RTEMS 6.1-rc4
- r -
- R : ADC_Type, HSEM_TypeDef
- r3_stack_pointer : Context_Control
- RACC : ENET_Type
- RAEM : ENET_Type
- RAFL : ENET_Type
- ram_loc : tms570_selftest_par_desc
- RAMECCErrorCode : RAMECC_HandleTypeDef
- RAMPVALR : DTS_TypeDef
- RANGE0 : TMPSNS_Type
- RANGE0_CLR : TMPSNS_Type
- RANGE0_SET : TMPSNS_Type
- RANGE0_TOG : TMPSNS_Type
- RANGE1 : TMPSNS_Type
- RANGE1_CLR : TMPSNS_Type
- RANGE1_SET : TMPSNS_Type
- RANGE1_TOG : TMPSNS_Type
- RANGE_CTRL : PDM_Type
- RANGE_STAT : PDM_Type
- rangeh : memscrub
- rangeh2 : memscrub
- rangel : memscrub
- rangel2 : memscrub
- Rank : ADC_ChannelConfTypeDef
- rap_id : section_detail
- RASR : ARM_MPU_Region_t
- Ratio : ADC_InjOversamplingTypeDef, ADC_OversamplingTypeDef
- raw : ALT_CLK_GROUP_RAW_CFG_s::ALT_CLK_GROUP_RAW_CFG_u
- RBAR : ARM_MPU_Region_t
- RBB_LPSR_CONFIGURE : ANADIG_PMU_Type
- RBB_LPSR_ENABLE_SP : ANADIG_PMU_Type
- RBB_LPSR_STBY_EN_SP : ANADIG_PMU_Type
- RBB_SOC_CONFIGURE : ANADIG_PMU_Type
- RBB_SOC_ENABLE_SP : ANADIG_PMU_Type
- RBB_SOC_STBY_EN_SP : ANADIG_PMU_Type
- rbEdge : _SmcStatus::_SmcStatusBits
- RBTree : Watchdog_Control
- rbx : Context_Control
- RCDDelay : FMC_SDRAM_TimingTypeDef
- RCMD : CAAM_Type
- RCMR : ENET_Type
- RCR : ENET_Type, TIM_TypeDef
- RCR1 : I2S_Type
- RCR2 : I2S_Type
- RCR3 : I2S_Type
- RCR4 : I2S_Type
- RCR5 : I2S_Type
- RCSR : I2S_Type
- RCTL : CAAM_Type
- rd_datacap : ALT_QSPI_TIMING_CONFIG_s
- RDAR : ENET_Type
- RDAR1 : ENET_Type
- RDAR2 : ENET_Type
- RDATA : CORDIC_TypeDef, FMAC_TypeDef
- RdBlockLen : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- RdBlockMisalign : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- RDHBUF : CAAM_Type
- RDHCNTL : CAAM_Type
- RDHDIG : CAAM_Type
- RDINT0 : CAAM_Type
- RDINT1 : CAAM_Type
- RDPinIndex : _flexio_mculcd_type
- RDPLevel : FLASH_OBProgramInitTypeDef
- RDR : I2S_Type, LPSPI_Type, SWPMI_TypeDef, USART_TypeDef
- RDSR : ENET_Type
- RDSR1 : ENET_Type
- RDSR2 : ENET_Type
- RDSTA : CAAM_Type
- rdtba : grethgbit
- rdyactivePolarity : _semc_nand_config, _semc_nor_config
- re_name : rtems_rtl_obj_print
- re_symbol : rtems_rtl_obj_print
- read : ctrace_per_cpu, i2c_dev, rtems_fdisk_driver_handlers, rtems_flashdev, rtems_jffs2_flash_control, rtems_nvdisk_driver_handlers, rtems_rtl_obj_cpmp, stm32f4_i2c_message
- read_2_reg : sc16is752_context
- read_ahead : rtems_disk_device
- read_ahead_chain : rtems_bdbuf_cache
- read_ahead_enabled : rtems_bdbuf_cache
- read_ahead_peeks : rtems_blkdev_stats
- read_ahead_priority : rtems_bdbuf_config
- read_ahead_task : rtems_bdbuf_cache
- read_ahead_transfers : rtems_blkdev_stats
- read_blocks : rtems_blkdev_stats
- READ_CTRL : OCOTP_Type
- read_entry : rtems_driver_address_table
- read_errors : rtems_blkdev_stats
- READ_FUSE_DATA : OCOTP_Type
- read_hits : rtems_blkdev_stats
- read_misses : rtems_blkdev_stats
- read_reg : sc16is752_context
- ReadBurst : FMC_SDRAM_InitTypeDef
- readBurstLen : _usdhc_config
- reader : rtems_stdio_redirect
- ReadMode : XQspiPsu
- ReadPipeDelay : FMC_SDRAM_InitTypeDef
- readRegRemainingTimes : _lpspi_master_edma_handle, _lpspi_master_handle, _lpspi_slave_edma_handle, _lpspi_slave_handle
- readSampleClkSrc : _flexspi_mem_config, _FlexSPIConfig
- readWatermarkLevel : _usdhc_config
- Ready : Scheduler_EDF_Context, Scheduler_EDF_SMP_Context, Scheduler_priority_Context, Scheduler_simple_Context, Scheduler_strong_APA_Context
- ready : ScoreSchedReqYield_Context
- ready_chain : Scheduler_priority_Ready_queue
- ready_major : Priority_bit_map_Information
- ready_minor : Priority_bit_map_Information
- Ready_node : Scheduler_strong_APA_Node
- Ready_queue : Scheduler_priority_Node, Scheduler_priority_SMP_Node
- ready_queue_index : Scheduler_EDF_SMP_Node
- Real_priority : _Thread_Control, Thread_Proxy_control
- real_priority_is_initial : RtemsTaskReqRestart_Context
- reason : Heap_Error_context
- rec : ctrace_per_cpu, rtems_rtl_unresolv_block, rtl_unresolved_name_data
- rec_valid : ctrace_per_cpu
- receive : RtemsEventReqSendReceive_Context
- receive_buffer : RtemsMessageReqBroadcast_Context, RtemsMessageReqReceive_Context, RtemsMessageReqUrgentSend_Context
- receive_condition_state : RtemsEventReqSendReceive_Context
- receive_option_set : RtemsEventReqSendReceive_Context
- receive_packet : MPCI_Control
- receive_size : RtemsMessageReqBroadcast_Context, RtemsMessageReqReceive_Context, RtemsMessageReqUrgentSend_Context
- receive_status : RtemsEventReqSendReceive_Context, RtemsMessageReqBroadcast_Context, RtemsMessageReqFlushPending_Context, RtemsMessageReqUrgentSend_Context
- receive_timeout : RtemsEventReqSendReceive_Context
- receive_type : RtemsEventReqSendReceive_Context
- received_events : RtemsEventReqSendReceive_Context
- received_events_parameter : RtemsEventReqSendReceive_Context
- receivedAddress : _lpi2c_slave_transfer
- receivedBytes : _pdm_edma_handle
- receiver_id : RtemsEventReqSendReceive_Context
- ReceptionType : __UART_HandleTypeDef
- recoverMode : _pwm_fault_param
- recs : ctrace_per_cpu, rtems_rtl_unresolv_block
- recursionlevel : rtems_filesystem_eval_path_context_t
- Recursive : CORE_ceiling_mutex_Control
- recursive : TQMtxContext
- RecvBuffer : XQspiPsu
- RecvBufferPtr : XQspiPsu
- Red : RTEMS_PACKED
- RedFieldPosition : RTEMS_PACKED
- RedMaskSize : RTEMS_PACKED
- ref_clk : ALT_CLK_PLL_CFG_s
- refCrc : _dcic_region_config
- referenceCurrentSource : dac12_config_t
- references : _rtems_rfs_file_shared, rtems_bdbuf_buffer
- referenceVoltageSource : _acmp_dac_config, _adc_config, _cmp_dac_config, dac12_config_t, lpadc_config_t
- refreshBurstLen : _semc_sdram_config
- refreshPeriod_nsPerRow : _semc_sdram_config
- RefreshRate : RTEMS_PACKED
- refreshUrgThreshold : _semc_sdram_config
- refs : rtems_fdt_blob, rtems_rtl_archive, rtems_rtl_obj, rtems_rtl_unresolv_symbol
- REFTOP_OTP_TRIM_VALUE : ANADIG_PMU_Type
- REG0 : DCDC_Type
- REG1 : DCDC_Type
- REG10 : DCDC_Type
- REG11 : DCDC_Type
- REG12 : DCDC_Type
- REG13 : DCDC_Type
- REG14 : DCDC_Type
- REG15 : DCDC_Type
- REG16 : DCDC_Type
- REG17 : DCDC_Type
- REG18 : DCDC_Type
- REG19 : DCDC_Type
- REG2 : DCDC_Type
- REG20 : DCDC_Type
- REG21 : DCDC_Type
- REG22 : DCDC_Type
- REG23 : DCDC_Type
- REG24 : DCDC_Type
- REG3 : DCDC_Type
- REG4 : DCDC_Type
- REG5 : DCDC_Type
- REG6 : DCDC_Type
- REG7 : DCDC_Type
- REG7P : DCDC_Type
- REG8 : DCDC_Type
- REG9 : DCDC_Type
- REG_1P1 : PMU_Type
- REG_1P1_CLR : PMU_Type
- REG_1P1_SET : PMU_Type
- REG_1P1_TOG : PMU_Type
- REG_2P5 : PMU_Type
- REG_2P5_CLR : PMU_Type
- REG_2P5_SET : PMU_Type
- REG_2P5_TOG : PMU_Type
- REG_3P0 : PMU_Type
- REG_3P0_CLR : PMU_Type
- REG_3P0_SET : PMU_Type
- REG_3P0_TOG : PMU_Type
- REG_CORE : PMU_Type
- REG_CORE_CLR : PMU_Type
- REG_CORE_SET : PMU_Type
- REG_CORE_TOG : PMU_Type
- REGATTR : IEE_Type
- regCtrl : _elcdif_pixel_format_reg
- regCtrl1 : _elcdif_pixel_format_reg
- REGION0_BOT_ADDR : IEE_APC_Type
- REGION0_RDC_D0 : IEE_APC_Type
- REGION0_RDC_D1 : IEE_APC_Type
- REGION0_TOP_ADDR : IEE_APC_Type
- region0AddrOffset : _bee_region_config
- Region0BaseAddress : _xecc_config
- Region0EndAddress : _xecc_config
- region0Mode : _bee_region_config
- region0SecLevel : _bee_region_config
- REGION1_BOT : BEE_Type
- REGION1_BOT_ADDR : IEE_APC_Type
- REGION1_RDC_D0 : IEE_APC_Type
- REGION1_RDC_D1 : IEE_APC_Type
- REGION1_TOP : BEE_Type
- REGION1_TOP_ADDR : IEE_APC_Type
- region1AddrOffset : _bee_region_config
- Region1BaseAddress : _xecc_config
- region1Bot : _bee_region_config
- Region1EndAddress : _xecc_config
- region1Mode : _bee_region_config
- region1SecLevel : _bee_region_config
- region1Top : _bee_region_config
- REGION2_BOT_ADDR : IEE_APC_Type
- REGION2_RDC_D0 : IEE_APC_Type
- REGION2_RDC_D1 : IEE_APC_Type
- REGION2_TOP_ADDR : IEE_APC_Type
- Region2BaseAddress : _xecc_config
- Region2EndAddress : _xecc_config
- REGION3_BOT_ADDR : IEE_APC_Type
- REGION3_RDC_D0 : IEE_APC_Type
- REGION3_RDC_D1 : IEE_APC_Type
- REGION3_TOP_ADDR : IEE_APC_Type
- Region3BaseAddress : _xecc_config
- Region3EndAddress : _xecc_config
- REGION4_BOT_ADDR : IEE_APC_Type
- REGION4_RDC_D0 : IEE_APC_Type
- REGION4_RDC_D1 : IEE_APC_Type
- REGION4_TOP_ADDR : IEE_APC_Type
- REGION5_BOT_ADDR : IEE_APC_Type
- REGION5_RDC_D0 : IEE_APC_Type
- REGION5_RDC_D1 : IEE_APC_Type
- REGION5_TOP_ADDR : IEE_APC_Type
- REGION6_BOT_ADDR : IEE_APC_Type
- REGION6_RDC_D0 : IEE_APC_Type
- REGION6_RDC_D1 : IEE_APC_Type
- REGION6_TOP_ADDR : IEE_APC_Type
- REGION7_BOT_ADDR : IEE_APC_Type
- REGION7_RDC_D0 : IEE_APC_Type
- REGION7_RDC_D1 : IEE_APC_Type
- REGION7_TOP_ADDR : IEE_APC_Type
- region_table : rtems_flashdev
- regions : rtems_flashdev_region_table
- Registers : _Thread_Control
- registers : rtems_debugger_threads
- Registry_node : Chain_Iterator
- REGKEY1 : IEE_Type
- REGKEY2 : IEE_Type
- REGPO : IEE_Type
- regs : DevGrlibReqApbuartInbyteNonblocking_Context, mpc55xx_dspi_bus_entry
- RegularContMode : DFSDM_Filter_HandleTypeDef
- RegularParam : DFSDM_Filter_InitTypeDef
- RegularTrigger : DFSDM_Filter_HandleTypeDef
- regulatorStrength : _pmu_gpc_body_bias_config
- REIE : CAAM_Type
- REIF : CAAM_Type
- REIH : CAAM_Type
- REIR0JR : CAAM_Type
- REIR0RTIC : CAAM_Type
- REIR2JR : CAAM_Type
- REIR2RTIC : CAAM_Type
- REIR4JR : CAAM_Type
- REIR4RTIC : CAAM_Type
- REIR5JR : CAAM_Type
- REIR5RTIC : CAAM_Type
- REIS : CAAM_Type
- rel : rtems_rtl_tramp_reloc, rtems_rtl_unresolv_reloc
- RelCardAdd : HAL_MMC_CardInfoTypeDef, HAL_SD_CardInfoTypeDef
- release : _rtems_rfs_file_system
- release_count : _rtems_rfs_file_system
- release_job : Scheduler_Operations
- release_job_counter : RtemsRatemonReqTimeout_Context
- release_modified : _rtems_rfs_file_system
- release_modified_count : _rtems_rfs_file_system
- released : _Regulator_Statistics, rtems_regulator_statistics
- RELOAD : CDOG_Type
- Reload : IWDG_InitTypeDef
- reloadFrequency : _pwm_config
- reloadLogic : _pwm_config
- reloadSelect : _pwm_config
- ReloadValue : RCC_CRSInitTypeDef, RCC_CRSSynchroInfoTypeDef
- reloc : rtems_rtl_unresolv_rec
- relocs : rtems_rtl_data
- relocs_size : rtems_rtl_rap
- remainingBytes : _lpi2c_master_handle
- remainingCount : _flexio_mculcd_edma_handle, _flexio_mculcd_handle, _flexio_mculcd_smartdma_handle
- remove : drvmgr_drv_ops
- remove_irq : sc16is752_context
- REND : CAAM_Type
- RepetitionCounter : TIM_Base_InitTypeDef
- reply_buffer : rtems_ftpfs_entry
- reply_current : rtems_ftpfs_entry
- reply_end : rtems_ftpfs_entry
- report_reasons : rtems_fstab_entry
- REPxR : HRTIM_Timerx_TypeDef
- req : rtems_blkdev_request
- Request : DMA_InitTypeDef, MDMA_InitTypeDef
- request : RtemsBarrierValPerf_Context, RtemsEventValPerf_Context, RtemsMessageValPerf_Context, RtemsPartValPerf_Context, RtemsRatemonReqTimeout_Context, RtemsSchedulerReqRemoveProcessor_Context, RtemsSemValPerf_Context, RtemsTaskValPerf_Context, ScoreCpuValPerf_Context, ScoreSchedSmpValSmp_Context, ScoreTqReqFlushFifo_Context, ScoreTqReqFlushPriority_Context, ScoreTqReqFlushPriorityInherit_Context, ScoreTqReqSurrender_Context, ScoreTqReqSurrenderPriorityInherit_Context, ScoreTqReqTimeout_Context, ScoreTqReqTimeoutPriorityInherit_Context
- RequestNumber : HAL_DMA_MuxRequestGeneratorConfigTypeDef, HAL_DMA_MuxSyncConfigTypeDef
- requests_left : listcb
- requestType : XBARAControlConfig
- required_by_affinity : RtemsSchedulerReqRemoveProcessor_Context
- RERRAR : CAN_Type
- RERRDR : CAN_Type
- RERRSYNR : CAN_Type
- RES1_TR3 : ADC_TypeDef
- reserve2 : _flexspi_nor_config
- reserved : _Mcid
- RESERVED : ADC_Common_TypeDef
- reserved : bootloader_api_entry_t
- RESERVED : DMA2D_TypeDef
- reserved : fh_sg_list
- RESERVED : FLASH_TypeDef, FMC_Bank3_TypeDef, HASH_TypeDef
- Reserved : MDMA_LinkNodeTypeDef
- RESERVED : OCTOSPI_TypeDef, RTC_TypeDef
- Reserved : RTEMS_PACKED, USB_OTG_HostChannelTypeDef
- Reserved0 : __attribute__
- reserved0 : _flexspi_mem_config, _flexspi_nor_config, _FlexSPIConfig
- RESERVED0 : DSI_TypeDef, DTS_TypeDef, FLASH_TypeDef
- reserved0 : flexspi_nor_driver_interface_t
- RESERVED0 : FMC_Bank2_TypeDef, GPV_TypeDef, HRTIM_Common_TypeDef, HRTIM_Master_TypeDef, HRTIM_Timerx_TypeDef, LTDC_Layer_TypeDef, LTDC_TypeDef, MDMA_Channel_TypeDef, PWR_TypeDef
- reserved0 : QspiInstFrame_t::_QspiInstFrame::_QspiInstFrameBM
- RESERVED0 : RTC_TypeDef
- Reserved0 : RTEMS_PACKED
- RESERVED0 : SAI_TypeDef, SDMMC_TypeDef, SPI_TypeDef, TAMP_TypeDef
- Reserved04 : USB_OTG_INEndpointTypeDef, USB_OTG_OUTEndpointTypeDef
- Reserved0C : USB_OTG_DeviceTypeDef, USB_OTG_INEndpointTypeDef, USB_OTG_OUTEndpointTypeDef
- Reserved1 : __attribute__
- reserved1 : _flexspi_mem_config, _FlexSPIConfig, _ivt_, _pmu_well_bias_option
- RESERVED1 : ADC_TypeDef, DSI_TypeDef, DTS_TypeDef, EXTI_Core_TypeDef, EXTI_TypeDef, FDCAN_GlobalTypeDef, FLASH_TypeDef
- reserved1 : flexspi_nor_driver_interface_t
- RESERVED1 : GFXMMU_TypeDef, GPV_TypeDef
- Reserved1 : HAL_MMC_CardCIDTypeDef, HAL_MMC_CardCSDTypeDef, HAL_SD_CardCIDTypeDef, HAL_SD_CardCSDTypeDef
- RESERVED1 : HRTIM_Master_TypeDef, LPTIM_TypeDef, LTDC_Layer_TypeDef, LTDC_TypeDef, OCTOSPI_TypeDef, PSSI_TypeDef, PWR_TypeDef
- reserved1 : QspiInstFrame_t::_QspiInstFrame::_QspiInstFrameBM
- RESERVED1 : RCC_TypeDef, RTC_TypeDef
- Reserved1 : RTEMS_PACKED
- RESERVED1 : SDMMC_TypeDef, SPI_TypeDef, SWPMI_TypeDef, SYSCFG_TypeDef, TAMP_TypeDef, TIM_TypeDef, TTCAN_TypeDef
- RESERVED10 : DBGMCU_TypeDef, DSI_TypeDef, GPV_TypeDef, OCTOSPI_TypeDef, RCC_Core_TypeDef, RCC_TypeDef
- RESERVED11 : GPV_TypeDef, OCTOSPI_TypeDef, RCC_TypeDef
- RESERVED117 : GPV_TypeDef
- RESERVED118 : GPV_TypeDef
- RESERVED119 : GPV_TypeDef
- RESERVED12 : GPV_TypeDef, OCTOSPI_TypeDef, RCC_TypeDef
- RESERVED120 : GPV_TypeDef
- RESERVED121 : GPV_TypeDef
- RESERVED122 : GPV_TypeDef
- RESERVED123 : GPV_TypeDef
- RESERVED124 : GPV_TypeDef
- RESERVED125 : GPV_TypeDef
- RESERVED126 : GPV_TypeDef
- RESERVED13 : GPV_TypeDef, OCTOSPI_TypeDef, RCC_TypeDef
- RESERVED14 : GPV_TypeDef, OCTOSPI_TypeDef
- RESERVED15 : GPV_TypeDef, OCTOSPI_TypeDef
- RESERVED16 : GPV_TypeDef, OCTOSPI_TypeDef
- RESERVED17 : GPV_TypeDef, OCTOSPI_TypeDef
- RESERVED18 : GPV_TypeDef, OCTOSPI_TypeDef
- Reserved18 : USB_OTG_INEndpointTypeDef, USB_OTG_OUTEndpointTypeDef
- RESERVED19 : GPV_TypeDef, OCTOSPI_TypeDef
- Reserved2 : __attribute__
- reserved2 : _flexspi_mem_config, _FlexSPIConfig, _ivt_, _pmu_well_bias_option
- RESERVED2 : ADC_TypeDef, CRC_TypeDef, DSI_TypeDef, DTS_TypeDef, EXTI_Core_TypeDef, EXTI_TypeDef, FDCAN_GlobalTypeDef, FLASH_TypeDef, GFXMMU_TypeDef, GPV_TypeDef
- Reserved2 : HAL_MMC_CardCIDTypeDef, HAL_MMC_CardCSDTypeDef, HAL_SD_CardCIDTypeDef, HAL_SD_CardCSDTypeDef
- RESERVED2 : LTDC_TypeDef, OCTOSPI_TypeDef, PSSI_TypeDef
- reserved2 : QspiInstFrame_t::_QspiInstFrame::_QspiInstFrameBM
- RESERVED2 : RCC_TypeDef, RTC_TypeDef
- Reserved2 : RTEMS_PACKED
- RESERVED2 : SDMMC_TypeDef, SPDIFRX_TypeDef, SPI_TypeDef, SYSCFG_TypeDef, TAMP_TypeDef
- RESERVED20 : GPV_TypeDef, OCTOSPI_TypeDef
- Reserved20 : USB_OTG_DeviceTypeDef
- RESERVED21 : GPV_TypeDef, OCTOSPI_TypeDef
- RESERVED22 : GPV_TypeDef, OCTOSPI_TypeDef
- RESERVED23 : GPV_TypeDef
- RESERVED24 : GPV_TypeDef
- RESERVED25 : GPV_TypeDef
- RESERVED26 : GPV_TypeDef
- Reserved3 : __attribute__
- reserved3 : _flexspi_mem_config, _FlexSPIConfig, _pmu_well_bias_option
- RESERVED3 : ADC_TypeDef, DSI_TypeDef, EXTI_TypeDef, FDCAN_GlobalTypeDef, FLASH_TypeDef, GPV_TypeDef
- Reserved3 : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- RESERVED3 : LTDC_TypeDef, OCTOSPI_TypeDef, RCC_TypeDef, RTC_TypeDef
- Reserved3 : RTEMS_PACKED
- RESERVED3 : SYSCFG_TypeDef, TAMP_TypeDef
- Reserved30 : USB_OTG_GlobalTypeDef
- Reserved4 : __attribute__
- reserved4 : _flexspi_mem_config, _FlexSPIConfig
- RESERVED4 : ADC_TypeDef, DBGMCU_TypeDef, DSI_TypeDef, EXTI_TypeDef, FDCAN_GlobalTypeDef, FLASH_TypeDef, GPV_TypeDef
- Reserved4 : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- RESERVED4 : OCTOSPI_TypeDef, RCC_TypeDef, SYSCFG_TypeDef, TAMP_TypeDef
- Reserved40 : USB_OTG_DeviceTypeDef
- Reserved40C : USB_OTG_HostTypeDef
- Reserved43 : USB_OTG_GlobalTypeDef
- Reserved44 : USB_OTG_DeviceTypeDef
- RESERVED5 : ADC_TypeDef, DBGMCU_TypeDef, DSI_TypeDef, EXTI_TypeDef, FDCAN_GlobalTypeDef, GPV_TypeDef, OCTOSPI_TypeDef, RCC_TypeDef, SYSCFG_TypeDef
- RESERVED6 : ADC_TypeDef, DBGMCU_TypeDef, DSI_TypeDef, EXTI_TypeDef, FDCAN_GlobalTypeDef, GPV_TypeDef, OCTOSPI_TypeDef, RCC_TypeDef, SYSCFG_TypeDef
- Reserved6 : USB_OTG_GlobalTypeDef
- RESERVED7 : ADC_TypeDef, DBGMCU_TypeDef, DSI_TypeDef, EXTI_TypeDef, FDCAN_GlobalTypeDef, GPV_TypeDef, OCTOSPI_TypeDef, RCC_TypeDef
- RESERVED8 : ADC_TypeDef, DBGMCU_TypeDef, DSI_TypeDef, EXTI_TypeDef, GPV_TypeDef, OCTOSPI_TypeDef, RCC_TypeDef
- RESERVED9 : ADC_TypeDef, DBGMCU_TypeDef, DSI_TypeDef, GPV_TypeDef, OCTOSPI_TypeDef, RCC_Core_TypeDef, RCC_TypeDef
- Reserved9 : USB_OTG_DeviceTypeDef
- reserved_for_alignment : CPU_Interrupt_frame
- reset : grclkgate
- resetDiv : _clock_group_config
- resetPin : _smartcard_interface_config
- resetPort : _smartcard_interface_config
- resetType : _smartcard_context
- RESFIFO : ADC_Type
- resizes : Heap_Statistics
- reslist : drvmgr_bus
- resolution : _adc_config
- Resolution : ADC_InitTypeDef
- resource : drvmgr_bus_res
- RESP1 : SDMMC_TypeDef
- RESP2 : SDMMC_TypeDef
- RESP3 : SDMMC_TypeDef
- RESP4 : SDMMC_TypeDef
- RESPCMD : SDMMC_TypeDef
- response : _usdhc_command
- Response : SDMMC_CmdInitTypeDef
- responseErrorFlags : _usdhc_command
- responseType : _usdhc_command
- RESTART : CDOG_Type
- restart_counter : RtemsTaskReqDelete_Context, RtemsTaskReqRestart_Context
- restart_enable : ALT_I2C_MASTER_CONFIG_s
- restart_extension_calls : RtemsTaskReqExit_Context
- restarting : RtemsTaskReqDelete_Context, RtemsTaskReqExit_Context, RtemsTaskReqRestart_Context
- restore_scheduler : ScoreTqReqTimeoutMrsp_Context
- restoreOrder : _ssarc_group_config
- restorePriority : _ssarc_group_config
- result : DevGrlibReqApbuartInbyteNonblocking_Context, DevGrlibReqIrqampGetTimestamp_Context, rtems_rtl_unresolved_archive_reloc_data, RtemsIoReqGetchark_Context, RtemsStatusReqIsEqual_Context, RtemsStatusReqIsSuccessful_Context, RtemsStatusReqText_Context, RtemsSupportReqIsNameValid_Context
- resumeWaitCycle : _flexspi_config
- resX : Mode_params
- resY : Mode_params
- retransmissions : tftp_net_config
- retries : i2c_bus
- retryMax : _GMacb
- ReTuning : _usdhc_transfer_callback
- return_argument : Thread_Wait_information
- return_argument_second : Thread_Wait_information
- return_code : MP_packet_Prefix, Thread_Wait_information
- return_packet : MPCI_Control
- REV : ENC_Type
- REVH : ENC_Type
- Revision : __attribute__
- revolutionCountCondition : _enc_config
- RFDR : FLEXSPI_Type
- RFIFO : CSI_Type
- RFL : SWPMI_TypeDef
- RFR : I2S_Type
- RGB_ADJUST : LCDIF_Type
- RGB_ADJUST_CLR : LCDIF_Type
- RGB_ADJUST_SET : LCDIF_Type
- RGB_ADJUST_TOG : LCDIF_Type
- rgb_or_yuv : _isi_Video
- RGCFR : DMAMUX_RequestGenStatus_TypeDef
- RGCR : DMAMUX_RequestGen_TypeDef
- RGD_W0 : OTFAD_Type
- RGD_W1 : OTFAD_Type
- RGSR : DMAMUX_RequestGenStatus_TypeDef
- right : rtems_bdbuf_buffer::rtems_bdbuf_avl_node
- RightBitShift : ADC_InjOversamplingTypeDef, ADC_OversamplingTypeDef, DFSDM_Channel_InitTypeDef
- rightData : _spdif_edma_transfer
- RightDelay : SAIEx_PdmMicDelayParamTypeDef
- rightTcd : _spdif_edma_handle
- ringNum : _enet_config, _enet_handle
- RIS : PSSI_TypeDef
- RISR : CRYP_TypeDef, DCMI_TypeDef
- rJumpwidth : _flexcan_timing_config
- RLR : HSEM_TypeDef, IWDG_TypeDef
- rm_code_segment : RTEMS_PACKED
- rm_data_segment : RTEMS_PACKED
- rm_entry : RTEMS_PACKED
- rm_stack_pointer : RTEMS_PACKED
- rm_stack_segment : RTEMS_PACKED
- RMA : CAAM_Type
- RMD : CAAM_Type
- RML : CAAM_Type
- rml_code_selector : RTEMS_PACKED
- rml_data_selector : RTEMS_PACKED
- rml_entry : RTEMS_PACKED
- RMON_R_BC_PKT : ENET_Type
- RMON_R_CRC_ALIGN : ENET_Type
- RMON_R_FRAG : ENET_Type
- RMON_R_JAB : ENET_Type
- RMON_R_MC_PKT : ENET_Type
- RMON_R_OCTETS : ENET_Type
- RMON_R_OVERSIZE : ENET_Type
- RMON_R_P1024TO2047 : ENET_Type
- RMON_R_P128TO255 : ENET_Type
- RMON_R_P256TO511 : ENET_Type
- RMON_R_P512TO1023 : ENET_Type
- RMON_R_P64 : ENET_Type
- RMON_R_P65TO127 : ENET_Type
- RMON_R_P_GTE2048 : ENET_Type
- RMON_R_PACKETS : ENET_Type
- RMON_R_UNDERSIZE : ENET_Type
- RMON_T_BC_PKT : ENET_Type
- RMON_T_COL : ENET_Type
- RMON_T_CRC_ALIGN : ENET_Type
- RMON_T_FRAG : ENET_Type
- RMON_T_JAB : ENET_Type
- RMON_T_MC_PKT : ENET_Type
- RMON_T_OCTETS : ENET_Type
- RMON_T_OVERSIZE : ENET_Type
- RMON_T_P1024TO2047 : ENET_Type
- RMON_T_P128TO255 : ENET_Type
- RMON_T_P256TO511 : ENET_Type
- RMON_T_P512TO1023 : ENET_Type
- RMON_T_P64 : ENET_Type
- RMON_T_P65TO127 : ENET_Type
- RMON_T_P_GTE2048 : ENET_Type
- RMON_T_PACKETS : ENET_Type
- RMON_T_UNDERSIZE : ENET_Type
- RMR : I2S_Type
- rmtp : CReqClockNanosleep_Context
- rmtp_obj : CReqClockNanosleep_Context
- RngClockSelection : RCC_PeriphCLKInitTypeDef
- Roff : ISI_R2Y
- ROMPATCHA : ROMC_Type
- ROMPATCHCNTL : ROMC_Type
- ROMPATCHD : ROMC_Type
- ROMPATCHENH : ROMC_Type
- ROMPATCHENL : ROMC_Type
- ROMPATCHSR : ROMC_Type
- root_dev : drvmgr
- root_directory : rtems_user_env_t
- rootloc : rtems_filesystem_eval_path_context_t
- ropMode : _elcdif_as_blend_config, _pxp_as_blend_config
- routine : RtemsIntrReqHandlerIterate_Context, Timer_Control, Timer_Scheduling_Data, Watchdog_Control
- routine_param : RtemsTimerReqFireAfter_Context, RtemsTimerReqFireWhen_Context, RtemsTimerReqServerFireAfter_Context, RtemsTimerReqServerFireWhen_Context
- routine_user_data : RtemsTimerReqFireAfter_Context, RtemsTimerReqFireWhen_Context, RtemsTimerReqReset_Context, RtemsTimerReqServerFireAfter_Context, RtemsTimerReqServerFireWhen_Context
- RowAddrCycles : XNandPsu_Geometry
- RowBitsNumber : FMC_SDRAM_InitTypeDef
- RowCycleDelay : FMC_SDRAM_TimingTypeDef
- rpath : link_map
- rpathlen : link_map, rtems_rtl_rap
- RPDelay : FMC_SDRAM_TimingTypeDef
- RQR : USART_TypeDef
- rqtp : CReqClockNanosleep_Context
- rqtp_obj : CReqClockNanosleep_Context
- RR : MU_Type
- RSEM : ENET_Type
- RSFL : ENET_Type
- rsid : lpc176x_scb
- RSR : LPSPI_Type, RCC_Core_TypeDef, RCC_TypeDef
- RSTA : CAAM_Type
- RSTC_CR : Rstc
- RSTC_MR : Rstc
- RSTC_SR : Rstc
- rstcon : lpc176x_scb
- RSTGT : SEMA4_Type
- RSTGT_R : RDC_SEMAPHORE_Type
- RSTGT_W : RDC_SEMAPHORE_Type
- RSTNTF : SEMA4_Type
- RSTx1R : HRTIM_Timerx_TypeDef
- RSTx2R : HRTIM_Timerx_TypeDef
- RSTxR : HRTIM_Timerx_TypeDef
- RsvdFieldPosition : RTEMS_PACKED
- RsvdMaskSize : RTEMS_PACKED
- RSWDT_CR : Rswdt
- RSWDT_MR : Rswdt
- RSWDT_SR : Rswdt
- rtactrl : grspwrouter
- rtbs : gr1553b
- rtc : gr1553b
- RTC_CALALR : Rtc
- RTC_CALR : Rtc
- RTC_CR : Rtc
- RTC_IDR : Rtc
- RTC_IER : Rtc
- RTC_IMR : Rtc
- RTC_MR : Rtc
- RTC_SCCR : Rtc
- RTC_SR : Rtc
- RTC_TIMALR : Rtc
- RTC_TIMR : Rtc
- RTC_VER : Rtc
- RTC_VERSION : Rtc
- RTC_WPMR : Rtc
- rtcCalEnable : _snvs_hp_rtc_config
- rtcCalValue : _snvs_hp_rtc_config
- RTCClockSelection : RCC_PeriphCLKInitTypeDef
- rtcomb : grspwrouter
- rtelip : gr1553b
- rtelm : gr1553b
- rtelp : gr1553b
- RTENT : CAAM_Type
- RTFRQCNT : CAAM_Type
- RTFRQMAX : CAAM_Type
- RTFRQMIN : CAAM_Type
- RTHR : CAAM_Type
- RTIC_DID : CAAM_Type
- RTIC_OWN : CAAM_Type
- rtl : rtems_rtl_obj_print
- rtmcc : gr1553b
- RTMCTL : CAAM_Type
- RTOR : USART_TypeDef
- RTPKRCNT10 : CAAM_Type
- RTPKRCNT32 : CAAM_Type
- RTPKRCNT54 : CAAM_Type
- RTPKRCNT76 : CAAM_Type
- RTPKRCNT98 : CAAM_Type
- RTPKRCNTBA : CAAM_Type
- RTPKRCNTDC : CAAM_Type
- RTPKRCNTFE : CAAM_Type
- RTPKRMAX : CAAM_Type
- RTPKRRNG : CAAM_Type
- RTPKRSQ : CAAM_Type
- rtpmap : grspwrouter
- rtrcfg : grspwrouter
- rts : gr1553b
- RTSBLIM : CAAM_Type
- RTSCMC : CAAM_Type
- RTSCMISC : CAAM_Type
- RTSCML : CAAM_Type
- RTSCR1C : CAAM_Type
- RTSCR1L : CAAM_Type
- RTSCR2C : CAAM_Type
- RTSCR2L : CAAM_Type
- RTSCR3C : CAAM_Type
- RTSCR3L : CAAM_Type
- RTSCR4C : CAAM_Type
- RTSCR4L : CAAM_Type
- RTSCR5C : CAAM_Type
- RTSCR5L : CAAM_Type
- RTSCR6PC : CAAM_Type
- RTSCR6PL : CAAM_Type
- RTSDCTL : CAAM_Type
- RTSR1 : EXTI_TypeDef
- RTSR2 : EXTI_TypeDef
- RTSR3 : EXTI_TypeDef
- RTSTATUS : CAAM_Type
- rtstba : gr1553b
- rtsw : gr1553b
- rtsy : gr1553b
- RTT_AR : Rtt
- RTT_MR : Rtt
- RTT_SR : Rtt
- RTT_VR : Rtt
- RTTOTSAM : CAAM_Type
- rtttc : gr1553b
- runBootloader : bootloader_api_entry_t
- runner_barrier_state : RtemsSignalReqCatch_Context
- runner_id : RtemsEventReqSendReceive_Context, RtemsSchedulerReqRemoveProcessor_Context, RtemsSignalReqCatch_Context, RtemsTaskReqDelete_Context, RtemsTaskReqExit_Context, RtemsTaskReqRestart_Context, RtemsTaskReqSetScheduler_Context, ScoreSchedSmpValSmp_Context, ScoreTqValSmp_Context, TQContext
- runner_mode : RtemsTaskReqMode_Context
- runner_sched : RtemsEventReqSendReceive_Context
- runner_scheduler_id : RtemsSemReqSetPriority_Context
- runner_stack : ScoreThreadValThread_Context
- runner_tcb : RtemsTaskReqDelete_Context, TQContext
- runner_thread : RtemsEventReqSendReceive_Context
- runner_wakeup : RtemsEventReqSendReceive_Context
- runningHash : _dcp_hash_ctx_internal
- RVID : CAAM_Type
- RVID_DC01 : CAAM_Type
- RVID_JR : CAAM_Type
- RVID_RTIC : CAAM_Type
- RW : AUDIO_PLL_Type, ETHERNET_PLL_Type, OSC_RC_400M_Type, PHY_LDO_Type, VIDEO_MUX_Type, VIDEO_PLL_Type, VMBANDGAP_Type
- RWD : FDCAN_GlobalTypeDef
- RWDOG : CAAM_Type
- rx : _lpi2c_master_edma_handle, spictrl
- RX : USBPHY_Type
- RX14MASK : CAN_Type
- RX15MASK : CAN_Type
- RX_BUF : EMVSIM_Type
- rx_buf : spi_ioc_transfer
- RX_CLR : USBPHY_Type
- RX_ERROR_STATUS : DSI_HOST_Type
- rx_nbits : spi_ioc_transfer
- RX_SET : USBPHY_Type
- RX_STATUS : EMVSIM_Type
- RX_THD : EMVSIM_Type
- rx_timeout_constant_ms : _lpuart_rtos_config
- rx_timeout_multiplier_ms : _lpuart_rtos_config
- RX_TOG : USBPHY_Type
- rxAccelerConfig : _enet_config
- RxAddr64bit : XQspiPsu_Msg
- rxAttribute : _enet_rx_frame_struct
- RXBC : FDCAN_GlobalTypeDef
- rxBdBase : _enet_rx_bd_ring
- rxBdNumber : _enet_buffer_config
- rxBdRing : _enet_handle
- rxBdStartAddrAlign : _enet_buffer_config
- RxBfrPtr : XQspiPsu_Msg
- rxBuffAlloc : _enet_config, _enet_handle
- rxBuffArray : _enet_rx_frame_struct
- rxBuffer : _flexspi_xfer
- rxBufferAlign : _enet_buffer_config
- RxBufferingMode : SWPMI_InitTypeDef
- rxBuffFree : _enet_config, _enet_handle
- rxBuffIfNull : _lpspi_master_edma_handle, _lpspi_slave_edma_handle
- rxBuffSizeAlign : _enet_buffer_config, _enet_handle
- RxBytes : XQspiPsu
- RXCDRP : DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type
- RxChNum : _Qspid
- RXCNT : CSI_Type
- RXCRC : SPI_TypeDef
- RxCRCInitializationPattern : SPI_InitTypeDef
- rxData : _dsi_transfer, _flexio_spi_master_handle, _flexio_spi_transfer, _flexio_uart_handle, _flexio_uart_transfer, _lpspi_master_edma_handle, _lpspi_master_handle, _lpspi_slave_edma_handle, _lpspi_slave_handle, _lpspi_transfer, _lpuart_handle, _lpuart_transfer, _usdhc_data
- rxDataMatchOnly : _lpi2c_match_config
- rxDataSize : _dsi_transfer, _flexio_uart_handle, _lpuart_handle
- rxDataSizeAll : _flexio_uart_dma_handle, _flexio_uart_edma_handle, _flexio_uart_handle, _lpuart_dma_handle, _lpuart_edma_handle, _lpuart_handle
- rxDmaHandle : _flexio_mculcd_edma_handle, _flexio_uart_dma_handle, _flexspi_dma_handle, _flexspi_edma_handle, _lpuart_dma_handle
- rxDoneFlag : _ILI9488_ctl
- RXDR : CEC_TypeDef, I2C_TypeDef, SPI_TypeDef
- rxEdmaHandle : _flexio_camera_edma_handle, _flexio_uart_edma_handle, _lpuart_edma_handle
- rxEdmaModulo : _flexio_mculcd_edma_handle
- RXESC : FDCAN_GlobalTypeDef
- RxEventType : __UART_HandleTypeDef
- RXF0A : FDCAN_GlobalTypeDef
- RXF0C : FDCAN_GlobalTypeDef
- RXF0S : FDCAN_GlobalTypeDef
- RXF1A : FDCAN_GlobalTypeDef
- RXF1C : FDCAN_GlobalTypeDef
- RXF1S : FDCAN_GlobalTypeDef
- RXFGMASK : CAN_Type
- rxFifoEdmaHandle : _flexcan_edma_handle
- rxFifoEmptyThreshold : _enet_config
- rxFifoFrameBuf : _flexcan_handle
- rxFifoFrameNum : _flexcan_handle
- rxFifoFullThreshold : _enet_config
- rxFifoState : _flexcan_edma_handle, _flexcan_handle
- rxFifoThreshold : _smartcard_context
- rxFifoTransferTotalNum : _flexcan_handle
- RXFIR : CAN_Type
- rxFrameError : _enet_rx_frame_struct
- rxFullSelect : _spdif_config
- rxGenIdx : _enet_rx_bd_ring
- rxHandle : _flexio_spi_master_dma_handle, _flexio_spi_master_edma_handle
- RXIC : ENET_Type
- rxIdleConfig : _lpuart_config
- rxIdleType : _lpuart_config
- RXIMR : CAN_Type
- rxInProgress : _flexio_spi_master_dma_handle, _flexio_spi_master_edma_handle
- RxISR : __I2S_HandleTypeDef, __SMARTCARD_HandleTypeDef, __SPI_HandleTypeDef, __UART_HandleTypeDef, __USART_HandleTypeDef
- RXLPRP : DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type
- rxMaintainEnable : _enet_buffer_config, _enet_handle
- rxMaxFrameLen : _enet_config
- RXMGMASK : CAN_Type
- rxPinIndex : _flexio_i2s_type
- RxPinIndex : _flexio_uart_type
- RxPinLevelInvert : SMARTCARD_AdvFeatureInitTypeDef, UART_AdvFeatureInitTypeDef
- rxPinPolarity : _flexio_i2s_config
- rxRemainingByteCount : _lpspi_master_edma_handle, _lpspi_master_handle, _lpspi_slave_edma_handle, _lpspi_slave_handle
- rxRemainingBytes : _flexio_spi_master_handle
- rxRingBuffer : _flexio_uart_handle, _lpuart_handle
- rxRingBufferHead : _flexio_uart_handle, _lpuart_handle
- rxRingBufferSize : _flexio_uart_handle, _lpuart_handle
- rxRingBufferTail : _flexio_uart_handle, _lpuart_handle
- rxRingLen : _enet_rx_bd_ring
- rxSampleClock : _flexspi_config
- rxShifterEndIndex : _flexio_mculcd_type
- rxShifterIndex : _flexio_i2s_type
- rxShifterNum : _flexio_mculcd_edma_handle
- rxShifterStartIndex : _flexio_mculcd_type
- rxSize : _flexio_camera_edma_handle, _flexspi_xfer
- RxSize : _SpidCmd, AfeCmd
- RxState : __SMARTCARD_HandleTypeDef, __UART_HandleTypeDef
- rxState : _flexio_camera_edma_handle, _flexio_uart_dma_handle, _flexio_uart_edma_handle, _flexio_uart_handle, _lpuart_dma_handle, _lpuart_edma_handle, _lpuart_handle
- RxState : IRDA_HandleTypeDef
- rxtCrossed : _smartcard_context
- rxTimerPolarity : _flexio_i2s_config
- rxWatermark : _flexspi_config, _lpspi_master_edma_handle, _lpspi_master_handle, _lpspi_slave_edma_handle, _lpspi_slave_handle
- RxXferCount : __I2S_HandleTypeDef, __SMARTCARD_HandleTypeDef, __SPI_HandleTypeDef, __UART_HandleTypeDef, __USART_HandleTypeDef, IRDA_HandleTypeDef, SWPMI_HandleTypeDef
- RxXferSize : __I2S_HandleTypeDef, __SMARTCARD_HandleTypeDef, __SPI_HandleTypeDef, __UART_HandleTypeDef, __USART_HandleTypeDef, IRDA_HandleTypeDef, MMC_HandleTypeDef, SD_HandleTypeDef, SWPMI_HandleTypeDef
