RTEMS 6.1-rc1
_sai_sdma_handle Struct Reference
SAI DMA transfer handle, users should not touch the content of the handle. More...
#include <fsl_sai_sdma.h>
sdma_handle_t * dmaHandle
uint8_t bytesPerFrame
uint8_t channel
uint8_t channelNums
uint8_t channelMask
uint8_t fifoOffset
uint32_t count
uint32_t state
uint32_t eventSource
sai_sdma_callback_t callback
void * userData
sdma_buffer_descriptor_t bdPool [SAI_XFER_QUEUE_SIZE]
sai_transfer_t saiQueue [SAI_XFER_QUEUE_SIZE]
size_t transferSize [SAI_XFER_QUEUE_SIZE]
volatile uint8_t queueUser
volatile uint8_t queueDriver
Field Documentation
◆ bdPool
sdma_buffer_descriptor_t _sai_sdma_handle::bdPool[SAI_XFER_QUEUE_SIZE]
BD pool for SDMA transfer.
◆ bytesPerFrame
uint8_t _sai_sdma_handle::bytesPerFrame
Bytes in a frame
◆ callback
sai_sdma_callback_t _sai_sdma_handle::callback
Callback for users while transfer finish or error occurs
◆ channel
uint8_t _sai_sdma_handle::channel
start data channel
◆ channelMask
uint8_t _sai_sdma_handle::channelMask
enabled channel mask value, refernece _sai_channel_mask
◆ channelNums
uint8_t _sai_sdma_handle::channelNums
total transfer channel numbers, used for multififo
◆ count
uint32_t _sai_sdma_handle::count
The transfer data count in a DMA request
◆ dmaHandle
sdma_handle_t* _sai_sdma_handle::dmaHandle
DMA handler for SAI send
◆ eventSource
uint32_t _sai_sdma_handle::eventSource
SAI event source number
◆ fifoOffset
uint8_t _sai_sdma_handle::fifoOffset
fifo address offset between multifo
◆ queueDriver
volatile uint8_t _sai_sdma_handle::queueDriver
Index for driver to get the transfer data and size
◆ queueUser
volatile uint8_t _sai_sdma_handle::queueUser
Index for user to queue transfer.
◆ saiQueue
sai_transfer_t _sai_sdma_handle::saiQueue[SAI_XFER_QUEUE_SIZE]
Transfer queue storing queued transfer.
◆ state
uint32_t _sai_sdma_handle::state
Internal state for SAI SDMA transfer
◆ transferSize
size_t _sai_sdma_handle::transferSize[SAI_XFER_QUEUE_SIZE]
Data bytes need to transfer
◆ userData
void* _sai_sdma_handle::userData
User callback parameter
