RTEMS
6.3
Toggle main menu visibility
include
part.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2020, 2021 embedded brains GmbH & Co. KG
13
* Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
38
* This file is part of the RTEMS quality process and was automatically
39
* generated. If you find something that needs to be fixed or
40
* worded better please post a report or patch to an RTEMS mailing list
41
* or raise a bug report:
42
43
* https://www.rtems.org/bugs.html
44
45
* For information on updating and regenerating please refer to the How-To
46
* section in the Software Requirements Engineering chapter of the
47
* RTEMS Software Engineering manual. The manual is provided as a part of
48
* a release. For development sources please refer to the online
49
* documentation at:
50
51
* https://docs.rtems.org
52
53
54
/* Generated from spec:/rtems/part/if/header */
55
56
#ifndef _RTEMS_RTEMS_PART_H
57
#define _RTEMS_RTEMS_PART_H
58
59
#include <stddef.h>
60
#include <stdint.h>
61
rtems/rtems/attr.h
62
rtems/rtems/status.h
63
rtems/rtems/types.h
64
#include <rtems/score/cpu.h>
65
66
#ifdef __cplusplus
67
extern
"C"
68
#endif
69
70
/* Generated from spec:/rtems/part/if/group */
71
80
81
/* Generated from spec:/rtems/part/if/alignment */
82
93
#define RTEMS_PARTITION_ALIGNMENT CPU_SIZEOF_POINTER
94
95
/* Generated from spec:/rtems/part/if/create */
96
235
rtems_status_code
rtems_partition_create
236
rtems_name
name,
237
void
*starting_address,
238
uintptr_t length,
239
size_t
buffer_size,
240
rtems_attribute
attribute_set,
241
rtems_id
id
242
243
244
/* Generated from spec:/rtems/part/if/ident */
245
316
rtems_status_code
rtems_partition_ident
317
rtems_name
name,
318
uint32_t node,
319
rtems_id
id
320
321
322
/* Generated from spec:/rtems/part/if/delete */
323
380
rtems_status_code
rtems_partition_delete
rtems_id
id
381
382
/* Generated from spec:/rtems/part/if/get-buffer */
383
438
rtems_status_code
rtems_partition_get_buffer
rtems_id
id
void
**buffer );
439
440
/* Generated from spec:/rtems/part/if/return-buffer */
441
483
rtems_status_code
rtems_partition_return_buffer
rtems_id
id
void
*buffer );
484
485
#ifdef __cplusplus
486
487
#endif
488
489
#endif
/* _RTEMS_RTEMS_PART_H */
attr.h
This header file provides Classic API directive attributes.
types.h
This header file provides types used by the Classic API.
rtems_attribute
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition
attr.h:96
rtems_status_code rtems_partition_return_buffer(rtems_id id, void *buffer)
Returns the buffer to the partition.
Definition
partreturnbuffer.c:87
rtems_status_code rtems_partition_delete(rtems_id id)
Deletes the partition.
Definition
partdelete.c:45
rtems_status_code rtems_partition_create(rtems_name name, void *starting_address, uintptr_t length, size_t buffer_size, rtems_attribute attribute_set, rtems_id *id)
Creates a partition.
Definition
partcreate.c:82
rtems_status_code rtems_partition_get_buffer(rtems_id id, void **buffer)
Tries to get a buffer from the partition.
Definition
partgetbuffer.c:50
rtems_status_code rtems_partition_ident(rtems_name name, uint32_t node, rtems_id *id)
Identifies a partition by the object name.
Definition
partident.c:45
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems_name
uint32_t rtems_name
This type represents Classic API object names.
Definition
types.h:226
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition
types.h:94
status.h
This header file provides the status codes of Classic API directives and support functions.
