RTEMS 6.3
Clock Manager
This group contains the Clock Manager implementation. More...
file  cpukit/include/rtems/rtems/clock.h
 This header file defines the Clock Manager API.
file  cpukit/include/rtems/rtems/clockimpl.h
 This header file provides the implementation interfaces of the Clock Manager.
file  cpukit/rtems/src/clockgetsecondssinceepoch.c
 This source file contains the implementation of rtems_clock_get_seconds_since_epoch().
file  cpukit/rtems/src/clockgettickspersecond.c
 This source file contains the implementation of rtems_clock_get_ticks_per_second().
file  cpukit/rtems/src/clockgettickssinceboot.c
 This source file contains the implementation of rtems_clock_get_ticks_since_boot().
file  cpukit/rtems/src/clockgettod.c
 This source file contains the implementation of rtems_clock_get_tod().
file  cpukit/rtems/src/clockgettodtimeval.c
 This source file contains the implementation of rtems_clock_get_tod_timeval().
file  cpukit/rtems/src/clockgetuptime.c
 This source file contains the implementation of rtems_clock_get_uptime().
file  cpukit/rtems/src/clockgetuptimenanoseconds.c
 This source file contains the implementation of rtems_clock_get_uptime_nanoseconds().
file  cpukit/rtems/src/clockgetuptimeseconds.c
 This source file contains the implementation of rtems_clock_get_uptime_seconds().
file  cpukit/rtems/src/clockgetuptimetimeval.c
 This source file contains the implementation of rtems_clock_get_uptime_timeval().
file  cpukit/rtems/src/clockset.c
 This source file contains the implementation of rtems_clock_set().
file  cpukit/rtems/src/clocktick.c
 This source file contains the implementation of rtems_clock_tick().
file  cpukit/rtems/src/clocktodtoseconds.c
 This source file contains the implementation of _TOD_To_seconds().
file  cpukit/rtems/src/clocktodvalidate.c
 This source file contains the implementation of _TOD_Validate().
enum  TOD_Ticks_validation { TOD_DISABLE_TICKS_VALIDATION = 0 , TOD_ENABLE_TICKS_VALIDATION = -1 }
 The enumerators of this type determine if the ticks member is validated in _TOD_Validate(). More...
rtems_status_code _TOD_Validate (const rtems_time_of_day *the_tod, TOD_Ticks_validation ticks_validation)
 Validates the time of day.
Watchdog_Interval _TOD_To_seconds (const rtems_time_of_day *the_tod)
 TOD to Seconds.
◆ TOD_Ticks_validation
Use this option to disable the validation of the ticks member in _TOD_Validate().
Use this option to enable the validation of the ticks member in _TOD_Validate().
◆ _TOD_To_seconds()
Watchdog_Interval _TOD_To_seconds ( const rtems_time_of_day * the_tod)
TOD to Seconds.
This function returns the number seconds between the epoch and the_tod.
Parameters
[in]the_todis the TOD structure to convert to seconds
Return values
Thismethod returns the number of seconds since epoch represented by the_tod
◆ _TOD_Validate()
rtems_status_code _TOD_Validate ( const rtems_time_of_day * the_tod,
TOD_Ticks_validation ticks_validation )
Parameters
the_todis the reference to the time of day structure to validate or NULL.
ticks_validationindicates if the ticks member of the time of day should be validated. Use TOD_ENABLE_TICKS_VALIDATION to validate the ticks member. Use TOD_DISABLE_TICKS_VALIDATION to skip the validation of the ticks member.
Return values
RTEMS_SUCCESSFULthe_tod references a valid time of day.
RTEMS_INVALID_CLOCKthe_tod references an invalid time of day.
RTEMS_INVALID_ADDRESSthe_tod reference is NULL.
