RTEMS 6.1-rc4
struct | _flexio_camera_edma_handle |
Camera eDMA handle. More... | |
Driver version | |
typedef struct _flexio_camera_edma_handle | flexio_camera_edma_handle_t |
Forward declaration of the handle typedef. | |
typedef void(* | flexio_camera_edma_transfer_callback_t) (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle, status_t status, void *userData) |
Camera transfer callback function. | |
#define | FSL_FLEXIO_CAMERA_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 1, 3)) |
FlexIO Camera EDMA driver version 2.1.3. | |
eDMA transactional | |
status_t | FLEXIO_CAMERA_TransferCreateHandleEDMA (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle, flexio_camera_edma_transfer_callback_t callback, void *userData, edma_handle_t *rxEdmaHandle) |
Initializes the Camera handle, which is used in transactional functions. | |
status_t | FLEXIO_CAMERA_TransferReceiveEDMA (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle, flexio_camera_transfer_t *xfer) |
Receives data using eDMA. | |
void | FLEXIO_CAMERA_TransferAbortReceiveEDMA (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle) |
Aborts the receive data which used the eDMA. | |
status_t | FLEXIO_CAMERA_TransferGetReceiveCountEDMA (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle, size_t *count) |
Gets the remaining bytes to be received. | |
void FLEXIO_CAMERA_TransferAbortReceiveEDMA | ( | FLEXIO_CAMERA_Type * | base, |
flexio_camera_edma_handle_t * | handle | ||
This function aborts the receive data which used the eDMA.
base | Pointer to the FLEXIO_CAMERA_Type. |
handle | Pointer to the flexio_camera_edma_handle_t structure. |
status_t FLEXIO_CAMERA_TransferCreateHandleEDMA | ( | FLEXIO_CAMERA_Type * | base, |
flexio_camera_edma_handle_t * | handle, | ||
flexio_camera_edma_transfer_callback_t | callback, | ||
void * | userData, | ||
edma_handle_t * | rxEdmaHandle | ||
handle | Pointer to flexio_camera_edma_handle_t structure. |
callback | The callback function. |
userData | The parameter of the callback function. |
rxEdmaHandle | User requested DMA handle for RX DMA transfer. |
kStatus_Success | Successfully create the handle. |
kStatus_OutOfRange | The FlexIO Camera eDMA type/handle table out of range. |
status_t FLEXIO_CAMERA_TransferGetReceiveCountEDMA | ( | FLEXIO_CAMERA_Type * | base, |
size_t * | count | ||
This function gets the number of bytes still not received.
count | Number of bytes sent so far by the non-blocking transaction. |
kStatus_Success | Succeed get the transfer count. |
kStatus_InvalidArgument | The count parameter is invalid. |
status_t FLEXIO_CAMERA_TransferReceiveEDMA | ( | FLEXIO_CAMERA_Type * | base, |
flexio_camera_transfer_t * | xfer | ||
This function receives data using eDMA. This is a non-blocking function, which returns right away. When all data is received, the receive callback function is called.
xfer | Camera eDMA transfer structure, see flexio_camera_transfer_t. |
kStatus_Success | if succeeded, others failed. |
kStatus_CAMERA_RxBusy | Previous transfer on going. |
flexio_camera_edma_transfer_callback_t _flexio_camera_edma_handle::callback |
Callback function.
uint8_t _flexio_camera_edma_handle::nbytes |
eDMA minor byte transfer count initially configured.
edma_handle_t* _flexio_camera_edma_handle::rxEdmaHandle |
The eDMA RX channel used.
size_t _flexio_camera_edma_handle::rxSize |
Total bytes to be received.
volatile uint8_t _flexio_camera_edma_handle::rxState |
RX transfer state
void* _flexio_camera_edma_handle::userData |
Camera callback function parameter.
