RTEMS 6.3
Directive Attributes
This group contains the implementation to support directive attributes. More...
file  cpukit/include/rtems/rtems/attr.h
 This header file provides Classic API directive attributes.
file  cpukit/include/rtems/rtems/attrimpl.h
 This header file provides the implementation interfaces of the Directive Attributes support.
#define ATTRIBUTES_NOT_SUPPORTED   0
#define ATTRIBUTES_REQUIRED   RTEMS_FLOATING_POINT
◆ ATTRIBUTES_NOT_SUPPORTED
This attribute constant indicates the attributes that are not supportable given the hardware configuration.
◆ ATTRIBUTES_REQUIRED
This attribute constant indicates the attributes that are required given the hardware configuration.
