RTEMS 6.1-rc1
struct | _lpi2c_slave_config |
Structure with settings to initialize the LPI2C slave module. More... | |
struct | _lpi2c_slave_transfer |
LPI2C slave transfer structure. More... | |
struct | _lpi2c_slave_handle |
LPI2C slave handle structure. More... | |
Typedefs | |
typedef enum _lpi2c_slave_address_match | lpi2c_slave_address_match_t |
LPI2C slave address match options. | |
typedef struct _lpi2c_slave_config | lpi2c_slave_config_t |
typedef enum _lpi2c_slave_transfer_event | lpi2c_slave_transfer_event_t |
Set of events sent to the callback for non blocking slave transfers. More... | |
typedef struct _lpi2c_slave_transfer | lpi2c_slave_transfer_t |
LPI2C slave transfer structure. | |
typedef struct _lpi2c_slave_handle | lpi2c_slave_handle_t |
typedef void(* | lpi2c_slave_transfer_callback_t) (LPI2C_Type *base, lpi2c_slave_transfer_t *transfer, void *userData) |
Slave event callback function pointer type. More... | |
Slave initialization and deinitialization | |
void | LPI2C_SlaveGetDefaultConfig (lpi2c_slave_config_t *slaveConfig) |
Provides a default configuration for the LPI2C slave peripheral. More... | |
void | LPI2C_SlaveInit (LPI2C_Type *base, const lpi2c_slave_config_t *slaveConfig, uint32_t sourceClock_Hz) |
Initializes the LPI2C slave peripheral. More... | |
void | LPI2C_SlaveDeinit (LPI2C_Type *base) |
Deinitializes the LPI2C slave peripheral. More... | |
Slave bus operations | |
status_t | LPI2C_SlaveSend (LPI2C_Type *base, void *txBuff, size_t txSize, size_t *actualTxSize) |
Performs a polling send transfer on the I2C bus. More... | |
status_t | LPI2C_SlaveReceive (LPI2C_Type *base, void *rxBuff, size_t rxSize, size_t *actualRxSize) |
Performs a polling receive transfer on the I2C bus. More... | |
Slave non-blocking | |
void | LPI2C_SlaveTransferCreateHandle (LPI2C_Type *base, lpi2c_slave_handle_t *handle, lpi2c_slave_transfer_callback_t callback, void *userData) |
Creates a new handle for the LPI2C slave non-blocking APIs. More... | |
status_t | LPI2C_SlaveTransferNonBlocking (LPI2C_Type *base, lpi2c_slave_handle_t *handle, uint32_t eventMask) |
Starts accepting slave transfers. More... | |
status_t | LPI2C_SlaveTransferGetCount (LPI2C_Type *base, lpi2c_slave_handle_t *handle, size_t *count) |
Gets the slave transfer status during a non-blocking transfer. More... | |
void | LPI2C_SlaveTransferAbort (LPI2C_Type *base, lpi2c_slave_handle_t *handle) |
Aborts the slave non-blocking transfers. More... | |
Slave IRQ handler | |
void | LPI2C_SlaveTransferHandleIRQ (LPI2C_Type *base, lpi2c_slave_handle_t *handle) |
Reusable routine to handle slave interrupts. More... | |
typedef struct _lpi2c_slave_config lpi2c_slave_config_t |
This structure holds configuration settings for the LPI2C slave peripheral. To initialize this structure to reasonable defaults, call the LPI2C_SlaveGetDefaultConfig() function and pass a pointer to your configuration structure instance.
The configuration structure can be made constant so it resides in flash.
typedef void(* lpi2c_slave_transfer_callback_t) (LPI2C_Type *base, lpi2c_slave_transfer_t *transfer, void *userData) |
This callback is used only for the slave non-blocking transfer API. To install a callback, use the LPI2C_SlaveSetCallback() function after you have created a handle.
base | Base address for the LPI2C instance on which the event occurred. |
transfer | Pointer to transfer descriptor containing values passed to and/or from the callback. |
userData | Arbitrary pointer-sized value passed from the application. |
typedef enum _lpi2c_slave_transfer_event lpi2c_slave_transfer_event_t |
These event enumerations are used for two related purposes. First, a bit mask created by OR'ing together events is passed to LPI2C_SlaveTransferNonBlocking() in order to specify which events to enable. Then, when the slave callback is invoked, it is passed the current event through its transfer parameter.
enum _lpi2c_slave_flags |
LPI2C slave peripheral flags.
The following status register flags can be cleared:
All flags except kLPI2C_SlaveBusyFlag and kLPI2C_SlaveBusBusyFlag can be enabled as interrupts.
void LPI2C_SlaveDeinit | ( | LPI2C_Type * | base | ) |
This function disables the LPI2C slave peripheral and gates the clock. It also performs a software reset to restore the peripheral to reset conditions.
base | The LPI2C peripheral base address. |
brief Deinitializes the LPI2C slave peripheral.
param base The LPI2C peripheral base address.
void LPI2C_SlaveGetDefaultConfig | ( | lpi2c_slave_config_t * | slaveConfig | ) |
This function provides the following default configuration for the LPI2C slave peripheral:
After calling this function, override any settings to customize the configuration, prior to initializing the master driver with LPI2C_SlaveInit(). Be sure to override at least the address0 member of the configuration structure with the desired slave address.
[out] | slaveConfig | User provided configuration structure that is set to default values. Refer to lpi2c_slave_config_t. |
brief Provides a default configuration for the LPI2C slave peripheral.
This function provides the following default configuration for the LPI2C slave peripheral: code slaveConfig->enableSlave = true; slaveConfig->address0 = 0U; slaveConfig->address1 = 0U; slaveConfig->addressMatchMode = kLPI2C_MatchAddress0; slaveConfig->filterDozeEnable = true; slaveConfig->filterEnable = true; slaveConfig->enableGeneralCall = false; slaveConfig->sclStall.enableAck = false; slaveConfig->sclStall.enableTx = true; slaveConfig->sclStall.enableRx = true; slaveConfig->sclStall.enableAddress = true; slaveConfig->ignoreAck = false; slaveConfig->enableReceivedAddressRead = false; slaveConfig->sdaGlitchFilterWidth_ns = 0; slaveConfig->sclGlitchFilterWidth_ns = 0; slaveConfig->dataValidDelay_ns = 0; slaveConfig->clockHoldTime_ns = 0; endcode
After calling this function, override any settings to customize the configuration, prior to initializing the master driver with LPI2C_SlaveInit(). Be sure to override at least the a address0 member of the configuration structure with the desired slave address.
param[out] slaveConfig User provided configuration structure that is set to default values. Refer to lpi2c_slave_config_t.
void LPI2C_SlaveInit | ( | LPI2C_Type * | base, |
const lpi2c_slave_config_t * | slaveConfig, | ||
uint32_t | sourceClock_Hz | ||
This function enables the peripheral clock and initializes the LPI2C slave peripheral as described by the user provided configuration.
slaveConfig | User provided peripheral configuration. Use LPI2C_SlaveGetDefaultConfig() to get a set of defaults that you can override. |
sourceClock_Hz | Frequency in Hertz of the LPI2C functional clock. Used to calculate the filter widths, data valid delay, and clock hold time. |
brief Initializes the LPI2C slave peripheral.
param base The LPI2C peripheral base address. param slaveConfig User provided peripheral configuration. Use LPI2C_SlaveGetDefaultConfig() to get a set of defaults that you can override. param sourceClock_Hz Frequency in Hertz of the LPI2C functional clock. Used to calculate the filter widths, data valid delay, and clock hold time.
status_t LPI2C_SlaveReceive | ( | LPI2C_Type * | base, |
void * | rxBuff, | ||
size_t | rxSize, | ||
size_t * | actualRxSize | ||
base | The LPI2C peripheral base address. | |
rxBuff | The pointer to the data to be transferred. | |
rxSize | The length in bytes of the data to be transferred. | |
[out] | actualRxSize |
brief Performs a polling receive transfer on the I2C bus.
param base The LPI2C peripheral base address. param rxBuff The pointer to the data to be transferred. param rxSize The length in bytes of the data to be transferred. param[out] actualRxSize return Error or success status returned by API.
status_t LPI2C_SlaveSend | ( | LPI2C_Type * | base, |
void * | txBuff, | ||
size_t | txSize, | ||
size_t * | actualTxSize | ||
txBuff | The pointer to the data to be transferred. | |
txSize | The length in bytes of the data to be transferred. | |
[out] | actualTxSize |
brief Performs a polling send transfer on the I2C bus.
param base The LPI2C peripheral base address. param txBuff The pointer to the data to be transferred. param txSize The length in bytes of the data to be transferred. param[out] actualTxSize return Error or success status returned by API.
void LPI2C_SlaveTransferAbort | ( | LPI2C_Type * | base, |
lpi2c_slave_handle_t * | handle | ||
handle | Pointer to lpi2c_slave_handle_t structure which stores the transfer state. |
kStatus_Success | |
kStatus_LPI2C_Idle |
brief Aborts the slave non-blocking transfers. note This API could be called at any time to stop slave for handling the bus events. param base The LPI2C peripheral base address. param handle Pointer to #lpi2c_slave_handle_t structure which stores the transfer state. retval kStatus_Success retval kStatus_LPI2C_Idle
void LPI2C_SlaveTransferCreateHandle | ( | LPI2C_Type * | base, |
lpi2c_slave_handle_t * | handle, | ||
lpi2c_slave_transfer_callback_t | callback, | ||
void * | userData | ||
The creation of a handle is for use with the non-blocking APIs. Once a handle is created, there is not a corresponding destroy handle. If the user wants to terminate a transfer, the LPI2C_SlaveTransferAbort() API shall be called.
[out] | handle | Pointer to the LPI2C slave driver handle. |
callback | User provided pointer to the asynchronous callback function. | |
userData | User provided pointer to the application callback data. |
brief Creates a new handle for the LPI2C slave non-blocking APIs.
note The function also enables the NVIC IRQ for the input LPI2C. Need to notice that on some SoCs the LPI2C IRQ is connected to INTMUX, in this case user needs to enable the associated INTMUX IRQ in application.
param base The LPI2C peripheral base address. param[out] handle Pointer to the LPI2C slave driver handle. param callback User provided pointer to the asynchronous callback function. param userData User provided pointer to the application callback data.
status_t LPI2C_SlaveTransferGetCount | ( | LPI2C_Type * | base, |
size_t * | count | ||
handle | Pointer to i2c_slave_handle_t structure. | |
[out] | count | Pointer to a value to hold the number of bytes transferred. May be NULL if the count is not required. |
kStatus_Success | |
kStatus_NoTransferInProgress |
brief Gets the slave transfer status during a non-blocking transfer. param base The LPI2C peripheral base address. param handle Pointer to i2c_slave_handle_t structure. param[out] count Pointer to a value to hold the number of bytes transferred. May be NULL if the count is not required. retval kStatus_Success retval kStatus_NoTransferInProgress
void LPI2C_SlaveTransferHandleIRQ | ( | LPI2C_Type * | base, |
brief Reusable routine to handle slave interrupts. note This function does not need to be called unless you are reimplementing the non blocking API's interrupt handler routines to add special functionality. param base The LPI2C peripheral base address. param handle Pointer to #lpi2c_slave_handle_t structure which stores the transfer state.
status_t LPI2C_SlaveTransferNonBlocking | ( | LPI2C_Type * | base, |
uint32_t | eventMask | ||
Call this API after calling I2C_SlaveInit() and LPI2C_SlaveTransferCreateHandle() to start processing transactions driven by an I2C master. The slave monitors the I2C bus and pass events to the callback that was passed into the call to LPI2C_SlaveTransferCreateHandle(). The callback is always invoked from the interrupt context.
The set of events received by the callback is customizable. To do so, set the eventMask parameter to the OR'd combination of lpi2c_slave_transfer_event_t enumerators for the events you wish to receive. The kLPI2C_SlaveTransmitEvent and kLPI2C_SlaveReceiveEvent events are always enabled and do not need to be included in the mask. Alternatively, you can pass 0 to get a default set of only the transmit and receive events that are always enabled. In addition, the kLPI2C_SlaveAllEvents constant is provided as a convenient way to enable all events.
eventMask | Bit mask formed by OR'ing together lpi2c_slave_transfer_event_t enumerators to specify which events to send to the callback. Other accepted values are 0 to get a default set of only the transmit and receive events, and kLPI2C_SlaveAllEvents to enable all events. |
kStatus_Success | Slave transfers were successfully started. |
kStatus_LPI2C_Busy | Slave transfers have already been started on this handle. |
brief Starts accepting slave transfers.
The set of events received by the callback is customizable. To do so, set the a eventMask parameter to the OR'd combination of lpi2c_slave_transfer_event_t enumerators for the events you wish to receive. The kLPI2C_SlaveTransmitEvent and kLPI2C_SlaveReceiveEvent events are always enabled and do not need to be included in the mask. Alternatively, you can pass 0 to get a default set of only the transmit and receive events that are always enabled. In addition, the kLPI2C_SlaveAllEvents constant is provided as a convenient way to enable all events.
param base The LPI2C peripheral base address. param handle Pointer to #lpi2c_slave_handle_t structure which stores the transfer state. param eventMask Bit mask formed by OR'ing together lpi2c_slave_transfer_event_t enumerators to specify which events to send to the callback. Other accepted values are 0 to get a default set of only the transmit and receive events, and kLPI2C_SlaveAllEvents to enable all events.
retval kStatus_Success Slave transfers were successfully started. retval kStatus_LPI2C_Busy Slave transfers have already been started on this handle.
uint8_t _lpi2c_slave_config::address0 |
Slave's 7-bit address.
uint8_t _lpi2c_slave_config::address1 |
Alternate slave 7-bit address.
lpi2c_slave_address_match_t _lpi2c_slave_config::addressMatchMode |
Address matching options.
uint32_t _lpi2c_master_config::baudRate_Hz |
Desired baud rate in Hertz.
uint8_t* _lpi2c_master_handle::buf |
Buffer pointer for current state.
uint32_t _lpi2c_master_config::busIdleTimeout_ns |
Bus idle timeout in nanoseconds. Set to 0 to disable.
lpi2c_slave_transfer_callback_t _lpi2c_slave_handle::callback |
Callback function called at transfer event.
uint32_t _lpi2c_slave_config::clockHoldTime_ns |
Width in nanoseconds of the clock hold time.
uint16_t _lpi2c_master_handle::commandBuffer[6] |
LPI2C command sequence. When all 6 command words are used: Start&addr&write[1 word] + subaddr[4 words] + restart&addr&read[1 word]
lpi2c_master_transfer_callback_t _lpi2c_master_handle::completionCallback |
Callback function pointer.
status_t _lpi2c_slave_transfer::completionStatus |
Success or error code describing how the transfer completed. Only applies for kLPI2C_SlaveCompletionEvent.
void* _lpi2c_master_transfer::data |
Pointer to data to transfer.
uint8_t* _lpi2c_slave_transfer::data |
Transfer buffer
size_t _lpi2c_master_transfer::dataSize |
Number of bytes to transfer.
size_t _lpi2c_slave_transfer::dataSize |
Transfer size
uint32_t _lpi2c_slave_config::dataValidDelay_ns |
Width in nanoseconds of the data valid delay.
bool _lpi2c_master_config::debugEnable |
Enable transfers to continue when halted in debug mode.
lpi2c_direction_t _lpi2c_master_transfer::direction |
Either kLPI2C_Read or kLPI2C_Write.
bool _lpi2c_master_config::enable |
Enable host request.
bool { ... } ::enable |
bool { ... } ::enableAck |
Enables SCL clock stretching during slave-transmit address byte(s) and slave-receiver address and data byte(s) to allow software to write the Transmit ACK Register before the ACK or NACK is transmitted. Clock stretching occurs when transmitting the 9th bit. When enableAckSCLStall is enabled, there is no need to set either enableRxDataSCLStall or enableAddressSCLStall.
bool _lpi2c_slave_config::enableAck |
bool { ... } ::enableAddress |
Enables SCL clock stretching when the address valid flag is asserted.
bool _lpi2c_slave_config::enableAddress |
bool _lpi2c_master_config::enableDoze |
Whether master is enabled in doze mode.
bool _lpi2c_slave_config::enableGeneralCall |
Enable general call address matching.
bool _lpi2c_master_config::enableMaster |
Whether to enable master mode.
bool _lpi2c_slave_config::enableReceivedAddressRead |
Enable reading the address received address as the first byte of data.
bool { ... } ::enableRx |
Enables SCL clock stretching when receive data flag is set during a slave-receive transfer.
bool _lpi2c_slave_config::enableRx |
bool _lpi2c_slave_config::enableSlave |
Enable slave mode.
bool _lpi2c_slave_config::enableTx |
Enables SCL clock stretching when the transmit data flag is set during a slave-transmit transfer.
bool { ... } ::enableTx |
lpi2c_slave_transfer_event_t _lpi2c_slave_transfer::event |
Reason the callback is being invoked.
uint32_t _lpi2c_slave_handle::eventMask |
Mask of enabled events.
bool _lpi2c_slave_config::filterDozeEnable |
Enable digital glitch filter in doze mode.
bool _lpi2c_slave_config::filterEnable |
Enable digital glitch filter.
uint32_t _lpi2c_master_transfer::flags |
Bit mask of options for the transfer. See enumeration _lpi2c_master_transfer_flags for available options. Set to 0 or kLPI2C_TransferDefaultFlag for normal transfers.
struct { ... } _lpi2c_master_config::hostRequest |
Host request options.
bool _lpi2c_master_config::ignoreAck |
Whether to ignore ACK/NACK.
bool _lpi2c_slave_config::ignoreAck |
Continue transfers after a NACK is detected.
bool _lpi2c_slave_handle::isBusy |
Whether transfer is busy.
uint32_t _lpi2c_match_config::match0 |
Match value 0.
uint32_t _lpi2c_match_config::match1 |
Match value 1.
lpi2c_data_match_config_mode_t _lpi2c_match_config::matchMode |
Data match configuration setting.
lpi2c_master_pin_config_t _lpi2c_master_config::pinConfig |
The pin configuration option.
uint32_t _lpi2c_master_config::pinLowTimeout_ns |
Pin low timeout in nanoseconds. Set to 0 to disable.
lpi2c_host_request_polarity_t { ... } ::polarity |
Host request pin polarity.
lpi2c_host_request_polarity_t _lpi2c_master_config::polarity |
uint8_t _lpi2c_slave_transfer::receivedAddress |
Matching address send by master.
uint16_t _lpi2c_master_handle::remainingBytes |
Remaining byte count in current state.
bool _lpi2c_match_config::rxDataMatchOnly |
When set to true, received data is ignored until a successful match.
uint8_t _lpi2c_master_config::sclGlitchFilterWidth_ns |
Width in nanoseconds of glitch filter on SCL pin. Set to 0 to disable.
uint32_t _lpi2c_slave_config::sclGlitchFilterWidth_ns |
Width in nanoseconds of the digital filter on the SCL signal. Set to 0 to disable.
uint8_t _lpi2c_master_config::sdaGlitchFilterWidth_ns |
Width in nanoseconds of glitch filter on SDA pin. Set to 0 to disable.
uint32_t _lpi2c_slave_config::sdaGlitchFilterWidth_ns |
Width in nanoseconds of the digital filter on the SDA signal. Set to 0 to disable.
uint16_t _lpi2c_master_transfer::slaveAddress |
The 7-bit slave address.
lpi2c_host_request_source_t { ... } ::source |
Host request source.
lpi2c_host_request_source_t _lpi2c_master_config::source |
uint8_t _lpi2c_master_handle::state |
Transfer state machine current state.
uint32_t _lpi2c_master_transfer::subaddress |
Sub address. Transferred MSB first.
size_t _lpi2c_master_transfer::subaddressSize |
Length of sub address to send in bytes. Maximum size is 4 bytes.
lpi2c_master_transfer_t _lpi2c_master_handle::transfer |
Copy of the current transfer info.
lpi2c_slave_transfer_t _lpi2c_slave_handle::transfer |
LPI2C slave transfer copy.
size_t _lpi2c_slave_transfer::transferredCount |
Number of bytes actually transferred since start or last repeated start.
uint32_t _lpi2c_slave_handle::transferredCount |
Count of bytes transferred.
void* _lpi2c_master_handle::userData |
Application data passed to callback.
void* _lpi2c_slave_handle::userData |
Callback parameter passed to callback.
bool _lpi2c_slave_handle::wasTransmit |
Whether the last transfer was a transmit.
