RTEMS
6.3
Toggle main menu visibility
include
asr.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2020 embedded brains GmbH & Co. KG
13
* Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
38
* This file is part of the RTEMS quality process and was automatically
39
* generated. If you find something that needs to be fixed or
40
* worded better please post a report or patch to an RTEMS mailing list
41
* or raise a bug report:
42
43
* https://www.rtems.org/bugs.html
44
45
* For information on updating and regenerating please refer to the How-To
46
* section in the Software Requirements Engineering chapter of the
47
* RTEMS Software Engineering manual. The manual is provided as a part of
48
* a release. For development sources please refer to the online
49
* documentation at:
50
51
* https://docs.rtems.org
52
53
54
/* Generated from spec:/rtems/signal/if/header-2 */
55
56
#ifndef _RTEMS_RTEMS_ASR_H
57
#define _RTEMS_RTEMS_ASR_H
58
59
#include <stdint.h>
60
61
#ifdef __cplusplus
62
extern
"C"
63
#endif
64
65
/* Generated from spec:/rtems/signal/if/asr */
66
77
typedef
void
rtems_asr
78
79
/* Generated from spec:/rtems/signal/if/set */
80
87
typedef
uint32_t
rtems_signal_set
88
89
/* Generated from spec:/rtems/signal/if/asr-entry */
90
97
typedef
rtems_asr
rtems_asr_entry
98
rtems_signal_set
99
100
101
/* Generated from spec:/rtems/signal/if/signal-00 */
102
109
#define RTEMS_SIGNAL_0 0x00000001
110
111
/* Generated from spec:/rtems/signal/if/signal-01 */
112
119
#define RTEMS_SIGNAL_1 0x00000002
120
121
/* Generated from spec:/rtems/signal/if/signal-02 */
122
129
#define RTEMS_SIGNAL_2 0x00000004
130
131
/* Generated from spec:/rtems/signal/if/signal-03 */
132
139
#define RTEMS_SIGNAL_3 0x00000008
140
141
/* Generated from spec:/rtems/signal/if/signal-04 */
142
149
#define RTEMS_SIGNAL_4 0x00000010
150
151
/* Generated from spec:/rtems/signal/if/signal-05 */
152
159
#define RTEMS_SIGNAL_5 0x00000020
160
161
/* Generated from spec:/rtems/signal/if/signal-06 */
162
169
#define RTEMS_SIGNAL_6 0x00000040
170
171
/* Generated from spec:/rtems/signal/if/signal-07 */
172
179
#define RTEMS_SIGNAL_7 0x00000080
180
181
/* Generated from spec:/rtems/signal/if/signal-08 */
182
189
#define RTEMS_SIGNAL_8 0x00000100
190
191
/* Generated from spec:/rtems/signal/if/signal-09 */
192
199
#define RTEMS_SIGNAL_9 0x00000200
200
201
/* Generated from spec:/rtems/signal/if/signal-10 */
202
209
#define RTEMS_SIGNAL_10 0x00000400
210
211
/* Generated from spec:/rtems/signal/if/signal-11 */
212
219
#define RTEMS_SIGNAL_11 0x00000800
220
221
/* Generated from spec:/rtems/signal/if/signal-12 */
222
229
#define RTEMS_SIGNAL_12 0x00001000
230
231
/* Generated from spec:/rtems/signal/if/signal-13 */
232
239
#define RTEMS_SIGNAL_13 0x00002000
240
241
/* Generated from spec:/rtems/signal/if/signal-14 */
242
249
#define RTEMS_SIGNAL_14 0x00004000
250
251
/* Generated from spec:/rtems/signal/if/signal-15 */
252
259
#define RTEMS_SIGNAL_15 0x00008000
260
261
/* Generated from spec:/rtems/signal/if/signal-16 */
262
269
#define RTEMS_SIGNAL_16 0x00010000
270
271
/* Generated from spec:/rtems/signal/if/signal-17 */
272
279
#define RTEMS_SIGNAL_17 0x00020000
280
281
/* Generated from spec:/rtems/signal/if/signal-18 */
282
289
#define RTEMS_SIGNAL_18 0x00040000
290
291
/* Generated from spec:/rtems/signal/if/signal-19 */
292
299
#define RTEMS_SIGNAL_19 0x00080000
300
301
/* Generated from spec:/rtems/signal/if/signal-20 */
302
309
#define RTEMS_SIGNAL_20 0x00100000
310
311
/* Generated from spec:/rtems/signal/if/signal-21 */
312
319
#define RTEMS_SIGNAL_21 0x00200000
320
321
/* Generated from spec:/rtems/signal/if/signal-22 */
322
329
#define RTEMS_SIGNAL_22 0x00400000
330
331
/* Generated from spec:/rtems/signal/if/signal-23 */
332
339
#define RTEMS_SIGNAL_23 0x00800000
340
341
/* Generated from spec:/rtems/signal/if/signal-24 */
342
349
#define RTEMS_SIGNAL_24 0x01000000
350
351
/* Generated from spec:/rtems/signal/if/signal-25 */
352
359
#define RTEMS_SIGNAL_25 0x02000000
360
361
/* Generated from spec:/rtems/signal/if/signal-26 */
362
369
#define RTEMS_SIGNAL_26 0x04000000
370
371
/* Generated from spec:/rtems/signal/if/signal-27 */
372
379
#define RTEMS_SIGNAL_27 0x08000000
380
381
/* Generated from spec:/rtems/signal/if/signal-28 */
382
389
#define RTEMS_SIGNAL_28 0x10000000
390
391
/* Generated from spec:/rtems/signal/if/signal-29 */
392
399
#define RTEMS_SIGNAL_29 0x20000000
400
401
/* Generated from spec:/rtems/signal/if/signal-30 */
402
409
#define RTEMS_SIGNAL_30 0x40000000
410
411
/* Generated from spec:/rtems/signal/if/signal-31 */
412
419
#define RTEMS_SIGNAL_31 0x80000000
420
421
#ifdef __cplusplus
422
423
#endif
424
425
#endif
/* _RTEMS_RTEMS_ASR_H */
rtems_asr
void rtems_asr
This type defines the return type of routines which are used to process asynchronous signals.
Definition
asr.h:77
rtems_signal_set
uint32_t rtems_signal_set
This integer type represents a bit field which can hold exactly 32 individual signals.
Definition
asr.h:87
rtems_asr_entry
rtems_asr(*) rtems_asr_entry(rtems_signal_set)
This type defines the prototype of routines which are used to process asynchronous signals.
Definition
asr.h:97
