RTEMS 6.1-rc1
Test context for spec:/rtems/intr/req/is-pending test case. More...
Data Fields | |
volatile uint32_t | interrupt_count |
This member contains the count of serviced interrupts. | |
bool | do_clear |
If this member is true, then the interrupt shall be cleared. | |
rtems_vector_number | vector |
This member contains the current vector number. | |
bool | pending_obj |
This member provides the bool object. | |
bool | valid_vector |
If this member is true, then the vector parameter shall be valid. | |
bool * | pending |
This member specifies if the pending parameter value. | |
rtems_status_code | status |
This member contains the return value of the rtems_interrupt_is_pending() call. | |
struct { | |
size_t pci [3] | |
This member defines the pre-condition indices for the next action. | |
size_t pcs [3] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsIntrReqIsPending_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
