RTEMS 6.1-rc1
Data Structures | Enumerator | Variables
Flexcan_driver
struct  _flexcan_frame
 FlexCAN message frame structure. More...
struct  _flexcan_timing_config
 FlexCAN protocol timing characteristic configuration structure. More...
struct  _flexcan_config
 FlexCAN module configuration structure. More...
struct  _flexcan_rx_mb_config
 FlexCAN Receive Message Buffer configuration structure. More...
struct  _flexcan_rx_fifo_config
 FlexCAN Legacy Rx FIFO configuration structure. More...
struct  _flexcan_mb_transfer
 FlexCAN Message Buffer transfer. More...
struct  _flexcan_fifo_transfer
 FlexCAN Rx FIFO transfer. More...
struct  _flexcan_handle
 FlexCAN handle structure. More...
uint32_t   _flexcan_frame::timestamp: 16
uint32_t   _flexcan_frame::length: 4
uint32_t   _flexcan_frame::type: 1
uint32_t   _flexcan_frame::format: 1
uint32_t   _flexcan_frame::__pad0__: 1
uint32_t   _flexcan_frame::idhit: 9
struct {
uint32_t   _flexcan_frame::id: 29
uint32_t   _flexcan_frame::__pad0__: 3
struct {
uint32_t   _flexcan_frame::dataWord0
uint32_t   _flexcan_frame::dataWord1
struct {
uint8_t   _flexcan_frame::dataByte3
uint8_t   _flexcan_frame::dataByte2
uint8_t   _flexcan_frame::dataByte1
uint8_t   _flexcan_frame::dataByte0
uint8_t   _flexcan_frame::dataByte7
uint8_t   _flexcan_frame::dataByte6
uint8_t   _flexcan_frame::dataByte5
uint8_t   _flexcan_frame::dataByte4
struct {
union {
   struct {
   struct {
uint16_t _flexcan_timing_config::preDivider
uint8_t _flexcan_timing_config::rJumpwidth
uint8_t _flexcan_timing_config::phaseSeg1
uint8_t _flexcan_timing_config::phaseSeg2
uint8_t _flexcan_timing_config::propSeg
uint32_t   _flexcan_config::baudRate
struct {
uint32_t   _flexcan_config::bitRate
struct {
union {
   struct {
   struct {
flexcan_clock_source_t _flexcan_config::clkSrc
flexcan_wake_up_source_t _flexcan_config::wakeupSrc
uint8_t _flexcan_config::maxMbNum
bool _flexcan_config::enableLoopBack
bool _flexcan_config::enableTimerSync
bool _flexcan_config::enableSelfWakeup
bool _flexcan_config::enableIndividMask
bool _flexcan_config::disableSelfReception
bool _flexcan_config::enableListenOnlyMode
bool _flexcan_config::enableSupervisorMode
flexcan_timing_config_t _flexcan_config::timingConfig
uint32_t _flexcan_rx_mb_config::id
flexcan_frame_format_t _flexcan_rx_mb_config::format
flexcan_frame_type_t _flexcan_rx_mb_config::type
uint32_t * _flexcan_rx_fifo_config::idFilterTable
uint8_t _flexcan_rx_fifo_config::idFilterNum
flexcan_rx_fifo_filter_type_t _flexcan_rx_fifo_config::idFilterType
flexcan_rx_fifo_priority_t _flexcan_rx_fifo_config::priority
flexcan_frame_t_flexcan_mb_transfer::frame
uint8_t _flexcan_mb_transfer::mbIdx
flexcan_frame_t_flexcan_fifo_transfer::frame
size_t _flexcan_fifo_transfer::frameNum
flexcan_transfer_callback_t _flexcan_handle::callback
void * _flexcan_handle::userData
flexcan_frame_t *volatile _flexcan_handle::mbFrameBuf [CAN_WORD1_COUNT]
flexcan_frame_t *volatile _flexcan_handle::rxFifoFrameBuf
size_t _flexcan_handle::rxFifoFrameNum
size_t _flexcan_handle::rxFifoTransferTotalNum
volatile uint8_t _flexcan_handle::mbState [CAN_WORD1_COUNT]
volatile uint8_t _flexcan_handle::rxFifoState
volatile uint32_t _flexcan_handle::timestamp [CAN_WORD1_COUNT]
Driver version
enum  {
  kStatus_FLEXCAN_TxBusy = MAKE_STATUS(kStatusGroup_FLEXCAN, 0) , kStatus_FLEXCAN_TxIdle = MAKE_STATUS(kStatusGroup_FLEXCAN, 1) , kStatus_FLEXCAN_TxSwitchToRx , kStatus_FLEXCAN_RxBusy = MAKE_STATUS(kStatusGroup_FLEXCAN, 3) ,
  kStatus_FLEXCAN_RxIdle = MAKE_STATUS(kStatusGroup_FLEXCAN, 4) , kStatus_FLEXCAN_RxOverflow = MAKE_STATUS(kStatusGroup_FLEXCAN, 5) , kStatus_FLEXCAN_RxFifoBusy = MAKE_STATUS(kStatusGroup_FLEXCAN, 6) , kStatus_FLEXCAN_RxFifoIdle = MAKE_STATUS(kStatusGroup_FLEXCAN, 7) ,
  kStatus_FLEXCAN_RxFifoOverflow = MAKE_STATUS(kStatusGroup_FLEXCAN, 8) , kStatus_FLEXCAN_RxFifoWarning = MAKE_STATUS(kStatusGroup_FLEXCAN, 9) , kStatus_FLEXCAN_RxFifoDisabled , kStatus_FLEXCAN_ErrorStatus = MAKE_STATUS(kStatusGroup_FLEXCAN, 11) ,
  kStatus_FLEXCAN_WakeUp = MAKE_STATUS(kStatusGroup_FLEXCAN, 12) , kStatus_FLEXCAN_UnHandled = MAKE_STATUS(kStatusGroup_FLEXCAN, 13) , kStatus_FLEXCAN_RxRemote = MAKE_STATUS(kStatusGroup_FLEXCAN, 14)
 FlexCAN transfer status. More...
enum  _flexcan_frame_format { kFLEXCAN_FrameFormatStandard = 0x0U , kFLEXCAN_FrameFormatExtend = 0x1U }
 FlexCAN frame format. More...
enum  _flexcan_frame_type { kFLEXCAN_FrameTypeData = 0x0U , kFLEXCAN_FrameTypeRemote = 0x1U }
 FlexCAN frame type. More...
enum  _flexcan_clock_source { kFLEXCAN_ClkSrcOsc = 0x0U , kFLEXCAN_ClkSrcPeri = 0x1U , kFLEXCAN_ClkSrc0 = 0x0U , kFLEXCAN_ClkSrc1 = 0x1U }
 FlexCAN clock source. More...
enum  _flexcan_wake_up_source { kFLEXCAN_WakeupSrcUnfiltered = 0x0U , kFLEXCAN_WakeupSrcFiltered = 0x1U }
 FlexCAN wake up source. More...
enum  _flexcan_rx_fifo_filter_type { kFLEXCAN_RxFifoFilterTypeA = 0x0U , kFLEXCAN_RxFifoFilterTypeB , kFLEXCAN_RxFifoFilterTypeC , kFLEXCAN_RxFifoFilterTypeD = 0x3U }
 FlexCAN Rx Fifo Filter type. More...
enum  _flexcan_rx_fifo_priority { kFLEXCAN_RxFifoPrioLow = 0x0U , kFLEXCAN_RxFifoPrioHigh = 0x1U }
 FlexCAN Enhanced/Legacy Rx FIFO priority. More...
enum  _flexcan_interrupt_enable {
  kFLEXCAN_BusOffInterruptEnable = CAN_CTRL1_BOFFMSK_MASK , kFLEXCAN_ErrorInterruptEnable = CAN_CTRL1_ERRMSK_MASK , kFLEXCAN_TxWarningInterruptEnable = CAN_CTRL1_TWRNMSK_MASK , kFLEXCAN_RxWarningInterruptEnable = CAN_CTRL1_RWRNMSK_MASK ,
  kFLEXCAN_WakeUpInterruptEnable = CAN_MCR_WAKMSK_MASK
 FlexCAN interrupt enable enumerations. More...
enum  _flexcan_flags {
  kFLEXCAN_SynchFlag = CAN_ESR1_SYNCH_MASK , kFLEXCAN_TxWarningIntFlag = CAN_ESR1_TWRNINT_MASK , kFLEXCAN_RxWarningIntFlag = CAN_ESR1_RWRNINT_MASK , kFLEXCAN_IdleFlag = CAN_ESR1_IDLE_MASK ,
  kFLEXCAN_FaultConfinementFlag = CAN_ESR1_FLTCONF_MASK , kFLEXCAN_TransmittingFlag = CAN_ESR1_TX_MASK , kFLEXCAN_ReceivingFlag = CAN_ESR1_RX_MASK , kFLEXCAN_BusOffIntFlag = CAN_ESR1_BOFFINT_MASK ,
  kFLEXCAN_ErrorIntFlag = CAN_ESR1_ERRINT_MASK , kFLEXCAN_WakeUpIntFlag = CAN_ESR1_WAKINT_MASK , kFLEXCAN_ErrorFlag
 FlexCAN status flags. More...
enum  _flexcan_error_flags {
  kFLEXCAN_TxErrorWarningFlag = CAN_ESR1_TXWRN_MASK , kFLEXCAN_RxErrorWarningFlag = CAN_ESR1_RXWRN_MASK , kFLEXCAN_StuffingError = CAN_ESR1_STFERR_MASK , kFLEXCAN_FormError = CAN_ESR1_FRMERR_MASK ,
  kFLEXCAN_CrcError = CAN_ESR1_CRCERR_MASK , kFLEXCAN_AckError = CAN_ESR1_ACKERR_MASK , kFLEXCAN_Bit0Error = CAN_ESR1_BIT0ERR_MASK , kFLEXCAN_Bit1Error = CAN_ESR1_BIT1ERR_MASK
 FlexCAN error status flags. More...
enum  { kFLEXCAN_RxFifoOverflowFlag = CAN_IFLAG1_BUF7I_MASK , kFLEXCAN_RxFifoWarningFlag = CAN_IFLAG1_BUF6I_MASK , kFLEXCAN_RxFifoFrameAvlFlag = CAN_IFLAG1_BUF5I_MASK }
 FlexCAN Legacy Rx FIFO status flags. More...
typedef enum _flexcan_frame_format flexcan_frame_format_t
typedef enum _flexcan_frame_type flexcan_frame_type_t
 FlexCAN frame type.
typedef enum _flexcan_clock_source flexcan_clock_source_t
typedef enum _flexcan_wake_up_source flexcan_wake_up_source_t
typedef enum _flexcan_rx_fifo_filter_type flexcan_rx_fifo_filter_type_t
typedef enum _flexcan_rx_fifo_priority flexcan_rx_fifo_priority_t
typedef struct _flexcan_frame flexcan_frame_t
typedef struct _flexcan_timing_config flexcan_timing_config_t
typedef struct _flexcan_config flexcan_config_t
typedef struct _flexcan_rx_mb_config flexcan_rx_mb_config_t
typedef struct _flexcan_rx_fifo_config flexcan_rx_fifo_config_t
typedef struct _flexcan_mb_transfer flexcan_mb_transfer_t
typedef struct _flexcan_fifo_transfer flexcan_fifo_transfer_t
typedef struct _flexcan_handle flexcan_handle_t
 FlexCAN handle structure definition.
typedef void(* flexcan_transfer_callback_t) (CAN_Type *base, flexcan_handle_t *handle, status_t status, uint32_t result, void *userData)
#define FSL_FLEXCAN_DRIVER_VERSION   (MAKE_VERSION(2, 9, 2))
 FlexCAN driver version.
#define FLEXCAN_WAIT_TIMEOUT   (1000U)
#define FLEXCAN_ID_STD(id)    (((uint32_t)(((uint32_t)(id)) << CAN_ID_STD_SHIFT)) & CAN_ID_STD_MASK)
 FlexCAN frame length helper macro. More...
#define FLEXCAN_ID_EXT(id)
#define FLEXCAN_RX_MB_STD_MASK(id, rtr, ide)
 FlexCAN Rx Message Buffer Mask helper macro. More...
#define FLEXCAN_RX_MB_EXT_MASK(id, rtr, ide)
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_A(id, rtr, ide)
 FlexCAN Legacy Rx FIFO Mask helper macro. More...
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_B_HIGH(id, rtr, ide)
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_B_LOW(id, rtr, ide)
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_HIGH(id)    (((uint32_t)(id)&0x7F8) << 21)
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_MID_HIGH(id)    (((uint32_t)(id)&0x7F8) << 13)
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_MID_LOW(id)    (((uint32_t)(id)&0x7F8) << 5)
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_LOW(id)    (((uint32_t)(id)&0x7F8) >> 3)
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_A(id, rtr, ide)
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_B_HIGH(id, rtr, ide)
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_B_LOW(id, rtr, ide)
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_HIGH(id)    ((FLEXCAN_ID_EXT(id) & 0x1FE00000) << 3)
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_MID_HIGH(id)
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_MID_LOW(id)
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_LOW(id)    ((FLEXCAN_ID_EXT(id) & 0x1FE00000) >> 21)
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_A(id, rtr, ide)    FLEXCAN_RX_FIFO_STD_MASK_TYPE_A(id, rtr, ide)
 FlexCAN Rx FIFO Filter helper macro. More...
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_B_HIGH(id, rtr, ide)
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_B_LOW(id, rtr, ide)
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_HIGH(id)
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_HIGH(id)
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_LOW(id)
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_LOW(id)
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_A(id, rtr, ide)    FLEXCAN_RX_FIFO_EXT_MASK_TYPE_A(id, rtr, ide)
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_B_HIGH(id, rtr, ide)
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_B_LOW(id, rtr, ide)
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_HIGH(id)
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_MID_HIGH(id)
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_MID_LOW(id)
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_LOW(id)    FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_LOW(id)
#define FLEXCAN_ERROR_AND_STATUS_INIT_FLAG
 FlexCAN interrupt/status flag helper macro. More...
#define FLEXCAN_WAKE_UP_FLAG   ((uint32_t)kFLEXCAN_WakeUpIntFlag)
#define FLEXCAN_MEMORY_ERROR_INIT_FLAG   (0U)
#define FLEXCAN_MEMORY_ENHANCED_RX_FIFO_INIT_FLAG   (0U)
 FlexCAN Enhanced Rx FIFO base address helper macro.
#define FLEXCAN_CALLBACK(x)    void(x)(CAN_Type * base, flexcan_handle_t * handle, status_t status, uint32_t result, void *userData)
 FlexCAN transfer callback function. More...
Initialization and deinitialization
void FLEXCAN_EnterFreezeMode (CAN_Type *base)
 Enter FlexCAN Freeze Mode. More...
void FLEXCAN_ExitFreezeMode (CAN_Type *base)
 Exit FlexCAN Freeze Mode. More...
uint32_t FLEXCAN_GetInstance (CAN_Type *base)
 Get the FlexCAN instance from peripheral base address. More...
bool FLEXCAN_CalculateImprovedTimingValues (CAN_Type *base, uint32_t bitRate, uint32_t sourceClock_Hz, flexcan_timing_config_t *pTimingConfig)
 Calculates the improved timing values by specific bit Rates for classical CAN. More...
void FLEXCAN_Init (CAN_Type *base, const flexcan_config_t *pConfig, uint32_t sourceClock_Hz)
 Initializes a FlexCAN instance. More...
void FLEXCAN_Deinit (CAN_Type *base)
 De-initializes a FlexCAN instance. More...
void FLEXCAN_GetDefaultConfig (flexcan_config_t *pConfig)
 Gets the default configuration structure. More...
Configuration.
void FLEXCAN_SetTimingConfig (CAN_Type *base, const flexcan_timing_config_t *pConfig)
 Sets the FlexCAN classical CAN protocol timing characteristic. More...
status_t FLEXCAN_SetBitRate (CAN_Type *base, uint32_t sourceClock_Hz, uint32_t bitRate_Bps)
 Set bit rate of FlexCAN classical CAN frame or CAN FD frame nominal phase. More...
void FLEXCAN_SetRxMbGlobalMask (CAN_Type *base, uint32_t mask)
 Sets the FlexCAN receive message buffer global mask. More...
void FLEXCAN_SetRxFifoGlobalMask (CAN_Type *base, uint32_t mask)
 Sets the FlexCAN receive FIFO global mask. More...
void FLEXCAN_SetRxIndividualMask (CAN_Type *base, uint8_t maskIdx, uint32_t mask)
 Sets the FlexCAN receive individual mask. More...
void FLEXCAN_SetTxMbConfig (CAN_Type *base, uint8_t mbIdx, bool enable)
 Configures a FlexCAN transmit message buffer. More...
void FLEXCAN_SetRxMbConfig (CAN_Type *base, uint8_t mbIdx, const flexcan_rx_mb_config_t *pRxMbConfig, bool enable)
 Configures a FlexCAN Receive Message Buffer. More...
void FLEXCAN_SetRxFifoConfig (CAN_Type *base, const flexcan_rx_fifo_config_t *pRxFifoConfig, bool enable)
 Configures the FlexCAN Legacy Rx FIFO. More...
Bus Operations
status_t FLEXCAN_WriteTxMb (CAN_Type *base, uint8_t mbIdx, const flexcan_frame_t *pTxFrame)
 Writes a FlexCAN Message to the Transmit Message Buffer. More...
status_t FLEXCAN_ReadRxMb (CAN_Type *base, uint8_t mbIdx, flexcan_frame_t *pRxFrame)
 Reads a FlexCAN Message from Receive Message Buffer. More...
status_t FLEXCAN_ReadRxFifo (CAN_Type *base, flexcan_frame_t *pRxFrame)
 Reads a FlexCAN Message from Legacy Rx FIFO. More...
Transactional
status_t FLEXCAN_TransferSendBlocking (CAN_Type *base, uint8_t mbIdx, flexcan_frame_t *pTxFrame)
 Performs a polling send transaction on the CAN bus. More...
status_t FLEXCAN_TransferReceiveBlocking (CAN_Type *base, uint8_t mbIdx, flexcan_frame_t *pRxFrame)
 Performs a polling receive transaction on the CAN bus. More...
status_t FLEXCAN_TransferReceiveFifoBlocking (CAN_Type *base, flexcan_frame_t *pRxFrame)
 Performs a polling receive transaction from Legacy Rx FIFO on the CAN bus. More...
void FLEXCAN_TransferCreateHandle (CAN_Type *base, flexcan_handle_t *handle, flexcan_transfer_callback_t callback, void *userData)
 Initializes the FlexCAN handle. More...
status_t FLEXCAN_TransferSendNonBlocking (CAN_Type *base, flexcan_handle_t *handle, flexcan_mb_transfer_t *pMbXfer)
 Sends a message using IRQ. More...
status_t FLEXCAN_TransferReceiveNonBlocking (CAN_Type *base, flexcan_handle_t *handle, flexcan_mb_transfer_t *pMbXfer)
 Receives a message using IRQ. More...
status_t FLEXCAN_TransferReceiveFifoNonBlocking (CAN_Type *base, flexcan_handle_t *handle, flexcan_fifo_transfer_t *pFifoXfer)
 Receives a message from Rx FIFO using IRQ. More...
status_t FLEXCAN_TransferGetReceiveFifoCount (CAN_Type *base, flexcan_handle_t *handle, size_t *count)
 Gets the Legacy Rx Fifo transfer status during a interrupt non-blocking receive. More...
uint32_t FLEXCAN_GetTimeStamp (flexcan_handle_t *handle, uint8_t mbIdx)
 Gets the detail index of Mailbox's Timestamp by handle. More...
void FLEXCAN_TransferAbortSend (CAN_Type *base, flexcan_handle_t *handle, uint8_t mbIdx)
 Aborts the interrupt driven message send process. More...
void FLEXCAN_TransferAbortReceive (CAN_Type *base, flexcan_handle_t *handle, uint8_t mbIdx)
 Aborts the interrupt driven message receive process. More...
void FLEXCAN_TransferAbortReceiveFifo (CAN_Type *base, flexcan_handle_t *handle)
 Aborts the interrupt driven message receive from Rx FIFO process. More...
void FLEXCAN_TransferHandleIRQ (CAN_Type *base, flexcan_handle_t *handle)
 FlexCAN IRQ handle function. More...
◆ FLEXCAN_CALLBACK
#define FLEXCAN_CALLBACK (   x)     void(x)(CAN_Type * base, flexcan_handle_t * handle, status_t status, uint32_t result, void *userData)
The FlexCAN transfer callback returns a value from the underlying layer. If the status equals to kStatus_FLEXCAN_ErrorStatus, the result parameter is the Content of FlexCAN status register which can be used to get the working status(or error status) of FlexCAN module. If the status equals to other FlexCAN Message Buffer transfer status, the result is the index of Message Buffer that generate transfer event. If the status equals to other FlexCAN Message Buffer transfer status, the result is meaningless and should be Ignored.
◆ FLEXCAN_ERROR_AND_STATUS_INIT_FLAG
Value:
(uint32_t)kFLEXCAN_ErrorIntFlag | FLEXCAN_MEMORY_ERROR_INIT_FLAG)
@ kFLEXCAN_RxWarningIntFlag
Definition: fsl_flexcan.h:503
@ kFLEXCAN_BusOffIntFlag
Definition: fsl_flexcan.h:508
@ kFLEXCAN_TxWarningIntFlag
Definition: fsl_flexcan.h:502
@ kFLEXCAN_ErrorIntFlag
Definition: fsl_flexcan.h:509
◆ FLEXCAN_ID_EXT
#define FLEXCAN_ID_EXT (   id)
Value:
(((uint32_t)(((uint32_t)(id)) << CAN_ID_EXT_SHIFT)) & \
(CAN_ID_EXT_MASK | CAN_ID_STD_MASK))
Extend Frame ID helper macro.
◆ FLEXCAN_ID_STD
#define FLEXCAN_ID_STD (   id)     (((uint32_t)(((uint32_t)(id)) << CAN_ID_STD_SHIFT)) & CAN_ID_STD_MASK)
FlexCAN Frame ID helper macro. Standard Frame ID helper macro.
◆ FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_A
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_A (   id,
  rtr,
  ide
Extend Rx FIFO Filter helper macro Type A helper macro.
◆ FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_B_HIGH
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_B_HIGH (   id,
  rtr,
  ide
Value:
id, rtr, ide)
Definition: fsl_flexcan.h:93
Extend Rx FIFO Filter helper macro Type B upper part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_B_LOW
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_B_LOW (   id,
  rtr,
  ide
Value:
id, rtr, ide)
Definition: fsl_flexcan.h:102
Extend Rx FIFO Filter helper macro Type B lower part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_HIGH
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_HIGH (   id)
Value:
id)
Definition: fsl_flexcan.h:109
Extend Rx FIFO Filter helper macro Type C upper part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_LOW
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_LOW (   id)     FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_LOW(id)
Extend Rx FIFO Filter helper macro Type C lower part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_MID_HIGH
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_MID_HIGH (   id)
Value:
id)
Definition: fsl_flexcan.h:112
Extend Rx FIFO Filter helper macro Type C mid-upper part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_MID_LOW
#define FLEXCAN_RX_FIFO_EXT_FILTER_TYPE_C_MID_LOW (   id)
Value:
id)
Definition: fsl_flexcan.h:117
Extend Rx FIFO Filter helper macro Type C mid-lower part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_MASK_TYPE_A
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_A (   id,
  rtr,
  ide
Value:
(((uint32_t)((uint32_t)(rtr) << 31) | (uint32_t)((uint32_t)(ide) << 30)) | \
(FLEXCAN_ID_EXT(id) << 1))
Definition: fsl_flexcan.h:42
Extend Rx FIFO Mask helper macro Type A helper macro.
◆ FLEXCAN_RX_FIFO_EXT_MASK_TYPE_B_HIGH
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_B_HIGH (   id,
  rtr,
  ide
Value:
((FLEXCAN_ID_EXT(id) & 0x1FFF8000) \
<< 1))
Extend Rx FIFO Mask helper macro Type B upper part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_MASK_TYPE_B_LOW
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_B_LOW (   id,
  rtr,
  ide
Value:
(((uint32_t)((uint32_t)(rtr) << 15) | (uint32_t)((uint32_t)(ide) << 14)) | \
((FLEXCAN_ID_EXT(id) & 0x1FFF8000) >> \
15))
Extend Rx FIFO Mask helper macro Type B lower part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_HIGH
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_HIGH (   id)     ((FLEXCAN_ID_EXT(id) & 0x1FE00000) << 3)
Extend Rx FIFO Mask helper macro Type C upper part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_LOW
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_LOW (   id)     ((FLEXCAN_ID_EXT(id) & 0x1FE00000) >> 21)
Extend Rx FIFO Mask helper macro Type C lower part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_MID_HIGH
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_MID_HIGH (   id)
Value:
((FLEXCAN_ID_EXT(id) & 0x1FE00000) >> \
5)
Extend Rx FIFO Mask helper macro Type C mid-upper part helper macro.
◆ FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_MID_LOW
#define FLEXCAN_RX_FIFO_EXT_MASK_TYPE_C_MID_LOW (   id)
Value:
13)
Extend Rx FIFO Mask helper macro Type C mid-lower part helper macro.
◆ FLEXCAN_RX_FIFO_STD_FILTER_TYPE_A
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_A (   id,
  rtr,
  ide
Standard Rx FIFO Filter helper macro Type A helper macro.
◆ FLEXCAN_RX_FIFO_STD_FILTER_TYPE_B_HIGH
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_B_HIGH (   id,
  rtr,
  ide
Value:
id, rtr, ide)
Definition: fsl_flexcan.h:66
Standard Rx FIFO Filter helper macro Type B upper part helper macro.
◆ FLEXCAN_RX_FIFO_STD_FILTER_TYPE_B_LOW
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_B_LOW (   id,
  rtr,
  ide
Value:
id, rtr, ide)
Definition: fsl_flexcan.h:71
Standard Rx FIFO Filter helper macro Type B lower part helper macro.
◆ FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_HIGH
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_HIGH (   id)
Value:
id)
Definition: fsl_flexcan.h:76
Standard Rx FIFO Filter helper macro Type C upper part helper macro.
◆ FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_LOW
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_LOW (   id)
Value:
id)
Definition: fsl_flexcan.h:85
Standard Rx FIFO Filter helper macro Type C lower part helper macro.
◆ FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_HIGH
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_HIGH (   id)
Value:
id)
Definition: fsl_flexcan.h:79
Standard Rx FIFO Filter helper macro Type C mid-upper part helper macro.
◆ FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_LOW
#define FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_LOW (   id)
Value:
id)
Definition: fsl_flexcan.h:82
Standard Rx FIFO Filter helper macro Type C mid-lower part helper macro.
◆ FLEXCAN_RX_FIFO_STD_MASK_TYPE_A
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_A (   id,
  rtr,
  ide
Value:
(FLEXCAN_ID_STD(id) << 1))
Definition: fsl_flexcan.h:39
Standard Rx FIFO Mask helper macro Type A helper macro.
◆ FLEXCAN_RX_FIFO_STD_MASK_TYPE_B_HIGH
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_B_HIGH (   id,
  rtr,
  ide
Value:
(((uint32_t)(id)&0x7FF) << 19))
Standard Rx FIFO Mask helper macro Type B upper part helper macro.
◆ FLEXCAN_RX_FIFO_STD_MASK_TYPE_B_LOW
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_B_LOW (   id,
  rtr,
  ide
Value:
(((uint32_t)(id)&0x7FF) << 3))
Standard Rx FIFO Mask helper macro Type B lower part helper macro.
◆ FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_HIGH
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_HIGH (   id)     (((uint32_t)(id)&0x7F8) << 21)
Standard Rx FIFO Mask helper macro Type C upper part helper macro.
◆ FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_LOW
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_LOW (   id)     (((uint32_t)(id)&0x7F8) >> 3)
Standard Rx FIFO Mask helper macro Type C lower part helper macro.
◆ FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_MID_HIGH
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_MID_HIGH (   id)     (((uint32_t)(id)&0x7F8) << 13)
Standard Rx FIFO Mask helper macro Type C mid-upper part helper macro.
◆ FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_MID_LOW
#define FLEXCAN_RX_FIFO_STD_MASK_TYPE_C_MID_LOW (   id)     (((uint32_t)(id)&0x7F8) << 5)
Standard Rx FIFO Mask helper macro Type C mid-lower part helper macro.
◆ FLEXCAN_RX_MB_EXT_MASK
#define FLEXCAN_RX_MB_EXT_MASK (   id,
  rtr,
  ide
Value:
Extend Rx Message Buffer Mask helper macro.
◆ FLEXCAN_RX_MB_STD_MASK
#define FLEXCAN_RX_MB_STD_MASK (   id,
  rtr,
  ide
Value:
Standard Rx Message Buffer Mask helper macro.
Typedef Documentation
◆ flexcan_clock_source_t
Deprecated:
Do not use the kFLEXCAN_ClkSrcOs. It has been superceded kFLEXCAN_ClkSrc0
Do not use the kFLEXCAN_ClkSrcPeri. It has been superceded kFLEXCAN_ClkSrc1
◆ flexcan_config_t
Deprecated:
Do not use the baudRate. It has been superceded bitRate
Do not use the baudRateFD. It has been superceded bitRateFD
◆ flexcan_rx_fifo_priority_t
The matching process starts from the Rx MB(or Enhanced/Legacy Rx FIFO) with higher priority. If no MB(or Enhanced/Legacy Rx FIFO filter) is satisfied, the matching process goes on with the Enhanced/Legacy Rx FIFO(or Rx MB) with lower priority.
◆ flexcan_rx_mb_config_t
This structure is used as the parameter of FLEXCAN_SetRxMbConfig() function. The FLEXCAN_SetRxMbConfig() function is used to configure FlexCAN Receive Message Buffer. The function abort previous receiving process, clean the Message Buffer and activate the Rx Message Buffer using given Message Buffer setting.
◆ anonymous enum
anonymous enum
Tx Message Buffer is Busy.
Tx Message Buffer is Idle.
Remote Message is send out and Message buffer changed to Receive one.
Rx Message Buffer is Busy.
Rx Message Buffer is Idle.
Rx Message Buffer is Overflowed.
Rx Message FIFO is Busy.
Rx Message FIFO is Idle.
Rx Message FIFO is overflowed.
Rx Message FIFO is almost overflowed.
Rx Message FIFO is disabled during reading.
FlexCAN Module Error and Status.
FlexCAN is waken up from STOP mode.
UnHadled Interrupt asserted.
Rx Remote Message Received in Mail box.
◆ anonymous enum
anonymous enum
The FlexCAN Legacy Rx FIFO Status enumerations are used to determine the status of the Rx FIFO. Because Rx FIFO occupy the MB0 ~ MB7 (Rx Fifo filter also occupies more Message Buffer space), Rx FIFO status flags are mapped to the corresponding Message Buffer status flags.
Rx FIFO overflow flag.
Rx FIFO almost full flag.
Frames available in Rx FIFO flag.
◆ _flexcan_clock_source
Deprecated:
kFLEXCAN_ClkSrcOsc
FlexCAN Protocol Engine clock from Oscillator.
kFLEXCAN_ClkSrcPeri
FlexCAN Protocol Engine clock from Peripheral Clock.
kFLEXCAN_ClkSrc0
FlexCAN Protocol Engine clock selected by user as SRC == 0.
kFLEXCAN_ClkSrc1
FlexCAN Protocol Engine clock selected by user as SRC == 1.
◆ _flexcan_error_flags
The FlexCAN Error Status enumerations is used to report current error of the FlexCAN bus. This enumerations should be used with KFLEXCAN_ErrorFlag in _flexcan_flags enumerations to ditermine which error is generated.
Tx Error Warning Status.
Rx Error Warning Status.
Stuffing Error.
kFLEXCAN_FormError
Form Error.
kFLEXCAN_CrcError
Cyclic Redundancy Check Error.
kFLEXCAN_AckError
Received no ACK on transmission.
kFLEXCAN_Bit0Error
Unable to send dominant bit.
kFLEXCAN_Bit1Error
Unable to send recessive bit.
◆ _flexcan_flags
This provides constants for the FlexCAN status flags for use in the FlexCAN functions.
Note
The CPU read action clears the bits corresponding to the FlEXCAN_ErrorFlag macro, therefore user need to read status flags and distinguish which error is occur using _flexcan_error_flags enumerations.
kFLEXCAN_SynchFlag
CAN Synchronization Status.
Tx Warning Interrupt Flag.
Rx Warning Interrupt Flag.
kFLEXCAN_IdleFlag
FlexCAN In IDLE Status.
FlexCAN Fault Confinement State.
FlexCAN In Transmission Status.
FlexCAN In Reception Status.
Bus Off Interrupt Flag.
CAN Error Interrupt Flag.
Self Wake-Up Interrupt Flag.
◆ _flexcan_frame_format
Standard frame format attribute.
Extend frame format attribute.
◆ _flexcan_frame_type
FlexCAN frame type.
Data frame type attribute.
Remote frame type attribute.
◆ _flexcan_interrupt_enable
This provides constants for the FlexCAN interrupt enable enumerations for use in the FlexCAN functions.
Note
FlexCAN Message Buffers and Legacy Rx FIFO interrupts not included in.
Bus Off interrupt, use bit 15.
CAN Error interrupt, use bit 14.
Tx Warning interrupt, use bit 11.
Rx Warning interrupt, use bit 10.
Self Wake Up interrupt, use bit 26.
◆ _flexcan_rx_fifo_filter_type
One full ID (standard and extended) per ID Filter element.
Two full standard IDs or two partial 14-bit ID slices per ID Filter Table element.
Four partial 8-bit Standard or extended ID slices per ID Filter Table element.
All frames rejected.
◆ _flexcan_rx_fifo_priority
Matching process start from Rx Message Buffer first.
Matching process start from Enhanced/Legacy Rx FIFO first.
◆ _flexcan_wake_up_source
FlexCAN uses unfiltered Rx input to detect edge.
FlexCAN uses filtered Rx input to detect edge.
◆ FLEXCAN_CalculateImprovedTimingValues()
bool FLEXCAN_CalculateImprovedTimingValues ( CAN_Type base,
uint32_t  bitRate,
flexcan_timing_config_t pTimingConfig
This function use to calculates the Classical CAN timing values according to the given bit rate. The Calculated timing values will be set in CTRL1/CBT/ENCBT register. The calculation is based on the recommendation of the CiA 301 v4.2.0 and previous version document.
Parameters
baseFlexCAN peripheral base address.
bitRateThe classical CAN speed in bps defined by user, should be less than or equal to 1Mbps.
sourceClock_HzThe Source clock frequency in Hz.
pTimingConfigPointer to the FlexCAN timing configuration structure.
Returns
TRUE if timing configuration found, FALSE if failed to find configuration.
brief Calculates the improved timing values by specific bit Rates for classical CAN.
param base FlexCAN peripheral base address. param bitRate The classical CAN speed in bps defined by user, should be less than or equal to 1Mbps. param sourceClock_Hz The Source clock frequency in Hz. param pTimingConfig Pointer to the FlexCAN timing configuration structure.
return TRUE if timing configuration found, FALSE if failed to find configuration.
◆ FLEXCAN_Deinit()
void FLEXCAN_Deinit ( CAN_Type base)
This function disables the FlexCAN module clock and sets all register values to the reset value.
Parameters
brief De-initializes a FlexCAN instance.
◆ FLEXCAN_EnterFreezeMode()
void FLEXCAN_EnterFreezeMode ( CAN_Type base)
This function makes the FlexCAN work under Freeze Mode.
Parameters
brief Enter FlexCAN Freeze Mode.
◆ FLEXCAN_ExitFreezeMode()
void FLEXCAN_ExitFreezeMode ( CAN_Type base)
This function makes the FlexCAN leave Freeze Mode.
Parameters
brief Exit FlexCAN Freeze Mode.
◆ FLEXCAN_GetDefaultConfig()
void FLEXCAN_GetDefaultConfig ( flexcan_config_t pConfig)
This function initializes the FlexCAN configuration structure to default values. The default values are as follows. flexcanConfig->clkSrc = kFLEXCAN_ClkSrc0; flexcanConfig->bitRate = 1000000U; flexcanConfig->bitRateFD = 2000000U; flexcanConfig->maxMbNum = 16; flexcanConfig->enableLoopBack = false; flexcanConfig->enableSelfWakeup = false; flexcanConfig->enableIndividMask = false; flexcanConfig->disableSelfReception = false; flexcanConfig->enableListenOnlyMode = false; flexcanConfig->enableDoze = false; flexcanConfig->enableMemoryErrorControl = true; flexcanConfig->enableNonCorrectableErrorEnterFreeze = true; flexcanConfig.timingConfig = timingConfig;
Parameters
pConfigPointer to the FlexCAN configuration structure.
brief Gets the default configuration structure.
This function initializes the FlexCAN configuration structure to default values. The default values are as follows. flexcanConfig->clkSrc = kFLEXCAN_ClkSrc0; flexcanConfig->bitRate = 1000000U; flexcanConfig->bitRateFD = 2000000U; flexcanConfig->maxMbNum = 16; flexcanConfig->enableLoopBack = false; flexcanConfig->enableSelfWakeup = false; flexcanConfig->enableIndividMask = false; flexcanConfig->disableSelfReception = false; flexcanConfig->enableListenOnlyMode = false; flexcanConfig->enableDoze = false; flexcanConfig->enablePretendedeNetworking = false; flexcanConfig->enableMemoryErrorControl = true; flexcanConfig->enableNonCorrectableErrorEnterFreeze = true; flexcanConfig->enableTransceiverDelayMeasure = true; flexcanConfig.timingConfig = timingConfig;
param pConfig Pointer to the FlexCAN configuration structure.
◆ FLEXCAN_GetInstance()
uint32_t FLEXCAN_GetInstance ( CAN_Type base)
Parameters
Returns
FlexCAN instance.
brief Get the FlexCAN instance from peripheral base address.
param base FlexCAN peripheral base address. return FlexCAN instance.
◆ FLEXCAN_GetTimeStamp()
uint32_t FLEXCAN_GetTimeStamp ( flexcan_handle_t handle,
uint8_t  mbIdx
Then function can only be used when calling non-blocking Data transfer (TX/RX) API, After TX/RX data transfer done (User can get the status by handler's callback function), we can get the detail index of Mailbox's timestamp by handle, Detail non-blocking data transfer API (TX/RX) contain. -FLEXCAN_TransferSendNonBlocking -FLEXCAN_TransferFDSendNonBlocking -FLEXCAN_TransferReceiveNonBlocking -FLEXCAN_TransferFDReceiveNonBlocking -FLEXCAN_TransferReceiveFifoNonBlocking
Parameters
handleFlexCAN handle pointer.
mbIdxThe FlexCAN Message Buffer index.
Return values
theindex of mailbox 's timestamp stored in the handle.
brief Gets the detail index of Mailbox's Timestamp by handle.
param handle FlexCAN handle pointer. param mbIdx The FlexCAN FD Message Buffer index. return the index of mailbox 's timestamp stored in the handle.
◆ FLEXCAN_Init()
void FLEXCAN_Init ( CAN_Type base,
const flexcan_config_t pConfig,
This function initializes the FlexCAN module with user-defined settings. This example shows how to set up the flexcan_config_t parameters and how to call the FLEXCAN_Init function by passing in these parameters.
flexcan_config_t flexcanConfig;
flexcanConfig.clkSrc = kFLEXCAN_ClkSrc0;
flexcanConfig.bitRate = 1000000U;
flexcanConfig.maxMbNum = 16;
flexcanConfig.enableLoopBack = false;
flexcanConfig.enableSelfWakeup = false;
flexcanConfig.enableIndividMask = false;
flexcanConfig.enableDoze = false;
flexcanConfig.disableSelfReception = false;
flexcanConfig.enableListenOnlyMode = false;
FLEXCAN_Init(CAN0, &flexcanConfig, 40000000UL);
uint8_t maxMbNum
Definition: fsl_flexcan.h:806
uint32_t bitRate
Definition: fsl_flexcan.h:798
bool enableListenOnlyMode
Definition: fsl_flexcan.h:812
bool enableSelfWakeup
Definition: fsl_flexcan.h:809
bool disableSelfReception
Definition: fsl_flexcan.h:811
flexcan_clock_source_t clkSrc
Definition: fsl_flexcan.h:804
bool enableLoopBack
Definition: fsl_flexcan.h:807
void FLEXCAN_Init(CAN_Type *base, const flexcan_config_t *pConfig, uint32_t sourceClock_Hz)
Definition: fsl_flexcan.c:780
bool enableIndividMask
Definition: fsl_flexcan.h:810
@ kFLEXCAN_ClkSrc0
Definition: fsl_flexcan.h:343
Definition: fsl_flexcan.h:786
Parameters
pConfigPointer to the user-defined configuration structure.
sourceClock_HzFlexCAN Protocol Engine clock source frequency in Hz.
brief Initializes a FlexCAN instance.
This function initializes the FlexCAN module with user-defined settings. This example shows how to set up the flexcan_config_t parameters and how to call the FLEXCAN_Init function by passing in these parameters. code flexcan_config_t flexcanConfig; flexcanConfig.clkSrc = kFLEXCAN_ClkSrc0; flexcanConfig.bitRate = 1000000U; flexcanConfig.maxMbNum = 16; flexcanConfig.enableLoopBack = false; flexcanConfig.enableSelfWakeup = false; flexcanConfig.enableIndividMask = false; flexcanConfig.disableSelfReception = false; flexcanConfig.enableListenOnlyMode = false; flexcanConfig.enableDoze = false; flexcanConfig.timingConfig = timingConfig; FLEXCAN_Init(CAN0, &flexcanConfig, 40000000UL); endcode
param base FlexCAN peripheral base address. param pConfig Pointer to the user-defined configuration structure. param sourceClock_Hz FlexCAN Protocol Engine clock source frequency in Hz.
◆ FLEXCAN_ReadRxFifo()
status_t FLEXCAN_ReadRxFifo ( CAN_Type base,
flexcan_frame_t pRxFrame
This function reads a CAN message from the FlexCAN Legacy Rx FIFO.
Parameters
pRxFramePointer to CAN message frame structure for reception.
Return values
kStatus_Success- Read Message from Rx FIFO successfully.
kStatus_Fail- Rx FIFO is not enabled.
brief Reads a FlexCAN Message from Legacy Rx FIFO.
param base FlexCAN peripheral base address. param pRxFrame Pointer to CAN message frame structure for reception. retval kStatus_Success - Read Message from Rx FIFO successfully. retval kStatus_Fail - Rx FIFO is not enabled.
◆ FLEXCAN_ReadRxMb()
status_t FLEXCAN_ReadRxMb ( CAN_Type base,
uint8_t  mbIdx,
This function reads a CAN message from a specified Receive Message Buffer. The function fills a receive CAN message frame structure with just received data and activates the Message Buffer again. The function returns immediately.
Parameters
Return values
kStatus_Success- Rx Message Buffer is full and has been read successfully.
kStatus_FLEXCAN_RxOverflow- Rx Message Buffer is already overflowed and has been read successfully.
kStatus_Fail- Rx Message Buffer is empty.
brief Reads a FlexCAN Message from Receive Message Buffer.
param base FlexCAN peripheral base address. param mbIdx The FlexCAN Message Buffer index. param pRxFrame Pointer to CAN message frame structure for reception. retval kStatus_Success - Rx Message Buffer is full and has been read successfully. retval kStatus_FLEXCAN_RxOverflow - Rx Message Buffer is already overflowed and has been read successfully. retval kStatus_Fail - Rx Message Buffer is empty.
◆ FLEXCAN_SetBitRate()
status_t FLEXCAN_SetBitRate ( CAN_Type base,
This function set the bit rate of classical CAN frame or CAN FD frame nominal phase base on FLEXCAN_CalculateImprovedTimingValues() API calculated timing values.
Note
Calling FLEXCAN_SetBitRate() overrides the bit rate set in FLEXCAN_Init().
Parameters
sourceClock_HzSource Clock in Hz.
bitRate_BpsBit rate in Bps.
Returns
kStatus_Success - Set CAN baud rate (only Nominal phase) successfully.
brief Set bit rate of FlexCAN classical CAN frame or CAN FD frame nominal phase.
note Calling FLEXCAN_SetBitRate() overrides the bit rate set in FLEXCAN_Init().
param base FlexCAN peripheral base address. param sourceClock_Hz Source Clock in Hz. param bitRate_Bps Bit rate in Bps. return kStatus_Success - Set CAN baud rate (only Nominal phase) successfully.
◆ FLEXCAN_SetRxFifoConfig()
void FLEXCAN_SetRxFifoConfig ( CAN_Type base,
const flexcan_rx_fifo_config_t pRxFifoConfig,
bool  enable
This function configures the FlexCAN Rx FIFO with given configuration.
Note
Legacy Rx FIFO only can receive classic CAN message.
Parameters
pRxFifoConfigPointer to the FlexCAN Legacy Rx FIFO configuration structure. Can be NULL when enable parameter is false.
enableEnable/disable Legacy Rx FIFO.
  • true: Enable Legacy Rx FIFO.
  • false: Disable Legacy Rx FIFO.
brief Configures the FlexCAN Legacy Rx FIFO.
This function configures the FlexCAN Rx FIFO with given configuration. note Legacy Rx FIFO only can receive classic CAN message.
param base FlexCAN peripheral base address. param pRxFifoConfig Pointer to the FlexCAN Legacy Rx FIFO configuration structure. Can be NULL when enable parameter is false. param enable Enable/disable Legacy Rx FIFO.
◆ FLEXCAN_SetRxFifoGlobalMask()
void FLEXCAN_SetRxFifoGlobalMask ( CAN_Type base,
uint32_t  mask
This function sets the global mask for FlexCAN FIFO in a matching process.
Parameters
maskRx Fifo Global Mask value.
brief Sets the FlexCAN receive FIFO global mask.
param base FlexCAN peripheral base address. param mask Rx Fifo Global Mask value.
◆ FLEXCAN_SetRxIndividualMask()
void FLEXCAN_SetRxIndividualMask ( CAN_Type base,
uint8_t  maskIdx,
uint32_t  mask
This function sets the individual mask for the FlexCAN matching process. The configuration is only effective when the Rx individual mask is enabled in the FLEXCAN_Init(). If the Rx FIFO is disabled, the individual mask is applied to the corresponding Message Buffer. If the Rx FIFO is enabled, the individual mask for Rx FIFO occupied Message Buffer is applied to the Rx Filter with the same index. Note that only the first 32 individual masks can be used as the Rx FIFO filter mask.
Parameters
maskIdxThe Index of individual Mask.
maskRx Individual Mask value.
brief Sets the FlexCAN receive individual mask.
param base FlexCAN peripheral base address. param maskIdx The Index of individual Mask. param mask Rx Individual Mask value.
◆ FLEXCAN_SetRxMbConfig()
void FLEXCAN_SetRxMbConfig ( CAN_Type base,
uint8_t  mbIdx,
const flexcan_rx_mb_config_t pRxMbConfig,
bool  enable
This function cleans a FlexCAN build-in Message Buffer and configures it as a Receive Message Buffer.
Parameters
mbIdxThe Message Buffer index.
pRxMbConfigPointer to the FlexCAN Message Buffer configuration structure.
enableEnable/disable Rx Message Buffer.
  • true: Enable Rx Message Buffer.
  • false: Disable Rx Message Buffer.
brief Configures a FlexCAN Receive Message Buffer.
param base FlexCAN peripheral base address. param mbIdx The Message Buffer index. param pRxMbConfig Pointer to the FlexCAN Message Buffer configuration structure. param enable Enable/disable Rx Message Buffer.
◆ FLEXCAN_SetRxMbGlobalMask()
void FLEXCAN_SetRxMbGlobalMask ( CAN_Type base,
uint32_t  mask
This function sets the global mask for the FlexCAN message buffer in a matching process. The configuration is only effective when the Rx individual mask is disabled in the FLEXCAN_Init().
Parameters
maskRx Message Buffer Global Mask value.
brief Sets the FlexCAN receive message buffer global mask.
param base FlexCAN peripheral base address. param mask Rx Message Buffer Global Mask value.
◆ FLEXCAN_SetTimingConfig()
void FLEXCAN_SetTimingConfig ( CAN_Type base,
const flexcan_timing_config_t pConfig
This function gives user settings to classical CAN or CAN FD nominal phase timing characteristic. The function is for an experienced user. For less experienced users, call the FLEXCAN_SetBitRate() instead.
Note
Calling FLEXCAN_SetTimingConfig() overrides the bit rate set in FLEXCAN_Init() or FLEXCAN_SetBitRate().
Parameters
pConfigPointer to the timing configuration structure.
brief Sets the FlexCAN classical protocol timing characteristic.
This function gives user settings to classical CAN or CAN FD nominal phase timing characteristic. The function is for an experienced user. For less experienced users, call the FLEXCAN_GetDefaultConfig() and get the default timing characteristicsthe, then call FLEXCAN_Init() and fill the bit rate field.
note Calling FLEXCAN_SetTimingConfig() overrides the bit rate set in FLEXCAN_Init().
param base FlexCAN peripheral base address. param pConfig Pointer to the timing configuration structure.
◆ FLEXCAN_SetTxMbConfig()
void FLEXCAN_SetTxMbConfig ( CAN_Type base,
uint8_t  mbIdx,
bool  enable
This function aborts the previous transmission, cleans the Message Buffer, and configures it as a Transmit Message Buffer.
Parameters
enableEnable/disable Tx Message Buffer.
  • true: Enable Tx Message Buffer.
  • false: Disable Tx Message Buffer.
brief Configures a FlexCAN transmit message buffer.
param base FlexCAN peripheral base address. param mbIdx The Message Buffer index. param enable Enable/disable Tx Message Buffer.
◆ FLEXCAN_TransferAbortReceive()
void FLEXCAN_TransferAbortReceive ( CAN_Type base,
uint8_t  mbIdx
This function aborts the interrupt driven message receive process.
Parameters
brief Aborts the interrupt driven message receive process.
param base FlexCAN peripheral base address. param handle FlexCAN handle pointer. param mbIdx The FlexCAN Message Buffer index.
◆ FLEXCAN_TransferAbortReceiveFifo()
void FLEXCAN_TransferAbortReceiveFifo ( CAN_Type base,
This function aborts the interrupt driven message receive from Rx FIFO process.
Parameters
brief Aborts the interrupt driven message receive from Legacy Rx FIFO process.
This function aborts the interrupt driven message receive from Legacy Rx FIFO process.
◆ FLEXCAN_TransferAbortSend()
void FLEXCAN_TransferAbortSend ( CAN_Type base,
uint8_t  mbIdx
This function aborts the interrupt driven message send process.
Parameters
brief Aborts the interrupt driven message send process.
◆ FLEXCAN_TransferCreateHandle()
void FLEXCAN_TransferCreateHandle ( CAN_Type base,
void *  userData
This function initializes the FlexCAN handle, which can be used for other FlexCAN transactional APIs. Usually, for a specified FlexCAN instance, call this API once to get the initialized handle.
Parameters
callbackThe callback function.
userDataThe parameter of the callback function.
brief Initializes the FlexCAN handle.
param base FlexCAN peripheral base address. param handle FlexCAN handle pointer. param callback The callback function. param userData The parameter of the callback function.
◆ FLEXCAN_TransferGetReceiveFifoCount()
status_t FLEXCAN_TransferGetReceiveFifoCount ( CAN_Type base,
size_t *  count
Parameters
countNumber of CAN messages receive so far by the non-blocking transaction.
Return values
kStatus_InvalidArgumentcount is Invalid.
kStatus_SuccessSuccessfully return the count.
brief Gets the Legacy Rx Fifo transfer status during a interrupt non-blocking receive.
param base FlexCAN peripheral base address. param handle FlexCAN handle pointer. param count Number of CAN messages receive so far by the non-blocking transaction. retval kStatus_InvalidArgument count is Invalid. retval kStatus_Success Successfully return the count.
◆ FLEXCAN_TransferHandleIRQ()
void FLEXCAN_TransferHandleIRQ ( CAN_Type base,
This function handles the FlexCAN Error, the Message Buffer, and the Rx FIFO IRQ request.
Parameters
brief FlexCAN IRQ handle function.
◆ FLEXCAN_TransferReceiveBlocking()
status_t FLEXCAN_TransferReceiveBlocking ( CAN_Type base,
uint8_t  mbIdx,
Note
A transfer handle does not need to be created before calling this API.
Parameters
baseFlexCAN peripheral base pointer.
Return values
brief Performs a polling receive transaction on the CAN bus.
note A transfer handle does not need to be created before calling this API.
param base FlexCAN peripheral base pointer. param mbIdx The FlexCAN Message Buffer index. param pRxFrame Pointer to CAN message frame structure for reception. retval kStatus_Success - Rx Message Buffer is full and has been read successfully. retval kStatus_FLEXCAN_RxOverflow - Rx Message Buffer is already overflowed and has been read successfully. retval kStatus_Fail - Rx Message Buffer is empty.
◆ FLEXCAN_TransferReceiveFifoBlocking()
status_t FLEXCAN_TransferReceiveFifoBlocking ( CAN_Type base,
Note
Parameters
Return values
brief Performs a polling receive transaction from Legacy Rx FIFO on the CAN bus.
param base FlexCAN peripheral base pointer. param pRxFrame Pointer to CAN message frame structure for reception. retval kStatus_Success - Read Message from Rx FIFO successfully. retval kStatus_Fail - Rx FIFO is not enabled.
◆ FLEXCAN_TransferReceiveFifoNonBlocking()
status_t FLEXCAN_TransferReceiveFifoNonBlocking ( CAN_Type base,
flexcan_fifo_transfer_t pFifoXfer
This function receives a message using IRQ. This is a non-blocking function, which returns right away. When all messages have been received, the receive callback function is called.
Parameters
pFifoXferFlexCAN Rx FIFO transfer structure. See the flexcan_fifo_transfer_t.
Return values
kStatus_Success- Start Rx FIFO receiving process successfully.
kStatus_FLEXCAN_RxFifoBusy- Rx FIFO is currently in use.
brief Receives a message from Legacy Rx FIFO using IRQ.
param base FlexCAN peripheral base address. param handle FlexCAN handle pointer. param pFifoXfer FlexCAN Rx FIFO transfer structure. See the ref flexcan_fifo_transfer_t. retval kStatus_Success - Start Rx FIFO receiving process successfully. retval kStatus_FLEXCAN_RxFifoBusy - Rx FIFO is currently in use.
◆ FLEXCAN_TransferReceiveNonBlocking()
status_t FLEXCAN_TransferReceiveNonBlocking ( CAN_Type base,
flexcan_mb_transfer_t pMbXfer
This function receives a message using IRQ. This is non-blocking function, which returns right away. When the message has been received, the receive callback function is called.
Parameters
pMbXferFlexCAN Message Buffer transfer structure. See the flexcan_mb_transfer_t.
Return values
kStatus_Success- Start Rx Message Buffer receiving process successfully.
kStatus_FLEXCAN_RxBusy- Rx Message Buffer is in use.
brief Receives a message using IRQ.
param base FlexCAN peripheral base address. param handle FlexCAN handle pointer. param pMbXfer FlexCAN Message Buffer transfer structure. See the flexcan_mb_transfer_t. retval kStatus_Success - Start Rx Message Buffer receiving process successfully. retval kStatus_FLEXCAN_RxBusy - Rx Message Buffer is in use.
◆ FLEXCAN_TransferSendBlocking()
status_t FLEXCAN_TransferSendBlocking ( CAN_Type base,
uint8_t  mbIdx,
flexcan_frame_t pTxFrame
Note
Parameters
pTxFramePointer to CAN message frame to be sent.
Return values
kStatus_Success- Write Tx Message Buffer Successfully.
kStatus_Fail- Tx Message Buffer is currently in use.
brief Performs a polling send transaction on the CAN bus.
param base FlexCAN peripheral base pointer. param mbIdx The FlexCAN Message Buffer index. param pTxFrame Pointer to CAN message frame to be sent. retval kStatus_Success - Write Tx Message Buffer Successfully. retval kStatus_Fail - Tx Message Buffer is currently in use.
◆ FLEXCAN_TransferSendNonBlocking()
status_t FLEXCAN_TransferSendNonBlocking ( CAN_Type base,
This function sends a message using IRQ. This is a non-blocking function, which returns right away. When messages have been sent out, the send callback function is called.
Parameters
Return values
kStatus_SuccessStart Tx Message Buffer sending process successfully.
kStatus_FailWrite Tx Message Buffer failed.
kStatus_FLEXCAN_TxBusyTx Message Buffer is in use.
brief Sends a message using IRQ.
param base FlexCAN peripheral base address. param handle FlexCAN handle pointer. param pMbXfer FlexCAN Message Buffer transfer structure. See the flexcan_mb_transfer_t. retval kStatus_Success Start Tx Message Buffer sending process successfully. retval kStatus_Fail Write Tx Message Buffer failed. retval kStatus_FLEXCAN_TxBusy Tx Message Buffer is in use.
◆ FLEXCAN_WriteTxMb()
status_t FLEXCAN_WriteTxMb ( CAN_Type base,
uint8_t  mbIdx,
const flexcan_frame_t pTxFrame
This function writes a CAN Message to the specified Transmit Message Buffer and changes the Message Buffer state to start CAN Message transmit. After that the function returns immediately.
Parameters
Return values
brief Writes a FlexCAN Message to the Transmit Message Buffer.
param base FlexCAN peripheral base address. param mbIdx The FlexCAN Message Buffer index. param pTxFrame Pointer to CAN message frame to be sent. retval kStatus_Success - Write Tx Message Buffer Successfully. retval kStatus_Fail - Tx Message Buffer is currently in use.
Variable Documentation
◆ __pad0__ [1/3]
Reserved.
◆  [2/3]
uint32_t { ... } ::__pad0__
Reserved.
◆  [3/3]
Reserved.
◆  [1/2]
uint32_t { ... } ::baudRate
FlexCAN bit rate in bps, for classical CAN or CANFD nominal phase.
◆ baudRate [2/2]
◆ bitRate [1/2]
◆  [2/2]
uint32_t { ... } ::bitRate
◆ callback
Callback function.
◆ clkSrc
Clock source for FlexCAN Protocol Engine.
◆  [1/2]
uint8_t { ... } ::dataByte0
CAN Frame payload byte0.
◆ dataByte0 [2/2]
◆  [1/2]
uint8_t { ... } ::dataByte1
CAN Frame payload byte1.
◆ dataByte1 [2/2]
◆ dataByte2 [1/2]
CAN Frame payload byte2.
◆  [2/2]
uint8_t { ... } ::dataByte2
◆ dataByte3 [1/2]
CAN Frame payload byte3.
◆  [2/2]
uint8_t { ... } ::dataByte3
◆ dataByte4 [1/2]
CAN Frame payload byte4.
◆  [2/2]
uint8_t { ... } ::dataByte4
◆ dataByte5 [1/2]
CAN Frame payload byte5.
◆  [2/2]
uint8_t { ... } ::dataByte5
◆ dataByte6 [1/2]
CAN Frame payload byte6.
◆  [2/2]
uint8_t { ... } ::dataByte6
◆ dataByte7 [1/2]
CAN Frame payload byte7.
◆  [2/2]
uint8_t { ... } ::dataByte7
◆  [1/2]
uint32_t { ... } ::dataWord0
CAN Frame payload word0.
◆ dataWord0 [2/2]
◆  [1/2]
uint32_t { ... } ::dataWord1
CAN Frame payload word1.
◆ dataWord1 [2/2]
◆ disableSelfReception
Enable or Disable Self Reflection.
◆ enableIndividMask
Enable or Disable Rx Individual Mask and Queue feature.
◆ enableListenOnlyMode
Enable or Disable Listen Only Mode.
◆ enableLoopBack
Enable or Disable Loop Back Self Test Mode.
◆ enableSelfWakeup
Enable or Disable Self Wakeup Mode.
◆ enableSupervisorMode
Enable or Disable Supervisor Mode, enable this mode will make registers allow only Supervisor access.
◆ enableTimerSync
Enable or Disable Timer Synchronization.
◆  [1/3]
uint32_t { ... } ::format
CAN Frame Identifier(STD or EXT format).
◆ format [2/3]
◆ format [3/3]
CAN Frame Identifier format(Standard of Extend).
◆ frame [1/2]
flexcan_frame_t* _flexcan_mb_transfer::frame
The buffer of CAN Message to be transfer.
◆ frame [2/2]
flexcan_frame_t* _flexcan_fifo_transfer::frame
The buffer of CAN Message to be received from Legacy Rx FIFO.
◆ frameNum
Number of CAN Message need to be received from Legacy or Ehanced Rx FIFO.
◆  [1/3]
uint32_t { ... } ::id
CAN Frame Identifier, should be set using FLEXCAN_ID_EXT() or FLEXCAN_ID_STD() macro.
◆ id [2/3]
◆ id [3/3]
CAN Message Buffer Frame Identifier, should be set using FLEXCAN_ID_EXT() or FLEXCAN_ID_STD() macro.
◆ idFilterNum
The FlexCAN Legacy Rx FIFO Filter elements quantity.
◆ idFilterTable
uint32_t* _flexcan_rx_fifo_config::idFilterTable
Pointer to the FlexCAN Legacy Rx FIFO identifier filter table.
◆ idFilterType
The FlexCAN Legacy Rx FIFO Filter type.
◆  [1/2]
uint32_t { ... } ::idhit
CAN Rx FIFO filter hit id(This value is only used in Rx FIFO receive mode).
◆ idhit [2/2]
◆  [1/2]
uint32_t { ... } ::length
CAN frame data length in bytes (Range: 0~8).
◆ length [2/2]
◆ maxMbNum
The maximum number of Message Buffers used by user.
◆ mbFrameBuf
flexcan_frame_t* volatile _flexcan_handle::mbFrameBuf[CAN_WORD1_COUNT]
The buffer for received CAN data from Message Buffers.
◆ mbIdx
The index of Message buffer used to transfer Message.
◆ mbState
volatile uint8_t _flexcan_handle::mbState[CAN_WORD1_COUNT]
Message Buffer transfer state.
◆ phaseSeg1
Classic CAN or CAN FD nominal phase Segment 1.
◆ phaseSeg2
Classic CAN or CAN FD nominal phase Segment 2.
◆ preDivider
Classic CAN or CAN FD nominal phase bit rate prescaler.
◆ priority
The FlexCAN Legacy Rx FIFO receive priority.
◆ propSeg
Classic CAN or CAN FD nominal phase Propagation Segment.
◆ rJumpwidth
Classic CAN or CAN FD nominal phase Re-sync Jump Width.
◆ rxFifoFrameBuf
flexcan_frame_t* volatile _flexcan_handle::rxFifoFrameBuf
The buffer for received CAN data from Legacy Rx FIFO.
◆ rxFifoFrameNum
The number of CAN messages remaining to be received from Legacy or Ehanced Rx FIFO.
◆ rxFifoState
Rx FIFO transfer state.
◆ rxFifoTransferTotalNum
Total CAN Message number need to be received from Legacy or Ehanced Rx FIFO.
◆ timestamp [1/3]
FlexCAN internal Free-Running Counter Time Stamp.
◆  [2/3]
uint32_t { ... } ::timestamp
◆ timestamp [3/3]
volatile uint32_t _flexcan_handle::timestamp[CAN_WORD1_COUNT]
Mailbox transfer timestamp.
◆  [1/3]
uint32_t { ... } ::type
CAN Frame Type(DATA or REMOTE).
◆ type [2/3]
◆ type [3/3]
CAN Frame Type(Data or Remote).
◆ userData
void* _flexcan_handle::userData
FlexCAN callback function parameter.
◆ wakeupSrc
Wake up source selection.
