RTEMS
6.3
Toggle main menu visibility
include
eventdata.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
/* COPYRIGHT (c) 1989-2008.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_RTEMS_EVENTDATA_H
39
#define _RTEMS_RTEMS_EVENTDATA_H
40
41
rtems/rtems/event.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
52
56
typedef
struct
60
rtems_event_set
pending_events
61
Event_Control
62
64
65
#ifdef __cplusplus
66
67
#endif
68
69
#endif
70
/* end of include file */
rtems_event_set
uint32_t rtems_event_set
This integer type represents a bit field which can hold exactly 32 individual events.
Definition
event.h:436
event.h
This header file provides the Event Manager API.
Event_Control
This structure is used to manage a set of events.
Definition
eventdata.h:56
Event_Control::pending_events
rtems_event_set pending_events
The member contains the pending events.
Definition
eventdata.h:60
