RTEMS 6.3
signal.h
2
10
11/*
12 * Copyright (C) 2020, 2021 embedded brains GmbH & Co. KG
13 * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/signal/if/header */
55
56#ifndef _RTEMS_RTEMS_SIGNAL_H
57#define _RTEMS_RTEMS_SIGNAL_H
58
59#include <rtems/rtems/asr.h>
60#include <rtems/rtems/modes.h>
61#include <rtems/rtems/status.h>
62#include <rtems/rtems/types.h>
63
64#ifdef __cplusplus
65extern "C" {
66#endif
67
68/* Generated from spec:/rtems/signal/if/group */
69
78
79/* Generated from spec:/rtems/signal/if/catch */
80
136 rtems_asr_entry asr_handler,
137 rtems_mode mode_set
138);
139
140/* Generated from spec:/rtems/signal/if/send */
141
202 rtems_id id,
203 rtems_signal_set signal_set
204);
205
206#ifdef __cplusplus
207}
208#endif
209
210#endif /* _RTEMS_RTEMS_SIGNAL_H */
This header file defines the parts of the Signal Manager API.
This header file provides types used by the Classic API.
uint32_t rtems_mode
This type represents a Classic API task mode set.
Definition modes.h:174
rtems_status_code rtems_signal_catch(rtems_asr_entry asr_handler, rtems_mode mode_set)
Establishes an asynchronous signal routine (ASR) for the calling task.
Definition signalcatch.c:50
rtems_status_code rtems_signal_send(rtems_id id, rtems_signal_set signal_set)
Sends the signal set to the task.
Definition signalsend.c:158
uint32_t rtems_signal_set
This integer type represents a bit field which can hold exactly 32 individual signals.
Definition asr.h:87
rtems_asr(*) rtems_asr_entry(rtems_signal_set)
This type defines the prototype of routines which are used to process asynchronous signals.
Definition asr.h:97
rtems_status_code
Definition status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition types.h:94
This header file provides the task modes API of the Task Manager.
This header file provides the status codes of Classic API directives and support functions.
