RTEMS 6.1-rc4
Test context for spec:/rtems/status/req/text test case. More...
rtems_status_code code
 This member specifies the status_code parameter value.
const char * result
 This member contains the return value of the rtems_status_text() call.
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsStatusReqText_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
