RTEMS 6.3
This header file provides the Timer Manager API. More...
#include <stddef.h>#include <rtems/rtems/attr.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>#include <rtems/score/watchdogticks.h>Go to the source code of this file.
| struct | rtems_timer_information |
| The structure contains information about a timer. More... | |
| #define | TIMER_CLASS_BIT_NOT_DORMANT 0x4 |
| This timer class bit indicates that the timer is not dormant. | |
| #define | TIMER_CLASS_BIT_ON_TASK 0x2 |
| This timer class bit indicates that the timer routine executes in a task context. | |
| #define | TIMER_CLASS_BIT_TIME_OF_DAY 0x1 |
| This timer class bit indicates that the timer uses a time of day. | |
| #define | RTEMS_TIMER_SERVER_DEFAULT_PRIORITY ( (rtems_task_priority) -1 ) |
| This constant represents the default value for the task priority of the Timer Server. | |
Typedefs | |
| typedef void | rtems_timer_service_routine |
| This type defines the return type of routines which can be fired by directives of the Timer Manager. | |
| typedef rtems_timer_service_routine(*) | rtems_timer_service_routine_entry(rtems_id, void *) |
| This type defines the prototype of routines which can be fired by directives of the Timer Manager. | |
Enumerations | |
| enum | Timer_Classes { TIMER_DORMANT , TIMER_INTERVAL = TIMER_CLASS_BIT_NOT_DORMANT , TIMER_INTERVAL_ON_TASK , TIMER_TIME_OF_DAY , TIMER_TIME_OF_DAY_ON_TASK } |
| The timer class indicates how the timer was most recently fired. More... | |
