RTEMS 6.1-rc1
__attribute__ Struct Reference
u8 Signature [4]
u16 Revision
u16 Features
u16 OptionalCmds
u8 JedecJtgPrmAdvCmd
u8 Reserved0
u16 ExtParamPageLen
u8 NumOfParamPages
u8 Reserved1 [17]
u8 DeviceManufacturer [12]
u8 DeviceModel [20]
u8 JedecManufacturerId
u8 DateCode [2]
u8 Reserved2 [13]
u32 BytesPerPage
u16 SpareBytesPerPage
u32 BytesPerPartialPage
u16 SpareBytesPerPartialPage
u32 PagesPerBlock
u32 BlocksPerLun
u8 NumLuns
u8 AddrCycles
u8 BitsPerCell
u16 MaxBadBlocksPerLun
u16 BlockEndurance
u8 GuaranteedValidBlock
u16 BlockEnduranceGVB
u8 ProgramsPerPage
u8 PartialProgAttr
u8 EccBits
u8 PlaneAddrBits
u8 PlaneOperationAttr
u8 EzNandSupport
u8 Reserved3 [12]
u8 IOPinCapacitance
u16 SDRTimingMode
u16 SDRPagecacheTimingMode
u16 TProg
u16 TBers
u16 TR
u16 TCcs
u8 NVDDRTimingMode
u8 NVDDR2TimingMode
u8 SynFeatures
u16 ClkInputPinCap
u16 IOPinCap
u16 InputPinCap
u8 InputPinCapMax
u8 DrvStrength
u16 TMr
u16 TAdl
u16 TEr
u8 NVDDR2Features
u8 NVDDR2WarmupCycles
u8 Reserved4 [4]
u16 VendorRevisionNum
u8 VendorSpecific [88]
u16 Crc
u8 Sig [4]
u8 Section0Type
u8 Section0Len
u8 Section1Type
u8 Section1Len
u8 ResSection [12]
u8 SectionData [256]
u8 NumEccBits
u8 CodeWordSize
u16 MaxBadBlocks
u16 Reserved
__u32 v32
__u32 m
__u16 v16
Field Documentation
◆ AddrCycles
u8 __attribute__::AddrCycles
Number of address cycles
◆ BitsPerCell
u8 __attribute__::BitsPerCell
Number of bits per cell
◆ BlockEndurance
u16 __attribute__::BlockEndurance
Block endurance
◆ BlockEnduranceGVB
u16 __attribute__::BlockEnduranceGVB
Block endurance for guaranteed valid block
◆ BlocksPerLun
u32 __attribute__::BlocksPerLun
Number of blocks per LUN
◆ BytesPerPage
u32 __attribute__::BytesPerPage
Number of data bytes per page
◆ BytesPerPartialPage
u32 __attribute__::BytesPerPartialPage
Number of data bytes per partial page
◆ ClkInputPinCap
u16 __attribute__::ClkInputPinCap
CLK input pin capacitance
◆ Crc
u16 __attribute__::Crc
Integrity CRC
◆ DateCode
u8 __attribute__::DateCode[2]
Date code
◆ DeviceManufacturer
u8 __attribute__::DeviceManufacturer[12]
Device manufacturer
◆ DeviceModel
u8 __attribute__::DeviceModel[20]
Device model
◆ DrvStrength
u8 __attribute__::DrvStrength
Driver strength support
◆ EccBits
u8 __attribute__::EccBits
Number of bits ECC correctability
◆ ExtParamPageLen
u16 __attribute__::ExtParamPageLen
Extended Parameter Page Length
◆ EzNandSupport
u8 __attribute__::EzNandSupport
EZ NAND support
◆ Features
u16 __attribute__::Features
Features supported
◆ GuaranteedValidBlock
u8 __attribute__::GuaranteedValidBlock
Guaranteed valid blocks at beginning of target
◆ InputPinCap
u16 __attribute__::InputPinCap
Input pin capacitance typical
◆ InputPinCapMax
u8 __attribute__::InputPinCapMax
Input pin capacitance maximum
◆ IOPinCap
u16 __attribute__::IOPinCap
I/O pin capacitance
◆ IOPinCapacitance
u8 __attribute__::IOPinCapacitance
I/O pin capacitance, maximum
◆ JedecJtgPrmAdvCmd
u8 __attribute__::JedecJtgPrmAdvCmd
ONFI JEDEC JTG primary advanced command support
◆ JedecManufacturerId
u8 __attribute__::JedecManufacturerId
JEDEC Manufacturer ID
◆ MaxBadBlocksPerLun
u16 __attribute__::MaxBadBlocksPerLun
Bad blocks maximum per LUN
◆ NumLuns
u8 __attribute__::NumLuns
Number of LUN's
◆ NumOfParamPages
u8 __attribute__::NumOfParamPages
Number of Parameter Pages
◆ NVDDR2Features
u8 __attribute__::NVDDR2Features
NVDDR2 Features
◆ NVDDR2TimingMode
u8 __attribute__::NVDDR2TimingMode
NVDDR2 timing mode support
◆ NVDDR2WarmupCycles
u8 __attribute__::NVDDR2WarmupCycles
NVDDR2 Warmup Cycles
◆ NVDDRTimingMode
u8 __attribute__::NVDDRTimingMode
NVDDR timing mode support
◆ OptionalCmds
u16 __attribute__::OptionalCmds
Optional commands supported
◆ PagesPerBlock
u32 __attribute__::PagesPerBlock
Number of pages per block
◆ PartialProgAttr
u8 __attribute__::PartialProgAttr
Partial programming attributes
◆ PlaneAddrBits
u8 __attribute__::PlaneAddrBits
Number of plane address bits
◆ PlaneOperationAttr
u8 __attribute__::PlaneOperationAttr
Multi-plane operation attributes
◆ ProgramsPerPage
u8 __attribute__::ProgramsPerPage
Number of programs per page
◆ Reserved0
u8 __attribute__::Reserved0
Reserved (11)
◆ Reserved1
u8 __attribute__::Reserved1
Reserved (15-31)
◆ Reserved2
u8 __attribute__::Reserved2[13]
Reserved (67-79)
◆ Reserved3
u8 __attribute__::Reserved3[12]
Reserved (116 - 127)
◆ Reserved4
u8 __attribute__::Reserved4[4]
Reserved (160 - 163)
◆ Revision
u16 __attribute__::Revision
Revision Number
◆ SDRPagecacheTimingMode
u16 __attribute__::SDRPagecacheTimingMode
SDR Program cache timing mode
◆ SDRTimingMode
u16 __attribute__::SDRTimingMode
SDR Timing mode support
◆ Signature
u8 __attribute__::Signature[4]
Parameter page signature
◆ SpareBytesPerPage
u16 __attribute__::SpareBytesPerPage
Number of spare bytes per page
◆ SpareBytesPerPartialPage
u16 __attribute__::SpareBytesPerPartialPage
Number of spare bytes per partial page
◆ SynFeatures
u8 __attribute__::SynFeatures
NVDDR/NVDDR2 features
◆ TAdl
u16 __attribute__::TAdl
Program page register clear enhancement value
◆ TBers
u16 __attribute__::TBers
Maximum block erase time
◆ TCcs
u16 __attribute__::TCcs
Maximum change column setup time
◆ TEr
u16 __attribute__::TEr
Typical page read time for EZ NAND
◆ TMr
u16 __attribute__::TMr
Maximum multi-plane read time
◆ TProg
u16 __attribute__::TProg
Maximum page program time
◆ TR
u16 __attribute__::TR
Maximum page read time
◆ VendorRevisionNum
u16 __attribute__::VendorRevisionNum
Vendor specific revision number
◆ VendorSpecific
u8 __attribute__::VendorSpecific[88]
Vendor specific
The documentation for this struct was generated from the following files:
