RTEMS 6.3
support.h
2
10
11/*
12 * Copyright (C) 2020, 2021 embedded brains GmbH & Co. KG
13 * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/support/if/header */
55
56#ifndef _RTEMS_RTEMS_SUPPORT_H
57#define _RTEMS_RTEMS_SUPPORT_H
58
59#include <stdbool.h>
60#include <stddef.h>
61#include <stdint.h>
62#include <rtems/config.h>
63#include <rtems/rtems/types.h>
65
66#ifdef __cplusplus
67extern "C" {
68#endif
69
70/* Generated from spec:/rtems/support/if/group */
71
79
80/* Generated from spec:/rtems/support/if/is-name-valid */
81
100static inline bool rtems_is_name_valid( rtems_name name )
101{
102 return name != 0;
103}
104
105/* Generated from spec:/rtems/support/if/microseconds-to-ticks */
106
130#define RTEMS_MICROSECONDS_TO_TICKS( _us ) \
131 ( ( _us ) / rtems_configuration_get_microseconds_per_tick() )
132
133/* Generated from spec:/rtems/support/if/milliseconds-to-microseconds */
134
155#define RTEMS_MILLISECONDS_TO_MICROSECONDS( _ms ) ( ( _ms ) * 1000UL )
156
157/* Generated from spec:/rtems/support/if/milliseconds-to-ticks */
158
181#define RTEMS_MILLISECONDS_TO_TICKS( _ms ) \
182 RTEMS_MICROSECONDS_TO_TICKS( RTEMS_MILLISECONDS_TO_MICROSECONDS( _ms ) )
183
184/* Generated from spec:/rtems/support/if/name-to-characters */
185
210static inline void rtems_name_to_characters(
211 rtems_name name,
212 char *c1,
213 char *c2,
214 char *c3,
215 char *c4
216)
217{
218 *c1 = (char) ( ( ( name ) >> 24 ) & 0xff );
219 *c2 = (char) ( ( ( name ) >> 16 ) & 0xff );
220 *c3 = (char) ( ( ( name ) >> 8 ) & 0xff );
221 *c4 = (char) ( ( name ) & 0xff );
222}
223
224/* Generated from spec:/rtems/support/if/workspace-allocate */
225
255bool rtems_workspace_allocate( size_t bytes, void **pointer );
256
257/* Generated from spec:/rtems/support/if/workspace-free */
258
282bool rtems_workspace_free( void *pointer );
283
284/* Generated from spec:/rtems/support/if/workspace-get-information */
285
312
313/* Generated from spec:/rtems/support/if/workspace-greedy-allocate */
314
332 const uintptr_t *block_sizes,
333 size_t block_count
334);
335
336/* Generated from spec:/rtems/support/if/workspace-greedy-allocate-all-except-largest */
337
370 uintptr_t *allocatable_size
371);
372
373/* Generated from spec:/rtems/support/if/workspace-greedy-free */
374
401
402#ifdef __cplusplus
403}
404#endif
405
406#endif /* _RTEMS_RTEMS_SUPPORT_H */
This header file provides types used by the Classic API.
bool rtems_workspace_allocate(size_t bytes, void **pointer)
Allocates a memory area from the RTEMS Workspace.
Definition workspace.c:61
bool rtems_workspace_free(void *pointer)
Frees the memory area allocated from the RTEMS Workspace.
Definition workspace.c:88
bool rtems_workspace_get_information(Heap_Information_block *the_info)
Gets information about the RTEMS Workspace.
Definition workspace.c:51
void rtems_workspace_greedy_free(void *opaque)
Frees space of a greedy allocation to the RTEMS Workspace.
Definition workspacegreedy.c:88
void * rtems_workspace_greedy_allocate(const uintptr_t *block_sizes, size_t block_count)
Greedy allocates that empties the RTEMS Workspace.
Definition workspacegreedy.c:52
void * rtems_workspace_greedy_allocate_all_except_largest(uintptr_t *allocatable_size)
Greedy allocates all blocks of the RTEMS Workspace except the largest free block.
Definition workspacegreedy.c:69
uint32_t rtems_name
This type represents Classic API object names.
Definition types.h:226
This header file provides interfaces of the Barrier Handler which are used by the implementation and ...
Information block returned by _Heap_Get_information().
Definition heapinfo.h:165
Definition bootldr.h:42
