RTEMS 6.1-rc1
rtems_flashdev Struct Reference
Flash device. More...
#include <flashdev.h>
int(* read )(rtems_flashdev *flash, uintptr_t offset, size_t count, void *buffer)
 Call to the device driver to read the flash device. More...
int(* write )(rtems_flashdev *flash, uintptr_t offset, size_t count, const void *buffer)
 Call to the device driver to write to the flash device. More...
int(* erase )(rtems_flashdev *flash, uintptr_t offset, size_t count)
 Call to the device driver to erase the flash device. More...
uint32_t(* jedec_id )(rtems_flashdev *flash)
 Call to the device driver to return the JEDEC ID. More...
int(* flash_type )(rtems_flashdev *flash, rtems_flashdev_flash_type *type)
 Call to the device driver to return the flash type. More...
int(* page_info_by_offset )(rtems_flashdev *flash, off_t search_offset, off_t *page_offset, size_t *page_size)
 Call to device driver to get size and offset of page at given offset. More...
int(* page_info_by_index )(rtems_flashdev *flashdev, off_t search_index, off_t *page_offset, size_t *page_size)
 Call to device driver to get size and offset of page at given index. More...
int(* page_count )(rtems_flashdev *flashdev, int *page_count)
 Call to device driver to return the number of pages on the flash device. More...
int(* write_block_size )(rtems_flashdev *flashdev, size_t *write_block_size)
 Call to device driver to return the minimum write size of the flash device. More...
void(* destroy )(rtems_flashdev *flashdev)
 Destroys the flash device. More...
void * driver
 Pointer to device driver.
rtems_recursive_mutex mutex
 Mutex to protect the flash device access.
rtems_flashdev_region_tableregion_table
 Region table defining size and memory for region allocations.
Flash device.
Field Documentation
◆ destroy
void(* rtems_flashdev::destroy) (rtems_flashdev *flashdev)
Parameters
[in]flashPointer to flash device.
◆ erase
int(* rtems_flashdev::erase) (rtems_flashdev *flash, uintptr_t offset, size_t count)
Parameters
[in]offsetAddress to erase at.
[in]countNumber of bytes to erase.
Return values
0Successful operation.
1Failed operation.
◆ flash_type
int(* rtems_flashdev::flash_type) (rtems_flashdev *flash, rtems_flashdev_flash_type *type)
Parameters
[in]flashThe flash device.
[out]typeThe type of flash device.
Return values
0Success @retbal Other Failure
◆ jedec_id
uint32_t(* rtems_flashdev::jedec_id) (rtems_flashdev *flash)
Parameters
Return values
JEDECID.
◆ page_count
int(* rtems_flashdev::page_count) (rtems_flashdev *flashdev, int *page_count)
Parameters
[out]page_countThe number of pages on the flash device.
Return values
0Success.
non-zeroFailed.
◆ page_info_by_index
int(* rtems_flashdev::page_info_by_index) (rtems_flashdev *flashdev, off_t search_index, off_t *page_offset, size_t *page_size)
Parameters
[in]search_indexThe index of the page which info is to be returned.
[out]page_offsetThe offset of the start of the page
[out]page_sizeThe size of the page
Return values
0Success.
non-zeroFailed.
◆ page_info_by_offset
int(* rtems_flashdev::page_info_by_offset) (rtems_flashdev *flash, off_t search_offset, off_t *page_offset, size_t *page_size)
Parameters
[in]search_offsetThe offset of the page which info is to be returned.
Return values
0Success.
non-zeroFailed.
◆ read
int(* rtems_flashdev::read) (rtems_flashdev *flash, uintptr_t offset, size_t count, void *buffer)
Parameters
[in]offsetAddress to read from.
[in]countNumber of bytes to read.
[out]bufferBuffer for data to be read into.
Return values
1Failed operation.
◆ write
int(* rtems_flashdev::write) (rtems_flashdev *flash, uintptr_t offset, size_t count, const void *buffer)
Parameters
[in]offsetAddress to write to.
[in]bufferBuffer for data to be written from.
Return values
1Failed operation.
◆ write_block_size
int(* rtems_flashdev::write_block_size) (rtems_flashdev *flashdev, size_t *write_block_size)
Parameters
[out]write_block_sizeThe minimum write size of the flash device.
Return values
0Success.
non-zeroFailed.
