57#ifndef _RTEMS_RTEMS_RATEMON_H
58#define _RTEMS_RTEMS_RATEMON_H
61#include <sys/_timespec.h>
217#define RTEMS_PERIOD_STATUS WATCHDOG_NO_TIMEOUT
This header file provides types used by the Classic API.
void rtems_rate_monotonic_report_statistics_with_plugin(const struct rtems_printer *printer)
Reports the period statistics using the printer plugin.
rtems_rate_monotonic_period_states
This enumeration defines the states in which a period may be.
Definition ratemon.h:91
rtems_status_code rtems_rate_monotonic_get_statistics(rtems_id id, rtems_rate_monotonic_period_statistics *status)
Gets the statistics of the period.
Definition ratemongetstatistics.c:45
rtems_status_code rtems_rate_monotonic_cancel(rtems_id id)
Cancels the period.
Definition ratemoncancel.c:71
rtems_status_code rtems_rate_monotonic_period(rtems_id id, rtems_interval length)
Concludes the current period and start the next period, or gets the period status.
Definition ratemonperiod.c:313
rtems_status_code rtems_rate_monotonic_delete(rtems_id id)
Deletes the period.
Definition ratemondelete.c:45
void rtems_rate_monotonic_report_statistics(void)
Reports the period statistics using the printk() printer.
Definition ratemonreportstatistics.c:178
rtems_status_code rtems_rate_monotonic_get_status(rtems_id id, rtems_rate_monotonic_period_status *status)
Gets the detailed status of the period.
Definition ratemongetstatus.c:46
rtems_status_code rtems_rate_monotonic_ident(rtems_name name, rtems_id *id)
Identifies a period by the object name.
Definition ratemonident.c:45
rtems_status_code rtems_rate_monotonic_create(rtems_name name, rtems_id *id)
Creates a period.
Definition ratemoncreate.c:50
void rtems_rate_monotonic_reset_all_statistics(void)
Resets the statistics of all periods.
Definition ratemonresetall.c:47
rtems_status_code rtems_rate_monotonic_reset_statistics(rtems_id id)
Resets the statistics of the period.
Definition ratemonresetstatistics.c:44
@ RATE_MONOTONIC_ACTIVE
This status indicates the period is on the watchdog chain, and running. The owner may be executing or...
Definition ratemon.h:102
@ RATE_MONOTONIC_EXPIRED
This status indicates the period is off the watchdog chain, and has expired. The owner may still exec...
Definition ratemon.h:109
@ RATE_MONOTONIC_INACTIVE
This status indicates the period is off the watchdog chain, and has never been initialized.
Definition ratemon.h:96
rtems_status_code
Definition status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition types.h:94
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition types.h:114
This header file provides the status codes of Classic API directives and support functions.
This structure provides the statistics of a period.
Definition ratemon.h:119
struct timespec min_wall_time
This member contains the least amount of CLOCK_MONOTONIC time used in a period.
Definition ratemon.h:152
uint32_t missed_count
This member contains the number of periods missed.
Definition ratemon.h:128
struct timespec total_cpu_time
This member contains the total amount of processor time used in a period.
Definition ratemon.h:146
uint32_t count
This member contains the number of periods executed.
Definition ratemon.h:123
struct timespec max_cpu_time
This member contains the highest amount of processor time used in a period.
Definition ratemon.h:140
struct timespec total_wall_time
This member contains the total amount of CLOCK_MONOTONIC time used in a period.
Definition ratemon.h:164
struct timespec min_cpu_time
This member contains the least amount of processor time used in a period.
Definition ratemon.h:134
struct timespec max_wall_time
This member contains the highest amount of CLOCK_MONOTONIC time used in a period.
Definition ratemon.h:158
This structure provides the detailed status of a period.
Definition ratemon.h:174
uint32_t postponed_jobs_count
This member contains the count of jobs which are not released yet.
Definition ratemon.h:206
struct timespec since_last_period
This member contains the time elapsed since the last successful invocation rtems_rate_monotonic_perio...
Definition ratemon.h:192
rtems_rate_monotonic_period_states state
This member contains the state of the period.
Definition ratemon.h:183
rtems_id owner
This member contains the identifier of the owner task of the period.
Definition ratemon.h:178
struct timespec executed_since_last_period
This member contains the processor time consumed by the owner task since the last successful invocati...
Definition ratemon.h:201
This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are ...
