RTEMS 6.1-rc4
Test context for spec:/score/tq/req/surrender test case. More...
CallWithinISRRequest request
 This member contains the call within ISR request.
SMP_barrier_Control barrier
 This member contains the barrier to synchronize the runner and the worker.
bool intend_to_block
 If this member is true, then the dequeued thread shall be in the intend to block wait state.
uint32_t expected_blocker_b_counter
 If this member contains the expected counter of worker B.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqSurrender_Run() parameter.
struct {
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqSurrender_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
