RTEMS 6.1-rc1
RTEMS port of Linux SPI user-space API. More...
Files | |
file | spidev.h |
RTEMS Port of Linux SPI API. | |
struct | spi_ioc_transfer |
SPI transfer message. More... | |
#define | SPI_IOC_MAGIC 's' |
#define | SPI_MSGSIZE(n) |
Calculates the size of the SPI message array. More... | |
#define | SPI_IOC_MESSAGE(n) _IOW(SPI_IOC_MAGIC, 0, char[SPI_MSGSIZE(n)]) |
Transfers an array with SPI messages. | |
#define | SPI_IOC_RD_MODE _IOR(SPI_IOC_MAGIC, 1, uint8_t) |
Reads the least-significant 8-bits of the SPI default mode. | |
#define | SPI_IOC_WR_MODE _IOW(SPI_IOC_MAGIC, 1, uint8_t) |
Writes the SPI default mode (the most-significant 24-bits of the mode are set to zero). | |
#define | SPI_IOC_RD_LSB_FIRST _IOR(SPI_IOC_MAGIC, 2, uint8_t) |
Reads the SPI default least-significant bit first setting. | |
#define | SPI_IOC_WR_LSB_FIRST _IOW(SPI_IOC_MAGIC, 2, uint8_t) |
Writes the SPI default least-significant-bit first setting. | |
#define | SPI_IOC_RD_BITS_PER_WORD _IOR(SPI_IOC_MAGIC, 3, uint8_t) |
Reads the SPI default bits per word. | |
#define | SPI_IOC_WR_BITS_PER_WORD _IOW(SPI_IOC_MAGIC, 3, uint8_t) |
Writes the SPI default bits per word. | |
#define | SPI_IOC_RD_MAX_SPEED_HZ _IOR(SPI_IOC_MAGIC, 4, uint32_t) |
Reads the SPI default speed in Hz. | |
#define | SPI_IOC_WR_MAX_SPEED_HZ _IOW(SPI_IOC_MAGIC, 4, uint32_t) |
Writes the SPI default speed in Hz. | |
#define | SPI_IOC_RD_MODE32 _IOR(SPI_IOC_MAGIC, 5, uint32_t) |
Reads the full 32-bit SPI default mode. | |
#define | SPI_IOC_WR_MODE32 _IOW(SPI_IOC_MAGIC, 5, uint32_t) |
Writes the full 32-bit SPI default mode. | |
SPI Transfer Flags | |
#define | SPI_CPHA 0x01 |
SPI transfer flag which sets the clock phase. | |
#define | SPI_CPOL 0x02 |
SPI transfer flag which sets the clock polarity. | |
#define | SPI_MODE_0 0 |
SPI transfer flag which sets SPI Mode 0 (clock starts low, sample on leading edge). | |
#define | SPI_MODE_1 SPI_CPHA |
SPI transfer flag which sets SPI Mode 0 (clock starts low, sample on trailing edge). | |
#define | SPI_MODE_2 SPI_CPOL |
SPI transfer flag which sets SPI Mode 0 (clock starts high, sample on leading edge). | |
#define | SPI_MODE_3 (SPI_CPOL | SPI_CPHA) |
SPI transfer flag which sets SPI Mode 0 (clock starts high, sample on trailing edge). | |
#define | SPI_CS_HIGH 0x04 |
SPI transfer flag which selects the device by setting the chip select line. | |
#define | SPI_LSB_FIRST 0x08 |
SPI transfer flag which triggers data transmission with the LSB being sent first. | |
#define | SPI_3WIRE 0x10 |
SPI transfer flag which uses a shared wire for master input/slave output as well as master output/slave input. | |
#define | SPI_LOOP 0x20 |
SPI transfer flag which initiates the loopback mode. | |
#define | SPI_NO_CS 0x40 |
SPI transfer flag which indicates that no chip select is needed due to only one device on the bus. | |
#define | SPI_READY 0x80 |
SPI transfer flag which pulls the slave to low level during pause. | |
#define | SPI_TX_DUAL 0x100 |
SPI transfer flag which sets up dual mode for transmission. | |
#define | SPI_TX_QUAD 0x200 |
SPI transfer flag which sets up quad mode for transmission. | |
#define | SPI_RX_DUAL 0x400 |
SPI transfer flag which sets up dual mode for reception. | |
#define | SPI_RX_QUAD 0x800 |
SPI transfer flag which sets up quad mode for reception. | |
Additional documentation is available through the Linux sources, see
/usr/src/linux/include/uapi/linux/spidev.h.
#define SPI_MSGSIZE | ( | n | ) |
