RTEMS 6.3
part.h File Reference
This header file provides the Partition Manager API. More...
#include <stddef.h>
#include <stdint.h>
#include <rtems/rtems/attr.h>
#include <rtems/score/cpu.h>
#define RTEMS_PARTITION_ALIGNMENT   CPU_SIZEOF_POINTER
 This constant defines the minimum alignment of a partition buffer in bytes.
rtems_status_code rtems_partition_create (rtems_name name, void *starting_address, uintptr_t length, size_t buffer_size, rtems_attribute attribute_set, rtems_id *id)
 Creates a partition.
rtems_status_code rtems_partition_ident (rtems_name name, uint32_t node, rtems_id *id)
 Identifies a partition by the object name.
rtems_status_code rtems_partition_delete (rtems_id id)
 Deletes the partition.
rtems_status_code rtems_partition_get_buffer (rtems_id id, void **buffer)
 Tries to get a buffer from the partition.
rtems_status_code rtems_partition_return_buffer (rtems_id id, void *buffer)
 Returns the buffer to the partition.
