RTEMS
6.3
Toggle main menu visibility
include
asrdata.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
/* COPYRIGHT (c) 1989-2013.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_RTEMS_ASRDATA_H
39
#define _RTEMS_RTEMS_ASRDATA_H
40
41
rtems/rtems/asr.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
52
57
typedef
struct
59
bool
is_enabled
61
rtems_asr_entry
handler
63
rtems_mode
mode_set
65
rtems_signal_set
signals_pending
66
ASR_Information
67
69
70
#ifdef __cplusplus
71
72
#endif
73
74
#endif
75
/* end of include file */
asr.h
This header file defines the parts of the Signal Manager API.
rtems_mode
uint32_t rtems_mode
This type represents a Classic API task mode set.
Definition
modes.h:174
rtems_signal_set
uint32_t rtems_signal_set
This integer type represents a bit field which can hold exactly 32 individual signals.
Definition
asr.h:87
rtems_asr_entry
rtems_asr(*) rtems_asr_entry(rtems_signal_set)
This type defines the prototype of routines which are used to process asynchronous signals.
Definition
asr.h:97
ASR_Information
Definition
asrdata.h:57
ASR_Information::handler
rtems_asr_entry handler
Definition
asrdata.h:61
ASR_Information::is_enabled
bool is_enabled
Definition
asrdata.h:59
ASR_Information::signals_pending
rtems_signal_set signals_pending
Definition
asrdata.h:65
ASR_Information::mode_set
rtems_mode mode_set
Definition
asrdata.h:63
