RTEMS 6.1-rc1
Test context for spec:/rtems/sem/val/smp test case. More...
rtems_id mutex_id
 This member contains the mutex identifier.
rtems_id mutex_2_id
 This member contains the second mutex identifier.
volatile bool done
 If this member is true, then the worker is done.
volatile bool done_2
 If this member is true, then the second worker is done.
