RTEMS 6.1-rc1
Data Fields | |
off_t | file_size |
int | ctrl_socket |
uint32_t | client_address |
int | data_socket |
size_t | reply_current |
size_t | reply_end |
char | reply_buffer [128] |
bool | eof |
bool | write |
bool | do_size_command |
ino_t | ino |
const char * | user |
const char * | password |
const char * | hostname |
const char * | filename |
char | buffer [] |
Connection entry for each open file stream.
int rtems_ftpfs_entry::ctrl_socket |
Control connection socket.
int rtems_ftpfs_entry::data_socket |
Data transfer socket.
bool rtems_ftpfs_entry::do_size_command |
Indicates if we should do a SIZE command.
The first call to the rtems_ftpfs_fstat() handler is issued by the path evaluation to check for access permission. For this case we avoid the SIZE command.
bool rtems_ftpfs_entry::eof |
End of file flag.
char rtems_ftpfs_entry::reply_buffer[128] |
Buffer for relpy data.
size_t rtems_ftpfs_entry::reply_current |
Current index into the reply buffer.
size_t rtems_ftpfs_entry::reply_end |
End index of the reply buffer.
