56#ifndef _RTEMS_RTEMS_SEM_H
57#define _RTEMS_RTEMS_SEM_H
This header file provides Classic API directive attributes.
This header file provides types used by the Classic API.
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition attr.h:96
uint32_t rtems_option
This type represents a Classic API directive option set.
Definition options.h:126
rtems_status_code rtems_semaphore_flush(rtems_id id)
Flushes the semaphore.
Definition semflush.c:44
rtems_status_code rtems_semaphore_create(rtems_name name, uint32_t count, rtems_attribute attribute_set, rtems_task_priority priority_ceiling, rtems_id *id)
Creates a semaphore.
Definition semcreate.c:54
rtems_status_code rtems_semaphore_ident(rtems_name name, uint32_t node, rtems_id *id)
Identifies a semaphore by the object name.
Definition semident.c:45
rtems_status_code rtems_semaphore_delete(rtems_id id)
Deletes the semaphore.
Definition semdelete.c:45
rtems_status_code rtems_semaphore_set_priority(rtems_id semaphore_id, rtems_id scheduler_id, rtems_task_priority new_priority, rtems_task_priority *old_priority)
Sets the priority by scheduler for the semaphore.
Definition semsetpriority.c:145
rtems_status_code rtems_semaphore_release(rtems_id id)
Releases the semaphore.
Definition semrelease.c:45
rtems_status_code rtems_semaphore_obtain(rtems_id id, rtems_option option_set, rtems_interval timeout)
Obtains the semaphore.
Definition semobtain.c:72
rtems_status_code
Definition status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition types.h:226
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition types.h:257
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition types.h:94
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition types.h:114
This header file provides the Classic API directive options.
This header file provides the status codes of Classic API directives and support functions.
