RTEMS
6.3
Toggle main menu visibility
include
statusimpl.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
/* COPYRIGHT (c) 1989-2008.
13
* On-Line Applications Research Corporation (OAR).
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_RTEMS_STATUSIMPL_H
38
#define _RTEMS_RTEMS_STATUSIMPL_H
39
40
rtems/rtems/status.h
41
rtems/score/threadimpl.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
54
65
66
static
inline
rtems_status_code
_Status_Get(
67
Status_Control
status
68
69
70
return
rtems_status_code
STATUS_GET_CLASSIC
( status );
71
72
73
static
inline
rtems_status_code
_Status_Get_after_wait(
74
const
Thread_Control *executing
75
76
77
return
_Status_Get( _Thread_Wait_get_status( executing ) );
78
79
81
82
#ifdef __cplusplus
83
84
#endif
85
86
#endif
87
/* end of include file */
rtems_status_code
rtems_status_code
Definition
status.h:85
STATUS_GET_CLASSIC
#define STATUS_GET_CLASSIC(status)
Macro to get the Classic API status code.
Definition
status.h:97
Status_Control
Status_Control
Status codes.
Definition
status.h:111
status.h
This header file provides the status codes of Classic API directives and support functions.
threadimpl.h
This header file provides interfaces of the Thread Handler which are only used by the implementation.
