RTEMS 6.1-rc1
JFFS2 filesystem instance information. More...
#include <jffs2.h>
uint32_t flash_size
 Flash size in bytes.
uint32_t flash_blocks
 Count of flash blocks (erasable units).
uint32_t flash_block_size
 Size of a flash block in bytes.
uint32_t used_size
 Used size in bytes. More...
uint32_t dirty_size
 Dirty size in bytes. More...
uint32_t wasted_size
 Wasted size in bytes. More...
uint32_t free_size
 Free size in bytes. More...
uint32_t bad_size
 Bad size in bytes. More...
uint32_t clean_blocks
 Count of clean blocks. More...
uint32_t dirty_blocks
 Count of dirty blocks. More...
uint32_t erasable_blocks
 Count of erasable blocks. More...
uint32_t free_blocks
 Count of free blocks. More...
uint32_t bad_blocks
 Count of bad blocks. More...
See also
RTEMS_JFFS2_GET_INFO.
Field Documentation
◆ bad_blocks
uint32_t rtems_jffs2_info::bad_blocks
Bad blocks are damaged.
◆ bad_size
uint32_t rtems_jffs2_info::bad_size
Bad size in bytes.
Bad areas indicate damaged flash blocks.
◆ clean_blocks
uint32_t rtems_jffs2_info::clean_blocks
Clean blocks contain only used areas.
◆ dirty_blocks
uint32_t rtems_jffs2_info::dirty_blocks
Dirty blocks contain dirty and used areas.
◆ dirty_size
uint32_t rtems_jffs2_info::dirty_size
Used areas contain no longer used data.
◆ erasable_blocks
uint32_t rtems_jffs2_info::erasable_blocks
Erase blocks contain only dirty or wasted areas.
◆ free_blocks
uint32_t rtems_jffs2_info::free_blocks
Free blocks contain a free area.
◆ free_size
uint32_t rtems_jffs2_info::free_size
Free size in bytes.
Free areas may be used to store new data.
◆ used_size
uint32_t rtems_jffs2_info::used_size
Used size in bytes.
Used areas contain valid data.
◆ wasted_size
uint32_t rtems_jffs2_info::wasted_size
Wasted areas are unusable.
