_OBS_LPSPI2_CLK_ROOT   172, 2
#define CCM_OBS_LPSPI3_CLK_ROOT   173, 2
#define CCM_OBS_LPSPI4_CLK_ROOT   174, 2
#define CCM_OBS_LPSPI5_CLK_ROOT   175, 0
#define CCM_OBS_LPSPI6_CLK_ROOT   176, 0
#define CCM_OBS_EMV1_CLK_ROOT   177, 2
#define CCM_OBS_EMV2_CLK_ROOT   178, 2
#define CCM_OBS_ENET1_CLK_ROOT   179, 2
#define CCM_OBS_ENET2_CLK_ROOT   180, 2
#define CCM_OBS_ENET_25M_CLK_ROOT   182, 2
#define CCM_OBS_ENET_TIMER1_CLK_ROOT   183, 2
#define CCM_OBS_ENET_TIMER2_CLK_ROOT   184, 2
#define CCM_OBS_USDHC1_CLK_ROOT   186, 2
#define CCM_OBS_USDHC2_CLK_ROOT   187, 2
#define CCM_OBS_ASRC_CLK_ROOT   188, 2
#define CCM_OBS_MQS_CLK_ROOT   189, 2
#define CCM_OBS_MIC_CLK_ROOT   190, 0
#define CCM_OBS_SPDIF_CLK_ROOT   191, 2
#define CCM_OBS_SAI1_CLK_ROOT   192, 2
#define CCM_OBS_SAI2_CLK_ROOT   193, 2
#define CCM_OBS_SAI3_CLK_ROOT   194, 2
#define CCM_OBS_SAI4_CLK_ROOT   195, 0
#define CCM_OBS_GC355_CLK_ROOT   196, 2
#define CCM_OBS_LCDIF_CLK_ROOT   197, 2
#define CCM_OBS_LCDIFV2_CLK_ROOT   198, 2
#define CCM_OBS_MIPI_REF_CLK_ROOT   199, 2
#define CCM_OBS_MIPI_ESC_CLK_ROOT   200, 2
#define CCM_OBS_CSI2_CLK_ROOT   201, 2
#define CCM_OBS_CSI2_ESC_CLK_ROOT   202, 2
#define CCM_OBS_CSI2_UI_CLK_ROOT   203, 2
#define CCM_OBS_CSI_CLK_ROOT   204, 2
#define CCM_OBS_CCM_CKO1_CLK_ROOT   205, 0
#define CCM_OBS_CCM_CKO2_CLK_ROOT   206, 2
#define CCM_OBS_CM7_CORE_STCLKEN   207, 4
#define CCM_OBS_CCM_FLEXRAM_CLK_ROOT   208, 4
#define CCM_OBS_MIPI_DSI_TXESC   209, 2
#define CCM_OBS_MIPI_DSI_RXESC   210, 2
#define CCM_OBS_OSC_RC_16M   224, 0
#define CCM_OBS_OSC_RC_48M   225, 0
#define CCM_OBS_OSC_RC_48M_DIV2   226, 0
#define CCM_OBS_OSC_RC_400M   227, 0
#define CCM_OBS_OSC_24M_OUT   229, 0
#define CCM_OBS_ARM_PLL_OUT   231, 2
#define CCM_OBS_SYS_PLL2_OUT   233, 2
#define CCM_OBS_SYS_PLL2_PFD0   234, 2
#define CCM_OBS_SYS_PLL2_PFD1   235, 2
#define CCM_OBS_SYS_PLL2_PFD2   236, 2
#define CCM_OBS_SYS_PLL2_PFD3   237, 2
#define CCM_OBS_SYS_PLL3_OUT   239, 2
#define CCM_OBS_SYS_PLL3_DIV2   240, 2
#define CCM_OBS_SYS_PLL3_PFD0   241, 2
#define CCM_OBS_SYS_PLL3_PFD1   242, 2
#define CCM_OBS_SYS_PLL3_PFD2   243, 2
#define CCM_OBS_SYS_PLL3_PFD3   244, 2
#define CCM_OBS_SYS_PLL1_OUT   246, 2
#define CCM_OBS_SYS_PLL1_DIV2   247, 2
#define CCM_OBS_SYS_PLL1_DIV5   248, 2
#define CCM_OBS_PLL_AUDIO_OUT   250, 2
#define CCM_OBS_PLL_VIDEO_OUT   252, 2
#define CCM_OBS_DIV   3
#define clock_ip_name_t   clock_lpcg_t
#define CLOCK_GetCpuClkFreq   CLOCK_GetM4Freq
#define PLL_PFD_COUNT   4
OSC operations
void CLOCK_InitExternalClk (bool bypassXtalOsc)
 Initialize the external 24MHz clock. More...
void CLOCK_DeinitExternalClk (void)
 Deinitialize the external 24MHz clock. More...
void CLOCK_SwitchOsc (clock_osc_t osc)
 Switch the OSC. More...
void CLOCK_InitRcOsc24M (void)
 Initialize the RC oscillator 24MHz clock. More...
void CLOCK_DeinitRcOsc24M (void)
 Power down the RCOSC 24M clock. More...
bool CLOCK_EnableUsbhs0Clock (clock_usb_src_t src, uint32_t freq)
 Enable USB HS clock. More...
bool CLOCK_EnableUsbhs1Clock (clock_usb_src_t src, uint32_t freq)
PLL/PFD operations
void CLOCK_InitArmPll (const clock_arm_pll_config_t *config)
 Initialize the ARM PLL. More...
void CLOCK_DeinitArmPll (void)
 De-initialize the ARM PLL. More...
void CLOCK_InitSysPll (const clock_sys_pll_config_t *config)
 Initialize the System PLL. More...
void CLOCK_DeinitSysPll (void)
 De-initialize the System PLL. More...
void CLOCK_InitUsb1Pll (const clock_usb_pll_config_t *config)
 Initialize the USB1 PLL. More...
void CLOCK_DeinitUsb1Pll (void)
 Deinitialize the USB1 PLL. More...
void CLOCK_InitUsb2Pll (const clock_usb_pll_config_t *config)
 Initialize the USB2 PLL. More...
void CLOCK_DeinitUsb2Pll (void)
 Deinitialize the USB2 PLL. More...
void CLOCK_InitAudioPll (const clock_audio_pll_config_t *config)
 Initializes the Audio PLL. More...
void CLOCK_DeinitAudioPll (void)
 De-initialize the Audio PLL. More...
void CLOCK_InitVideoPll (const clock_video_pll_config_t *config)
 Initialize the video PLL. More...
void CLOCK_DeinitVideoPll (void)
 De-initialize the Video PLL. More...
void CLOCK_InitEnetPll (const clock_enet_pll_config_t *config)
 Initialize the ENET PLL. More...
void CLOCK_DeinitEnetPll (void)
 Deinitialize the ENET PLL. More...
uint32_t CLOCK_GetPllFreq (clock_pll_t pll)
 Get current PLL output frequency. More...
void CLOCK_InitSysPfd (clock_pfd_t pfd, uint8_t pfdFrac)
 Initialize the System PLL PFD. More...
void CLOCK_DeinitSysPfd (clock_pfd_t pfd)
 De-initialize the System PLL PFD. More...
bool CLOCK_IsSysPfdEnabled (clock_pfd_t pfd)
 Check if Sys PFD is enabled. More...
void CLOCK_InitUsb1Pfd (clock_pfd_t pfd, uint8_t pfdFrac)
 Initialize the USB1 PLL PFD. More...
void CLOCK_DeinitUsb1Pfd (clock_pfd_t pfd)
 De-initialize the USB1 PLL PFD. More...
bool CLOCK_IsUsb1PfdEnabled (clock_pfd_t pfd)
 Check if Usb1 PFD is enabled. More...
uint32_t CLOCK_GetSysPfdFreq (clock_pfd_t pfd)
 Get current System PLL PFD output frequency. More...
uint32_t CLOCK_GetUsb1PfdFreq (clock_pfd_t pfd)
 Get current USB1 PLL PFD output frequency. More...
bool CLOCK_EnableUsbhs0PhyPllClock (clock_usb_phy_src_t src, uint32_t freq)
 Enable USB HS PHY PLL clock. More...
void CLOCK_DisableUsbhs0PhyPllClock (void)
 Disable USB HS PHY PLL clock. More...
bool CLOCK_EnableUsbhs1PhyPllClock (clock_usb_phy_src_t src, uint32_t freq)
void CLOCK_DisableUsbhs1PhyPllClock (void)
Clock Output Inferfaces
void CLOCK_SetClockOutput1 (clock_output1_selection_t selection, clock_output_divider_t divider)
 Set the clock source and the divider of the clock output1. More...
void CLOCK_SetClockOutput2 (clock_output2_selection_t selection, clock_output_divider_t divider)
 Set the clock source and the divider of the clock output2. More...
uint32_t CLOCK_GetClockOutCLKO1Freq (void)
 Get the frequency of clock output1 clock signal. More...
uint32_t CLOCK_GetClockOutClkO2Freq (void)
 Get the frequency of clock output2 clock signal. More...
OSC operations
void CLOCK_OSC_EnableOsc24M (void)
 Enable OSC 24Mhz. More...
void CLOCK_OSC_SetOsc24MWorkMode (clock_24MOsc_mode_t workMode)
 Set the work mode of 24MHz crystal oscillator, the available modes are high gian mode, low power mode, and bypass mode. More...
void CLOCK_OSC_EnableOscRc400M (void)
 Enable OSC RC 400Mhz. More...
void CLOCK_OSC_TrimOscRc400M (bool enable, bool bypass, uint16_t trim)
 Trims OSC RC 400MHz. More...
void CLOCK_OSC_SetOscRc400MRefClkDiv (uint8_t divValue)
 Set the divide value for ref_clk to generate slow clock. More...
void CLOCK_OSC_SetOscRc400MFastClkCount (uint16_t targetCount)
 Set the target count for the fast clock. More...
void CLOCK_OSC_SetOscRc400MHysteresisValue (uint8_t negHysteresis, uint8_t posHysteresis)
 Set the negative and positive hysteresis value for the tuned clock. More...
void CLOCK_OSC_BypassOscRc400MTuneLogic (bool enableBypass)
 Bypass/un-bypass the tune logic. More...
void CLOCK_OSC_EnableOscRc400MTuneLogic (bool enable)
 Start/Stop the tune logic. More...
void CLOCK_OSC_FreezeOscRc400MTuneValue (bool enableFreeze)
 Freeze/Unfreeze the tuning value. More...
void CLOCK_OSC_SetOscRc400MTuneValue (uint8_t tuneValue)
 Set the 400MHz RC oscillator tune value when the tune logic is disabled. More...
void CLOCK_OSC_Set1MHzOutputBehavior (clock_1MHzOut_behavior_t behavior)
 Set the behavior of the 1MHz output clock, such as disable the 1MHz clock output, enable the free-running 1MHz clock output, enable the locked 1MHz clock output. More...
void CLOCK_OSC_SetLocked1MHzCount (uint16_t count)
 Set the count for the locked 1MHz clock out. More...
bool CLOCK_OSC_CheckLocked1MHzErrorFlag (void)
 Check the error flag for locked 1MHz clock out. More...
void CLOCK_OSC_ClearLocked1MHzErrorFlag (void)
 Clear the error flag for locked 1MHz clock out. More...
uint16_t CLOCK_OSC_GetCurrentOscRc400MFastClockCount (void)
 Get current count for the fast clock during the tune process. More...
uint8_t CLOCK_OSC_GetCurrentOscRc400MTuneValue (void)
 Get current tune value used by oscillator during tune process. More...
void CLOCK_OSC_SetOsc16MConfig (clock_16MOsc_source_t source, bool enablePowerSave, bool enableClockOut)
 Configure the 16MHz oscillator. More...
status_t CLOCK_CalcArmPllFreq (clock_arm_pll_config_t *config, uint32_t freqInMhz)
 Calculate corresponding config values per given frequency. More...
status_t CLOCK_InitArmPllWithFreq (uint32_t freqInMhz)
 Initializes the Arm PLL with Specific Frequency (in Mhz). More...
void CLOCK_CalcPllSpreadSpectrum (uint32_t factor, uint32_t range, uint32_t mod, clock_pll_ss_config_t *ss)
 Calculate spread spectrum step and stop. More...
void CLOCK_InitSysPll1 (const clock_sys_pll1_config_t *config)
 Initialize the System PLL1. More...
void CLOCK_DeinitSysPll1 (void)
 De-initialize the System PLL1.
void CLOCK_GPC_SetSysPll1OutputFreq (const clock_sys_pll1_gpc_config_t *config)
 Set System PLL1 output frequency in GPC mode. More...
void CLOCK_InitSysPll2 (const clock_sys_pll2_config_t *config)
 Initialize the System PLL2. More...
void CLOCK_DeinitSysPll2 (void)
 De-initialize the System PLL2.
bool CLOCK_IsSysPll2PfdEnabled (clock_pfd_t pfd)
 Check if Sys PLL2 PFD is enabled. More...
void CLOCK_InitSysPll3 (void)
 Initialize the System PLL3. More...
void CLOCK_DeinitSysPll3 (void)
 De-initialize the System PLL3.
bool CLOCK_IsSysPll3PfdEnabled (clock_pfd_t pfd)
 Check if Sys PLL3 PFD is enabled. More...
PLL/PFD operations
void CLOCK_SetPllBypass (clock_pll_t pll, bool bypass)
 PLL bypass setting. More...
status_t CLOCK_CalcAvPllFreq (clock_av_pll_config_t *config, uint32_t freqInMhz)
status_t CLOCK_InitAudioPllWithFreq (uint32_t freqInMhz, bool ssEnable, uint32_t ssRange, uint32_t ssMod)
 Initializes the Audio PLL with Specific Frequency (in Mhz). More...
void CLOCK_GPC_SetAudioPllOutputFreq (const clock_audio_pll_gpc_config_t *config)
 Set Audio PLL output frequency in GPC mode. More...
status_t CLOCK_InitVideoPllWithFreq (uint32_t freqInMhz, bool ssEnable, uint32_t ssRange, uint32_t ssMod)
 Initializes the Video PLL with Specific Frequency (in Mhz). More...
void CLOCK_GPC_SetVideoPllOutputFreq (const clock_video_pll_gpc_config_t *config)
 Set Video PLL output frequency in GPC mode. More...
void CLOCK_InitPfd (clock_pll_t pll, clock_pfd_t pfd, uint8_t frac)
 Initialize PLL PFD. More...
void CLOCK_DeinitPfd (clock_pll_t pll, clock_pfd_t pfd)
 De-initialize selected PLL PFD. More...
uint32_t CLOCK_GetPfdFreq (clock_pll_t pll, clock_pfd_t pfd)
 Get current PFD output frequency. More...
uint32_t CLOCK_GetFreqFromObs (uint32_t obsSigIndex, uint32_t obsIndex)
void CLOCK_OSCPLL_ControlBySetPointMode (clock_name_t name, uint16_t spValue, uint16_t stbyValue)
 Set this clock works in SetPoint control Mode. More...
void CLOCK_OSCPLL_ControlByCpuLowPowerMode (clock_name_t name, uint8_t domainId, clock_level_t level0, clock_level_t level1)
 Set this clock works in CPU Low Power Mode. More...
void CLOCK_ROOT_ControlBySetPointMode (clock_root_t name, const clock_root_setpoint_config_t *spTable)
 Set this clock works in SetPoint controlled Mode. More...
void CLOCK_LPCG_ControlBySetPointMode (clock_lpcg_t name, uint16_t spValue, uint16_t stbyValue)
void CLOCK_LPCG_ControlByCpuLowPowerMode (clock_lpcg_t name, uint8_t domainId, clock_level_t level0, clock_level_t level1)
◆ ADC_CLOCKS
#define ADC_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Adc1, kCLOCK_Adc2 \
@ kCLOCK_Adc1
Definition: fsl_clock.h:539
@ kCLOCK_Adc2
Definition: fsl_clock.h:535
◆ ADC_ETC_CLOCKS
Value:
kCLOCK_Adc_Etc \
◆ AOI_CLOCKS [1/2]
#define AOI_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Aoi1, kCLOCK_Aoi2 \
@ kCLOCK_Aoi2
Definition: fsl_clock.h:538
@ kCLOCK_Aoi1
Definition: fsl_clock.h:571
◆ AOI_CLOCKS [2/2]
#define AOI_CLOCKS
Value:
◆ ASRC_CLOCKS
#define ASRC_CLOCKS
Value:
kCLOCK_Asrc \
◆ BEE_CLOCKS
#define BEE_CLOCKS
Value:
kCLOCK_Bee \
◆ CAAM_CLOCKS
#define CAAM_CLOCKS
Value:
kCLOCK_Caam \
◆ CDOG_CLOCKS
#define CDOG_CLOCKS
Value:
kCLOCK_Cdog \
◆ CLOCK_GetCoreSysClkFreq [1/2]
For compatible with other platforms without CCM.
◆ CLOCK_GetCoreSysClkFreq [2/2]
◆ CLOCK_ROOT_DIV_TUPLE
Value:
@ kCLOCK_UartDiv
Definition: fsl_clock.h:836
@ kCLOCK_Flexio1Div
Definition: fsl_clock.h:887
@ kCLOCK_Lpi2cDiv
Definition: fsl_clock.h:892
@ kCLOCK_LpspiDiv
Definition: fsl_clock.h:805
@ kCLOCK_Sai3PreDiv
Definition: fsl_clock.h:845
@ kCLOCK_Sai3Div
Definition: fsl_clock.h:849
@ kCLOCK_TraceDiv
Definition: fsl_clock.h:824
@ kCLOCK_Spdif0PreDiv
Definition: fsl_clock.h:875
@ kCLOCK_Sai2PreDiv
Definition: fsl_clock.h:866
@ kCLOCK_Sai1Div
Definition: fsl_clock.h:861
@ kCLOCK_LcdifDiv
Definition: fsl_clock.h:807
@ kCLOCK_Spdif0Div
Definition: fsl_clock.h:879
@ kCLOCK_LcdifPreDiv
Definition: fsl_clock.h:896
@ kCLOCK_Sai2Div
Definition: fsl_clock.h:870
@ kCLOCK_Usdhc2Div
Definition: fsl_clock.h:828
@ kCLOCK_Flexio2PreDiv
Definition: fsl_clock.h:853
@ kCLOCK_Flexio1PreDiv
Definition: fsl_clock.h:883
@ kCLOCK_Usdhc1Div
Definition: fsl_clock.h:832
@ kCLOCK_NonePreDiv
Definition: fsl_clock.h:904
@ kCLOCK_Flexio2Div
Definition: fsl_clock.h:841
@ kCLOCK_CsiDiv
Definition: fsl_clock.h:901
@ kCLOCK_FlexspiDiv
Definition: fsl_clock.h:810
@ kCLOCK_Sai1PreDiv
Definition: fsl_clock.h:857
@ kCLOCK_CanDiv
Definition: fsl_clock.h:819
◆ CLOCK_ROOT_MUX_TUPLE
Value:
@ kCLOCK_Lpi2cMux
Definition: fsl_clock.h:760
@ kCLOCK_Flexio1Mux
Definition: fsl_clock.h:755
@ kCLOCK_CsiMux
Definition: fsl_clock.h:769
@ kCLOCK_Usdhc2Mux
Definition: fsl_clock.h:712
@ kCLOCK_CanMux
Definition: fsl_clock.h:741
@ kCLOCK_Sai3Mux
Definition: fsl_clock.h:720
@ kCLOCK_TraceMux
Definition: fsl_clock.h:695
@ kCLOCK_UartMux
Definition: fsl_clock.h:746
@ kCLOCK_SpdifMux
Definition: fsl_clock.h:751
@ kCLOCK_FlexspiMux
Definition: fsl_clock.h:708
@ kCLOCK_Sai2Mux
Definition: fsl_clock.h:724
@ kCLOCK_Flexio2Mux
Definition: fsl_clock.h:737
@ kCLOCK_LpspiMux
Definition: fsl_clock.h:703
◆ CMP_CLOCKS [1/2]
#define CMP_CLOCKS
Value:
@ kCLOCK_Acmp3
Definition: fsl_clock.h:579
@ kCLOCK_Acmp4
Definition: fsl_clock.h:580
@ kCLOCK_Acmp2
Definition: fsl_clock.h:578
@ kCLOCK_Acmp1
Definition: fsl_clock.h:577
◆ CMP_CLOCKS [2/2]
#define CMP_CLOCKS
Value:
◆ CSI_CLOCKS [1/2]
#define CSI_CLOCKS
Value:
kCLOCK_Csi \
◆ CSI_CLOCKS [2/2]
#define CSI_CLOCKS
Value:
kCLOCK_Csi \
◆ DAC_CLOCKS
#define DAC_CLOCKS
Value:
kCLOCK_Dac \
◆ DCDC_CLOCKS [1/3]
#define DCDC_CLOCKS
Value:
kCLOCK_Dcdc \
◆ DCDC_CLOCKS [2/3]
#define DCDC_CLOCKS
Value:
kCLOCK_Dcdc \
◆ DCDC_CLOCKS [3/3]
#define DCDC_CLOCKS
Value:
kCLOCK_Dcdc \
◆ DCIC_CLOCKS
#define DCIC_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Dcic_Mipi, kCLOCK_Dcic_Lcd \
@ kCLOCK_Dcic_Mipi
Definition: fsl_clock.h:632
@ kCLOCK_Dcic_Lcd
Definition: fsl_clock.h:633
◆ DCP_CLOCKS
#define DCP_CLOCKS
Value:
kCLOCK_Dcp \
◆ DMAMUX_CLOCKS [1/2]
Value:
kCLOCK_Dma \
◆ DMAMUX_CLOCKS [2/2]
Value:
kCLOCK_Edma, kCLOCK_Edma_Lpsr \
@ kCLOCK_Edma_Lpsr
Definition: fsl_clock.h:521
◆ EDMA_CLOCKS [1/2]
#define EDMA_CLOCKS
Value:
kCLOCK_Dma \
◆ EDMA_CLOCKS [2/2]
#define EDMA_CLOCKS
Value:
◆ EMVSIM_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Sim1, kCLOCK_Sim2 \
@ kCLOCK_Sim1
Definition: fsl_clock.h:609
@ kCLOCK_Sim2
Definition: fsl_clock.h:610
◆ ENC_CLOCKS [1/2]
#define ENC_CLOCKS
Value:
@ kCLOCK_Enc3
Definition: fsl_clock.h:599
@ kCLOCK_Enc2
Definition: fsl_clock.h:598
@ kCLOCK_Enc1
Definition: fsl_clock.h:597
@ kCLOCK_Enc4
Definition: fsl_clock.h:600
◆ ENC_CLOCKS [2/2]
#define ENC_CLOCKS
Value:
◆ ENET_CLOCKS [1/2]
#define ENET_CLOCKS
Value:
kCLOCK_Enet \
◆ ENET_CLOCKS [2/2]
#define ENET_CLOCKS
Value:
kCLOCK_Enet, kCLOCK_Enet_1g \
@ kCLOCK_Enet_1g
Definition: fsl_clock.h:612
◆ EWM_CLOCKS [1/2]
#define EWM_CLOCKS
Value:
kCLOCK_Ewm0 \
◆ EWM_CLOCKS [2/2]
#define EWM_CLOCKS
Value:
kCLOCK_Ewm0 \
◆ FLEXCAN_CLOCKS [1/2]
Value:
kCLOCK_IpInvalid, kCLOCK_Can1, kCLOCK_Can2 \
@ kCLOCK_Can2
Definition: fsl_clock.h:522
@ kCLOCK_Can1
Definition: fsl_clock.h:520
◆ FLEXCAN_CLOCKS [2/2]
Value:
kCLOCK_IpInvalid, kCLOCK_Can1, kCLOCK_Can2, kCLOCK_Can3 \
@ kCLOCK_Can3
Definition: fsl_clock.h:584
◆ FLEXCAN_PERIPH_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Can1S, kCLOCK_Can2S \
@ kCLOCK_Can2S
Definition: fsl_clock.h:523
@ kCLOCK_Can1S
◆ FLEXIO_CLOCKS [1/2]
Value:
kCLOCK_IpInvalid, kCLOCK_Flexio1, kCLOCK_Flexio2 \
@ kCLOCK_Flexio1
Definition: fsl_clock.h:604
@ kCLOCK_Flexio2
Definition: fsl_clock.h:567
◆ FLEXIO_CLOCKS [2/2]
Value:
◆ FLEXRAM_CLOCKS [1/2]
Value:
kCLOCK_FlexRam \
◆ FLEXRAM_CLOCKS [2/2]
Value:
kCLOCK_Flexram \
◆ FLEXSPI_CLOCKS [1/2]
Value:
kCLOCK_FlexSpi \
◆ FLEXSPI_CLOCKS [2/2]
Value:
kCLOCK_IpInvalid, kCLOCK_Flexspi1, kCLOCK_Flexspi2 \
@ kCLOCK_Flexspi2
Definition: fsl_clock.h:527
@ kCLOCK_Flexspi1
Definition: fsl_clock.h:526
◆ FLEXSPI_EXSC_CLOCKS
Value:
kCLOCK_FlexSpiExsc \
◆ FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL [1/2]
#define FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL   0
Configure whether driver controls clock.
When set to 0, peripheral drivers will enable clock in initialize function and disable clock in de-initialize function. When set to 1, peripheral driver will not control the clock, application could control the clock out of the driver.
Note
All drivers share this feature switcher. If it is set to 1, application should handle clock enable and disable for all drivers.
◆ FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL [2/2]
Note
◆ GPC_CLOCKS
#define GPC_CLOCKS
Value:
kCLOCK_Gpc \
◆ GPIO_CLOCKS [1/2]
#define GPIO_CLOCKS
Value:
@ kCLOCK_Gpio2
Definition: fsl_clock.h:528
@ kCLOCK_Gpio4
Definition: fsl_clock.h:573
@ kCLOCK_Gpio5
Definition: fsl_clock.h:546
@ kCLOCK_Gpio1
Definition: fsl_clock.h:544
@ kCLOCK_Gpio3
Definition: fsl_clock.h:562
◆ GPIO_CLOCKS [2/2]
#define GPIO_CLOCKS
Value:
@ kCLOCK_Gpio
Definition: fsl_clock.h:550
◆ GPT_CLOCKS [1/2]
#define GPT_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Gpt1, kCLOCK_Gpt2 \
@ kCLOCK_Gpt1
Definition: fsl_clock.h:541
@ kCLOCK_Gpt2
Definition: fsl_clock.h:525
◆ GPT_CLOCKS [2/2]
#define GPT_CLOCKS
Value:
@ kCLOCK_Gpt6
Definition: fsl_clock.h:568
@ kCLOCK_Gpt4
Definition: fsl_clock.h:566
@ kCLOCK_Gpt3
Definition: fsl_clock.h:565
@ kCLOCK_Gpt5
◆ GPU2D_CLOCKS
Value:
kCLOCK_Gpu2d \
◆ IEE_CLOCKS
#define IEE_CLOCKS
Value:
kCLOCK_Iee \
◆ IOMUXC_CLOCKS
Value:
kCLOCK_Iomuxc, kCLOCK_Iomuxc_Lpsr \
@ kCLOCK_Iomuxc_Lpsr
Definition: fsl_clock.h:549
◆ kCLOCK_CoreSysClk
◆ KEYMANAGER_CLOCKS
Value:
kCLOCK_Key_Manager \
◆ KPP_CLOCKS [1/2]
#define KPP_CLOCKS
Value:
kCLOCK_Kpp \
◆ KPP_CLOCKS [2/2]
#define KPP_CLOCKS
Value:
kCLOCK_Kpp \
◆ LCDIF_CLOCKS [1/2]
Value:
kCLOCK_Lcd \
◆ LCDIF_CLOCKS [2/2]
Value:
kCLOCK_Lcdif \
◆ LCDIF_PERIPH_CLOCKS
Value:
kCLOCK_LcdPixel \
◆ LCDIFV2_CLOCKS
Value:
kCLOCK_Lcdifv2 \
◆ LMEM_CLOCKS
#define LMEM_CLOCKS
Value:
kCLOCK_Lmem \
◆ LPADC_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Lpadc1, kCLOCK_Lpadc2 \
@ kCLOCK_Lpadc1
Definition: fsl_clock.h:554
@ kCLOCK_Lpadc2
Definition: fsl_clock.h:555
◆ LPI2C_CLOCKS [1/2]
Value:
@ kCLOCK_Lpi2c4
@ kCLOCK_Lpi2c1
Definition: fsl_clock.h:552
@ kCLOCK_Lpi2c3
@ kCLOCK_Lpi2c2
Definition: fsl_clock.h:553
◆ LPI2C_CLOCKS [2/2]
Value:
@ kCLOCK_Lpi2c5
Definition: fsl_clock.h:601
@ kCLOCK_Lpi2c6
Definition: fsl_clock.h:602
◆ LPSPI_CLOCKS [1/2]
Value:
@ kCLOCK_Lpspi3
Definition: fsl_clock.h:533
@ kCLOCK_Lpspi4
Definition: fsl_clock.h:534
@ kCLOCK_Lpspi1
Definition: fsl_clock.h:531
@ kCLOCK_Lpspi2
Definition: fsl_clock.h:532
◆ LPSPI_CLOCKS [2/2]
Value:
@ kCLOCK_Lpspi6
Definition: fsl_clock.h:608
@ kCLOCK_Lpspi5
Definition: fsl_clock.h:607
◆ LPUART_CLOCKS [1/2]
Value:
kCLOCK_Lpuart6, kCLOCK_Lpuart7, kCLOCK_Lpuart8 \
@ kCLOCK_Lpuart3
Definition: fsl_clock.h:519
@ kCLOCK_Lpuart2
@ kCLOCK_Lpuart7
Definition: fsl_clock.h:616
@ kCLOCK_Lpuart1
Definition: fsl_clock.h:615
@ kCLOCK_Lpuart4
Definition: fsl_clock.h:543
@ kCLOCK_Lpuart8
Definition: fsl_clock.h:628
@ kCLOCK_Lpuart5
◆ LPUART_CLOCKS [2/2]
Value:
kCLOCK_Lpuart12 \
@ kCLOCK_Lpuart11
Definition: fsl_clock.h:595
@ kCLOCK_Lpuart10
Definition: fsl_clock.h:594
@ kCLOCK_Lpuart9
Definition: fsl_clock.h:593
◆ MIPI_CSI2RX_CLOCKS
Value:
kCLOCK_Mipi_Csi \
◆ MIPI_DSI_HOST_CLOCKS
Value:
kCLOCK_Mipi_Dsi \
◆ MQS_CLOCKS [1/2]
#define MQS_CLOCKS
Value:
kCLOCK_Mqs \
◆ MQS_CLOCKS [2/2]
#define MQS_CLOCKS
Value:
kCLOCK_Mqs \
◆ MU_CLOCKS
#define MU_CLOCKS
Value:
kCLOCK_Mu_B \
◆ OCOTP_CLOCKS
Value:
kCLOCK_Ocotp \
◆ OCRAM_EXSC_CLOCKS
Value:
kCLOCK_OcramExsc \
◆ PDM_CLOCKS
#define PDM_CLOCKS
Value:
kCLOCK_Pdm \
◆ PIT_CLOCKS [1/2]
#define PIT_CLOCKS
Value:
kCLOCK_Pit \
Clock ip name array for PIT.
◆ PIT_CLOCKS [2/2]
#define PIT_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Pit1, kCLOCK_Pit2 \
@ kCLOCK_Pit2
@ kCLOCK_Pit1
Definition: fsl_clock.h:561
◆ PUF_CLOCKS
#define PUF_CLOCKS
Value:
kCLOCK_Puf \
◆ PWM_CLOCKS [1/2]
#define PWM_CLOCKS
Value:
@ kCLOCK_Pwm3
@ kCLOCK_Pwm2
@ kCLOCK_Pwm4
Definition: fsl_clock.h:596
@ kCLOCK_Pwm1
@ kCLOCK_IpInvalid
Definition: fsl_clock.h:637
Clock ip name array for PWM.
◆ PWM_CLOCKS [2/2]
#define PWM_CLOCKS
◆ PXP_CLOCKS [1/2]
#define PXP_CLOCKS
Value:
kCLOCK_Pxp \
Clock ip name array for PXP.
◆ PXP_CLOCKS [2/2]
#define PXP_CLOCKS
Value:
kCLOCK_Pxp \
◆ RDC_CLOCKS
#define RDC_CLOCKS
Value:
@ kCLOCK_M4_Xrdc
Definition: fsl_clock.h:530
@ kCLOCK_M7_Xrdc
Definition: fsl_clock.h:529
◆ RTWDOG_CLOCKS
#define RTWDOG_CLOCKS
Value:
kCLOCK_Wdog3 \
Clock ip name array for RTWDOG.
◆ SAI_CLOCKS [1/2]
#define SAI_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Sai1, kCLOCK_Sai2, kCLOCK_Sai3 \
@ kCLOCK_Sai1
@ kCLOCK_Sai2
Definition: fsl_clock.h:613
@ kCLOCK_Sai3
Definition: fsl_clock.h:614
Clock ip name array for SAI.
◆ SAI_CLOCKS [2/2]
#define SAI_CLOCKS
Value:
@ kCLOCK_Sai4
Definition: fsl_clock.h:624
◆ SEMA_CLOCKS
#define SEMA_CLOCKS
Value:
kCLOCK_Sema \
◆ SEMC_CLOCKS [1/2]
#define SEMC_CLOCKS
Value:
kCLOCK_Semc \
Clock ip name array for SEMC.
◆ SEMC_CLOCKS [2/2]
#define SEMC_CLOCKS
Value:
kCLOCK_Semc \
◆ SEMC_EXSC_CLOCKS
#define SEMC_EXSC_CLOCKS
Value:
kCLOCK_SemcExsc \
Clock ip name array for SEMC EXSC.
◆ SPDIF_CLOCKS [1/2]
#define SPDIF_CLOCKS
Value:
kCLOCK_Spdif \
Clock ip name array for SPDIF.
◆ SPDIF_CLOCKS [2/2]
Value:
kCLOCK_Spdif \
◆ SRC_CLOCKS
#define SRC_CLOCKS
Value:
kCLOCK_Src \
◆ SSARC_CLOCKS
Value:
kCLOCK_Ssarc \
◆ TMR_CLOCKS [1/2]
#define TMR_CLOCKS
Value:
@ kCLOCK_Timer3
Definition: fsl_clock.h:636
@ kCLOCK_Timer2
Definition: fsl_clock.h:635
@ kCLOCK_Timer1
Definition: fsl_clock.h:634
@ kCLOCK_Timer4
Definition: fsl_clock.h:629
Clock ip name array for QTIMER.
◆ TMR_CLOCKS [2/2]
#define TMR_CLOCKS
Value:
@ kCLOCK_Qtimer3
@ kCLOCK_Qtimer2
Definition: fsl_clock.h:570
@ kCLOCK_Qtimer1
Definition: fsl_clock.h:569
@ kCLOCK_Qtimer4
Definition: fsl_clock.h:572
◆ TRNG_CLOCKS
#define TRNG_CLOCKS
Value:
kCLOCK_Trng \
Clock ip name array for TRNG.
◆ TSC_CLOCKS
#define TSC_CLOCKS
Value:
kCLOCK_Tsc \
Clock ip name array for TSC.
◆ USB_CLOCKS
#define USB_CLOCKS
Value:
kCLOCK_Usb \
◆ USDHC_CLOCKS [1/2]
#define USDHC_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Usdhc1, kCLOCK_Usdhc2 \
@ kCLOCK_Usdhc2
Definition: fsl_clock.h:623
@ kCLOCK_Usdhc1
Definition: fsl_clock.h:622
Clock ip name array for USDHC.
◆ USDHC_CLOCKS [2/2]
Value:
◆ WDOG_CLOCKS [1/2]
#define WDOG_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Wdog1, kCLOCK_Wdog2 \
@ kCLOCK_Wdog2
@ kCLOCK_Wdog1
Definition: fsl_clock.h:575
Clock ip name array for WDOG.
◆ WDOG_CLOCKS [2/2]
#define WDOG_CLOCKS
Value:
@ kCLOCK_Wdog3
Definition: fsl_clock.h:605
@ kCLOCK_Wdog4
Definition: fsl_clock.h:515
◆ XBAR_CLOCKS
#define XBAR_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Xbar1, kCLOCK_Xbar2, kCLOCK_Xbar3 \
@ kCLOCK_Xbar3
Definition: fsl_clock.h:556
@ kCLOCK_Xbar1
Definition: fsl_clock.h:560
@ kCLOCK_Xbar2
◆ XBARA_CLOCKS [1/2]
#define XBARA_CLOCKS
Value:
kCLOCK_IpInvalid, kCLOCK_Xbar1 \
Clock ip name array for XBARA.
◆ XBARA_CLOCKS [2/2]
Value:
◆ XBARB_CLOCKS [1/2]
#define XBARB_CLOCKS
Value:
Clock ip name array for XBARB.
◆ XBARB_CLOCKS [2/2]
Value:
◆ XECC_CLOCKS
#define XECC_CLOCKS
Value:
kCLOCK_Xecc \
Typedef Documentation
◆ clock_arm_pll_config_t
The output clock frequency is:
Fout=Fin*loopDivider /(2 * postDivider).
Fin is always 24MHz.
◆ clock_div_t
typedef enum _clock_div clock_div_t
DIV control names for clock div setting.
These constants define div control names for clock div setting.
  • 0:7: REG offset to CCM_BASE in bytes.
  • 8:15: Root clock setting bit field shift.
  • 16:31: Root clock setting bit field width.
◆ clock_mux_t
typedef enum _clock_mux clock_mux_t
MUX control names for clock mux setting.
These constants define the mux control names for clock mux setting.
◆ _clock_16MOsc_source
Source from 16MHz RC oscialltor.
Source from 24MHz crystal oscillator.
◆ _clock_1MHzOut_behavior
Disable 1MHz output clock.
Enable 1MHz output clock, and select locked 1MHz to output.
Enable 1MHZ output clock, and select free-running 1MHz to output.
◆ _clock_24MOsc_mode
24MHz crystal oscillator work as high gain mode.
24MHz crystal oscillator work as bypass mode.
24MHz crystal oscillator work as low power mode.
◆ _clock_control_mode
kCLOCK_SoftwareMode
Software control mode.
kCLOCK_GpcMode
GPC control mode.
◆ _clock_div
enum _clock_div
kCLOCK_ArmDiv
core div name
kCLOCK_PeriphClk2Div
periph clock2 div name
kCLOCK_SemcDiv
semc div name
kCLOCK_AhbDiv
ahb div name
kCLOCK_IpgDiv
ipg div name
kCLOCK_LpspiDiv
lpspi div name
kCLOCK_LcdifDiv
lcdif div name
kCLOCK_FlexspiDiv
flexspi div name
kCLOCK_PerclkDiv
perclk div name
kCLOCK_CanDiv
can div name
kCLOCK_TraceDiv
trace div name
kCLOCK_Usdhc2Div
usdhc2 div name
kCLOCK_Usdhc1Div
usdhc1 div name
kCLOCK_UartDiv
uart div name
kCLOCK_Flexio2Div
flexio2 pre div name
kCLOCK_Sai3PreDiv
sai3 pre div name
kCLOCK_Sai3Div
sai3 div name
sai3 pre div name
kCLOCK_Sai1PreDiv
sai1 pre div name
kCLOCK_Sai1Div
sai1 div name
kCLOCK_Sai2PreDiv
sai2 pre div name
kCLOCK_Sai2Div
sai2 div name
kCLOCK_Spdif0PreDiv
spdif pre div name
kCLOCK_Spdif0Div
spdif div name
flexio1 pre div name
kCLOCK_Flexio1Div
flexio1 div name
kCLOCK_Lpi2cDiv
lpi2c div name
kCLOCK_LcdifPreDiv
lcdif pre div name
kCLOCK_CsiDiv
csi div name
kCLOCK_NonePreDiv
None Pre div.
◆ _clock_div_value
Clock divider value.
kCLOCK_ArmDivBy1
ARM clock divider set to divided by 1.
kCLOCK_ArmDivBy2
ARM clock divider set to divided by 2.
kCLOCK_ArmDivBy3
ARM clock divider set to divided by 3.
kCLOCK_ArmDivBy4
ARM clock divider set to divided by 4.
kCLOCK_ArmDivBy5
ARM clock divider set to divided by 5.
kCLOCK_ArmDivBy6
ARM clock divider set to divided by 6.
kCLOCK_ArmDivBy7
ARM clock divider set to divided by 7.
kCLOCK_ArmDivBy8
ARM clock divider set to divided by 8.
kCLOCK_PeriphClk2DivBy1
PeriphClk2 divider set to divided by 1.
kCLOCK_PeriphClk2DivBy2
PeriphClk2 divider set to divided by 2.
kCLOCK_PeriphClk2DivBy3
PeriphClk2 divider set to divided by 3.
kCLOCK_PeriphClk2DivBy4
PeriphClk2 divider set to divided by 4.
kCLOCK_PeriphClk2DivBy5
PeriphClk2 divider set to divided by 5.
kCLOCK_PeriphClk2DivBy6
PeriphClk2 divider set to divided by 6.
kCLOCK_PeriphClk2DivBy7
PeriphClk2 divider set to divided by 7.
kCLOCK_PeriphClk2DivBy8
PeriphClk2 divider set to divided by 8.
kCLOCK_SemcDivBy1
SEMC divider set to divided by 1.
kCLOCK_SemcDivBy2
SEMC divider set to divided by 2.
kCLOCK_SemcDivBy3
SEMC divider set to divided by 3.
kCLOCK_SemcDivBy4
SEMC divider set to divided by 4.
kCLOCK_SemcDivBy5
SEMC divider set to divided by 5.
kCLOCK_SemcDivBy6
SEMC divider set to divided by 6.
kCLOCK_SemcDivBy7
SEMC divider set to divided by 7.
kCLOCK_SemcDivBy8
SEMC divider set to divided by 8.
kCLOCK_AhbDivBy1
AHB divider set to divided by 1.
kCLOCK_AhbDivBy2
AHB divider set to divided by 2.
kCLOCK_AhbDivBy3
AHB divider set to divided by 3.
kCLOCK_AhbDivBy4
AHB divider set to divided by 4.
kCLOCK_AhbDivBy5
AHB divider set to divided by 5.
kCLOCK_AhbDivBy6
AHB divider set to divided by 6.
kCLOCK_AhbDivBy7
AHB divider set to divided by 7.
kCLOCK_AhbDivBy8
AHB divider set to divided by 8.
kCLOCK_IpgDivBy1
Ipg divider set to divided by 1.
kCLOCK_IpgDivBy2
Ipg divider set to divided by 2.
kCLOCK_IpgDivBy3
Ipg divider set to divided by 3.
kCLOCK_IpgDivBy4
Ipg divider set to divided by 4.
kCLOCK_LpspiDivBy1
LPSPI divider set to divided by 1.
kCLOCK_LpspiDivBy2
LPSPI divider set to divided by 2.
kCLOCK_LpspiDivBy3
LPSPI divider set to divided by 3.
kCLOCK_LpspiDivBy4
LPSPI divider set to divided by 4.
kCLOCK_LpspiDivBy5
LPSPI divider set to divided by 5.
kCLOCK_LpspiDivBy6
LPSPI divider set to divided by 6.
kCLOCK_LpspiDivBy7
LPSPI divider set to divided by 7.
kCLOCK_LpspiDivBy8
LPSPI divider set to divided by 8.
kCLOCK_LcdifDivBy1
LPDIF divider set to divided by 1.
kCLOCK_LcdifDivBy2
LPDIF divider set to divided by 2.
kCLOCK_LcdifDivBy3
LPDIF divider set to divided by 3.
kCLOCK_LcdifDivBy4
LPDIF divider set to divided by 4.
kCLOCK_LcdifDivBy5
LPDIF divider set to divided by 5.
kCLOCK_LcdifDivBy6
LPDIF divider set to divided by 6.
kCLOCK_LcdifDivBy7
LPDIF divider set to divided by 7.
kCLOCK_LcdifDivBy8
LPDIF divider set to divided by 8.
kCLOCK_FlexspiDivBy1
FLEXSPI divider set to divided by 1.
kCLOCK_FlexspiDivBy2
FLEXSPI divider set to divided by 2.
kCLOCK_FlexspiDivBy3
FLEXSPI divider set to divided by 3.
kCLOCK_FlexspiDivBy4
FLEXSPI divider set to divided by 4.
kCLOCK_FlexspiDivBy5
FLEXSPI divider set to divided by 5.
kCLOCK_FlexspiDivBy6
FLEXSPI divider set to divided by 6.
kCLOCK_FlexspiDivBy7
FLEXSPI divider set to divided by 7.
kCLOCK_FlexspiDivBy8
FLEXSPI divider set to divided by 8.
kCLOCK_TraceDivBy1
TRACE divider set to divided by 1.
kCLOCK_TraceDivBy2
TRACE divider set to divided by 2.
kCLOCK_TraceDivBy3
TRACE divider set to divided by 3.
kCLOCK_TraceDivBy4
TRACE divider set to divided by 4.
kCLOCK_Usdhc2DivBy1
USDHC2 divider set to divided by 1.
kCLOCK_Usdhc2DivBy2
USDHC2 divider set to divided by 2.
kCLOCK_Usdhc2DivBy3
USDHC2 divider set to divided by 3.
kCLOCK_Usdhc2DivBy4
USDHC2 divider set to divided by 4.
kCLOCK_Usdhc2DivBy5
USDHC2 divider set to divided by 5.
kCLOCK_Usdhc2DivBy6
USDHC2 divider set to divided by 6.
kCLOCK_Usdhc2DivBy7
USDHC2 divider set to divided by 7.
kCLOCK_Usdhc2DivBy8
USDHC2 divider set to divided by 8.
kCLOCK_Usdhc1DivBy1
USDHC1 divider set to divided by 1.
kCLOCK_Usdhc1DivBy2
USDHC1 divider set to divided by 2.
kCLOCK_Usdhc1DivBy3
USDHC1 divider set to divided by 3.
kCLOCK_Usdhc1DivBy4
USDHC1 divider set to divided by 4.
kCLOCK_Usdhc1DivBy5
USDHC1 divider set to divided by 5.
kCLOCK_Usdhc1DivBy6
USDHC1 divider set to divided by 6.
kCLOCK_Usdhc1DivBy7
USDHC1 divider set to divided by 7.
kCLOCK_Usdhc1DivBy8
USDHC1 divider set to divided by 8.
kCLOCK_Flexio2DivBy1
Flexio2 divider set to divided by 1.
kCLOCK_Flexio2DivBy2
Flexio2 divider set to divided by 2.
kCLOCK_Flexio2DivBy3
Flexio2 divider set to divided by 3.
kCLOCK_Flexio2DivBy4
Flexio2 divider set to divided by 4.
kCLOCK_Flexio2DivBy5
Flexio2 divider set to divided by 5.
kCLOCK_Flexio2DivBy6
Flexio2 divider set to divided by 6.
kCLOCK_Flexio2DivBy7
Flexio2 divider set to divided by 7.
kCLOCK_Flexio2DivBy8
Flexio2 divider set to divided by 8.
kCLOCK_Sai3PreDivBy1
SAI3ClkPred divider set to divided by 1.
kCLOCK_Sai3PreDivBy2
SAI3ClkPred divider set to divided by 2.
kCLOCK_Sai3PreDivBy3
SAI3ClkPred divider set to divided by 3.
kCLOCK_Sai3PreDivBy4
SAI3ClkPred divider set to divided by 4.
kCLOCK_Sai3PreDivBy5
SAI3ClkPred divider set to divided by 5.
kCLOCK_Sai3PreDivBy6
SAI3ClkPred divider set to divided by 6.
kCLOCK_Sai3PreDivBy7
SAI3ClkPred divider set to divided by 7.
kCLOCK_Sai3PreDivBy8
SAI3ClkPred divider set to divided by 8.
kCLOCK_Flexio2PreDivBy1
Flexio2 pre divider set to divided by 1.
kCLOCK_Flexio2PreDivBy2
Flexio2 pre divider set to divided by 2.
kCLOCK_Flexio2PreDivBy3
Flexio2 pre divider set to divided by 3.
kCLOCK_Flexio2PreDivBy4
Flexio2 pre divider set to divided by 4.
kCLOCK_Flexio2PreDivBy5
Flexio2 pre divider set to divided by 5.
kCLOCK_Flexio2PreDivBy6
Flexio2 pre divider set to divided by 6.
kCLOCK_Flexio2PreDivBy7
Flexio2 pre divider set to divided by 7.
kCLOCK_Flexio2PreDivBy8
Flexio2 pre divider set to divided by 8.
kCLOCK_Sai1PreDivBy1
SAI1 pred divider set to divided by 1.
kCLOCK_Sai1PreDivBy2
SAI1 pred divider set to divided by 2.
kCLOCK_Sai1PreDivBy3
SAI1 pred divider set to divided by 3.
kCLOCK_Sai1PreDivBy4
SAI1 pred divider set to divided by 4.
kCLOCK_Sai1PreDivBy5
SAI1 pred divider set to divided by 5.
kCLOCK_Sai1PreDivBy6
SAI1 pred divider set to divided by 6.
kCLOCK_Sai1PreDivBy7
SAI1 pred divider set to divided by 7.
kCLOCK_Sai1PreDivBy8
SAI1 pred divider set to divided by 8.
kCLOCK_Sai2PreDivBy1
SAI2ClkPred divider set to divided by 1.
kCLOCK_Sai2PreDivBy2
SAI2ClkPred divider set to divided by 2.
kCLOCK_Sai2PreDivBy3
SAI2ClkPred divider set to divided by 3.
kCLOCK_Sai2PreDivBy4
SAI2ClkPred divider set to divided by 4.
kCLOCK_Sai2PreDivBy5
SAI2ClkPred divider set to divided by 5.
kCLOCK_Sai2PreDivBy6
SAI2ClkPred divider set to divided by 6.
kCLOCK_Sai2PreDivBy7
SAI2ClkPred divider set to divided by 7.
kCLOCK_Sai2PreDivBy8
SAI2ClkPred divider set to divided by 8.
kCLOCK_Spdif0PreDivBy1
SPDIF0 pred divider set to divided by 1.
kCLOCK_Spdif0PreDivBy2
SPDIF0 pred divider set to divided by 2.
kCLOCK_Spdif0PreDivBy3
SPDIF0 pred divider set to divided by 3.
kCLOCK_Spdif0PreDivBy4
SPDIF0 pred divider set to divided by 4.
kCLOCK_Spdif0PreDivBy5
SPDIF0 pred divider set to divided by 5.
kCLOCK_Spdif0PreDivBy6
SPDIF0 pred divider set to divided by 6.
kCLOCK_Spdif0PreDivBy7
SPDIF0 pred divider set to divided by 7.
kCLOCK_Spdif0PreDivBy8
SPDIF0 pred divider set to divided by 8.
kCLOCK_Spdif0DivBy1
SPDIF divider set to divided by 1.
kCLOCK_Spdif0DivBy2
SPDIF divider set to divided by 2.
kCLOCK_Spdif0DivBy3
SPDIF divider set to divided by 3.
kCLOCK_Spdif0DivBy4
SPDIF divider set to divided by 4.
kCLOCK_Spdif0DivBy5
SPDIF divider set to divided by 5.
kCLOCK_Spdif0DivBy6
SPDIF divider set to divided by 6.
kCLOCK_Spdif0DivBy7
SPDIF divider set to divided by 7.
kCLOCK_Spdif0DivBy8
SPDIF divider set to divided by 8.
kCLOCK_Flexio1PreDivBy1
Flexio1 pre divider set to divided by 1.
kCLOCK_Flexio1PreDivBy2
Flexio1 pre divider set to divided by 2.
kCLOCK_Flexio1PreDivBy3
Flexio1 pre divider set to divided by 3.
kCLOCK_Flexio1PreDivBy4
Flexio1 pre divider set to divided by 4.
kCLOCK_Flexio1PreDivBy5
Flexio1 pre divider set to divided by 5.
kCLOCK_Flexio1PreDivBy6
Flexio1 pre divider set to divided by 6.
kCLOCK_Flexio1PreDivBy7
Flexio1 pre divider set to divided by 7.
kCLOCK_Flexio1PreDivBy8
Flexio1 pre divider set to divided by 8.
kCLOCK_Flexio1DivBy1
Flexio1 divider set to divided by 1.
kCLOCK_Flexio1DivBy2
Flexio1 divider set to divided by 2.
kCLOCK_Flexio1DivBy3
Flexio1 divider set to divided by 3.
kCLOCK_Flexio1DivBy4
Flexio1 divider set to divided by 4.
kCLOCK_Flexio1DivBy5
Flexio1 divider set to divided by 5.
kCLOCK_Flexio1DivBy6
Flexio1 divider set to divided by 6.
kCLOCK_Flexio1DivBy7
Flexio1 divider set to divided by 7.
kCLOCK_Flexio1DivBy8
Flexio1 divider set to divided by 8.
kCLOCK_LcdifPreDivBy1
Lcdif pre divider set to divided by 1.
kCLOCK_LcdifPreDivBy2
Lcdif pre divider set to divided by 2.
kCLOCK_LcdifPreDivBy3
Lcdif pre divider set to divided by 3.
kCLOCK_LcdifPreDivBy4
Lcdif pre divider set to divided by 4.
kCLOCK_LcdifPreDivBy5
Lcdif pre divider set to divided by 5.
kCLOCK_LcdifPreDivBy6
Lcdif pre divider set to divided by 6.
kCLOCK_LcdifPreDivBy7
Lcdif pre divider set to divided by 7.
kCLOCK_LcdifPreDivBy8
Lcdif pre divider set to divided by 8.
kCLOCK_CsiDivBy1
Csi pre divider set to divided by 1.
kCLOCK_CsiDivBy2
Csi pre divider set to divided by 2.
kCLOCK_CsiDivBy3
Csi pre divider set to divided by 3.
kCLOCK_CsiDivBy4
Csi pre divider set to divided by 4.
kCLOCK_CsiDivBy5
Csi pre divider set to divided by 5.
kCLOCK_CsiDivBy6
Csi pre divider set to divided by 6.
kCLOCK_CsiDivBy7
Csi pre divider set to divided by 7.
kCLOCK_CsiDivBy8
Csi pre divider set to divided by 8.
kCLOCK_MiscDivBy1
Misc divider like LPI2C set to divided by1.
kCLOCK_MiscDivBy2
Misc divider like LPI2C set to divided by2.
kCLOCK_MiscDivBy3
Misc divider like LPI2C set to divided by3.
kCLOCK_MiscDivBy4
Misc divider like LPI2C set to divided by4.
kCLOCK_MiscDivBy5
Misc divider like LPI2C set to divided by5.
kCLOCK_MiscDivBy6
Misc divider like LPI2C set to divided by6.
kCLOCK_MiscDivBy7
Misc divider like LPI2C set to divided by7.
kCLOCK_MiscDivBy8
Misc divider like LPI2C set to divided by8.
kCLOCK_MiscDivBy9
Misc divider like LPI2C set to divided by9.
kCLOCK_MiscDivBy10
Misc divider like LPI2C set to divided by10.
kCLOCK_MiscDivBy11
Misc divider like LPI2C set to divided by11.
kCLOCK_MiscDivBy12
Misc divider like LPI2C set to divided by12.
kCLOCK_MiscDivBy13
Misc divider like LPI2C set to divided by13.
kCLOCK_MiscDivBy14
Misc divider like LPI2C set to divided by14.
kCLOCK_MiscDivBy15
Misc divider like LPI2C set to divided by15.
kCLOCK_MiscDivBy16
Misc divider like LPI2C set to divided by16.
kCLOCK_MiscDivBy17
Misc divider like LPI2C set to divided by17.
kCLOCK_MiscDivBy18
Misc divider like LPI2C set to divided by18.
kCLOCK_MiscDivBy19
Misc divider like LPI2C set to divided by19.
kCLOCK_MiscDivBy20
Misc divider like LPI2C set to divided by20.
kCLOCK_MiscDivBy21
Misc divider like LPI2C set to divided by21.
kCLOCK_MiscDivBy22
Misc divider like LPI2C set to divided by22.
kCLOCK_MiscDivBy23
Misc divider like LPI2C set to divided by23.
kCLOCK_MiscDivBy24
Misc divider like LPI2C set to divided by24.
kCLOCK_MiscDivBy25
Misc divider like LPI2C set to divided by25.
kCLOCK_MiscDivBy26
Misc divider like LPI2C set to divided by26.
kCLOCK_MiscDivBy27
Misc divider like LPI2C set to divided by27.
kCLOCK_MiscDivBy28
Misc divider like LPI2C set to divided by28.
kCLOCK_MiscDivBy29
Misc divider like LPI2C set to divided by29.
kCLOCK_MiscDivBy30
Misc divider like LPI2C set to divided by30.
kCLOCK_MiscDivBy31
Misc divider like LPI2C set to divided by31.
kCLOCK_MiscDivBy32
Misc divider like LPI2C set to divided by32.
kCLOCK_MiscDivBy33
Misc divider like LPI2C set to divided by33.
kCLOCK_MiscDivBy34
Misc divider like LPI2C set to divided by34.
kCLOCK_MiscDivBy35
Misc divider like LPI2C set to divided by35.
kCLOCK_MiscDivBy36
Misc divider like LPI2C set to divided by36.
kCLOCK_MiscDivBy37
Misc divider like LPI2C set to divided by37.
kCLOCK_MiscDivBy38
Misc divider like LPI2C set to divided by38.
kCLOCK_MiscDivBy39
Misc divider like LPI2C set to divided by39.
kCLOCK_MiscDivBy40
Misc divider like LPI2C set to divided by40.
kCLOCK_MiscDivBy41
Misc divider like LPI2C set to divided by41.
kCLOCK_MiscDivBy42
Misc divider like LPI2C set to divided by42.
kCLOCK_MiscDivBy43
Misc divider like LPI2C set to divided by43.
kCLOCK_MiscDivBy44
Misc divider like LPI2C set to divided by44.
kCLOCK_MiscDivBy45
Misc divider like LPI2C set to divided by45.
kCLOCK_MiscDivBy46
Misc divider like LPI2C set to divided by46.
kCLOCK_MiscDivBy47
Misc divider like LPI2C set to divided by47.
kCLOCK_MiscDivBy48
Misc divider like LPI2C set to divided by48.
kCLOCK_MiscDivBy49
Misc divider like LPI2C set to divided by49.
kCLOCK_MiscDivBy50
Misc divider like LPI2C set to divided by50.
kCLOCK_MiscDivBy51
Misc divider like LPI2C set to divided by51.
kCLOCK_MiscDivBy52
Misc divider like LPI2C set to divided by52.
kCLOCK_MiscDivBy53
Misc divider like LPI2C set to divided by53.
kCLOCK_MiscDivBy54
Misc divider like LPI2C set to divided by54.
kCLOCK_MiscDivBy55
Misc divider like LPI2C set to divided by55.
kCLOCK_MiscDivBy56
Misc divider like LPI2C set to divided by56.
kCLOCK_MiscDivBy57
Misc divider like LPI2C set to divided by57.
kCLOCK_MiscDivBy58
Misc divider like LPI2C set to divided by58.
kCLOCK_MiscDivBy59
Misc divider like LPI2C set to divided by59.
kCLOCK_MiscDivBy60
Misc divider like LPI2C set to divided by60.
kCLOCK_MiscDivBy61
Misc divider like LPI2C set to divided by61.
kCLOCK_MiscDivBy62
Misc divider like LPI2C set to divided by62.
kCLOCK_MiscDivBy63
Misc divider like LPI2C set to divided by63.
kCLOCK_MiscDivBy64
Misc divider like LPI2C set to divided by64.
◆ _clock_gate_value [1/2]
Clock gate value.
kCLOCK_ClockNotNeeded
Clock is off during all modes.
kCLOCK_ClockNeededRun
Clock is on in run mode, but off in WAIT and STOP modes
kCLOCK_ClockNeededRunWait
Clock is on during all modes, except STOP mode
kCLOCK_Off
Clock is off.
kCLOCK_On
Clock is on
◆ _clock_gate_value [2/2]
Clock gate value.
kCLOCK_Off
Clock is off.
kCLOCK_On
Clock is on
◆ _clock_group
FlexRAM clock group.
Mipi Dsi clock group.
kCLOCK_Group_Last
Last clock group.
◆ _clock_ip_name
CCM CCGR gate control for each module independently.
kCLOCK_Aips_tz1
CCGR0, CG0
kCLOCK_Aips_tz2
CCGR0, CG1
kCLOCK_Mqs
CCGR0, CG2
kCLOCK_FlexSpiExsc
CCGR0, CG3
kCLOCK_Sim_M_Main
CCGR0, CG4
kCLOCK_Dcp
CCGR0, CG5
kCLOCK_Lpuart3
CCGR0, CG6
kCLOCK_Can1
CCGR0, CG7
kCLOCK_Can1S
CCGR0, CG8
kCLOCK_Can2
CCGR0, CG9
kCLOCK_Can2S
CCGR0, CG10
kCLOCK_Trace
CCGR0, CG11
kCLOCK_Gpt2
CCGR0, CG12
kCLOCK_Gpt2S
CCGR0, CG13
kCLOCK_Lpuart2
CCGR0, CG14
kCLOCK_Gpio2
CCGR0, CG15
kCLOCK_Lpspi1
CCGR1, CG0
kCLOCK_Lpspi2
CCGR1, CG1
kCLOCK_Lpspi3
CCGR1, CG2
kCLOCK_Lpspi4
CCGR1, CG3
kCLOCK_Adc2
CCGR1, CG4
kCLOCK_Enet
CCGR1, CG5
kCLOCK_Pit
CCGR1, CG6
kCLOCK_Aoi2
CCGR1, CG7
kCLOCK_Adc1
CCGR1, CG8
kCLOCK_SemcExsc
CCGR1, CG9
kCLOCK_Gpt1
CCGR1, CG10
kCLOCK_Gpt1S
CCGR1, CG11
kCLOCK_Lpuart4
CCGR1, CG12
kCLOCK_Gpio1
CCGR1, CG13
kCLOCK_Csu
CCGR1, CG14
kCLOCK_Gpio5
CCGR1, CG15
kCLOCK_OcramExsc
CCGR2, CG0
kCLOCK_Csi
CCGR2, CG1
kCLOCK_IomuxcSnvs
CCGR2, CG2
kCLOCK_Lpi2c1
CCGR2, CG3
kCLOCK_Lpi2c2
CCGR2, CG4
kCLOCK_Lpi2c3
CCGR2, CG5
kCLOCK_Ocotp
CCGR2, CG6
kCLOCK_Xbar3
CCGR2, CG7
kCLOCK_Ipmux1
CCGR2, CG8
kCLOCK_Ipmux2
CCGR2, CG9
kCLOCK_Ipmux3
CCGR2, CG10
kCLOCK_Xbar1
CCGR2, CG11
kCLOCK_Xbar2
CCGR2, CG12
kCLOCK_Gpio3
CCGR2, CG13
kCLOCK_Lcd
CCGR2, CG14
kCLOCK_Pxp
CCGR2, CG15
kCLOCK_Flexio2
CCGR3, CG0
kCLOCK_Lpuart5
CCGR3, CG1
kCLOCK_Semc
CCGR3, CG2
kCLOCK_Lpuart6
CCGR3, CG3
kCLOCK_Aoi1
CCGR3, CG4
kCLOCK_LcdPixel
CCGR3, CG5
kCLOCK_Gpio4
CCGR3, CG6
kCLOCK_Ewm0
CCGR3, CG7
kCLOCK_Wdog1
CCGR3, CG8
kCLOCK_FlexRam
CCGR3, CG9
kCLOCK_Acmp1
CCGR3, CG10
kCLOCK_Acmp2
CCGR3, CG11
kCLOCK_Acmp3
CCGR3, CG12
kCLOCK_Acmp4
CCGR3, CG13
kCLOCK_Ocram
CCGR3, CG14
kCLOCK_IomuxcSnvsGpr
CCGR3, CG15
kCLOCK_Sim_m7_clk_r
CCGR4, CG0
kCLOCK_Iomuxc
CCGR4, CG1
kCLOCK_IomuxcGpr
CCGR4, CG2
kCLOCK_Bee
CCGR4, CG3
kCLOCK_SimM7
CCGR4, CG4
kCLOCK_Tsc
CCGR4, CG5
kCLOCK_SimM
CCGR4, CG6
kCLOCK_SimEms
CCGR4, CG7
kCLOCK_Pwm1
CCGR4, CG8
kCLOCK_Pwm2
CCGR4, CG9
kCLOCK_Pwm3
CCGR4, CG10
kCLOCK_Pwm4
CCGR4, CG11
kCLOCK_Enc1
CCGR4, CG12
kCLOCK_Enc2
CCGR4, CG13
kCLOCK_Enc3
CCGR4, CG14
kCLOCK_Enc4
CCGR4, CG15
kCLOCK_Rom
CCGR5, CG0
kCLOCK_Flexio1
CCGR5, CG1
kCLOCK_Wdog3
CCGR5, CG2
kCLOCK_Dma
CCGR5, CG3
kCLOCK_Kpp
CCGR5, CG4
kCLOCK_Wdog2
CCGR5, CG5
kCLOCK_Aips_tz4
CCGR5, CG6
kCLOCK_Spdif
CCGR5, CG7
kCLOCK_SimMain
CCGR5, CG8
kCLOCK_Sai1
CCGR5, CG9
kCLOCK_Sai2
CCGR5, CG10
kCLOCK_Sai3
CCGR5, CG11
kCLOCK_Lpuart1
CCGR5, CG12
kCLOCK_Lpuart7
CCGR5, CG13
kCLOCK_SnvsHp
CCGR5, CG14
kCLOCK_SnvsLp
CCGR5, CG15
kCLOCK_UsbOh3
CCGR6, CG0
kCLOCK_Usdhc1
CCGR6, CG1
kCLOCK_Usdhc2
CCGR6, CG2
kCLOCK_Dcdc
CCGR6, CG3
kCLOCK_Ipmux4
CCGR6, CG4
kCLOCK_FlexSpi
CCGR6, CG5
kCLOCK_Trng
CCGR6, CG6
kCLOCK_Lpuart8
CCGR6, CG7
kCLOCK_Timer4
CCGR6, CG8
kCLOCK_Aips_tz3
CCGR6, CG9
kCLOCK_SimPer
CCGR6, CG10
kCLOCK_Anadig
CCGR6, CG11
kCLOCK_Lpi2c4
CCGR6, CG12
kCLOCK_Timer1
CCGR6, CG13
kCLOCK_Timer2
CCGR6, CG14
kCLOCK_Timer3
CCGR6, CG15
◆ _clock_level
kCLOCK_Level0
Not needed in any mode.
kCLOCK_Level1
Needed in RUN mode.
kCLOCK_Level2
Needed in RUN and WAIT mode.
kCLOCK_Level3
Needed in RUN, WAIT and STOP mode.
kCLOCK_Level4
Always on in any mode.
◆ _clock_lpcg
Clock LPCG index.
kCLOCK_M7
Clock LPCG M7.
kCLOCK_M4
Clock LPCG M4.
kCLOCK_Sim_M7
Clock LPCG SIM M7.
kCLOCK_Sim_M
Clock LPCG SIM M4.
kCLOCK_Sim_Disp
Clock LPCG SIM DISP.
kCLOCK_Sim_Per
Clock LPCG SIM PER.
kCLOCK_Sim_Lpsr
Clock LPCG SIM LPSR.
kCLOCK_Anadig
Clock LPCG Anadig.
kCLOCK_Dcdc
Clock LPCG DCDC.
kCLOCK_Src
Clock LPCG SRC.
kCLOCK_Ccm
Clock LPCG CCM.
kCLOCK_Gpc
Clock LPCG GPC.
kCLOCK_Ssarc
Clock LPCG SSARC.
kCLOCK_Sim_R
Clock LPCG SIM_R.
kCLOCK_Wdog1
Clock LPCG WDOG1.
kCLOCK_Wdog2
Clock LPCG WDOG2.
kCLOCK_Wdog3
Clock LPCG WDOG3.
kCLOCK_Wdog4
Clock LPCG WDOG4.
kCLOCK_Ewm0
Clock LPCG EWM0.
kCLOCK_Sema
Clock LPCG SEMA.
kCLOCK_Mu_A
Clock LPCG MU_A.
kCLOCK_Mu_B
Clock LPCG MU_B.
kCLOCK_Edma
Clock LPCG EDMA.
kCLOCK_Edma_Lpsr
Clock LPCG EDMA_LPSR.
kCLOCK_Romcp
Clock LPCG ROMCP.
kCLOCK_Ocram
Clock LPCG OCRAM.
kCLOCK_Flexram
Clock LPCG FLEXRAM.
kCLOCK_Lmem
Clock LPCG Lmem.
kCLOCK_Flexspi1
Clock LPCG Flexspi1.
kCLOCK_Flexspi2
Clock LPCG Flexspi2.
kCLOCK_Rdc
Clock LPCG RDC.
kCLOCK_M7_Xrdc
Clock LPCG M7 XRDC.
kCLOCK_M4_Xrdc
Clock LPCG M4 XRDC.
kCLOCK_Semc
Clock LPCG SEMC.
kCLOCK_Xecc
Clock LPCG XECC.
kCLOCK_Iee
Clock LPCG IEE.
kCLOCK_Key_Manager
Clock LPCG KEY_MANAGER.
kCLOCK_Puf
Clock LPCG PUF.
kCLOCK_Ocotp
Clock LPCG OSOTP.
kCLOCK_Snvs_Hp
Clock LPCG SNVS_HP.
kCLOCK_Snvs
Clock LPCG SNVS.
kCLOCK_Caam
Clock LPCG Caam.
kCLOCK_Jtag_Mux
Clock LPCG JTAG_MUX.
kCLOCK_Cstrace
Clock LPCG CSTRACE.
kCLOCK_Xbar1
Clock LPCG XBAR1.
kCLOCK_Xbar2
Clock LPCG XBAR2.
kCLOCK_Xbar3
Clock LPCG XBAR3.
kCLOCK_Aoi1
Clock LPCG AOI1.
kCLOCK_Aoi2
Clock LPCG AOI2.
kCLOCK_Adc_Etc
Clock LPCG ADC_ETC.
kCLOCK_Iomuxc
Clock LPCG IOMUXC.
kCLOCK_Iomuxc_Lpsr
Clock LPCG IOMUXC_LPSR.
kCLOCK_Gpio
Clock LPCG GPIO.
kCLOCK_Kpp
Clock LPCG KPP.
kCLOCK_Flexio1
Clock LPCG FLEXIO1.
kCLOCK_Flexio2
Clock LPCG FLEXIO2.
kCLOCK_Lpadc1
Clock LPCG LPADC1.
kCLOCK_Lpadc2
Clock LPCG LPADC2.
kCLOCK_Dac
Clock LPCG DAC.
kCLOCK_Acmp1
Clock LPCG ACMP1.
kCLOCK_Acmp2
Clock LPCG ACMP2.
kCLOCK_Acmp3
Clock LPCG ACMP3.
kCLOCK_Acmp4
Clock LPCG ACMP4.
kCLOCK_Pit1
Clock LPCG PIT1.
kCLOCK_Pit2
Clock LPCG PIT2.
kCLOCK_Gpt1
Clock LPCG GPT1.
kCLOCK_Gpt2
Clock LPCG GPT2.
kCLOCK_Gpt3
Clock LPCG GPT3.
kCLOCK_Gpt4
Clock LPCG GPT4.
kCLOCK_Gpt5
Clock LPCG GPT5.
kCLOCK_Gpt6
Clock LPCG GPT6.
kCLOCK_Qtimer1
Clock LPCG QTIMER1.
kCLOCK_Qtimer2
Clock LPCG QTIMER2.
kCLOCK_Qtimer3
Clock LPCG QTIMER3.
kCLOCK_Qtimer4
Clock LPCG QTIMER4.
kCLOCK_Enc1
Clock LPCG Enc1.
kCLOCK_Enc2
Clock LPCG Enc2.
kCLOCK_Enc3
Clock LPCG Enc3.
kCLOCK_Enc4
Clock LPCG Enc4.
kCLOCK_Hrtimer
Clock LPCG Hrtimer.
kCLOCK_Pwm1
Clock LPCG PWM1.
kCLOCK_Pwm2
Clock LPCG PWM2.
kCLOCK_Pwm3
Clock LPCG PWM3.
kCLOCK_Pwm4
Clock LPCG PWM4.
kCLOCK_Can1
Clock LPCG CAN1.
kCLOCK_Can2
Clock LPCG CAN2.
kCLOCK_Can3
Clock LPCG CAN3.
kCLOCK_Lpuart1
Clock LPCG LPUART1.
kCLOCK_Lpuart2
Clock LPCG LPUART2.
kCLOCK_Lpuart3
Clock LPCG LPUART3.
kCLOCK_Lpuart4
Clock LPCG LPUART4.
kCLOCK_Lpuart5
Clock LPCG LPUART5.
kCLOCK_Lpuart6
Clock LPCG LPUART6.
kCLOCK_Lpuart7
Clock LPCG LPUART7.
kCLOCK_Lpuart8
Clock LPCG LPUART8.
kCLOCK_Lpuart9
Clock LPCG LPUART9.
kCLOCK_Lpuart10
Clock LPCG LPUART10.
kCLOCK_Lpuart11
Clock LPCG LPUART11.
kCLOCK_Lpuart12
Clock LPCG LPUART12.
kCLOCK_Lpi2c1
Clock LPCG LPI2C1.
kCLOCK_Lpi2c2
Clock LPCG LPI2C2.
kCLOCK_Lpi2c3
Clock LPCG LPI2C3.
kCLOCK_Lpi2c4
Clock LPCG LPI2C4.
kCLOCK_Lpi2c5
Clock LPCG LPI2C5.
kCLOCK_Lpi2c6
Clock LPCG LPI2C6.
kCLOCK_Lpspi1
Clock LPCG LPSPI1.
kCLOCK_Lpspi2
Clock LPCG LPSPI2.
kCLOCK_Lpspi3
Clock LPCG LPSPI3.
kCLOCK_Lpspi4
Clock LPCG LPSPI4.
kCLOCK_Lpspi5
Clock LPCG LPSPI5.
kCLOCK_Lpspi6
Clock LPCG LPSPI6.
kCLOCK_Sim1
Clock LPCG SIM1.
kCLOCK_Sim2
Clock LPCG SIM2.
kCLOCK_Enet
Clock LPCG ENET.
kCLOCK_Enet_1g
Clock LPCG ENET 1G.
kCLOCK_Usb
Clock LPCG USB.
kCLOCK_Cdog
Clock LPCG CDOG.
kCLOCK_Usdhc1
Clock LPCG USDHC1.
kCLOCK_Usdhc2
Clock LPCG USDHC2.
kCLOCK_Asrc
Clock LPCG ASRC.
kCLOCK_Mqs
Clock LPCG MQS.
kCLOCK_Pdm
Clock LPCG PDM.
kCLOCK_Spdif
Clock LPCG SPDIF.
kCLOCK_Sai1
Clock LPCG SAI1.
kCLOCK_Sai2
Clock LPCG SAI2.
kCLOCK_Sai3
Clock LPCG SAI3.
kCLOCK_Sai4
Clock LPCG SAI4.
kCLOCK_Pxp
Clock LPCG PXP.
kCLOCK_Gpu2d
Clock LPCG GPU2D.
kCLOCK_Lcdif
Clock LPCG LCDIF.
kCLOCK_Lcdifv2
Clock LPCG LCDIFV2.
kCLOCK_Mipi_Dsi
Clock LPCG MIPI DSI.
kCLOCK_Mipi_Csi
Clock LPCG MIPI CSI.
kCLOCK_Csi
Clock LPCG CSI.
kCLOCK_Dcic_Mipi
Clock LPCG DCIC MIPI.
kCLOCK_Dcic_Lcd
Clock LPCG DCIC LCD.
kCLOCK_Video_Mux
Clock LPCG VIDEO MUX.
kCLOCK_Uniq_Edt_I
Clock LPCG Uniq_Edt_I.
kCLOCK_IpInvalid
Invalid value.
◆ _clock_mode_t [1/2]
System clock mode.
kCLOCK_ModeRun
Remain in run mode.
kCLOCK_ModeWait
Transfer to wait mode.
kCLOCK_ModeStop
Transfer to stop mode.
kCLOCK_ModeRun
Remain in run mode.
kCLOCK_ModeWait
kCLOCK_ModeStop
◆ _clock_mode_t [2/2]
System clock mode.
kCLOCK_ModeRun
Remain in run mode.
kCLOCK_ModeWait
kCLOCK_ModeStop
kCLOCK_ModeRun
Remain in run mode.
kCLOCK_ModeWait
kCLOCK_ModeStop
◆ _clock_mux
enum _clock_mux
kCLOCK_Pll3SwMux
pll3_sw_clk mux name
kCLOCK_PeriphMux
periph mux name
kCLOCK_SemcAltMux
semc mux name
kCLOCK_SemcMux
semc mux name
kCLOCK_PrePeriphMux
pre-periph mux name
kCLOCK_TraceMux
trace mux name
kCLOCK_PeriphClk2Mux
periph clock2 mux name
kCLOCK_LpspiMux
lpspi mux name
kCLOCK_FlexspiMux
flexspi mux name
kCLOCK_Usdhc2Mux
usdhc2 mux name
kCLOCK_Usdhc1Mux
usdhc1 mux name
kCLOCK_Sai3Mux
sai3 mux name
kCLOCK_Sai2Mux
sai2 mux name
kCLOCK_Sai1Mux
sai1 mux name
kCLOCK_PerclkMux
perclk mux name
kCLOCK_Flexio2Mux
flexio2 mux name
kCLOCK_CanMux
can mux name
kCLOCK_UartMux
uart mux name
kCLOCK_SpdifMux
spdif mux name
kCLOCK_Flexio1Mux
flexio1 mux name
kCLOCK_Lpi2cMux
lpi2c mux name
kCLOCK_LcdifPreMux
lcdif pre mux name
kCLOCK_CsiMux
csi mux name
◆ _clock_name [1/2]
Clock name used to get clock frequency.
kCLOCK_CpuClk
CPU clock
kCLOCK_AhbClk
AHB clock
kCLOCK_SemcClk
SEMC clock
kCLOCK_IpgClk
IPG clock
kCLOCK_PerClk
PER clock
kCLOCK_OscClk
OSC clock selected by PMU_LOWPWR_CTRL[OSC_SEL].
kCLOCK_RtcClk
RTC clock. (RTCCLK)
kCLOCK_ArmPllClk
ARMPLLCLK.
kCLOCK_Usb1PllClk
USB1PLLCLK.
kCLOCK_Usb1PllPfd0Clk
USB1PLLPDF0CLK.
kCLOCK_Usb1PllPfd1Clk
USB1PLLPFD1CLK.
kCLOCK_Usb1PllPfd2Clk
USB1PLLPFD2CLK.
kCLOCK_Usb1PllPfd3Clk
USB1PLLPFD3CLK.
kCLOCK_Usb1SwClk
USB1PLLSWCLK
kCLOCK_Usb1Sw120MClk
USB1PLLSw120MCLK
kCLOCK_Usb1Sw60MClk
USB1PLLSw60MCLK
kCLOCK_Usb1Sw80MClk
USB1PLLSw80MCLK
kCLOCK_Usb2PllClk
USB2PLLCLK.
kCLOCK_SysPllClk
SYSPLLCLK.
kCLOCK_SysPllPfd0Clk
SYSPLLPDF0CLK.
kCLOCK_SysPllPfd1Clk
SYSPLLPFD1CLK.
kCLOCK_SysPllPfd2Clk
SYSPLLPFD2CLK.
kCLOCK_SysPllPfd3Clk
SYSPLLPFD3CLK.
kCLOCK_EnetPll0Clk
Enet PLLCLK ref_enetpll0.
kCLOCK_EnetPll1Clk
Enet PLLCLK ref_enetpll1.
kCLOCK_AudioPllClk
Audio PLLCLK.
kCLOCK_VideoPllClk
Video PLLCLK.
kCLOCK_NoneName
None Clock Name.
kCLOCK_OscRc16M
16MHz RC Oscillator.
kCLOCK_OscRc48M
48MHz RC Oscillator.
kCLOCK_OscRc48MDiv2
48MHz RC Oscillator Div2.
kCLOCK_OscRc400M
400MHz RC Oscillator.
kCLOCK_Osc24M
24MHz Oscillator.
kCLOCK_Osc24MOut
48MHz Oscillator Out.
kCLOCK_ArmPll
ARM PLL.
kCLOCK_ArmPllOut
ARM PLL Out.
kCLOCK_SysPll2
SYS PLL2.
kCLOCK_SysPll2Out
SYS PLL2 OUT.
kCLOCK_SysPll2Pfd0
SYS PLL2 PFD0.
kCLOCK_SysPll2Pfd1
SYS PLL2 PFD1.
kCLOCK_SysPll2Pfd2
SYS PLL2 PFD2.
kCLOCK_SysPll2Pfd3
SYS PLL2 PFD3.
kCLOCK_SysPll3
SYS PLL3.
kCLOCK_SysPll3Out
SYS PLL3 OUT.
kCLOCK_SysPll3Div2
SYS PLL3 DIV2
kCLOCK_SysPll3Pfd0
SYS PLL3 PFD0.
kCLOCK_SysPll3Pfd1
SYS PLL3 PFD1
kCLOCK_SysPll3Pfd2
SYS PLL3 PFD2
kCLOCK_SysPll3Pfd3
SYS PLL3 PFD3
kCLOCK_SysPll1
SYS PLL1.
kCLOCK_SysPll1Out
SYS PLL1 OUT.
kCLOCK_SysPll1Div2
SYS PLL1 DIV2.
kCLOCK_SysPll1Div5
SYS PLL1 DIV5.
kCLOCK_AudioPll
SYS AUDIO PLL.
kCLOCK_AudioPllOut
SYS AUDIO PLL OUT.
kCLOCK_VideoPll
SYS VIDEO PLL.
kCLOCK_VideoPllOut
SYS VIDEO PLL OUT.
kCLOCK_CpuClk
SYS CPU CLK.
kCLOCK_CoreSysClk
SYS CORE SYS CLK.
kCLOCK_Reserved
Reserved.
◆ _clock_name [2/2]
Clock name.
kCLOCK_CpuClk
CPU clock
kCLOCK_AhbClk
AHB clock
kCLOCK_SemcClk
SEMC clock
kCLOCK_IpgClk
IPG clock
kCLOCK_PerClk
PER clock
kCLOCK_OscClk
kCLOCK_RtcClk
RTC clock. (RTCCLK)
kCLOCK_ArmPllClk
ARMPLLCLK.
kCLOCK_Usb1PllClk
USB1PLLCLK.
USB1PLLPDF0CLK.
USB1PLLPFD1CLK.
USB1PLLPFD2CLK.
USB1PLLPFD3CLK.
kCLOCK_Usb1SwClk
USB1PLLSWCLK
USB1PLLSw120MCLK
kCLOCK_Usb1Sw60MClk
USB1PLLSw60MCLK
kCLOCK_Usb1Sw80MClk
USB1PLLSw80MCLK
kCLOCK_Usb2PllClk
USB2PLLCLK.
kCLOCK_SysPllClk
SYSPLLCLK.
SYSPLLPDF0CLK.
SYSPLLPFD1CLK.
SYSPLLPFD2CLK.
SYSPLLPFD3CLK.
kCLOCK_EnetPll0Clk
kCLOCK_EnetPll1Clk
kCLOCK_AudioPllClk
Audio PLLCLK.
kCLOCK_VideoPllClk
Video PLLCLK.
kCLOCK_NoneName
None Clock Name.
kCLOCK_OscRc16M
kCLOCK_OscRc48M
kCLOCK_OscRc48MDiv2
kCLOCK_OscRc400M
kCLOCK_Osc24M
24MHz Oscillator.
kCLOCK_Osc24MOut
kCLOCK_ArmPll
ARM PLL.
kCLOCK_ArmPllOut
ARM PLL Out.
kCLOCK_SysPll2
SYS PLL2.
kCLOCK_SysPll2Out
SYS PLL2 OUT.
kCLOCK_SysPll2Pfd0
SYS PLL2 PFD0.
kCLOCK_SysPll2Pfd1
SYS PLL2 PFD1.
kCLOCK_SysPll2Pfd2
SYS PLL2 PFD2.
kCLOCK_SysPll2Pfd3
SYS PLL2 PFD3.
kCLOCK_SysPll3
SYS PLL3.
kCLOCK_SysPll3Out
SYS PLL3 OUT.
kCLOCK_SysPll3Div2
SYS PLL3 DIV2
kCLOCK_SysPll3Pfd0
SYS PLL3 PFD0.
kCLOCK_SysPll3Pfd1
SYS PLL3 PFD1
kCLOCK_SysPll3Pfd2
SYS PLL3 PFD2
kCLOCK_SysPll3Pfd3
SYS PLL3 PFD3
kCLOCK_SysPll1
SYS PLL1.
kCLOCK_SysPll1Out
SYS PLL1 OUT.
kCLOCK_SysPll1Div2
SYS PLL1 DIV2.
kCLOCK_SysPll1Div5
SYS PLL1 DIV5.
kCLOCK_AudioPll
SYS AUDIO PLL.
kCLOCK_AudioPllOut
SYS AUDIO PLL OUT.
kCLOCK_VideoPll
SYS VIDEO PLL.
kCLOCK_VideoPllOut
SYS VIDEO PLL OUT.
kCLOCK_CpuClk
SYS CPU CLK.
kCLOCK_CoreSysClk
SYS CORE SYS CLK.
kCLOCK_Reserved
Reserved.
◆ _clock_osc [1/2]
enum _clock_osc
OSC 24M sorce select.
kCLOCK_RcOsc
On chip OSC.
kCLOCK_XtalOsc
24M Xtal OSC
kCLOCK_RcOsc
On chip OSC.
kCLOCK_XtalOsc
24M Xtal OSC
◆ _clock_osc [2/2]
enum _clock_osc
kCLOCK_RcOsc
On chip OSC.
kCLOCK_XtalOsc
24M Xtal OSC
kCLOCK_RcOsc
On chip OSC.
kCLOCK_XtalOsc
24M Xtal OSC
◆ _clock_output1_selection
The enumerater of clock output1's clock source, such as USB1 PLL, SYS PLL and so on.
kCLOCK_OutputPllUsb1
Selects USB1 PLL clock(Divided by 2) output.
kCLOCK_OutputPllSys
Selects SYS PLL clock(Divided by 2) output.
kCLOCK_OutputPllVideo
Selects Video PLL clock(Divided by 2) output.
kCLOCK_OutputSemcClk
Selects semc clock root output.
kCLOCK_OutputLcdifPixClk
Selects Lcdif pix clock root output.
kCLOCK_OutputAhbClk
Selects AHB clock root output.
kCLOCK_OutputIpgClk
Selects IPG clock root output.
kCLOCK_OutputPerClk
Selects PERCLK clock root output.
kCLOCK_OutputCkilSyncClk
Selects Ckil clock root output.
kCLOCK_OutputPll4MainClk
Selects PLL4 main clock output.
kCLOCK_DisableClockOutput1
Disables CLKO1.
◆ _clock_output2_selection
The enumerater of clock output2's clock source, such as USDHC1 clock root, LPI2C clock root and so on.
kCLOCK_OutputUsdhc1Clk
Selects USDHC1 clock root output.
kCLOCK_OutputLpi2cClk
Selects LPI2C clock root output.
kCLOCK_OutputCsiClk
Selects CSI clock root output.
kCLOCK_OutputOscClk
Selects OSC output.
kCLOCK_OutputUsdhc2Clk
Selects USDHC2 clock root output.
kCLOCK_OutputSai1Clk
Selects SAI1 clock root output.
kCLOCK_OutputSai2Clk
Selects SAI2 clock root output.
kCLOCK_OutputSai3Clk
Selects SAI3 clock root output.
kCLOCK_OutputCanClk
Selects CAN clock root output.
kCLOCK_OutputFlexspiClk
Selects FLEXSPI clock root output.
kCLOCK_OutputUartClk
Selects UART clock root output.
kCLOCK_OutputSpdif0Clk
Selects SPDIF0 clock root output.
kCLOCK_DisableClockOutput2
Disables CLKO2.
◆ _clock_output_divider
The enumerator of clock output's divider.
kCLOCK_DivideBy1
Output clock divided by 1.
kCLOCK_DivideBy2
Output clock divided by 2.
kCLOCK_DivideBy3
Output clock divided by 3.
kCLOCK_DivideBy4
Output clock divided by 4.
kCLOCK_DivideBy5
Output clock divided by 5.
kCLOCK_DivideBy6
Output clock divided by 6.
kCLOCK_DivideBy7
Output clock divided by 7.
kCLOCK_DivideBy8
Output clock divided by 8.
◆ _clock_pfd [1/2]
enum _clock_pfd
PLL PFD name.
kCLOCK_Pfd0
PLL PFD0
kCLOCK_Pfd1
PLL PFD1
kCLOCK_Pfd2
PLL PFD2
kCLOCK_Pfd3
PLL PFD3
kCLOCK_Pfd0
PLL PFD0
kCLOCK_Pfd1
PLL PFD1
kCLOCK_Pfd2
PLL PFD2
kCLOCK_Pfd3
PLL PFD3
◆ _clock_pfd [2/2]
enum _clock_pfd
PLL PFD name.
kCLOCK_Pfd0
PLL PFD0
kCLOCK_Pfd1
PLL PFD1
kCLOCK_Pfd2
PLL PFD2
kCLOCK_Pfd3
PLL PFD3
kCLOCK_Pfd0
PLL PFD0
kCLOCK_Pfd1
PLL PFD1
kCLOCK_Pfd2
PLL PFD2
kCLOCK_Pfd3
PLL PFD3
◆ _clock_pll [1/2]
enum _clock_pll
PLL name.
kCLOCK_PllArm
PLL ARM
kCLOCK_PllSys
PLL SYS
kCLOCK_PllUsb1
PLL USB1
kCLOCK_PllAudio
PLL Audio
kCLOCK_PllVideo
PLL Video
kCLOCK_PllEnet
PLL Enet0
kCLOCK_PllEnet25M
PLL Enet1
kCLOCK_PllUsb2
PLL USB2
kCLOCK_PllArm
ARM PLL.
kCLOCK_PllSys1
SYS1 PLL, it has a dedicated frequency of 1GHz.
kCLOCK_PllSys2
SYS2 PLL, it has a dedicated frequency of 528MHz.
kCLOCK_PllSys3
SYS3 PLL, it has a dedicated frequency of 480MHz.
kCLOCK_PllAudio
Audio PLL.
kCLOCK_PllVideo
Video PLL.
kCLOCK_PllInvalid
Invalid value.
◆ _clock_pll [2/2]
enum _clock_pll
PLL name.
kCLOCK_PllArm
PLL ARM
kCLOCK_PllSys
PLL SYS
kCLOCK_PllUsb1
PLL USB1
kCLOCK_PllAudio
PLL Audio
kCLOCK_PllVideo
PLL Video
kCLOCK_PllEnet
PLL Enet0
kCLOCK_PllEnet25M
PLL Enet1
kCLOCK_PllUsb2
PLL USB2
kCLOCK_PllArm
ARM PLL.
kCLOCK_PllSys1
kCLOCK_PllSys2
kCLOCK_PllSys3
kCLOCK_PllAudio
Audio PLL.
kCLOCK_PllVideo
Video PLL.
kCLOCK_PllInvalid
Invalid value.
◆ _clock_pll_clk_src [1/2]
PLL clock source, bypass cloco source also.
kCLOCK_PllClkSrc24M
Pll clock source 24M
kCLOCK_PllSrcClkPN
Pll clock source CLK1_P and CLK1_N
kCLOCK_PllClkSrc24M
kCLOCK_PllSrcClkPN
◆ _clock_pll_clk_src [2/2]
kCLOCK_PllClkSrc24M
kCLOCK_PllSrcClkPN
kCLOCK_PllClkSrc24M
kCLOCK_PllSrcClkPN
◆ _clock_pll_post_div
PLL post divider enumeration.
kCLOCK_PllPostDiv8
Divide by 8.
kCLOCK_PllPostDiv4
Divide by 4.
◆ _clock_root [1/2]
The enumerator of clock root.
kCLOCK_Usdhc1ClkRoot
USDHC1 clock root.
kCLOCK_Usdhc2ClkRoot
USDHC2 clock root.
kCLOCK_FlexspiClkRoot
FLEXSPI clock root.
kCLOCK_CsiClkRoot
CSI clock root.
kCLOCK_LpspiClkRoot
LPSPI clock root.
kCLOCK_TraceClkRoot
Trace clock root.
kCLOCK_Sai1ClkRoot
SAI1 clock root.
kCLOCK_Sai2ClkRoot
SAI2 clock root.
kCLOCK_Sai3ClkRoot
SAI3 clock root.
kCLOCK_Lpi2cClkRoot
LPI2C clock root.
kCLOCK_CanClkRoot
CAN clock root.
kCLOCK_UartClkRoot
UART clock root.
kCLOCK_LcdifClkRoot
LCD clock root.
kCLOCK_SpdifClkRoot
SPDIF clock root.
kCLOCK_Flexio1ClkRoot
FLEXIO1 clock root.
kCLOCK_Flexio2ClkRoot
FLEXIO2 clock root.
kCLOCK_Root_M7
CLOCK Root M7.
kCLOCK_Root_M4
CLOCK Root M4.
kCLOCK_Root_Bus
CLOCK Root Bus.
kCLOCK_Root_Bus_Lpsr
CLOCK Root Bus Lpsr.
kCLOCK_Root_Semc
CLOCK Root Semc.
kCLOCK_Root_Cssys
CLOCK Root Cssys.
kCLOCK_Root_Cstrace
CLOCK Root Cstrace.
kCLOCK_Root_M4_Systick
CLOCK Root M4 Systick.
kCLOCK_Root_M7_Systick
CLOCK Root M7 Systick.
kCLOCK_Root_Adc1
CLOCK Root Adc1.
kCLOCK_Root_Adc2
CLOCK Root Adc2.
kCLOCK_Root_Acmp
CLOCK Root Acmp.
kCLOCK_Root_Flexio1
CLOCK Root Flexio1.
kCLOCK_Root_Flexio2
CLOCK Root Flexio2.
kCLOCK_Root_Gpt1
CLOCK Root Gpt1.
kCLOCK_Root_Gpt2
CLOCK Root Gpt2.
kCLOCK_Root_Gpt3
CLOCK Root Gpt3.
kCLOCK_Root_Gpt4
CLOCK Root Gpt4.
kCLOCK_Root_Gpt5
CLOCK Root Gpt5.
kCLOCK_Root_Gpt6
CLOCK Root Gpt6.
kCLOCK_Root_Flexspi1
CLOCK Root Flexspi1.
kCLOCK_Root_Flexspi2
CLOCK Root Flexspi2.
kCLOCK_Root_Can1
CLOCK Root Can1.
kCLOCK_Root_Can2
CLOCK Root Can2.
kCLOCK_Root_Can3
CLOCK Root Can3.
kCLOCK_Root_Lpuart1
CLOCK Root Lpuart1.
kCLOCK_Root_Lpuart2
CLOCK Root Lpuart2.
kCLOCK_Root_Lpuart3
CLOCK Root Lpuart3.
kCLOCK_Root_Lpuart4
CLOCK Root Lpuart4.
kCLOCK_Root_Lpuart5
CLOCK Root Lpuart5.
kCLOCK_Root_Lpuart6
CLOCK Root Lpuart6.
kCLOCK_Root_Lpuart7
CLOCK Root Lpuart7.
kCLOCK_Root_Lpuart8
CLOCK Root Lpuart8.
kCLOCK_Root_Lpuart9
CLOCK Root Lpuart9.
kCLOCK_Root_Lpuart10
CLOCK Root Lpuart10.
kCLOCK_Root_Lpuart11
CLOCK Root Lpuart11.
kCLOCK_Root_Lpuart12
CLOCK Root Lpuart12.
kCLOCK_Root_Lpi2c1
CLOCK Root Lpi2c1.
kCLOCK_Root_Lpi2c2
CLOCK Root Lpi2c2.
kCLOCK_Root_Lpi2c3
CLOCK Root Lpi2c3.
kCLOCK_Root_Lpi2c4
CLOCK Root Lpi2c4.
kCLOCK_Root_Lpi2c5
CLOCK Root Lpi2c5.
kCLOCK_Root_Lpi2c6
CLOCK Root Lpi2c6.
kCLOCK_Root_Lpspi1
CLOCK Root Lpspi1.
kCLOCK_Root_Lpspi2
CLOCK Root Lpspi2.
kCLOCK_Root_Lpspi3
CLOCK Root Lpspi3.
kCLOCK_Root_Lpspi4
CLOCK Root Lpspi4.
kCLOCK_Root_Lpspi5
CLOCK Root Lpspi5.
kCLOCK_Root_Lpspi6
CLOCK Root Lpspi6.
kCLOCK_Root_Emv1
CLOCK Root Emv1.
kCLOCK_Root_Emv2
CLOCK Root Emv2.
kCLOCK_Root_Enet1
CLOCK Root Enet1.
kCLOCK_Root_Enet2
CLOCK Root Enet2.
kCLOCK_Root_Enet_25m
CLOCK Root Enet 25M.
kCLOCK_Root_Enet_Timer1
CLOCK Root Enet Timer1.
kCLOCK_Root_Enet_Timer2
CLOCK Root Enet Timer2.
kCLOCK_Root_Usdhc1
CLOCK Root Usdhc1.
kCLOCK_Root_Usdhc2
CLOCK Root Usdhc2.
kCLOCK_Root_Asrc
CLOCK Root Asrc.
kCLOCK_Root_Mqs
CLOCK Root Mqs.
kCLOCK_Root_Mic
CLOCK Root MIC.
kCLOCK_Root_Spdif
CLOCK Root Spdif
kCLOCK_Root_Sai1
CLOCK Root Sai1.
kCLOCK_Root_Sai2
CLOCK Root Sai2.
kCLOCK_Root_Sai3
CLOCK Root Sai3.
kCLOCK_Root_Sai4
CLOCK Root Sai4.
kCLOCK_Root_Gc355
CLOCK Root Gc355.
kCLOCK_Root_Lcdif
CLOCK Root Lcdif.
kCLOCK_Root_Lcdifv2
CLOCK Root Lcdifv2.
kCLOCK_Root_Mipi_Ref
CLOCK Root Mipi Ref.
kCLOCK_Root_Mipi_Esc
CLOCK Root Mipi Esc.
kCLOCK_Root_Csi2
CLOCK Root Csi2.
kCLOCK_Root_Csi2_Esc
CLOCK Root Csi2 Esc.
kCLOCK_Root_Csi2_Ui
CLOCK Root Csi2 Ui.
kCLOCK_Root_Csi
CLOCK Root Csi.
kCLOCK_Root_Cko1
CLOCK Root CKo1.
kCLOCK_Root_Cko2
CLOCK Root CKo2.
◆ _clock_root [2/2]
Root clock index.
USDHC1 clock root.
USDHC2 clock root.
FLEXSPI clock root.
kCLOCK_CsiClkRoot
CSI clock root.
kCLOCK_LpspiClkRoot
LPSPI clock root.
kCLOCK_TraceClkRoot
Trace clock root.
kCLOCK_Sai1ClkRoot
SAI1 clock root.
kCLOCK_Sai2ClkRoot
SAI2 clock root.
kCLOCK_Sai3ClkRoot
SAI3 clock root.
kCLOCK_Lpi2cClkRoot
LPI2C clock root.
kCLOCK_CanClkRoot
CAN clock root.
kCLOCK_UartClkRoot
UART clock root.
kCLOCK_LcdifClkRoot
LCD clock root.
kCLOCK_SpdifClkRoot
SPDIF clock root.
FLEXIO1 clock root.
FLEXIO2 clock root.
kCLOCK_Root_M7
CLOCK Root M7.
kCLOCK_Root_M4
CLOCK Root M4.
kCLOCK_Root_Bus
CLOCK Root Bus.
kCLOCK_Root_Semc
CLOCK Root Semc.
kCLOCK_Root_Cssys
CLOCK Root Cssys.
kCLOCK_Root_Cstrace
CLOCK Root Cstrace.
kCLOCK_Root_Adc1
CLOCK Root Adc1.
kCLOCK_Root_Adc2
CLOCK Root Adc2.
kCLOCK_Root_Acmp
CLOCK Root Acmp.
kCLOCK_Root_Flexio1
CLOCK Root Flexio1.
kCLOCK_Root_Flexio2
CLOCK Root Flexio2.
kCLOCK_Root_Gpt1
CLOCK Root Gpt1.
kCLOCK_Root_Gpt2
CLOCK Root Gpt2.
kCLOCK_Root_Gpt3
CLOCK Root Gpt3.
kCLOCK_Root_Gpt4
CLOCK Root Gpt4.
kCLOCK_Root_Gpt5
CLOCK Root Gpt5.
kCLOCK_Root_Gpt6
CLOCK Root Gpt6.
kCLOCK_Root_Can1
CLOCK Root Can1.
kCLOCK_Root_Can2
CLOCK Root Can2.
kCLOCK_Root_Can3
CLOCK Root Can3.
kCLOCK_Root_Lpuart1
CLOCK Root Lpuart1.
kCLOCK_Root_Lpuart2
CLOCK Root Lpuart2.
kCLOCK_Root_Lpuart3
CLOCK Root Lpuart3.
kCLOCK_Root_Lpuart4
CLOCK Root Lpuart4.
kCLOCK_Root_Lpuart5
CLOCK Root Lpuart5.
kCLOCK_Root_Lpuart6
CLOCK Root Lpuart6.
kCLOCK_Root_Lpuart7
CLOCK Root Lpuart7.
kCLOCK_Root_Lpuart8
CLOCK Root Lpuart8.
kCLOCK_Root_Lpuart9
CLOCK Root Lpuart9.
kCLOCK_Root_Lpi2c1
CLOCK Root Lpi2c1.
kCLOCK_Root_Lpi2c2
CLOCK Root Lpi2c2.
kCLOCK_Root_Lpi2c3
CLOCK Root Lpi2c3.
kCLOCK_Root_Lpi2c4
CLOCK Root Lpi2c4.
kCLOCK_Root_Lpi2c5
CLOCK Root Lpi2c5.
kCLOCK_Root_Lpi2c6
CLOCK Root Lpi2c6.
kCLOCK_Root_Lpspi1
CLOCK Root Lpspi1.
kCLOCK_Root_Lpspi2
CLOCK Root Lpspi2.
kCLOCK_Root_Lpspi3
CLOCK Root Lpspi3.
kCLOCK_Root_Lpspi4
CLOCK Root Lpspi4.
kCLOCK_Root_Lpspi5
CLOCK Root Lpspi5.
kCLOCK_Root_Lpspi6
CLOCK Root Lpspi6.
kCLOCK_Root_Emv1
CLOCK Root Emv1.
kCLOCK_Root_Emv2
CLOCK Root Emv2.
kCLOCK_Root_Enet1
CLOCK Root Enet1.
kCLOCK_Root_Enet2
CLOCK Root Enet2.
kCLOCK_Root_Usdhc1
CLOCK Root Usdhc1.
kCLOCK_Root_Usdhc2
CLOCK Root Usdhc2.
kCLOCK_Root_Asrc
CLOCK Root Asrc.
kCLOCK_Root_Mqs
CLOCK Root Mqs.
kCLOCK_Root_Mic
CLOCK Root MIC.
kCLOCK_Root_Spdif
CLOCK Root Spdif
kCLOCK_Root_Sai1
CLOCK Root Sai1.
kCLOCK_Root_Sai2
CLOCK Root Sai2.
kCLOCK_Root_Sai3
CLOCK Root Sai3.
kCLOCK_Root_Sai4
CLOCK Root Sai4.
kCLOCK_Root_Gc355
CLOCK Root Gc355.
kCLOCK_Root_Lcdif
CLOCK Root Lcdif.
kCLOCK_Root_Lcdifv2
CLOCK Root Lcdifv2.
kCLOCK_Root_Csi2
CLOCK Root Csi2.
kCLOCK_Root_Csi2_Ui
CLOCK Root Csi2 Ui.
kCLOCK_Root_Csi
CLOCK Root Csi.
kCLOCK_Root_Cko1
CLOCK Root CKo1.
kCLOCK_Root_Cko2
CLOCK Root CKo2.
◆ _clock_root_mux_source
The enumerator of clock roots' clock source mux value.
kCLOCK_M7_ClockRoot_MuxOscRc48MDiv2
M7 mux from MuxOscRc48MDiv2.
kCLOCK_M7_ClockRoot_MuxOsc24MOut
M7 mux from MuxOsc24MOut.
kCLOCK_M7_ClockRoot_MuxOscRc400M
M7 mux from MuxOscRc400M.
kCLOCK_M7_ClockRoot_MuxOscRc16M
M7 mux from MuxOscRc16M.
kCLOCK_M7_ClockRoot_MuxArmPllOut
M7 mux from MuxArmPllOut.
kCLOCK_M7_ClockRoot_MuxSysPll3Out
M7 mux from MuxSysPll3Out.
kCLOCK_M4_ClockRoot_MuxOscRc48MDiv2
M4 mux from MuxOscRc48MDiv2.
kCLOCK_M4_ClockRoot_MuxOsc24MOut
M4 mux from MuxOsc24MOut.
kCLOCK_M4_ClockRoot_MuxOscRc400M
M4 mux from MuxOscRc400M.
kCLOCK_M4_ClockRoot_MuxOscRc16M
M4 mux from MuxOscRc16M.
kCLOCK_M4_ClockRoot_MuxSysPll3Pfd3
M4 mux from MuxSysPll3Pfd3.
kCLOCK_M4_ClockRoot_MuxSysPll3Out
M4 mux from MuxSysPll3Out.
kCLOCK_M4_ClockRoot_MuxSysPll2Out
M4 mux from MuxSysPll2Out.
kCLOCK_M4_ClockRoot_MuxSysPll1Div5
M4 mux from MuxSysPll1Div5.
kCLOCK_BUS_ClockRoot_MuxOscRc48MDiv2
BUS mux from MuxOscRc48MDiv2.
kCLOCK_BUS_ClockRoot_MuxOsc24MOut
BUS mux from MuxOsc24MOut.
kCLOCK_BUS_ClockRoot_MuxOscRc400M
BUS mux from MuxOscRc400M.
kCLOCK_BUS_ClockRoot_MuxOscRc16M
BUS mux from MuxOscRc16M.
kCLOCK_BUS_ClockRoot_MuxSysPll3Out
BUS mux from MuxSysPll3Out.
kCLOCK_BUS_ClockRoot_MuxSysPll1Div5
BUS mux from MuxSysPll1Div5.
kCLOCK_BUS_ClockRoot_MuxSysPll2Out
BUS mux from MuxSysPll2Out.
kCLOCK_BUS_ClockRoot_MuxSysPll2Pfd3
BUS mux from MuxSysPll2Pfd3.
kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc48MDiv2
BUS_LPSR mux from MuxOscRc48MDiv2.
kCLOCK_BUS_LPSR_ClockRoot_MuxOsc24MOut
BUS_LPSR mux from MuxOsc24MOut.
kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc400M
BUS_LPSR mux from MuxOscRc400M.
kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc16M
BUS_LPSR mux from MuxOscRc16M.
kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll3Pfd3
BUS_LPSR mux from MuxSysPll3Pfd3.
kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll3Out
BUS_LPSR mux from MuxSysPll3Out.
kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll2Out
BUS_LPSR mux from MuxSysPll2Out.
kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll1Div5
BUS_LPSR mux from MuxSysPll1Div5.
kCLOCK_SEMC_ClockRoot_MuxOscRc48MDiv2
SEMC mux from MuxOscRc48MDiv2.
kCLOCK_SEMC_ClockRoot_MuxOsc24MOut
SEMC mux from MuxOsc24MOut.
kCLOCK_SEMC_ClockRoot_MuxOscRc400M
SEMC mux from MuxOscRc400M.
kCLOCK_SEMC_ClockRoot_MuxOscRc16M
SEMC mux from MuxOscRc16M.
kCLOCK_SEMC_ClockRoot_MuxSysPll1Div5
SEMC mux from MuxSysPll1Div5.
kCLOCK_SEMC_ClockRoot_MuxSysPll2Out
SEMC mux from MuxSysPll2Out.
kCLOCK_SEMC_ClockRoot_MuxSysPll2Pfd1
SEMC mux from MuxSysPll2Pfd1.
kCLOCK_SEMC_ClockRoot_MuxSysPll3Pfd0
SEMC mux from MuxSysPll3Pfd0.
kCLOCK_CSSYS_ClockRoot_MuxOscRc48MDiv2
CSSYS mux from MuxOscRc48MDiv2.
kCLOCK_CSSYS_ClockRoot_MuxOsc24MOut
CSSYS mux from MuxOsc24MOut.
kCLOCK_CSSYS_ClockRoot_MuxOscRc400M
CSSYS mux from MuxOscRc400M.
kCLOCK_CSSYS_ClockRoot_MuxOscRc16M
CSSYS mux from MuxOscRc16M.
kCLOCK_CSSYS_ClockRoot_MuxSysPll3Div2
CSSYS mux from MuxSysPll3Div2.
kCLOCK_CSSYS_ClockRoot_MuxSysPll1Div5
CSSYS mux from MuxSysPll1Div5.
kCLOCK_CSSYS_ClockRoot_MuxSysPll2Out
CSSYS mux from MuxSysPll2Out.
kCLOCK_CSSYS_ClockRoot_MuxSysPll2Pfd3
CSSYS mux from MuxSysPll2Pfd3.
kCLOCK_CSTRACE_ClockRoot_MuxOscRc48MDiv2
CSTRACE mux from MuxOscRc48MDiv2.
kCLOCK_CSTRACE_ClockRoot_MuxOsc24MOut
CSTRACE mux from MuxOsc24MOut.
kCLOCK_CSTRACE_ClockRoot_MuxOscRc400M
CSTRACE mux from MuxOscRc400M.
kCLOCK_CSTRACE_ClockRoot_MuxOscRc16M
CSTRACE mux from MuxOscRc16M.
kCLOCK_CSTRACE_ClockRoot_MuxSysPll3Div2
CSTRACE mux from MuxSysPll3Div2.
kCLOCK_CSTRACE_ClockRoot_MuxSysPll1Div5
CSTRACE mux from MuxSysPll1Div5.
kCLOCK_CSTRACE_ClockRoot_MuxSysPll2Pfd1
CSTRACE mux from MuxSysPll2Pfd1.
kCLOCK_CSTRACE_ClockRoot_MuxSysPll2Out
CSTRACE mux from MuxSysPll2Out.
kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc48MDiv2
M4_SYSTICK mux from MuxOscRc48MDiv2.
kCLOCK_M4_SYSTICK_ClockRoot_MuxOsc24MOut
M4_SYSTICK mux from MuxOsc24MOut.
kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc400M
M4_SYSTICK mux from MuxOscRc400M.
kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc16M
M4_SYSTICK mux from MuxOscRc16M.
kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll3Pfd3
M4_SYSTICK mux from MuxSysPll3Pfd3.
kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll3Out
M4_SYSTICK mux from MuxSysPll3Out.
kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll2Pfd0
M4_SYSTICK mux from MuxSysPll2Pfd0.
kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll1Div5
M4_SYSTICK mux from MuxSysPll1Div5.
kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc48MDiv2
M7_SYSTICK mux from MuxOscRc48MDiv2.
kCLOCK_M7_SYSTICK_ClockRoot_MuxOsc24MOut
M7_SYSTICK mux from MuxOsc24MOut.
kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc400M
M7_SYSTICK mux from MuxOscRc400M.
kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc16M
M7_SYSTICK mux from MuxOscRc16M.
kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll2Out
M7_SYSTICK mux from MuxSysPll2Out.
kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll3Div2
M7_SYSTICK mux from MuxSysPll3Div2.
kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll1Div5
M7_SYSTICK mux from MuxSysPll1Div5.
kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll2Pfd0
M7_SYSTICK mux from MuxSysPll2Pfd0.
kCLOCK_ADC1_ClockRoot_MuxOscRc48MDiv2
ADC1 mux from MuxOscRc48MDiv2.
kCLOCK_ADC1_ClockRoot_MuxOsc24MOut
ADC1 mux from MuxOsc24MOut.
kCLOCK_ADC1_ClockRoot_MuxOscRc400M
ADC1 mux from MuxOscRc400M.
kCLOCK_ADC1_ClockRoot_MuxOscRc16M
ADC1 mux from MuxOscRc16M.
kCLOCK_ADC1_ClockRoot_MuxSysPll3Div2
ADC1 mux from MuxSysPll3Div2.
kCLOCK_ADC1_ClockRoot_MuxSysPll1Div5
ADC1 mux from MuxSysPll1Div5.
kCLOCK_ADC1_ClockRoot_MuxSysPll2Out
ADC1 mux from MuxSysPll2Out.
kCLOCK_ADC1_ClockRoot_MuxSysPll2Pfd3
ADC1 mux from MuxSysPll2Pfd3.
kCLOCK_ADC2_ClockRoot_MuxOscRc48MDiv2
ADC2 mux from MuxOscRc48MDiv2.
kCLOCK_ADC2_ClockRoot_MuxOsc24MOut
ADC2 mux from MuxOsc24MOut.
kCLOCK_ADC2_ClockRoot_MuxOscRc400M
ADC2 mux from MuxOscRc400M.
kCLOCK_ADC2_ClockRoot_MuxOscRc16M
ADC2 mux from MuxOscRc16M.
kCLOCK_ADC2_ClockRoot_MuxSysPll3Div2
ADC2 mux from MuxSysPll3Div2.
kCLOCK_ADC2_ClockRoot_MuxSysPll1Div5
ADC2 mux from MuxSysPll1Div5.
kCLOCK_ADC2_ClockRoot_MuxSysPll2Out
ADC2 mux from MuxSysPll2Out.
kCLOCK_ADC2_ClockRoot_MuxSysPll2Pfd3
ADC2 mux from MuxSysPll2Pfd3.
kCLOCK_ACMP_ClockRoot_MuxOscRc48MDiv2
ACMP mux from MuxOscRc48MDiv2.
kCLOCK_ACMP_ClockRoot_MuxOsc24MOut
ACMP mux from MuxOsc24MOut.
kCLOCK_ACMP_ClockRoot_MuxOscRc400M
ACMP mux from MuxOscRc400M.
kCLOCK_ACMP_ClockRoot_MuxOscRc16M
ACMP mux from MuxOscRc16M.
kCLOCK_ACMP_ClockRoot_MuxSysPll3Out
ACMP mux from MuxSysPll3Out.
kCLOCK_ACMP_ClockRoot_MuxSysPll1Div5
ACMP mux from MuxSysPll1Div5.
kCLOCK_ACMP_ClockRoot_MuxAudioPllOut
ACMP mux from MuxAudioPllOut.
kCLOCK_ACMP_ClockRoot_MuxSysPll2Pfd3
ACMP mux from MuxSysPll2Pfd3.
kCLOCK_FLEXIO1_ClockRoot_MuxOscRc48MDiv2
FLEXIO1 mux from MuxOscRc48MDiv2.
kCLOCK_FLEXIO1_ClockRoot_MuxOsc24MOut
FLEXIO1 mux from MuxOsc24MOut.
kCLOCK_FLEXIO1_ClockRoot_MuxOscRc400M
FLEXIO1 mux from MuxOscRc400M.
kCLOCK_FLEXIO1_ClockRoot_MuxOscRc16M
FLEXIO1 mux from MuxOscRc16M.
kCLOCK_FLEXIO1_ClockRoot_MuxSysPll3Div2
FLEXIO1 mux from MuxSysPll3Div2.
kCLOCK_FLEXIO1_ClockRoot_MuxSysPll1Div5
FLEXIO1 mux from MuxSysPll1Div5.
kCLOCK_FLEXIO1_ClockRoot_MuxSysPll2Out
FLEXIO1 mux from MuxSysPll2Out.
kCLOCK_FLEXIO1_ClockRoot_MuxSysPll2Pfd3
FLEXIO1 mux from MuxSysPll2Pfd3.
kCLOCK_FLEXIO2_ClockRoot_MuxOscRc48MDiv2
FLEXIO2 mux from MuxOscRc48MDiv2.
kCLOCK_FLEXIO2_ClockRoot_MuxOsc24MOut
FLEXIO2 mux from MuxOsc24MOut.
kCLOCK_FLEXIO2_ClockRoot_MuxOscRc400M
FLEXIO2 mux from MuxOscRc400M.
kCLOCK_FLEXIO2_ClockRoot_MuxOscRc16M
FLEXIO2 mux from MuxOscRc16M.
kCLOCK_FLEXIO2_ClockRoot_MuxSysPll3Div2
FLEXIO2 mux from MuxSysPll3Div2.
kCLOCK_FLEXIO2_ClockRoot_MuxSysPll1Div5
FLEXIO2 mux from MuxSysPll1Div5.
kCLOCK_FLEXIO2_ClockRoot_MuxSysPll2Out
FLEXIO2 mux from MuxSysPll2Out.
kCLOCK_FLEXIO2_ClockRoot_MuxSysPll2Pfd3
FLEXIO2 mux from MuxSysPll2Pfd3.
kCLOCK_GPT1_ClockRoot_MuxOscRc48MDiv2
GPT1 mux from MuxOscRc48MDiv2.
kCLOCK_GPT1_ClockRoot_MuxOsc24MOut
GPT1 mux from MuxOsc24MOut.
kCLOCK_GPT1_ClockRoot_MuxOscRc400M
GPT1 mux from MuxOscRc400M.
kCLOCK_GPT1_ClockRoot_MuxOscRc16M
GPT1 mux from MuxOscRc16M.
kCLOCK_GPT1_ClockRoot_MuxSysPll3Div2
GPT1 mux from MuxSysPll3Div2.
kCLOCK_GPT1_ClockRoot_MuxSysPll1Div5
GPT1 mux from MuxSysPll1Div5.
kCLOCK_GPT1_ClockRoot_MuxSysPll3Pfd2
GPT1 mux from MuxSysPll3Pfd2.
kCLOCK_GPT1_ClockRoot_MuxSysPll3Pfd3
GPT1 mux from MuxSysPll3Pfd3.
kCLOCK_GPT2_ClockRoot_MuxOscRc48MDiv2
GPT2 mux from MuxOscRc48MDiv2.
kCLOCK_GPT2_ClockRoot_MuxOsc24MOut
GPT2 mux from MuxOsc24MOut.
kCLOCK_GPT2_ClockRoot_MuxOscRc400M
GPT2 mux from MuxOscRc400M.
kCLOCK_GPT2_ClockRoot_MuxOscRc16M
GPT2 mux from MuxOscRc16M.
kCLOCK_GPT2_ClockRoot_MuxSysPll3Div2
GPT2 mux from MuxSysPll3Div2.
kCLOCK_GPT2_ClockRoot_MuxSysPll1Div5
GPT2 mux from MuxSysPll1Div5.
kCLOCK_GPT2_ClockRoot_MuxAudioPllOut
GPT2 mux from MuxAudioPllOut.
kCLOCK_GPT2_ClockRoot_MuxVideoPllOut
GPT2 mux from MuxVideoPllOut.
kCLOCK_GPT3_ClockRoot_MuxOscRc48MDiv2
GPT3 mux from MuxOscRc48MDiv2.
kCLOCK_GPT3_ClockRoot_MuxOsc24MOut
GPT3 mux from MuxOsc24MOut.
kCLOCK_GPT3_ClockRoot_MuxOscRc400M
GPT3 mux from MuxOscRc400M.
kCLOCK_GPT3_ClockRoot_MuxOscRc16M
GPT3 mux from MuxOscRc16M.
kCLOCK_GPT3_ClockRoot_MuxSysPll3Div2
GPT3 mux from MuxSysPll3Div2.
kCLOCK_GPT3_ClockRoot_MuxSysPll1Div5
GPT3 mux from MuxSysPll1Div5.
kCLOCK_GPT3_ClockRoot_MuxAudioPllOut
GPT3 mux from MuxAudioPllOut.
kCLOCK_GPT3_ClockRoot_MuxVideoPllOut
GPT3 mux from MuxVideoPllOut.
kCLOCK_GPT4_ClockRoot_MuxOscRc48MDiv2
GPT4 mux from MuxOscRc48MDiv2.
kCLOCK_GPT4_ClockRoot_MuxOsc24MOut
GPT4 mux from MuxOsc24MOut.
kCLOCK_GPT4_ClockRoot_MuxOscRc400M
GPT4 mux from MuxOscRc400M.
kCLOCK_GPT4_ClockRoot_MuxOscRc16M
GPT4 mux from MuxOscRc16M.
kCLOCK_GPT4_ClockRoot_MuxSysPll3Div2
GPT4 mux from MuxSysPll3Div2.
kCLOCK_GPT4_ClockRoot_MuxSysPll1Div5
GPT4 mux from MuxSysPll1Div5.
kCLOCK_GPT4_ClockRoot_MuxSysPll3Pfd2
GPT4 mux from MuxSysPll3Pfd2.
kCLOCK_GPT4_ClockRoot_MuxSysPll3Pfd3
GPT4 mux from MuxSysPll3Pfd3.
kCLOCK_GPT5_ClockRoot_MuxOscRc48MDiv2
GPT5 mux from MuxOscRc48MDiv2.
kCLOCK_GPT5_ClockRoot_MuxOsc24MOut
GPT5 mux from MuxOsc24MOut.
kCLOCK_GPT5_ClockRoot_MuxOscRc400M
GPT5 mux from MuxOscRc400M.
kCLOCK_GPT5_ClockRoot_MuxOscRc16M
GPT5 mux from MuxOscRc16M.
kCLOCK_GPT5_ClockRoot_MuxSysPll3Div2
GPT5 mux from MuxSysPll3Div2.
kCLOCK_GPT5_ClockRoot_MuxSysPll1Div5
GPT5 mux from MuxSysPll1Div5.
kCLOCK_GPT5_ClockRoot_MuxSysPll3Pfd2
GPT5 mux from MuxSysPll3Pfd2.
kCLOCK_GPT5_ClockRoot_MuxSysPll3Pfd3
GPT5 mux from MuxSysPll3Pfd3.
kCLOCK_GPT6_ClockRoot_MuxOscRc48MDiv2
GPT6 mux from MuxOscRc48MDiv2.
kCLOCK_GPT6_ClockRoot_MuxOsc24MOut
GPT6 mux from MuxOsc24MOut.
kCLOCK_GPT6_ClockRoot_MuxOscRc400M
GPT6 mux from MuxOscRc400M.
kCLOCK_GPT6_ClockRoot_MuxOscRc16M
GPT6 mux from MuxOscRc16M.
kCLOCK_GPT6_ClockRoot_MuxSysPll3Div2
GPT6 mux from MuxSysPll3Div2.
kCLOCK_GPT6_ClockRoot_MuxSysPll1Div5
GPT6 mux from MuxSysPll1Div5.
kCLOCK_GPT6_ClockRoot_MuxSysPll3Pfd2
GPT6 mux from MuxSysPll3Pfd2.
kCLOCK_GPT6_ClockRoot_MuxSysPll3Pfd3
GPT6 mux from MuxSysPll3Pfd3.
kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc48MDiv2
FLEXSPI1 mux from MuxOscRc48MDiv2.
kCLOCK_FLEXSPI1_ClockRoot_MuxOsc24MOut
FLEXSPI1 mux from MuxOsc24MOut.
kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc400M
FLEXSPI1 mux from MuxOscRc400M.
kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc16M
FLEXSPI1 mux from MuxOscRc16M.
kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll3Pfd0
FLEXSPI1 mux from MuxSysPll3Pfd0.
kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll2Out
FLEXSPI1 mux from MuxSysPll2Out.
kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll2Pfd2
FLEXSPI1 mux from MuxSysPll2Pfd2.
kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll3Out
FLEXSPI1 mux from MuxSysPll3Out.
kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc48MDiv2
FLEXSPI2 mux from MuxOscRc48MDiv2.
kCLOCK_FLEXSPI2_ClockRoot_MuxOsc24MOut
FLEXSPI2 mux from MuxOsc24MOut.
kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc400M
FLEXSPI2 mux from MuxOscRc400M.
kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc16M
FLEXSPI2 mux from MuxOscRc16M.
kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll3Pfd0
FLEXSPI2 mux from MuxSysPll3Pfd0.
kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll2Out
FLEXSPI2 mux from MuxSysPll2Out.
kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll2Pfd2
FLEXSPI2 mux from MuxSysPll2Pfd2.
kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll3Out
FLEXSPI2 mux from MuxSysPll3Out.
kCLOCK_CAN1_ClockRoot_MuxOscRc48MDiv2
CAN1 mux from MuxOscRc48MDiv2.
kCLOCK_CAN1_ClockRoot_MuxOsc24MOut
CAN1 mux from MuxOsc24MOut.
kCLOCK_CAN1_ClockRoot_MuxOscRc400M
CAN1 mux from MuxOscRc400M.
kCLOCK_CAN1_ClockRoot_MuxOscRc16M
CAN1 mux from MuxOscRc16M.
kCLOCK_CAN1_ClockRoot_MuxSysPll3Div2
CAN1 mux from MuxSysPll3Div2.
kCLOCK_CAN1_ClockRoot_MuxSysPll1Div5
CAN1 mux from MuxSysPll1Div5.
kCLOCK_CAN1_ClockRoot_MuxSysPll2Out
CAN1 mux from MuxSysPll2Out.
kCLOCK_CAN1_ClockRoot_MuxSysPll2Pfd3
CAN1 mux from MuxSysPll2Pfd3.
kCLOCK_CAN2_ClockRoot_MuxOscRc48MDiv2
CAN2 mux from MuxOscRc48MDiv2.
kCLOCK_CAN2_ClockRoot_MuxOsc24MOut
CAN2 mux from MuxOsc24MOut.
kCLOCK_CAN2_ClockRoot_MuxOscRc400M
CAN2 mux from MuxOscRc400M.
kCLOCK_CAN2_ClockRoot_MuxOscRc16M
CAN2 mux from MuxOscRc16M.
kCLOCK_CAN2_ClockRoot_MuxSysPll3Div2
CAN2 mux from MuxSysPll3Div2.
kCLOCK_CAN2_ClockRoot_MuxSysPll1Div5
CAN2 mux from MuxSysPll1Div5.
kCLOCK_CAN2_ClockRoot_MuxSysPll2Out
CAN2 mux from MuxSysPll2Out.
kCLOCK_CAN2_ClockRoot_MuxSysPll2Pfd3
CAN2 mux from MuxSysPll2Pfd3.
kCLOCK_CAN3_ClockRoot_MuxOscRc48MDiv2
CAN3 mux from MuxOscRc48MDiv2.
kCLOCK_CAN3_ClockRoot_MuxOsc24MOut
CAN3 mux from MuxOsc24MOut.
kCLOCK_CAN3_ClockRoot_MuxOscRc400M
CAN3 mux from MuxOscRc400M.
kCLOCK_CAN3_ClockRoot_MuxOscRc16M
CAN3 mux from MuxOscRc16M.
kCLOCK_CAN3_ClockRoot_MuxSysPll3Pfd3
CAN3 mux from MuxSysPll3Pfd3.
kCLOCK_CAN3_ClockRoot_MuxSysPll3Out
CAN3 mux from MuxSysPll3Out.
kCLOCK_CAN3_ClockRoot_MuxSysPll2Pfd3
CAN3 mux from MuxSysPll2Pfd3.
kCLOCK_CAN3_ClockRoot_MuxSysPll1Div5
CAN3 mux from MuxSysPll1Div5.
kCLOCK_LPUART1_ClockRoot_MuxOscRc48MDiv2
LPUART1 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART1_ClockRoot_MuxOsc24MOut
LPUART1 mux from MuxOsc24MOut.
kCLOCK_LPUART1_ClockRoot_MuxOscRc400M
LPUART1 mux from MuxOscRc400M.
kCLOCK_LPUART1_ClockRoot_MuxOscRc16M
LPUART1 mux from MuxOscRc16M.
kCLOCK_LPUART1_ClockRoot_MuxSysPll3Div2
LPUART1 mux from MuxSysPll3Div2.
kCLOCK_LPUART1_ClockRoot_MuxSysPll1Div5
LPUART1 mux from MuxSysPll1Div5.
kCLOCK_LPUART1_ClockRoot_MuxSysPll2Out
LPUART1 mux from MuxSysPll2Out.
kCLOCK_LPUART1_ClockRoot_MuxSysPll2Pfd3
LPUART1 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART2_ClockRoot_MuxOscRc48MDiv2
LPUART2 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART2_ClockRoot_MuxOsc24MOut
LPUART2 mux from MuxOsc24MOut.
kCLOCK_LPUART2_ClockRoot_MuxOscRc400M
LPUART2 mux from MuxOscRc400M.
kCLOCK_LPUART2_ClockRoot_MuxOscRc16M
LPUART2 mux from MuxOscRc16M.
kCLOCK_LPUART2_ClockRoot_MuxSysPll3Div2
LPUART2 mux from MuxSysPll3Div2.
kCLOCK_LPUART2_ClockRoot_MuxSysPll1Div5
LPUART2 mux from MuxSysPll1Div5.
kCLOCK_LPUART2_ClockRoot_MuxSysPll2Out
LPUART2 mux from MuxSysPll2Out.
kCLOCK_LPUART2_ClockRoot_MuxSysPll2Pfd3
LPUART2 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART3_ClockRoot_MuxOscRc48MDiv2
LPUART3 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART3_ClockRoot_MuxOsc24MOut
LPUART3 mux from MuxOsc24MOut.
kCLOCK_LPUART3_ClockRoot_MuxOscRc400M
LPUART3 mux from MuxOscRc400M.
kCLOCK_LPUART3_ClockRoot_MuxOscRc16M
LPUART3 mux from MuxOscRc16M.
kCLOCK_LPUART3_ClockRoot_MuxSysPll3Div2
LPUART3 mux from MuxSysPll3Div2.
kCLOCK_LPUART3_ClockRoot_MuxSysPll1Div5
LPUART3 mux from MuxSysPll1Div5.
kCLOCK_LPUART3_ClockRoot_MuxSysPll2Out
LPUART3 mux from MuxSysPll2Out.
kCLOCK_LPUART3_ClockRoot_MuxSysPll2Pfd3
LPUART3 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART4_ClockRoot_MuxOscRc48MDiv2
LPUART4 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART4_ClockRoot_MuxOsc24MOut
LPUART4 mux from MuxOsc24MOut.
kCLOCK_LPUART4_ClockRoot_MuxOscRc400M
LPUART4 mux from MuxOscRc400M.
kCLOCK_LPUART4_ClockRoot_MuxOscRc16M
LPUART4 mux from MuxOscRc16M.
kCLOCK_LPUART4_ClockRoot_MuxSysPll3Div2
LPUART4 mux from MuxSysPll3Div2.
kCLOCK_LPUART4_ClockRoot_MuxSysPll1Div5
LPUART4 mux from MuxSysPll1Div5.
kCLOCK_LPUART4_ClockRoot_MuxSysPll2Out
LPUART4 mux from MuxSysPll2Out.
kCLOCK_LPUART4_ClockRoot_MuxSysPll2Pfd3
LPUART4 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART5_ClockRoot_MuxOscRc48MDiv2
LPUART5 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART5_ClockRoot_MuxOsc24MOut
LPUART5 mux from MuxOsc24MOut.
kCLOCK_LPUART5_ClockRoot_MuxOscRc400M
LPUART5 mux from MuxOscRc400M.
kCLOCK_LPUART5_ClockRoot_MuxOscRc16M
LPUART5 mux from MuxOscRc16M.
kCLOCK_LPUART5_ClockRoot_MuxSysPll3Div2
LPUART5 mux from MuxSysPll3Div2.
kCLOCK_LPUART5_ClockRoot_MuxSysPll1Div5
LPUART5 mux from MuxSysPll1Div5.
kCLOCK_LPUART5_ClockRoot_MuxSysPll2Out
LPUART5 mux from MuxSysPll2Out.
kCLOCK_LPUART5_ClockRoot_MuxSysPll2Pfd3
LPUART5 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART6_ClockRoot_MuxOscRc48MDiv2
LPUART6 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART6_ClockRoot_MuxOsc24MOut
LPUART6 mux from MuxOsc24MOut.
kCLOCK_LPUART6_ClockRoot_MuxOscRc400M
LPUART6 mux from MuxOscRc400M.
kCLOCK_LPUART6_ClockRoot_MuxOscRc16M
LPUART6 mux from MuxOscRc16M.
kCLOCK_LPUART6_ClockRoot_MuxSysPll3Div2
LPUART6 mux from MuxSysPll3Div2.
kCLOCK_LPUART6_ClockRoot_MuxSysPll1Div5
LPUART6 mux from MuxSysPll1Div5.
kCLOCK_LPUART6_ClockRoot_MuxSysPll2Out
LPUART6 mux from MuxSysPll2Out.
kCLOCK_LPUART6_ClockRoot_MuxSysPll2Pfd3
LPUART6 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART7_ClockRoot_MuxOscRc48MDiv2
LPUART7 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART7_ClockRoot_MuxOsc24MOut
LPUART7 mux from MuxOsc24MOut.
kCLOCK_LPUART7_ClockRoot_MuxOscRc400M
LPUART7 mux from MuxOscRc400M.
kCLOCK_LPUART7_ClockRoot_MuxOscRc16M
LPUART7 mux from MuxOscRc16M.
kCLOCK_LPUART7_ClockRoot_MuxSysPll3Div2
LPUART7 mux from MuxSysPll3Div2.
kCLOCK_LPUART7_ClockRoot_MuxSysPll1Div5
LPUART7 mux from MuxSysPll1Div5.
kCLOCK_LPUART7_ClockRoot_MuxSysPll2Out
LPUART7 mux from MuxSysPll2Out.
kCLOCK_LPUART7_ClockRoot_MuxSysPll2Pfd3
LPUART7 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART8_ClockRoot_MuxOscRc48MDiv2
LPUART8 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART8_ClockRoot_MuxOsc24MOut
LPUART8 mux from MuxOsc24MOut.
kCLOCK_LPUART8_ClockRoot_MuxOscRc400M
LPUART8 mux from MuxOscRc400M.
kCLOCK_LPUART8_ClockRoot_MuxOscRc16M
LPUART8 mux from MuxOscRc16M.
kCLOCK_LPUART8_ClockRoot_MuxSysPll3Div2
LPUART8 mux from MuxSysPll3Div2.
kCLOCK_LPUART8_ClockRoot_MuxSysPll1Div5
LPUART8 mux from MuxSysPll1Div5.
kCLOCK_LPUART8_ClockRoot_MuxSysPll2Out
LPUART8 mux from MuxSysPll2Out.
kCLOCK_LPUART8_ClockRoot_MuxSysPll2Pfd3
LPUART8 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART9_ClockRoot_MuxOscRc48MDiv2
LPUART9 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART9_ClockRoot_MuxOsc24MOut
LPUART9 mux from MuxOsc24MOut.
kCLOCK_LPUART9_ClockRoot_MuxOscRc400M
LPUART9 mux from MuxOscRc400M.
kCLOCK_LPUART9_ClockRoot_MuxOscRc16M
LPUART9 mux from MuxOscRc16M.
kCLOCK_LPUART9_ClockRoot_MuxSysPll3Div2
LPUART9 mux from MuxSysPll3Div2.
kCLOCK_LPUART9_ClockRoot_MuxSysPll1Div5
LPUART9 mux from MuxSysPll1Div5.
kCLOCK_LPUART9_ClockRoot_MuxSysPll2Out
LPUART9 mux from MuxSysPll2Out.
kCLOCK_LPUART9_ClockRoot_MuxSysPll2Pfd3
LPUART9 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART10_ClockRoot_MuxOscRc48MDiv2
LPUART10 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART10_ClockRoot_MuxOsc24MOut
LPUART10 mux from MuxOsc24MOut.
kCLOCK_LPUART10_ClockRoot_MuxOscRc400M
LPUART10 mux from MuxOscRc400M.
kCLOCK_LPUART10_ClockRoot_MuxOscRc16M
LPUART10 mux from MuxOscRc16M.
kCLOCK_LPUART10_ClockRoot_MuxSysPll3Div2
LPUART10 mux from MuxSysPll3Div2.
kCLOCK_LPUART10_ClockRoot_MuxSysPll1Div5
LPUART10 mux from MuxSysPll1Div5.
kCLOCK_LPUART10_ClockRoot_MuxSysPll2Out
LPUART10 mux from MuxSysPll2Out.
kCLOCK_LPUART10_ClockRoot_MuxSysPll2Pfd3
LPUART10 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART11_ClockRoot_MuxOscRc48MDiv2
LPUART11 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART11_ClockRoot_MuxOsc24MOut
LPUART11 mux from MuxOsc24MOut.
kCLOCK_LPUART11_ClockRoot_MuxOscRc400M
LPUART11 mux from MuxOscRc400M.
kCLOCK_LPUART11_ClockRoot_MuxOscRc16M
LPUART11 mux from MuxOscRc16M.
kCLOCK_LPUART11_ClockRoot_MuxSysPll3Pfd3
LPUART11 mux from MuxSysPll3Pfd3.
kCLOCK_LPUART11_ClockRoot_MuxSysPll3Out
LPUART11 mux from MuxSysPll3Out.
kCLOCK_LPUART11_ClockRoot_MuxSysPll2Pfd3
LPUART11 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART11_ClockRoot_MuxSysPll1Div5
LPUART11 mux from MuxSysPll1Div5.
kCLOCK_LPUART12_ClockRoot_MuxOscRc48MDiv2
LPUART12 mux from MuxOscRc48MDiv2.
kCLOCK_LPUART12_ClockRoot_MuxOsc24MOut
LPUART12 mux from MuxOsc24MOut.
kCLOCK_LPUART12_ClockRoot_MuxOscRc400M
LPUART12 mux from MuxOscRc400M.
kCLOCK_LPUART12_ClockRoot_MuxOscRc16M
LPUART12 mux from MuxOscRc16M.
kCLOCK_LPUART12_ClockRoot_MuxSysPll3Pfd3
LPUART12 mux from MuxSysPll3Pfd3.
kCLOCK_LPUART12_ClockRoot_MuxSysPll3Out
LPUART12 mux from MuxSysPll3Out.
kCLOCK_LPUART12_ClockRoot_MuxSysPll2Pfd3
LPUART12 mux from MuxSysPll2Pfd3.
kCLOCK_LPUART12_ClockRoot_MuxSysPll1Div5
LPUART12 mux from MuxSysPll1Div5.
kCLOCK_LPI2C1_ClockRoot_MuxOscRc48MDiv2
LPI2C1 mux from MuxOscRc48MDiv2.
kCLOCK_LPI2C1_ClockRoot_MuxOsc24MOut
LPI2C1 mux from MuxOsc24MOut.
kCLOCK_LPI2C1_ClockRoot_MuxOscRc400M
LPI2C1 mux from MuxOscRc400M.
kCLOCK_LPI2C1_ClockRoot_MuxOscRc16M
LPI2C1 mux from MuxOscRc16M.
kCLOCK_LPI2C1_ClockRoot_MuxSysPll3Div2
LPI2C1 mux from MuxSysPll3Div2.
kCLOCK_LPI2C1_ClockRoot_MuxSysPll1Div5
LPI2C1 mux from MuxSysPll1Div5.
kCLOCK_LPI2C1_ClockRoot_MuxSysPll2Out
LPI2C1 mux from MuxSysPll2Out.
kCLOCK_LPI2C1_ClockRoot_MuxSysPll2Pfd3
LPI2C1 mux from MuxSysPll2Pfd3.
kCLOCK_LPI2C2_ClockRoot_MuxOscRc48MDiv2
LPI2C2 mux from MuxOscRc48MDiv2.
kCLOCK_LPI2C2_ClockRoot_MuxOsc24MOut
LPI2C2 mux from MuxOsc24MOut.
kCLOCK_LPI2C2_ClockRoot_MuxOscRc400M
LPI2C2 mux from MuxOscRc400M.
kCLOCK_LPI2C2_ClockRoot_MuxOscRc16M
LPI2C2 mux from MuxOscRc16M.
kCLOCK_LPI2C2_ClockRoot_MuxSysPll3Div2
LPI2C2 mux from MuxSysPll3Div2.
kCLOCK_LPI2C2_ClockRoot_MuxSysPll1Div5
LPI2C2 mux from MuxSysPll1Div5.
kCLOCK_LPI2C2_ClockRoot_MuxSysPll2Out
LPI2C2 mux from MuxSysPll2Out.
kCLOCK_LPI2C2_ClockRoot_MuxSysPll2Pfd3
LPI2C2 mux from MuxSysPll2Pfd3.
kCLOCK_LPI2C3_ClockRoot_MuxOscRc48MDiv2
LPI2C3 mux from MuxOscRc48MDiv2.
kCLOCK_LPI2C3_ClockRoot_MuxOsc24MOut
LPI2C3 mux from MuxOsc24MOut.
kCLOCK_LPI2C3_ClockRoot_MuxOscRc400M
LPI2C3 mux from MuxOscRc400M.
kCLOCK_LPI2C3_ClockRoot_MuxOscRc16M
LPI2C3 mux from MuxOscRc16M.
kCLOCK_LPI2C3_ClockRoot_MuxSysPll3Div2
LPI2C3 mux from MuxSysPll3Div2.
kCLOCK_LPI2C3_ClockRoot_MuxSysPll1Div5
LPI2C3 mux from MuxSysPll1Div5.
kCLOCK_LPI2C3_ClockRoot_MuxSysPll2Out
LPI2C3 mux from MuxSysPll2Out.
kCLOCK_LPI2C3_ClockRoot_MuxSysPll2Pfd3
LPI2C3 mux from MuxSysPll2Pfd3.
kCLOCK_LPI2C4_ClockRoot_MuxOscRc48MDiv2
LPI2C4 mux from MuxOscRc48MDiv2.
kCLOCK_LPI2C4_ClockRoot_MuxOsc24MOut
LPI2C4 mux from MuxOsc24MOut.
kCLOCK_LPI2C4_ClockRoot_MuxOscRc400M
LPI2C4 mux from MuxOscRc400M.
kCLOCK_LPI2C4_ClockRoot_MuxOscRc16M
LPI2C4 mux from MuxOscRc16M.
kCLOCK_LPI2C4_ClockRoot_MuxSysPll3Div2
LPI2C4 mux from MuxSysPll3Div2.
kCLOCK_LPI2C4_ClockRoot_MuxSysPll1Div5
LPI2C4 mux from MuxSysPll1Div5.
kCLOCK_LPI2C4_ClockRoot_MuxSysPll2Out
LPI2C4 mux from MuxSysPll2Out.
kCLOCK_LPI2C4_ClockRoot_MuxSysPll2Pfd3
LPI2C4 mux from MuxSysPll2Pfd3.
kCLOCK_LPI2C5_ClockRoot_MuxOscRc48MDiv2
LPI2C5 mux from MuxOscRc48MDiv2.
kCLOCK_LPI2C5_ClockRoot_MuxOsc24MOut
LPI2C5 mux from MuxOsc24MOut.
kCLOCK_LPI2C5_ClockRoot_MuxOscRc400M
LPI2C5 mux from MuxOscRc400M.
kCLOCK_LPI2C5_ClockRoot_MuxOscRc16M
LPI2C5 mux from MuxOscRc16M.
kCLOCK_LPI2C5_ClockRoot_MuxSysPll3Pfd3
LPI2C5 mux from MuxSysPll3Pfd3.
kCLOCK_LPI2C5_ClockRoot_MuxSysPll3Out
LPI2C5 mux from MuxSysPll3Out.
kCLOCK_LPI2C5_ClockRoot_MuxSysPll2Pfd3
LPI2C5 mux from MuxSysPll2Pfd3.
kCLOCK_LPI2C5_ClockRoot_MuxSysPll1Div5
LPI2C5 mux from MuxSysPll1Div5.
kCLOCK_LPI2C6_ClockRoot_MuxOscRc48MDiv2
LPI2C6 mux from MuxOscRc48MDiv2.
kCLOCK_LPI2C6_ClockRoot_MuxOsc24MOut
LPI2C6 mux from MuxOsc24MOut.
kCLOCK_LPI2C6_ClockRoot_MuxOscRc400M
LPI2C6 mux from MuxOscRc400M.
kCLOCK_LPI2C6_ClockRoot_MuxOscRc16M
LPI2C6 mux from MuxOscRc16M.
kCLOCK_LPI2C6_ClockRoot_MuxSysPll3Pfd3
LPI2C6 mux from MuxSysPll3Pfd3.
kCLOCK_LPI2C6_ClockRoot_MuxSysPll3Out
LPI2C6 mux from MuxSysPll3Out.
kCLOCK_LPI2C6_ClockRoot_MuxSysPll2Pfd3
LPI2C6 mux from MuxSysPll2Pfd3.
kCLOCK_LPI2C6_ClockRoot_MuxSysPll1Div5
LPI2C6 mux from MuxSysPll1Div5.
kCLOCK_LPSPI1_ClockRoot_MuxOscRc48MDiv2
LPSPI1 mux from MuxOscRc48MDiv2.
kCLOCK_LPSPI1_ClockRoot_MuxOsc24MOut
LPSPI1 mux from MuxOsc24MOut.
kCLOCK_LPSPI1_ClockRoot_MuxOscRc400M
LPSPI1 mux from MuxOscRc400M.
kCLOCK_LPSPI1_ClockRoot_MuxOscRc16M
LPSPI1 mux from MuxOscRc16M.
kCLOCK_LPSPI1_ClockRoot_MuxSysPll3Pfd2
LPSPI1 mux from MuxSysPll3Pfd2.
kCLOCK_LPSPI1_ClockRoot_MuxSysPll1Div5
LPSPI1 mux from MuxSysPll1Div5.
kCLOCK_LPSPI1_ClockRoot_MuxSysPll2Out
LPSPI1 mux from MuxSysPll2Out.
kCLOCK_LPSPI1_ClockRoot_MuxSysPll2Pfd3
LPSPI1 mux from MuxSysPll2Pfd3.
kCLOCK_LPSPI2_ClockRoot_MuxOscRc48MDiv2
LPSPI2 mux from MuxOscRc48MDiv2.
kCLOCK_LPSPI2_ClockRoot_MuxOsc24MOut
LPSPI2 mux from MuxOsc24MOut.
kCLOCK_LPSPI2_ClockRoot_MuxOscRc400M
LPSPI2 mux from MuxOscRc400M.
kCLOCK_LPSPI2_ClockRoot_MuxOscRc16M
LPSPI2 mux from MuxOscRc16M.
kCLOCK_LPSPI2_ClockRoot_MuxSysPll3Pfd2
LPSPI2 mux from MuxSysPll3Pfd2.
kCLOCK_LPSPI2_ClockRoot_MuxSysPll1Div5
LPSPI2 mux from MuxSysPll1Div5.
kCLOCK_LPSPI2_ClockRoot_MuxSysPll2Out
LPSPI2 mux from MuxSysPll2Out.
kCLOCK_LPSPI2_ClockRoot_MuxSysPll2Pfd3
LPSPI2 mux from MuxSysPll2Pfd3.
kCLOCK_LPSPI3_ClockRoot_MuxOscRc48MDiv2
LPSPI3 mux from MuxOscRc48MDiv2.
kCLOCK_LPSPI3_ClockRoot_MuxOsc24MOut
LPSPI3 mux from MuxOsc24MOut.
kCLOCK_LPSPI3_ClockRoot_MuxOscRc400M
LPSPI3 mux from MuxOscRc400M.
kCLOCK_LPSPI3_ClockRoot_MuxOscRc16M
LPSPI3 mux from MuxOscRc16M.
kCLOCK_LPSPI3_ClockRoot_MuxSysPll3Pfd2
LPSPI3 mux from MuxSysPll3Pfd2.
kCLOCK_LPSPI3_ClockRoot_MuxSysPll1Div5
LPSPI3 mux from MuxSysPll1Div5.
kCLOCK_LPSPI3_ClockRoot_MuxSysPll2Out
LPSPI3 mux from MuxSysPll2Out.
kCLOCK_LPSPI3_ClockRoot_MuxSysPll2Pfd3
LPSPI3 mux from MuxSysPll2Pfd3.
kCLOCK_LPSPI4_ClockRoot_MuxOscRc48MDiv2
LPSPI4 mux from MuxOscRc48MDiv2.
kCLOCK_LPSPI4_ClockRoot_MuxOsc24MOut
LPSPI4 mux from MuxOsc24MOut.
kCLOCK_LPSPI4_ClockRoot_MuxOscRc400M
LPSPI4 mux from MuxOscRc400M.
kCLOCK_LPSPI4_ClockRoot_MuxOscRc16M
LPSPI4 mux from MuxOscRc16M.
kCLOCK_LPSPI4_ClockRoot_MuxSysPll3Pfd2
LPSPI4 mux from MuxSysPll3Pfd2.
kCLOCK_LPSPI4_ClockRoot_MuxSysPll1Div5
LPSPI4 mux from MuxSysPll1Div5.
kCLOCK_LPSPI4_ClockRoot_MuxSysPll2Out
LPSPI4 mux from MuxSysPll2Out.
kCLOCK_LPSPI4_ClockRoot_MuxSysPll2Pfd3
LPSPI4 mux from MuxSysPll2Pfd3.
kCLOCK_LPSPI5_ClockRoot_MuxOscRc48MDiv2
LPSPI5 mux from MuxOscRc48MDiv2.
kCLOCK_LPSPI5_ClockRoot_MuxOsc24MOut
LPSPI5 mux from MuxOsc24MOut.
kCLOCK_LPSPI5_ClockRoot_MuxOscRc400M
LPSPI5 mux from MuxOscRc400M.
kCLOCK_LPSPI5_ClockRoot_MuxOscRc16M
LPSPI5 mux from MuxOscRc16M.
kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Pfd3
LPSPI5 mux from MuxSysPll3Pfd3.
kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Out
LPSPI5 mux from MuxSysPll3Out.
kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Pfd2
LPSPI5 mux from MuxSysPll3Pfd2.
kCLOCK_LPSPI5_ClockRoot_MuxSysPll1Div5
LPSPI5 mux from MuxSysPll1Div5.
kCLOCK_LPSPI6_ClockRoot_MuxOscRc48MDiv2
LPSPI6 mux from MuxOscRc48MDiv2.
kCLOCK_LPSPI6_ClockRoot_MuxOsc24MOut
LPSPI6 mux from MuxOsc24MOut.
kCLOCK_LPSPI6_ClockRoot_MuxOscRc400M
LPSPI6 mux from MuxOscRc400M.
kCLOCK_LPSPI6_ClockRoot_MuxOscRc16M
LPSPI6 mux from MuxOscRc16M.
kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Pfd3
LPSPI6 mux from MuxSysPll3Pfd3.
kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Out
LPSPI6 mux from MuxSysPll3Out.
kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Pfd2
LPSPI6 mux from MuxSysPll3Pfd2.
kCLOCK_LPSPI6_ClockRoot_MuxSysPll1Div5
LPSPI6 mux from MuxSysPll1Div5.
kCLOCK_EMV1_ClockRoot_MuxOscRc48MDiv2
EMV1 mux from MuxOscRc48MDiv2.
kCLOCK_EMV1_ClockRoot_MuxOsc24MOut
EMV1 mux from MuxOsc24MOut.
kCLOCK_EMV1_ClockRoot_MuxOscRc400M
EMV1 mux from MuxOscRc400M.
kCLOCK_EMV1_ClockRoot_MuxOscRc16M
EMV1 mux from MuxOscRc16M.
kCLOCK_EMV1_ClockRoot_MuxSysPll3Div2
EMV1 mux from MuxSysPll3Div2.
kCLOCK_EMV1_ClockRoot_MuxSysPll1Div5
EMV1 mux from MuxSysPll1Div5.
kCLOCK_EMV1_ClockRoot_MuxSysPll2Out
EMV1 mux from MuxSysPll2Out.
kCLOCK_EMV1_ClockRoot_MuxSysPll2Pfd3
EMV1 mux from MuxSysPll2Pfd3.
kCLOCK_EMV2_ClockRoot_MuxOscRc48MDiv2
EMV2 mux from MuxOscRc48MDiv2.
kCLOCK_EMV2_ClockRoot_MuxOsc24MOut
EMV2 mux from MuxOsc24MOut.
kCLOCK_EMV2_ClockRoot_MuxOscRc400M
EMV2 mux from MuxOscRc400M.
kCLOCK_EMV2_ClockRoot_MuxOscRc16M
EMV2 mux from MuxOscRc16M.
kCLOCK_EMV2_ClockRoot_MuxSysPll3Div2
EMV2 mux from MuxSysPll3Div2.
kCLOCK_EMV2_ClockRoot_MuxSysPll1Div5
EMV2 mux from MuxSysPll1Div5.
kCLOCK_EMV2_ClockRoot_MuxSysPll2Out
EMV2 mux from MuxSysPll2Out.
kCLOCK_EMV2_ClockRoot_MuxSysPll2Pfd3
EMV2 mux from MuxSysPll2Pfd3.
kCLOCK_ENET1_ClockRoot_MuxOscRc48MDiv2
ENET1 mux from MuxOscRc48MDiv2.
kCLOCK_ENET1_ClockRoot_MuxOsc24MOut
ENET1 mux from MuxOsc24MOut.
kCLOCK_ENET1_ClockRoot_MuxOscRc400M
ENET1 mux from MuxOscRc400M.
kCLOCK_ENET1_ClockRoot_MuxOscRc16M
ENET1 mux from MuxOscRc16M.
kCLOCK_ENET1_ClockRoot_MuxSysPll1Div2
ENET1 mux from MuxSysPll1Div2.
kCLOCK_ENET1_ClockRoot_MuxAudioPllOut
ENET1 mux from MuxAudioPllOut.
kCLOCK_ENET1_ClockRoot_MuxSysPll1Div5
ENET1 mux from MuxSysPll1Div5.
kCLOCK_ENET1_ClockRoot_MuxSysPll2Pfd1
ENET1 mux from MuxSysPll2Pfd1.
kCLOCK_ENET2_ClockRoot_MuxOscRc48MDiv2
ENET2 mux from MuxOscRc48MDiv2.
kCLOCK_ENET2_ClockRoot_MuxOsc24MOut
ENET2 mux from MuxOsc24MOut.
kCLOCK_ENET2_ClockRoot_MuxOscRc400M
ENET2 mux from MuxOscRc400M.
kCLOCK_ENET2_ClockRoot_MuxOscRc16M
ENET2 mux from MuxOscRc16M.
kCLOCK_ENET2_ClockRoot_MuxSysPll1Div2
ENET2 mux from MuxSysPll1Div2.
kCLOCK_ENET2_ClockRoot_MuxAudioPllOut
ENET2 mux from MuxAudioPllOut.
kCLOCK_ENET2_ClockRoot_MuxSysPll1Div5
ENET2 mux from MuxSysPll1Div5.
kCLOCK_ENET2_ClockRoot_MuxSysPll2Pfd1
ENET2 mux from MuxSysPll2Pfd1.
kCLOCK_ENET_25M_ClockRoot_MuxOscRc48MDiv2
ENET_25M mux from MuxOscRc48MDiv2.
kCLOCK_ENET_25M_ClockRoot_MuxOsc24MOut
ENET_25M mux from MuxOsc24MOut.
kCLOCK_ENET_25M_ClockRoot_MuxOscRc400M
ENET_25M mux from MuxOscRc400M.
kCLOCK_ENET_25M_ClockRoot_MuxOscRc16M
ENET_25M mux from MuxOscRc16M.
kCLOCK_ENET_25M_ClockRoot_MuxSysPll1Div2
ENET_25M mux from MuxSysPll1Div2.
kCLOCK_ENET_25M_ClockRoot_MuxAudioPllOut
ENET_25M mux from MuxAudioPllOut.
kCLOCK_ENET_25M_ClockRoot_MuxSysPll1Div5
ENET_25M mux from MuxSysPll1Div5.
kCLOCK_ENET_25M_ClockRoot_MuxSysPll2Pfd1
ENET_25M mux from MuxSysPll2Pfd1.
kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc48MDiv2
ENET_TIMER1 mux from MuxOscRc48MDiv2.
kCLOCK_ENET_TIMER1_ClockRoot_MuxOsc24MOut
ENET_TIMER1 mux from MuxOsc24MOut.
kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc400M
ENET_TIMER1 mux from MuxOscRc400M.
kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc16M
ENET_TIMER1 mux from MuxOscRc16M.
kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll1Div2
ENET_TIMER1 mux from MuxSysPll1Div2.
kCLOCK_ENET_TIMER1_ClockRoot_MuxAudioPllOut
ENET_TIMER1 mux from MuxAudioPllOut.
kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll1Div5
ENET_TIMER1 mux from MuxSysPll1Div5.
kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll2Pfd1
ENET_TIMER1 mux from MuxSysPll2Pfd1.
kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc48MDiv2
ENET_TIMER2 mux from MuxOscRc48MDiv2.
kCLOCK_ENET_TIMER2_ClockRoot_MuxOsc24MOut
ENET_TIMER2 mux from MuxOsc24MOut.
kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc400M
ENET_TIMER2 mux from MuxOscRc400M.
kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc16M
ENET_TIMER2 mux from MuxOscRc16M.
kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll1Div2
ENET_TIMER2 mux from MuxSysPll1Div2.
kCLOCK_ENET_TIMER2_ClockRoot_MuxAudioPllOut
ENET_TIMER2 mux from MuxAudioPllOut.
kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll1Div5
ENET_TIMER2 mux from MuxSysPll1Div5.
kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll2Pfd1
ENET_TIMER2 mux from MuxSysPll2Pfd1.
kCLOCK_USDHC1_ClockRoot_MuxOscRc48MDiv2
USDHC1 mux from MuxOscRc48MDiv2.
kCLOCK_USDHC1_ClockRoot_MuxOsc24MOut
USDHC1 mux from MuxOsc24MOut.
kCLOCK_USDHC1_ClockRoot_MuxOscRc400M
USDHC1 mux from MuxOscRc400M.
kCLOCK_USDHC1_ClockRoot_MuxOscRc16M
USDHC1 mux from MuxOscRc16M.
kCLOCK_USDHC1_ClockRoot_MuxSysPll2Pfd2
USDHC1 mux from MuxSysPll2Pfd2.
kCLOCK_USDHC1_ClockRoot_MuxSysPll2Pfd0
USDHC1 mux from MuxSysPll2Pfd0.
kCLOCK_USDHC1_ClockRoot_MuxSysPll1Div5
USDHC1 mux from MuxSysPll1Div5.
kCLOCK_USDHC1_ClockRoot_MuxArmPllOut
USDHC1 mux from MuxArmPllOut.
kCLOCK_USDHC2_ClockRoot_MuxOscRc48MDiv2
USDHC2 mux from MuxOscRc48MDiv2.
kCLOCK_USDHC2_ClockRoot_MuxOsc24MOut
USDHC2 mux from MuxOsc24MOut.
kCLOCK_USDHC2_ClockRoot_MuxOscRc400M
USDHC2 mux from MuxOscRc400M.
kCLOCK_USDHC2_ClockRoot_MuxOscRc16M
USDHC2 mux from MuxOscRc16M.
kCLOCK_USDHC2_ClockRoot_MuxSysPll2Pfd2
USDHC2 mux from MuxSysPll2Pfd2.
kCLOCK_USDHC2_ClockRoot_MuxSysPll2Pfd0
USDHC2 mux from MuxSysPll2Pfd0.
kCLOCK_USDHC2_ClockRoot_MuxSysPll1Div5
USDHC2 mux from MuxSysPll1Div5.
kCLOCK_USDHC2_ClockRoot_MuxArmPllOut
USDHC2 mux from MuxArmPllOut.
kCLOCK_ASRC_ClockRoot_MuxOscRc48MDiv2
ASRC mux from MuxOscRc48MDiv2.
kCLOCK_ASRC_ClockRoot_MuxOsc24MOut
ASRC mux from MuxOsc24MOut.
kCLOCK_ASRC_ClockRoot_MuxOscRc400M
ASRC mux from MuxOscRc400M.
kCLOCK_ASRC_ClockRoot_MuxOscRc16M
ASRC mux from MuxOscRc16M.
kCLOCK_ASRC_ClockRoot_MuxSysPll1Div5
ASRC mux from MuxSysPll1Div5.
kCLOCK_ASRC_ClockRoot_MuxSysPll3Div2
ASRC mux from MuxSysPll3Div2.
kCLOCK_ASRC_ClockRoot_MuxAudioPllOut
ASRC mux from MuxAudioPllOut.
kCLOCK_ASRC_ClockRoot_MuxSysPll2Pfd3
ASRC mux from MuxSysPll2Pfd3.
kCLOCK_MQS_ClockRoot_MuxOscRc48MDiv2
MQS mux from MuxOscRc48MDiv2.
kCLOCK_MQS_ClockRoot_MuxOsc24MOut
MQS mux from MuxOsc24MOut.
kCLOCK_MQS_ClockRoot_MuxOscRc400M
MQS mux from MuxOscRc400M.
kCLOCK_MQS_ClockRoot_MuxOscRc16M
MQS mux from MuxOscRc16M.
kCLOCK_MQS_ClockRoot_MuxSysPll1Div5
MQS mux from MuxSysPll1Div5.
kCLOCK_MQS_ClockRoot_MuxSysPll3Div2
MQS mux from MuxSysPll3Div2.
kCLOCK_MQS_ClockRoot_MuxAudioPllOut
MQS mux from MuxAudioPllOut.
kCLOCK_MQS_ClockRoot_MuxSysPll2Pfd3
MQS mux from MuxSysPll2Pfd3.
kCLOCK_MIC_ClockRoot_MuxOscRc48MDiv2
MIC mux from MuxOscRc48MDiv2.
kCLOCK_MIC_ClockRoot_MuxOsc24MOut
MIC mux from MuxOsc24MOut.
kCLOCK_MIC_ClockRoot_MuxOscRc400M
MIC mux from MuxOscRc400M.
kCLOCK_MIC_ClockRoot_MuxOscRc16M
MIC mux from MuxOscRc16M.
kCLOCK_MIC_ClockRoot_MuxSysPll3Pfd3
MIC mux from MuxSysPll3Pfd3.
kCLOCK_MIC_ClockRoot_MuxSysPll3Out
MIC mux from MuxSysPll3Out.
kCLOCK_MIC_ClockRoot_MuxAudioPllOut
MIC mux from MuxAudioPllOut.
kCLOCK_MIC_ClockRoot_MuxSysPll1Div5
MIC mux from MuxSysPll1Div5.
kCLOCK_SPDIF_ClockRoot_MuxOscRc48MDiv2
SPDIF mux from MuxOscRc48MDiv2.
kCLOCK_SPDIF_ClockRoot_MuxOsc24MOut
SPDIF mux from MuxOsc24MOut.
kCLOCK_SPDIF_ClockRoot_MuxOscRc400M
SPDIF mux from MuxOscRc400M.
kCLOCK_SPDIF_ClockRoot_MuxOscRc16M
SPDIF mux from MuxOscRc16M.
kCLOCK_SPDIF_ClockRoot_MuxAudioPllOut
SPDIF mux from MuxAudioPllOut.
kCLOCK_SPDIF_ClockRoot_MuxSysPll3Out
SPDIF mux from MuxSysPll3Out.
kCLOCK_SPDIF_ClockRoot_MuxSysPll3Pfd2
SPDIF mux from MuxSysPll3Pfd2.
kCLOCK_SPDIF_ClockRoot_MuxSysPll2Pfd3
SPDIF mux from MuxSysPll2Pfd3.
kCLOCK_SAI1_ClockRoot_MuxOscRc48MDiv2
SAI1 mux from MuxOscRc48MDiv2.
kCLOCK_SAI1_ClockRoot_MuxOsc24MOut
SAI1 mux from MuxOsc24MOut.
kCLOCK_SAI1_ClockRoot_MuxOscRc400M
SAI1 mux from MuxOscRc400M.
kCLOCK_SAI1_ClockRoot_MuxOscRc16M
SAI1 mux from MuxOscRc16M.
kCLOCK_SAI1_ClockRoot_MuxAudioPllOut
SAI1 mux from MuxAudioPllOut.
kCLOCK_SAI1_ClockRoot_MuxSysPll3Pfd2
SAI1 mux from MuxSysPll3Pfd2.
kCLOCK_SAI1_ClockRoot_MuxSysPll1Div5
SAI1 mux from MuxSysPll1Div5.
kCLOCK_SAI1_ClockRoot_MuxSysPll2Pfd3
SAI1 mux from MuxSysPll2Pfd3.
kCLOCK_SAI2_ClockRoot_MuxOscRc48MDiv2
SAI2 mux from MuxOscRc48MDiv2.
kCLOCK_SAI2_ClockRoot_MuxOsc24MOut
SAI2 mux from MuxOsc24MOut.
kCLOCK_SAI2_ClockRoot_MuxOscRc400M
SAI2 mux from MuxOscRc400M.
kCLOCK_SAI2_ClockRoot_MuxOscRc16M
SAI2 mux from MuxOscRc16M.
kCLOCK_SAI2_ClockRoot_MuxAudioPllOut
SAI2 mux from MuxAudioPllOut.
kCLOCK_SAI2_ClockRoot_MuxSysPll3Pfd2
SAI2 mux from MuxSysPll3Pfd2.
kCLOCK_SAI2_ClockRoot_MuxSysPll1Div5
SAI2 mux from MuxSysPll1Div5.
kCLOCK_SAI2_ClockRoot_MuxSysPll2Pfd3
SAI2 mux from MuxSysPll2Pfd3.
kCLOCK_SAI3_ClockRoot_MuxOscRc48MDiv2
SAI3 mux from MuxOscRc48MDiv2.
kCLOCK_SAI3_ClockRoot_MuxOsc24MOut
SAI3 mux from MuxOsc24MOut.
kCLOCK_SAI3_ClockRoot_MuxOscRc400M
SAI3 mux from MuxOscRc400M.
kCLOCK_SAI3_ClockRoot_MuxOscRc16M
SAI3 mux from MuxOscRc16M.
kCLOCK_SAI3_ClockRoot_MuxAudioPllOut
SAI3 mux from MuxAudioPllOut.
kCLOCK_SAI3_ClockRoot_MuxSysPll3Pfd2
SAI3 mux from MuxSysPll3Pfd2.
kCLOCK_SAI3_ClockRoot_MuxSysPll1Div5
SAI3 mux from MuxSysPll1Div5.
kCLOCK_SAI3_ClockRoot_MuxSysPll2Pfd3
SAI3 mux from MuxSysPll2Pfd3.
kCLOCK_SAI4_ClockRoot_MuxOscRc48MDiv2
SAI4 mux from MuxOscRc48MDiv2.
kCLOCK_SAI4_ClockRoot_MuxOsc24MOut
SAI4 mux from MuxOsc24MOut.
kCLOCK_SAI4_ClockRoot_MuxOscRc400M
SAI4 mux from MuxOscRc400M.
kCLOCK_SAI4_ClockRoot_MuxOscRc16M
SAI4 mux from MuxOscRc16M.
kCLOCK_SAI4_ClockRoot_MuxSysPll3Pfd3
SAI4 mux from MuxSysPll3Pfd3.
kCLOCK_SAI4_ClockRoot_MuxSysPll3Out
SAI4 mux from MuxSysPll3Out.
kCLOCK_SAI4_ClockRoot_MuxAudioPllOut
SAI4 mux from MuxAudioPllOut.
kCLOCK_SAI4_ClockRoot_MuxSysPll1Div5
SAI4 mux from MuxSysPll1Div5.
kCLOCK_GC355_ClockRoot_MuxOscRc48MDiv2
GC355 mux from MuxOscRc48MDiv2.
kCLOCK_GC355_ClockRoot_MuxOsc24MOut
GC355 mux from MuxOsc24MOut.
kCLOCK_GC355_ClockRoot_MuxOscRc400M
GC355 mux from MuxOscRc400M.
kCLOCK_GC355_ClockRoot_MuxOscRc16M
GC355 mux from MuxOscRc16M.
kCLOCK_GC355_ClockRoot_MuxSysPll2Out
GC355 mux from MuxSysPll2Out.
kCLOCK_GC355_ClockRoot_MuxSysPll2Pfd1
GC355 mux from MuxSysPll2Pfd1.
kCLOCK_GC355_ClockRoot_MuxSysPll3Out
GC355 mux from MuxSysPll3Out.
kCLOCK_GC355_ClockRoot_MuxVideoPllOut
GC355 mux from MuxVideoPllOut.
kCLOCK_LCDIF_ClockRoot_MuxOscRc48MDiv2
LCDIF mux from MuxOscRc48MDiv2.
kCLOCK_LCDIF_ClockRoot_MuxOsc24MOut
LCDIF mux from MuxOsc24MOut.
kCLOCK_LCDIF_ClockRoot_MuxOscRc400M
LCDIF mux from MuxOscRc400M.
kCLOCK_LCDIF_ClockRoot_MuxOscRc16M
LCDIF mux from MuxOscRc16M.
kCLOCK_LCDIF_ClockRoot_MuxSysPll2Out
LCDIF mux from MuxSysPll2Out.
kCLOCK_LCDIF_ClockRoot_MuxSysPll2Pfd2
LCDIF mux from MuxSysPll2Pfd2.
kCLOCK_LCDIF_ClockRoot_MuxSysPll3Pfd0
LCDIF mux from MuxSysPll3Pfd0.
kCLOCK_LCDIF_ClockRoot_MuxVideoPllOut
LCDIF mux from MuxVideoPllOut.
kCLOCK_LCDIFV2_ClockRoot_MuxOscRc48MDiv2
LCDIFV2 mux from MuxOscRc48MDiv2.
kCLOCK_LCDIFV2_ClockRoot_MuxOsc24MOut
LCDIFV2 mux from MuxOsc24MOut.
kCLOCK_LCDIFV2_ClockRoot_MuxOscRc400M
LCDIFV2 mux from MuxOscRc400M.
kCLOCK_LCDIFV2_ClockRoot_MuxOscRc16M
LCDIFV2 mux from MuxOscRc16M.
kCLOCK_LCDIFV2_ClockRoot_MuxSysPll2Out
LCDIFV2 mux from MuxSysPll2Out.
kCLOCK_LCDIFV2_ClockRoot_MuxSysPll2Pfd2
LCDIFV2 mux from MuxSysPll2Pfd2.
kCLOCK_LCDIFV2_ClockRoot_MuxSysPll3Pfd0
LCDIFV2 mux from MuxSysPll3Pfd0.
kCLOCK_LCDIFV2_ClockRoot_MuxVideoPllOut
LCDIFV2 mux from MuxVideoPllOut.
kCLOCK_MIPI_REF_ClockRoot_MuxOscRc48MDiv2
MIPI_REF mux from MuxOscRc48MDiv2.
kCLOCK_MIPI_REF_ClockRoot_MuxOsc24MOut
MIPI_REF mux from MuxOsc24MOut.
kCLOCK_MIPI_REF_ClockRoot_MuxOscRc400M
MIPI_REF mux from MuxOscRc400M.
kCLOCK_MIPI_REF_ClockRoot_MuxOscRc16M
MIPI_REF mux from MuxOscRc16M.
kCLOCK_MIPI_REF_ClockRoot_MuxSysPll2Out
MIPI_REF mux from MuxSysPll2Out.
kCLOCK_MIPI_REF_ClockRoot_MuxSysPll2Pfd0
MIPI_REF mux from MuxSysPll2Pfd0.
kCLOCK_MIPI_REF_ClockRoot_MuxSysPll3Pfd0
MIPI_REF mux from MuxSysPll3Pfd0.
kCLOCK_MIPI_REF_ClockRoot_MuxVideoPllOut
MIPI_REF mux from MuxVideoPllOut.
kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc48MDiv2
MIPI_ESC mux from MuxOscRc48MDiv2.
kCLOCK_MIPI_ESC_ClockRoot_MuxOsc24MOut
MIPI_ESC mux from MuxOsc24MOut.
kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc400M
MIPI_ESC mux from MuxOscRc400M.
kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc16M
MIPI_ESC mux from MuxOscRc16M.
kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll2Out
MIPI_ESC mux from MuxSysPll2Out.
kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll2Pfd0
MIPI_ESC mux from MuxSysPll2Pfd0.
kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll3Pfd0
MIPI_ESC mux from MuxSysPll3Pfd0.
kCLOCK_MIPI_ESC_ClockRoot_MuxVideoPllOut
MIPI_ESC mux from MuxVideoPllOut.
kCLOCK_CSI2_ClockRoot_MuxOscRc48MDiv2
CSI2 mux from MuxOscRc48MDiv2.
kCLOCK_CSI2_ClockRoot_MuxOsc24MOut
CSI2 mux from MuxOsc24MOut.
kCLOCK_CSI2_ClockRoot_MuxOscRc400M
CSI2 mux from MuxOscRc400M.
kCLOCK_CSI2_ClockRoot_MuxOscRc16M
CSI2 mux from MuxOscRc16M.
kCLOCK_CSI2_ClockRoot_MuxSysPll2Pfd2
CSI2 mux from MuxSysPll2Pfd2.
kCLOCK_CSI2_ClockRoot_MuxSysPll3Out
CSI2 mux from MuxSysPll3Out.
kCLOCK_CSI2_ClockRoot_MuxSysPll2Pfd0
CSI2 mux from MuxSysPll2Pfd0.
kCLOCK_CSI2_ClockRoot_MuxVideoPllOut
CSI2 mux from MuxVideoPllOut.
kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc48MDiv2
CSI2_ESC mux from MuxOscRc48MDiv2.
kCLOCK_CSI2_ESC_ClockRoot_MuxOsc24MOut
CSI2_ESC mux from MuxOsc24MOut.
kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc400M
CSI2_ESC mux from MuxOscRc400M.
kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc16M
CSI2_ESC mux from MuxOscRc16M.
kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll2Pfd2
CSI2_ESC mux from MuxSysPll2Pfd2.
kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll3Out
CSI2_ESC mux from MuxSysPll3Out.
kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll2Pfd0
CSI2_ESC mux from MuxSysPll2Pfd0.
kCLOCK_CSI2_ESC_ClockRoot_MuxVideoPllOut
CSI2_ESC mux from MuxVideoPllOut.
kCLOCK_CSI2_UI_ClockRoot_MuxOscRc48MDiv2
CSI2_UI mux from MuxOscRc48MDiv2.
kCLOCK_CSI2_UI_ClockRoot_MuxOsc24MOut
CSI2_UI mux from MuxOsc24MOut.
kCLOCK_CSI2_UI_ClockRoot_MuxOscRc400M
CSI2_UI mux from MuxOscRc400M.
kCLOCK_CSI2_UI_ClockRoot_MuxOscRc16M
CSI2_UI mux from MuxOscRc16M.
kCLOCK_CSI2_UI_ClockRoot_MuxSysPll2Pfd2
CSI2_UI mux from MuxSysPll2Pfd2.
kCLOCK_CSI2_UI_ClockRoot_MuxSysPll3Out
CSI2_UI mux from MuxSysPll3Out.
kCLOCK_CSI2_UI_ClockRoot_MuxSysPll2Pfd0
CSI2_UI mux from MuxSysPll2Pfd0.
kCLOCK_CSI2_UI_ClockRoot_MuxVideoPllOut
CSI2_UI mux from MuxVideoPllOut.
kCLOCK_CSI_ClockRoot_MuxOscRc48MDiv2
CSI mux from MuxOscRc48MDiv2.
kCLOCK_CSI_ClockRoot_MuxOsc24MOut
CSI mux from MuxOsc24MOut.
kCLOCK_CSI_ClockRoot_MuxOscRc400M
CSI mux from MuxOscRc400M.
kCLOCK_CSI_ClockRoot_MuxOscRc16M
CSI mux from MuxOscRc16M.
kCLOCK_CSI_ClockRoot_MuxSysPll2Pfd2
CSI mux from MuxSysPll2Pfd2.
kCLOCK_CSI_ClockRoot_MuxSysPll3Out
CSI mux from MuxSysPll3Out.
kCLOCK_CSI_ClockRoot_MuxSysPll3Pfd1
CSI mux from MuxSysPll3Pfd1.
kCLOCK_CSI_ClockRoot_MuxVideoPllOut
CSI mux from MuxVideoPllOut.
kCLOCK_CKO1_ClockRoot_MuxOscRc48MDiv2
CKO1 mux from MuxOscRc48MDiv2.
kCLOCK_CKO1_ClockRoot_MuxOsc24MOut
CKO1 mux from MuxOsc24MOut.
kCLOCK_CKO1_ClockRoot_MuxOscRc400M
CKO1 mux from MuxOscRc400M.
kCLOCK_CKO1_ClockRoot_MuxOscRc16M
CKO1 mux from MuxOscRc16M.
kCLOCK_CKO1_ClockRoot_MuxSysPll2Pfd2
CKO1 mux from MuxSysPll2Pfd2.
kCLOCK_CKO1_ClockRoot_MuxSysPll2Out
CKO1 mux from MuxSysPll2Out.
kCLOCK_CKO1_ClockRoot_MuxSysPll3Pfd1
CKO1 mux from MuxSysPll3Pfd1.
kCLOCK_CKO1_ClockRoot_MuxSysPll1Div5
CKO1 mux from MuxSysPll1Div5.
kCLOCK_CKO2_ClockRoot_MuxOscRc48MDiv2
CKO2 mux from MuxOscRc48MDiv2.
kCLOCK_CKO2_ClockRoot_MuxOsc24MOut
CKO2 mux from MuxOsc24MOut.
kCLOCK_CKO2_ClockRoot_MuxOscRc400M
CKO2 mux from MuxOscRc400M.
kCLOCK_CKO2_ClockRoot_MuxOscRc16M
CKO2 mux from MuxOscRc16M.
kCLOCK_CKO2_ClockRoot_MuxSysPll2Pfd3
CKO2 mux from MuxSysPll2Pfd3.
CKO2 mux from MuxOscRc48M.
kCLOCK_CKO2_ClockRoot_MuxSysPll3Pfd1
CKO2 mux from MuxSysPll3Pfd1.
kCLOCK_CKO2_ClockRoot_MuxAudioPllOut
CKO2 mux from MuxAudioPllOut.
◆ _clock_usb_phy_src [1/2]
Source of the USB HS PHY.
kCLOCK_Usbphy480M
Use 480M.
kCLOCK_Usbphy480M
Use 480M.
◆ _clock_usb_phy_src [2/2]
kCLOCK_Usbphy480M
Use 480M.
kCLOCK_Usbphy480M
Use 480M.
◆ _clock_usb_src [1/2]
USB clock source definition.
kCLOCK_Usb480M
Use 480M.
kCLOCK_UsbSrcUnused
Used when the function does not care the clock source.
kCLOCK_Usb480M
Use 480M.
kCLOCK_UsbSrcUnused
◆ _clock_usb_src [2/2]
kCLOCK_Usb480M
Use 480M.
kCLOCK_UsbSrcUnused
kCLOCK_Usb480M
Use 480M.
kCLOCK_UsbSrcUnused
◆ CLOCK_CalcArmPllFreq()
status_t CLOCK_CalcArmPllFreq ( clock_arm_pll_config_t config,
uint32_t  freqInMhz
Calculate corresponding config values per given frequency.
This function calculates config valudes per given frequency for Arm PLL
Parameters
configpll config structure
freqInMhztarget frequency
◆ CLOCK_CalcAvPllFreq()
status_t CLOCK_CalcAvPllFreq ( clock_av_pll_config_t config,
uint32_t  freqInMhz
This function calculates config valudes per given frequency for Audio/Video PLL.
Parameters
◆ CLOCK_CalcPllSpreadSpectrum()
void CLOCK_CalcPllSpreadSpectrum ( uint32_t  factor,
uint32_t  range,
uint32_t  mod,
clock_pll_ss_config_t ss
Calculate spread spectrum step and stop.
This function calculate spread spectrum step and stop according to given parameters. For integer PLL (syspll2) the factor is mfd, while for other fractional PLLs (audio/video/syspll1), the factor is denominator.
Parameters
factorfactor to calculate step/stop
rangespread spectrum range
modspread spectrum modulation frequency
sscalculated spread spectrum values
◆ CLOCK_DeinitArmPll()
void CLOCK_DeinitArmPll ( void  )
De-initialize the ARM PLL.
brief De-initialize the ARM PLL.
◆ CLOCK_DeinitAudioPll()
void CLOCK_DeinitAudioPll ( void  )
De-initialize the Audio PLL.
brief De-initialize the Audio PLL.
◆ CLOCK_DeinitEnetPll()
void CLOCK_DeinitEnetPll ( void  )
Deinitialize the ENET PLL.
This function disables the ENET PLL.
brief Deinitialize the ENET PLL.
◆ CLOCK_DeinitExternalClk()
void CLOCK_DeinitExternalClk ( void  )
Deinitialize the external 24MHz clock.
This function disables the external 24MHz clock.
After this function, please call CLOCK_SetXtal0Freq to set external clock frequency to 0.
brief Deinitialize the external 24MHz clock.
After this function, please call ref CLOCK_SetXtal0Freq to set external clock frequency to 0.
◆ CLOCK_DeinitPfd()
void CLOCK_DeinitPfd ( clock_pll_t  pll,
clock_pfd_t  pfd
De-initialize selected PLL PFD.
Parameters
pllWhich PLL of targeting PFD to be operated.
pfdWhich PFD clock to enable.
brief De-initialize selected PLL PFD.
param pll Which PLL of targeting PFD to be operated. param pfd Which PFD clock to enable.
◆ CLOCK_DeinitRcOsc24M()
void CLOCK_DeinitRcOsc24M ( void  )
Power down the RCOSC 24M clock.
brief Power down the RCOSC 24M clock.
◆ CLOCK_DeinitSysPfd()
void CLOCK_DeinitSysPfd ( clock_pfd_t  pfd)
De-initialize the System PLL PFD.
This function disables the System PLL PFD.
Parameters
pfdWhich PFD clock to disable.
brief De-initialize the System PLL PFD.
param pfd Which PFD clock to disable.
◆ CLOCK_DeinitSysPll()
void CLOCK_DeinitSysPll ( void  )
De-initialize the System PLL.
brief De-initialize the System PLL.
◆ CLOCK_DeinitUsb1Pfd()
void CLOCK_DeinitUsb1Pfd ( clock_pfd_t  pfd)
De-initialize the USB1 PLL PFD.
This function disables the USB1 PLL PFD.
Parameters
brief De-initialize the USB1 PLL PFD.
◆ CLOCK_DeinitUsb1Pll()
void CLOCK_DeinitUsb1Pll ( void  )
Deinitialize the USB1 PLL.
brief Deinitialize the USB1 PLL.
◆ CLOCK_DeinitUsb2Pll()
void CLOCK_DeinitUsb2Pll ( void  )
Deinitialize the USB2 PLL.
brief Deinitialize the USB2 PLL.
◆ CLOCK_DeinitVideoPll()
void CLOCK_DeinitVideoPll ( void  )
De-initialize the Video PLL.
brief De-initialize the Video PLL.
◆ CLOCK_DisableUsbhs0PhyPllClock()
void CLOCK_DisableUsbhs0PhyPllClock ( void  )
Disable USB HS PHY PLL clock.
This function disables USB HS PHY PLL clock.
brief Disable USB HS PHY PLL clock.
brief Enable USB HS clock.
This function only enables the access to USB HS prepheral, upper layer should first call the ref CLOCK_EnableUsbhs0PhyPllClock to enable the PHY clock to use USB HS.
param src USB HS does not care about the clock source, here must be ref kCLOCK_UsbSrcUnused. param freq USB HS does not care about the clock source, so this parameter is ignored. retval true The clock is set successfully. retval false The clock source is invalid to get proper USB HS clock.
◆ CLOCK_DisableUsbhs1PhyPllClock()
void CLOCK_DisableUsbhs1PhyPllClock ( void  )
◆ CLOCK_EnableUsbhs0Clock()
bool CLOCK_EnableUsbhs0Clock ( clock_usb_src_t  src,
uint32_t  freq
This function only enables the access to USB HS prepheral, upper layer should first call the CLOCK_EnableUsbhs0PhyPllClock to enable the PHY clock to use USB HS.
Parameters
srcUSB HS does not care about the clock source, here must be kCLOCK_UsbSrcUnused.
freqUSB HS does not care about the clock source, so this parameter is ignored.
Return values
trueThe clock is set successfully.
falseThe clock source is invalid to get proper USB HS clock.
Parameters
Return values
Parameters
Return values
◆ CLOCK_EnableUsbhs0PhyPllClock()
bool CLOCK_EnableUsbhs0PhyPllClock ( clock_usb_phy_src_t  src,
uint32_t  freq
Enable USB HS PHY PLL clock.
This function enables the internal 480MHz USB PHY PLL clock.
Parameters
srcUSB HS PHY PLL clock source.
freqThe frequency specified by src.
Return values
brief Enable USB HS PHY PLL clock.
param src USB HS PHY PLL clock source. param freq The frequency specified by src. retval true The clock is set successfully. retval false The clock source is invalid to get proper USB HS clock.
Parameters
Return values
◆ CLOCK_EnableUsbhs1Clock()
bool CLOCK_EnableUsbhs1Clock ( clock_usb_src_t  src,
uint32_t  freq
Parameters
Return values
Parameters
Return values
Parameters
Return values
◆ CLOCK_EnableUsbhs1PhyPllClock()
bool CLOCK_EnableUsbhs1PhyPllClock ( clock_usb_phy_src_t  src,
uint32_t  freq
Parameters
Return values
Parameters
Return values
◆ CLOCK_GetAhbFreq()
uint32_t CLOCK_GetAhbFreq ( void  )
Gets the AHB clock frequency.
Returns
The AHB clock frequency value in hertz.
brief Gets the AHB clock frequency.
return The AHB clock frequency value in hertz.
◆ CLOCK_GetClockOutCLKO1Freq()
uint32_t CLOCK_GetClockOutCLKO1Freq ( void  )
Get the frequency of clock output1 clock signal.
Returns
The frequency of clock output1 clock signal.
brief Get the frequency of clock output1 clock signal.
return The frequency of clock output1 clock signal.
◆ CLOCK_GetClockOutClkO2Freq()
uint32_t CLOCK_GetClockOutClkO2Freq ( void  )
Get the frequency of clock output2 clock signal.
Returns
The frequency of clock output2 clock signal.
brief Get the frequency of clock output2 clock signal.
return The frequency of clock output2 clock signal.
◆ CLOCK_GetClockRootFreq()
uint32_t CLOCK_GetClockRootFreq ( clock_root_t  clockRoot)
Gets the frequency of selected clock root.
Parameters
clockRootThe clock root used to get the frequency, please refer to clock_root_t.
Returns
The frequency of selected clock root.
brief Gets the frequency of selected clock root.
param clockRoot The clock root used to get the frequency, please refer to clock_root_t. return The frequency of selected clock root.
◆ CLOCK_GetFreq()
uint32_t CLOCK_GetFreq ( clock_name_t  name)
Gets the clock frequency for a specific clock name.
This function checks the current clock configurations and then calculates the clock frequency for a specific clock name defined in clock_name_t.
Parameters
nameClock names defined in clock_name_t
Returns
Clock frequency value in hertz
brief Gets the clock frequency for a specific clock name.
param clockName Clock names defined in clock_name_t return Clock frequency value in hertz
Parameters
Returns
◆ CLOCK_GetIpgFreq()
uint32_t CLOCK_GetIpgFreq ( void  )
Gets the IPG clock frequency.
Returns
The IPG clock frequency value in hertz.
brief Gets the IPG clock frequency.
return The IPG clock frequency value in hertz.
◆ CLOCK_GetPerClkFreq()
uint32_t CLOCK_GetPerClkFreq ( void  )
Gets the PER clock frequency.
Returns
The PER clock frequency value in hertz.
brief Gets the PER clock frequency.
return The PER clock frequency value in hertz.
◆ CLOCK_GetPfdFreq()
uint32_t CLOCK_GetPfdFreq ( clock_pll_t  pll,
clock_pfd_t  pfd
Get current PFD output frequency.
This function get current output frequency of specific System PLL PFD
Parameters
pfdpfd name to get frequency.
Returns
The PFD output frequency in hertz.
◆ CLOCK_GetPllFreq()
uint32_t CLOCK_GetPllFreq ( clock_pll_t  pll)
Get current PLL output frequency.
This function get current output frequency of specific PLL
Parameters
pllpll name to get frequency.
Returns
The PLL output frequency in hertz.
brief Get current PLL output frequency.
param pll pll name to get frequency. return The PLL output frequency in hertz.
Parameters
Returns
◆ CLOCK_GetSemcFreq()
uint32_t CLOCK_GetSemcFreq ( void  )
Gets the SEMC clock frequency.
Returns
The SEMC clock frequency value in hertz.
brief Gets the SEMC clock frequency.
return The SEMC clock frequency value in hertz.
◆ CLOCK_GetSysPfdFreq()
uint32_t CLOCK_GetSysPfdFreq ( clock_pfd_t  pfd)
Get current System PLL PFD output frequency.
Parameters
Returns
brief Get current System PLL PFD output frequency.
param pfd pfd name to get frequency. return The PFD output frequency in hertz.
◆ CLOCK_GetUsb1PfdFreq()
uint32_t CLOCK_GetUsb1PfdFreq ( clock_pfd_t  pfd)
Get current USB1 PLL PFD output frequency.
This function get current output frequency of specific USB1 PLL PFD
Parameters
Returns
brief Get current USB1 PLL PFD output frequency.
◆ CLOCK_GPC_SetAudioPllOutputFreq()
void CLOCK_GPC_SetAudioPllOutputFreq ( const clock_audio_pll_gpc_config_t config)
Set Audio PLL output frequency in GPC mode.
Parameters
configPointer to clock_audio_pll_gpc_config_t structure.
◆ CLOCK_GPC_SetSysPll1OutputFreq()
void CLOCK_GPC_SetSysPll1OutputFreq ( const clock_sys_pll1_gpc_config_t config)
Set System PLL1 output frequency in GPC mode.
Parameters
configPointer to clock_sys_pll1_gpc_config_t.
◆ CLOCK_GPC_SetVideoPllOutputFreq()
void CLOCK_GPC_SetVideoPllOutputFreq ( const clock_video_pll_gpc_config_t config)
Set Video PLL output frequency in GPC mode.
Parameters
◆ CLOCK_InitArmPll()
void CLOCK_InitArmPll ( const clock_arm_pll_config_t config)
Initialize the ARM PLL.
This function initialize the ARM PLL with specific settings
Parameters
configconfiguration to set to PLL.
brief Initialize the ARM PLL.
param config configuration to set to PLL.
Parameters
◆ CLOCK_InitArmPllWithFreq()
status_t CLOCK_InitArmPllWithFreq ( uint32_t  freqInMhz)
Initializes the Arm PLL with Specific Frequency (in Mhz).
This function initializes the Arm PLL with specific frequency
Parameters
◆ CLOCK_InitAudioPll()
void CLOCK_InitAudioPll ( const clock_audio_pll_config_t config)
Initializes the Audio PLL.
This function initializes the Audio PLL with specific settings
Parameters
configConfiguration to set to PLL.
brief Initializes the Audio PLL.
param config Configuration to set to PLL.
Parameters
◆ CLOCK_InitAudioPllWithFreq()
status_t CLOCK_InitAudioPllWithFreq ( uint32_t  freqInMhz,
bool  ssEnable,
uint32_t  ssRange,
uint32_t  ssMod
Initializes the Audio PLL with Specific Frequency (in Mhz).
This function initializes the Audio PLL with specific frequency
Parameters
ssEnableenable spread spectrum or not
ssRangerange spread spectrum range
ssModspread spectrum modulation frequency
◆ CLOCK_InitEnetPll()
void CLOCK_InitEnetPll ( const clock_enet_pll_config_t config)
Initialize the ENET PLL.
This function initializes the ENET PLL with specific settings.
Parameters
brief Initialize the ENET PLL.
◆ CLOCK_InitExternalClk()
void CLOCK_InitExternalClk ( bool  bypassXtalOsc)
Initialize the external 24MHz clock.
This function supports two modes:
  1. Use external crystal oscillator.
  2. Bypass the external crystal oscillator, using input source clock directly.
After this function, please call CLOCK_SetXtal0Freq to inform clock driver the external clock frequency.
Parameters
bypassXtalOscPass in true to bypass the external crystal oscillator.
Note
This device does not support bypass external crystal oscillator, so the input parameter should always be false.
brief Initialize the external 24MHz clock.
After this function, please call ref CLOCK_SetXtal0Freq to inform clock driver the external clock frequency.
param bypassXtalOsc Pass in true to bypass the external crystal oscillator. note This device does not support bypass external crystal oscillator, so the input parameter should always be false.
◆ CLOCK_InitPfd()
void CLOCK_InitPfd ( clock_pll_t  pll,
clock_pfd_t  pfd,
uint8_t  frac
Initialize PLL PFD.
This function initializes the System PLL PFD. During new value setting, the clock output is disabled to prevent glitch.
Parameters
fracThe PFD FRAC value.
Note
It is recommended that PFD settings are kept between 12-35.
◆ CLOCK_InitRcOsc24M()
void CLOCK_InitRcOsc24M ( void  )
Initialize the RC oscillator 24MHz clock.
brief Initialize the RC oscillator 24MHz clock.
◆ CLOCK_InitSysPfd()
void CLOCK_InitSysPfd ( clock_pfd_t  pfd,
uint8_t  pfdFrac
Initialize the System PLL PFD.
Parameters
pfdFracThe PFD FRAC value.
Note
brief Initialize the System PLL PFD.
param pfd Which PFD clock to enable. param pfdFrac The PFD FRAC value. note It is recommended that PFD settings are kept between 12-35.
◆ CLOCK_InitSysPll()
void CLOCK_InitSysPll ( const clock_sys_pll_config_t config)
Initialize the System PLL.
This function initializes the System PLL with specific settings
Parameters
brief Initialize the System PLL.
◆ CLOCK_InitSysPll1()
void CLOCK_InitSysPll1 ( const clock_sys_pll1_config_t config)
Initialize the System PLL1.
This function initializes the System PLL1 with specific settings
Parameters
configConfiguration to set to PLL1.
◆ CLOCK_InitSysPll2()
void CLOCK_InitSysPll2 ( const clock_sys_pll2_config_t config)
Initialize the System PLL2.
This function initializes the System PLL2 with specific settings
Parameters
configConfiguration to configure spread spectrum. This parameter can be NULL, if no need to enabled spread spectrum
◆ CLOCK_InitSysPll3()
void CLOCK_InitSysPll3 ( void  )
Initialize the System PLL3.
This function initializes the System PLL3 with specific settings
◆ CLOCK_InitUsb1Pfd()
void CLOCK_InitUsb1Pfd ( clock_pfd_t  pfd,
uint8_t  pfdFrac
Initialize the USB1 PLL PFD.
This function initializes the USB1 PLL PFD. During new value setting, the clock output is disabled to prevent glitch.
Parameters
Note
brief Initialize the USB1 PLL PFD.
◆ CLOCK_InitUsb1Pll()
void CLOCK_InitUsb1Pll ( const clock_usb_pll_config_t config)
Initialize the USB1 PLL.
This function initializes the USB1 PLL with specific settings
Parameters
brief Initialize the USB1 PLL.
◆ CLOCK_InitUsb2Pll()
void CLOCK_InitUsb2Pll ( const clock_usb_pll_config_t config)
Initialize the USB2 PLL.
This function initializes the USB2 PLL with specific settings
Parameters
brief Initialize the USB2 PLL.
◆ CLOCK_InitVideoPll()
void CLOCK_InitVideoPll ( const clock_video_pll_config_t config)
Initialize the video PLL.
This function configures the Video PLL with specific settings
Parameters
brief Initialize the video PLL.
Parameters
◆ CLOCK_InitVideoPllWithFreq()
status_t CLOCK_InitVideoPllWithFreq ( uint32_t  freqInMhz,
bool  ssEnable,
uint32_t  ssRange,
uint32_t  ssMod
Initializes the Video PLL with Specific Frequency (in Mhz).
This function initializes the Video PLL with specific frequency
Parameters
◆ CLOCK_IsSysPfdEnabled()
bool CLOCK_IsSysPfdEnabled ( clock_pfd_t  pfd)
Check if Sys PFD is enabled.
Parameters
pfdPFD control name
Returns
PFD bypass status.
  • true: power on.
  • false: power off.
brief Check if Sys PFD is enabled
param pfd PFD control name return PFD bypass status.
  • true: power on.
  • false: power off.
◆ CLOCK_IsSysPll2PfdEnabled()
bool CLOCK_IsSysPll2PfdEnabled ( clock_pfd_t  pfd)
Check if Sys PLL2 PFD is enabled.
Parameters
pfdPFD control name
Returns
PFD bypass status.
  • true: power on.
  • false: power off.
Note
Only useful in software control mode.
brief Check if Sys PLL2 PFD is enabled
  • true: power on.
  • false: power off. note Only useful in software control mode.
◆ CLOCK_IsSysPll3PfdEnabled()
bool CLOCK_IsSysPll3PfdEnabled ( clock_pfd_t  pfd)
Check if Sys PLL3 PFD is enabled.
Parameters
pfdPFD control name
Returns
PFD bypass status.
  • true: power on.
  • false: power off.
Note
brief Check if Sys PLL3 PFD is enabled
  • true: power on.
◆ CLOCK_IsUsb1PfdEnabled()
bool CLOCK_IsUsb1PfdEnabled ( clock_pfd_t  pfd)
Check if Usb1 PFD is enabled.
Parameters
pfdPFD control name.
Returns
PFD bypass status.
  • true: power on.
  • false: power off.
brief Check if Usb1 PFD is enabled
param pfd PFD control name. return PFD bypass status.
  • true: power on.
  • false: power off.
◆ CLOCK_LPCG_ControlByCpuLowPowerMode()
void CLOCK_LPCG_ControlByCpuLowPowerMode ( clock_lpcg_t  name,
uint8_t  domainId,
clock_level_t  level0,
clock_level_t  level1
Set this clock works in CPU Low Power Mode.
Note
When LOCK_MODE bit is set, control mode can not be changed until next system reset.
Parameters
nameClock gate name, see clock_lpcg_t.
domainIdDomains that on the whitelist can change this clock.
level0,level1Depend level of this clock.
◆ CLOCK_LPCG_ControlBySetPointMode()
void CLOCK_LPCG_ControlBySetPointMode ( clock_lpcg_t  name,
uint16_t  spValue,
uint16_t  stbyValue
Set this clock works in SetPoint control Mode.
Note
Parameters
spValueBit0~Bit15 hold value for Setpoint 0~16 respectively. A bitfield value of 0 implies clock will be shutdown in this Setpoint. A bitfield value of 1 implies clock will be turn on in this Setpoint.
stbyValueBit0~Bit15 hold value for Setpoint 0~16 standby. A bitfield value of 0 implies clock will be shutdown during standby. A bitfield value of 1 represent clock will keep Setpoint setting during standby.
◆ CLOCK_OSC_BypassOscRc400MTuneLogic()
void CLOCK_OSC_BypassOscRc400MTuneLogic ( bool  enableBypass)
Bypass/un-bypass the tune logic.
Parameters
enableBypassUsed to control whether to bypass the turn logic.
  • true Bypass the tune logic and use the programmed oscillator frequency to run the oscillator. Function CLOCK_OSC_SetOscRc400MTuneValue() can be used to set oscillator frequency.
  • false Use the output of tune logic to run the oscillator.
brief Bypass/un-bypass the tune logic
param enableBypass Used to control whether to bypass the turn logic.
◆ CLOCK_OSC_CheckLocked1MHzErrorFlag()
bool CLOCK_OSC_CheckLocked1MHzErrorFlag ( void  )
Check the error flag for locked 1MHz clock out.
Returns
The error flag for locked 1MHz clock out.
  • true The count value has been reached within one diviced ref clock period
  • false No effect.
brief Check the error flag for locked 1MHz clock out.
return The error flag for locked 1MHz clock out.
  • false No effect.
◆ CLOCK_OSC_ClearLocked1MHzErrorFlag()
void CLOCK_OSC_ClearLocked1MHzErrorFlag ( void  )
Clear the error flag for locked 1MHz clock out.
brief Clear the error flag for locked 1MHz clock out.
◆ CLOCK_OSC_EnableOsc24M()
void CLOCK_OSC_EnableOsc24M ( void  )
Enable OSC 24Mhz.
This function enables OSC 24Mhz.
◆ CLOCK_OSC_EnableOscRc400M()
void CLOCK_OSC_EnableOscRc400M ( void  )
Enable OSC RC 400Mhz.
This function enables OSC RC 400Mhz.
◆ CLOCK_OSC_EnableOscRc400MTuneLogic()
void CLOCK_OSC_EnableOscRc400MTuneLogic ( bool  enable)
Start/Stop the tune logic.
Parameters
enableUsed to start or stop the tune logic.
  • true Start tuning
  • false Stop tuning and reset the tuning logic.
brief Start/Stop the tune logic.
param enable Used to start or stop the tune logic.
  • true Start tuning
◆ CLOCK_OSC_FreezeOscRc400MTuneValue()
void CLOCK_OSC_FreezeOscRc400MTuneValue ( bool  enableFreeze)
Freeze/Unfreeze the tuning value.
Parameters
enableFreezeUsed to control whether to freeze the tune value.
  • true Freeze the tune at the current tuned value and the oscillator runs at tje frozen tune value.
  • false Unfreezes and continues the tune operation.
brief Freeze/Unfreeze the tuning value.
param enableFreeze Used to control whether to freeze the tune value.
◆ CLOCK_OSC_GetCurrentOscRc400MFastClockCount()
uint16_t CLOCK_OSC_GetCurrentOscRc400MFastClockCount ( void  )
Get current count for the fast clock during the tune process.
Returns
The current count for the fast clock.
brief Get current count for the fast clock during the tune process.
return The current count for the fast clock.
◆ CLOCK_OSC_GetCurrentOscRc400MTuneValue()
uint8_t CLOCK_OSC_GetCurrentOscRc400MTuneValue ( void  )
Get current tune value used by oscillator during tune process.
Returns
The current tune value.
brief Get current tune value used by oscillator during tune process.
return The current tune value.
◆ CLOCK_OSC_Set1MHzOutputBehavior()
void CLOCK_OSC_Set1MHzOutputBehavior ( clock_1MHzOut_behavior_t  behavior)
Set the behavior of the 1MHz output clock, such as disable the 1MHz clock output, enable the free-running 1MHz clock output, enable the locked 1MHz clock output.
Note
The 1MHz clock is divided from 400M RC Oscillator.
Parameters
behaviorThe behavior of 1MHz output clock, please refer to clock_1MHzOut_behavior_t for details.
brief Set the behavior of the 1MHz output clock, such as disable the 1MHz clock output, enable the free-running 1MHz clock output, enable the locked 1MHz clock output.
note The 1MHz clock is divided from 400M RC Oscillator.
param behavior The behavior of 1MHz output clock, please refer to clock_1MHzOut_behavior_t for details.
◆ CLOCK_OSC_SetLocked1MHzCount()
void CLOCK_OSC_SetLocked1MHzCount ( uint16_t  count)
Set the count for the locked 1MHz clock out.
Parameters
countUsed to set the desired target for the locked 1MHz clock out, the value in number of clock cycles of the fast clock per divided ref_clk.
brief Set the count for the locked 1MHz clock out.
param count Used to set the desired target for the locked 1MHz clock out, the value in number of clock cycles of the osc_out_400M per divided ref_clk.
◆ CLOCK_OSC_SetOsc16MConfig()
void CLOCK_OSC_SetOsc16MConfig ( clock_16MOsc_source_t  source,
bool  enablePowerSave,
bool  enableClockOut
Configure the 16MHz oscillator.
Parameters
sourceUsed to select the source for 16MHz RC oscillator, please refer to clock_16MOsc_source_t.
enablePowerSaveEnable/disable power save mode function at 16MHz OSC.
  • true Enable power save mode function at 16MHz osc.
  • false Disable power save mode function at 16MHz osc.
enableClockOutEnable/Disable clock output for 16MHz RCOSC.
  • true Enable clock output for 16MHz RCOSC.
  • false Disable clock output for 16MHz RCOSC.
brief Configure the 16MHz oscillator.
param source Used to select the source for 16MHz RC oscillator, please refer to clock_16MOsc_source_t. param enablePowerSave Enable/disable power save mode function at 16MHz OSC.
  • false Disable power save mode function at 16MHz osc. param enableClockOut Enable/Disable clock output for 16MHz RCOSC.
◆ CLOCK_OSC_SetOsc24MWorkMode()
void CLOCK_OSC_SetOsc24MWorkMode ( clock_24MOsc_mode_t  workMode)
Set the work mode of 24MHz crystal oscillator, the available modes are high gian mode, low power mode, and bypass mode.
Parameters
workModeThe work mode of 24MHz crystal oscillator, please refer to clock_24MOsc_mode_t for details.
brief Set the work mode of 24MHz crystal oscillator, the available modes are high gian mode, low power mode, and bypass mode.
param workMode The work mode of 24MHz crystal oscillator, please refer to clock_24MOsc_mode_t for details.
◆ CLOCK_OSC_SetOscRc400MFastClkCount()
void CLOCK_OSC_SetOscRc400MFastClkCount ( uint16_t  targetCount)
Set the target count for the fast clock.
Parameters
targetCountThe desired target for the fast clock, should be the number of clock cycles of the fast_clk per divided ref_clk.
brief Set the target count for the fast clock.
param targetCount The desired target for the fast clock, should be the number of clock cycles of the fast_clk per divided ref_clk.
◆ CLOCK_OSC_SetOscRc400MHysteresisValue()
void CLOCK_OSC_SetOscRc400MHysteresisValue ( uint8_t  negHysteresis,
uint8_t  posHysteresis
Set the negative and positive hysteresis value for the tuned clock.
Note
The hysteresis value should be set after the clock is tuned.
Parameters
negHysteresisThe negative hysteresis value for the turned clock, this value in number of clock cycles of the fast clock
posHysteresisThe positive hysteresis value for the turned clock, this value in number of clock cycles of the fast clock
brief Set the negative and positive hysteresis value for the tuned clock.
note The hysteresis value should be set after the clock is tuned.
param negHysteresis The negative hysteresis value for the turned clock, this value in number of clock cycles of the fast clock param posHysteresis The positive hysteresis value for the turned clock, this value in number of clock cycles of the fast clock
◆ CLOCK_OSC_SetOscRc400MRefClkDiv()
void CLOCK_OSC_SetOscRc400MRefClkDiv ( uint8_t  divValue)
Set the divide value for ref_clk to generate slow clock.
Note
slow_clk = ref_clk / (divValue + 1), and the recommand divide value is 24.
Parameters
divValueThe divide value to be set, the available range is 0~63.
brief Set the divide value for ref_clk to generate slow clock.
note slow_clk = ref_clk / (divValue + 1), and the recommand divide value is 24.
param divValue The divide value to be set, the available range is 0~63.
◆ CLOCK_OSC_SetOscRc400MTuneValue()
void CLOCK_OSC_SetOscRc400MTuneValue ( uint8_t  tuneValue)
Set the 400MHz RC oscillator tune value when the tune logic is disabled.
Parameters
tuneValueThe tune value to determine the frequency of Oscillator.
◆ CLOCK_OSC_TrimOscRc400M()
void CLOCK_OSC_TrimOscRc400M ( bool  enable,
bool  bypass,
uint16_t  trim
Trims OSC RC 400MHz.
Parameters
enableUsed to enable trim function.
bypassBypass the trim function.
trimTrim value.
◆ CLOCK_OSCPLL_ControlByCpuLowPowerMode()
void CLOCK_OSCPLL_ControlByCpuLowPowerMode ( clock_name_t  name,
uint8_t  domainId,
Note
Parameters
nameClock source name, see clock_name_t.
◆ CLOCK_OSCPLL_ControlBySetPointMode()
void CLOCK_OSCPLL_ControlBySetPointMode ( clock_name_t  name,
uint16_t  spValue,
uint16_t  stbyValue
Note
Parameters
◆ CLOCK_ROOT_ControlBySetPointMode()
void CLOCK_ROOT_ControlBySetPointMode ( clock_root_t  name,
const clock_root_setpoint_config_t spTable
Set this clock works in SetPoint controlled Mode.
Note
Parameters
nameClock root name, see clock_root_t.
spTablePoint to the array that stores clock root settings for each setpoint. Note that the pointed array must have 16 elements.
◆ CLOCK_SetClockOutput1()
void CLOCK_SetClockOutput1 ( clock_output1_selection_t  selection,
clock_output_divider_t  divider
Set the clock source and the divider of the clock output1.
Parameters
selectionThe clock source to be output, please refer to clock_output1_selection_t.
dividerThe divider of the output clock signal, please refer to clock_output_divider_t.
brief Set the clock source and the divider of the clock output1.
param selection The clock source to be output, please refer to clock_output1_selection_t. param divider The divider of the output clock signal, please refer to clock_output_divider_t.
◆ CLOCK_SetClockOutput2()
void CLOCK_SetClockOutput2 ( clock_output2_selection_t  selection,
Set the clock source and the divider of the clock output2.
Parameters
selectionThe clock source to be output, please refer to clock_output2_selection_t.
brief Set the clock source and the divider of the clock output2.
param selection The clock source to be output, please refer to clock_output2_selection_t. param divider The divider of the output clock signal, please refer to clock_output_divider_t.
◆ CLOCK_SetGroupConfig()
void CLOCK_SetGroupConfig ( clock_group_t  group,
const clock_group_config_t config
Set the clock group configuration.
Parameters
groupWhich group to configure, see clock_group_t.
configConfiguration to set.
◆ CLOCK_SetPllBypass()
void CLOCK_SetPllBypass ( clock_pll_t  pll,
bool  bypass
PLL bypass setting.
Parameters
pllPLL control name (see clock_pll_t enumeration)
bypassBypass the PLL.
  • true: Bypass the PLL.
  • false:Not bypass the PLL.
◆ CLOCK_SwitchOsc()
void CLOCK_SwitchOsc ( clock_osc_t  osc)
Switch the OSC.
This function switches the OSC source for SoC.
Parameters
oscOSC source to switch to.
brief Switch the OSC.
param osc OSC source to switch to.
Variable Documentation
◆ clockOff
bool _clock_group_config::clockOff
Turn off the clock.
◆ denominator [1/2]
uint32_t _clock_audio_pll_config::denominator
30 bit denominator of fractional loop divider
◆ denominator [2/2]
uint32_t _clock_audio_pll_gpc_config::denominator
◆ div [1/2]
uint8_t _clock_root_config_t::div
it's the actual divider
◆ div [2/2]
uint8_t _clock_root_setpoint_config_t::div
◆ div0
uint8_t _clock_group_config::div0
Divide root clock by div0 + 1, valid range: 0 ~ 15.
◆ enableClkOutput
bool _clock_enet_pll_config::enableClkOutput
Power on and enable PLL clock output for ENET0 (ref_enetpll0).
◆ enableClkOutput1
bool _clock_enet_pll_config::enableClkOutput1
Power on and enable PLL clock output for ENET1 (ref_enetpll1).
◆ enableClkOutput25M
bool _clock_enet_pll_config::enableClkOutput25M
Power on and enable PLL clock output for ENET2 (ref_enetpll2).
◆ g_rtcXtalFreq
volatile uint32_t g_rtcXtalFreq
extern
External RTC XTAL (32K OSC) clock frequency.
The RTC XTAL (32K OSC) clock frequency in Hz, when the clock is setup, use the function CLOCK_SetRtcXtalFreq to set the value in to clock driver.
◆ g_xtalFreq
volatile uint32_t g_xtalFreq
extern
External XTAL (24M OSC/SYSOSC) clock frequency.
The XTAL (24M OSC/SYSOSC) clock frequency in Hz, when the clock is setup, use the function CLOCK_SetXtalFreq to set the value in to clock driver. For example, if XTAL is 24MHz,
CLOCK_SetXtalFreq(240000000);
void CLOCK_InitExternalClk(bool bypassXtalOsc)
Definition: fsl_clock.c:189
◆ grade
uint8_t _clock_root_setpoint_config_t::grade
Indicate speed grade for each SetPoint
◆ loopDivider [1/5]
uint32_t _clock_arm_pll_config::loopDivider
PLL loop divider. Valid range for divider value: 54-108. Fout=Fin*loopDivider/2.
PLL loop divider. Valid range: 104-208.
◆ loopDivider [2/5]
uint8_t _clock_usb_pll_config::loopDivider
PLL loop divider. 0 - Fout=Fref*20; 1 - Fout=Fref*22
◆ loopDivider [3/5]
uint8_t _clock_audio_pll_config::loopDivider
PLL loop divider. Valid range for DIV_SELECT divider value: 27~54.
◆ loopDivider [4/5]
uint8_t _clock_enet_pll_config::loopDivider
Controls the frequency of the ENET0 reference clock. b00 25MHz b01 50MHz b10 100MHz (not 50% duty cycle) b11 125MHz
◆ loopDivider [5/5]
uint8_t _clock_audio_pll_gpc_config::loopDivider
PLL loop divider.
◆ loopDivider1
uint8_t _clock_enet_pll_config::loopDivider1
Controls the frequency of the ENET1 reference clock. b00 25MHz b01 50MHz b10 100MHz (not 50% duty cycle) b11 125MHz
◆ mfd
uint32_t _clock_sys_pll2_config::mfd
Denominator of spread spectrum
◆ mux [1/2]
uint8_t _clock_root_config_t::mux
See clock_root_mux_source_t for details.
◆ mux [2/2]
uint8_t _clock_root_setpoint_config_t::mux
◆ numerator [1/2]
uint32_t _clock_audio_pll_config::numerator
30 bit numerator of fractional loop divider.
◆ numerator [2/2]
uint32_t _clock_audio_pll_gpc_config::numerator
◆ pllDiv2En
bool _clock_sys_pll1_config::pllDiv2En
Enable Sys Pll1 divide-by-2 clock or not.
◆ pllDiv5En
bool _clock_sys_pll1_config::pllDiv5En
Enable Sys Pll1 divide-by-5 clock or not.
◆ postDivider [1/2]
uint8_t _clock_audio_pll_config::postDivider
Divider after the PLL, should only be 1, 2, 4, 8, 16.
Divider after the PLL, 0x0=divided by 1, 0x1=divided by 2, 0x2=divided by 4, 0x3=divided by 8, 0x4=divided by 16, 0x5=divided by 32.
◆ postDivider [2/2]
clock_pll_post_div_t _clock_arm_pll_config::postDivider
Post divider.
◆ resetDiv
uint16_t _clock_group_config::resetDiv
resetDiv + 1 should be common multiple of all dividers, valid range 0 ~ 255.
◆ src [1/2]
uint8_t _clock_usb_pll_config::src
Pll clock source, reference _clock_pll_clk_src
◆ src [2/2]
uint8_t _clock_enet_pll_config::src
◆ ss [1/4]
clock_pll_ss_config_t* _clock_sys_pll2_config::ss
Spread spectrum parameter, it can be NULL, if ssEnable is set to false
◆ ss [2/4]
clock_pll_ss_config_t* _clock_sys_pll1_config::ss
◆ ss [3/4]
clock_pll_ss_config_t* _clock_audio_pll_config::ss
◆ ss [4/4]
clock_pll_ss_config_t* _clock_audio_pll_gpc_config::ss
◆ ssEnable [1/4]
bool _clock_sys_pll2_config::ssEnable
Enable spread spectrum flag
◆ ssEnable [2/4]
bool _clock_sys_pll1_config::ssEnable
◆ ssEnable [3/4]
bool _clock_audio_pll_config::ssEnable
◆ ssEnable [4/4]
bool _clock_audio_pll_gpc_config::ssEnable
◆ step
uint16_t _clock_pll_ss_config::step
Spread spectrum step value to get frequency change step.
◆ stop
uint16_t _clock_pll_ss_config::stop
Spread spectrum stop value to get frequency change.
