RTEMS 6.3
This header file defines the Clock Manager API. More...
#include <stdbool.h>#include <stdint.h>#include <time.h>#include <rtems/config.h>#include <sys/_timespec.h>#include <sys/_timeval.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>#include <rtems/score/watchdogticks.h>Go to the source code of this file.
| #define | rtems_clock_get_ticks_per_second(void) |
| Gets the number of clock ticks per second configured for the application. | |
| #define | rtems_clock_get_ticks_since_boot(void) |
| Gets the number of clock ticks since some time point during the system initialization or the last overflow of the clock tick counter. | |
| rtems_status_code | rtems_clock_set (const rtems_time_of_day *time_of_day) |
| Sets the CLOCK_REALTIME to the time of day. | |
| rtems_status_code | rtems_clock_get_tod (rtems_time_of_day *time_of_day) |
| Gets the time of day associated with the current CLOCK_REALTIME. | |
| rtems_status_code | rtems_clock_get_tod_timeval (struct timeval *time_of_day) |
| Gets the seconds and microseconds elapsed since the Unix epoch and the current CLOCK_REALTIME. | |
| void | rtems_clock_get_realtime (struct timespec *time_snapshot) |
| Gets the time elapsed since the Unix epoch measured using CLOCK_REALTIME in seconds and nanoseconds format. | |
| void | rtems_clock_get_realtime_bintime (struct bintime *time_snapshot) |
| Gets the time elapsed since the Unix epoch measured using CLOCK_REALTIME in binary time format. | |
| void | rtems_clock_get_realtime_timeval (struct timeval *time_snapshot) |
| Gets the time elapsed since the Unix epoch measured using CLOCK_REALTIME in seconds and microseconds format. | |
| void | rtems_clock_get_realtime_coarse (struct timespec *time_snapshot) |
| Gets the time elapsed since the Unix epoch measured using CLOCK_REALTIME in coarse resolution in seconds and nanoseconds format. | |
| void | rtems_clock_get_realtime_coarse_bintime (struct bintime *time_snapshot) |
| Gets the time elapsed since the Unix epoch measured using CLOCK_REALTIME in coarse resolution in binary time format. | |
| void | rtems_clock_get_realtime_coarse_timeval (struct timeval *time_snapshot) |
| Gets the time elapsed since the Unix epoch measured using CLOCK_REALTIME in coarse resolution in seconds and microseconds format. | |
| void | rtems_clock_get_monotonic (struct timespec *time_snapshot) |
| Gets the time elapsed since some fixed time point in the past measured using the CLOCK_MONOTONIC in seconds and nanoseconds format. | |
| void | rtems_clock_get_monotonic_bintime (struct bintime *time_snapshot) |
| Gets the time elapsed since some fixed time point in the past measured using the CLOCK_MONOTONIC in binary time format. | |
| int64_t | rtems_clock_get_monotonic_sbintime (void) |
| Gets the time elapsed since some fixed time point in the past measured using the CLOCK_MONOTONIC in signed binary time format. | |
| void | rtems_clock_get_monotonic_timeval (struct timeval *time_snapshot) |
| Gets the time elapsed since some fixed time point in the past measured using the CLOCK_MONOTONIC in seconds and microseconds format. | |
| void | rtems_clock_get_monotonic_coarse (struct timespec *time_snapshot) |
| Gets the time elapsed since some fixed time point in the past measured using the CLOCK_MONOTONIC in coarse resolution in seconds and nanoseconds format. | |
| void | rtems_clock_get_monotonic_coarse_bintime (struct bintime *time_snapshot) |
| Gets the time elapsed since some fixed time point in the past measured using the CLOCK_MONOTONIC in coarse resolution in binary time format. | |
| void | rtems_clock_get_monotonic_coarse_timeval (struct timeval *time_snapshot) |
| Gets the time elapsed since some fixed time point in the past measured using the CLOCK_MONOTONIC in coarse resolution in seconds and microseconds format. | |
| void | rtems_clock_get_boot_time (struct timespec *boot_time) |
| Gets the time elapsed since the Unix epoch at some time point during system initialization in seconds and nanoseconds format. | |
| void | rtems_clock_get_boot_time_bintime (struct bintime *boot_time) |
| Gets the time elapsed since the Unix epoch at some time point during system initialization in binary time format. | |
| void | rtems_clock_get_boot_time_timeval (struct timeval *boot_time) |
| Gets the time elapsed since the Unix epoch at some time point during system initialization in seconds and microseconds format. | |
| rtems_status_code | rtems_clock_get_seconds_since_epoch (rtems_interval *seconds_since_rtems_epoch) |
| Gets the seconds elapsed since the RTEMS epoch and the current CLOCK_REALTIME. | |
| rtems_status_code | rtems_clock_get_uptime (struct timespec *uptime) |
| Gets the seconds and nanoseconds elapsed since some time point during the system initialization using CLOCK_MONOTONIC. | |
| void | rtems_clock_get_uptime_timeval (struct timeval *uptime) |
| Gets the seconds and microseconds elapsed since some time point during the system initialization using CLOCK_MONOTONIC. | |
| time_t | rtems_clock_get_uptime_seconds (void) |
| Gets the seconds elapsed since some time point during the system initialization using CLOCK_MONOTONIC. | |
| uint64_t | rtems_clock_get_uptime_nanoseconds (void) |
| Gets the nanoseconds elapsed since some time point during the system initialization using CLOCK_MONOTONIC. | |
| rtems_status_code | rtems_clock_tick (void) |
| Announces a clock tick. | |
| rtems_status_code rtems_clock_tick | ( | void | ) |
The following constraints apply to this directive:
