RTEMS 6.1-rc4
Data Structures | Variables
Lpuart_edma_driver
struct  _lpuart_edma_handle
 LPUART eDMA handle. More...
lpuart_edma_transfer_callback_t _lpuart_edma_handle::callback
void * _lpuart_edma_handle::userData
size_t _lpuart_edma_handle::rxDataSizeAll
size_t _lpuart_edma_handle::txDataSizeAll
edma_handle_t_lpuart_edma_handle::txEdmaHandle
edma_handle_t_lpuart_edma_handle::rxEdmaHandle
uint8_t _lpuart_edma_handle::nbytes
volatile uint8_t _lpuart_edma_handle::txState
volatile uint8_t _lpuart_edma_handle::rxState
Driver version
typedef struct _lpuart_edma_handle lpuart_edma_handle_t
typedef void(* lpuart_edma_transfer_callback_t) (LPUART_Type *base, lpuart_edma_handle_t *handle, status_t status, void *userData)
 LPUART transfer callback function.
#define FSL_LPUART_EDMA_DRIVER_VERSION   (MAKE_VERSION(2, 6, 0))
 LPUART EDMA driver version.
eDMA transactional
void LPUART_TransferCreateHandleEDMA (LPUART_Type *base, lpuart_edma_handle_t *handle, lpuart_edma_transfer_callback_t callback, void *userData, edma_handle_t *txEdmaHandle, edma_handle_t *rxEdmaHandle)
 Initializes the LPUART handle which is used in transactional functions.
status_t LPUART_SendEDMA (LPUART_Type *base, lpuart_edma_handle_t *handle, lpuart_transfer_t *xfer)
 Sends data using eDMA.
status_t LPUART_ReceiveEDMA (LPUART_Type *base, lpuart_edma_handle_t *handle, lpuart_transfer_t *xfer)
 Receives data using eDMA.
void LPUART_TransferAbortSendEDMA (LPUART_Type *base, lpuart_edma_handle_t *handle)
 Aborts the sent data using eDMA.
void LPUART_TransferAbortReceiveEDMA (LPUART_Type *base, lpuart_edma_handle_t *handle)
 Aborts the received data using eDMA.
status_t LPUART_TransferGetSendCountEDMA (LPUART_Type *base, lpuart_edma_handle_t *handle, uint32_t *count)
 Gets the number of bytes written to the LPUART TX register.
status_t LPUART_TransferGetReceiveCountEDMA (LPUART_Type *base, lpuart_edma_handle_t *handle, uint32_t *count)
 Gets the number of received bytes.
void LPUART_TransferEdmaHandleIRQ (LPUART_Type *base, void *lpuartEdmaHandle)
 LPUART eDMA IRQ handle function.
◆ LPUART_ReceiveEDMA()
status_t LPUART_ReceiveEDMA ( LPUART_Type base,
lpuart_edma_handle_t handle,
lpuart_transfer_t xfer
This function receives data using eDMA. This is non-blocking function, which returns right away. When all data is received, the receive callback function is called.
Parameters
baseLPUART peripheral base address.
handlePointer to lpuart_edma_handle_t structure.
xferLPUART eDMA transfer structure, see lpuart_transfer_t.
Return values
kStatus_Successif succeed, others fail.
kStatus_LPUART_RxBusyPrevious transfer ongoing.
kStatus_InvalidArgumentInvalid argument.
brief Receives data using eDMA.
param base LPUART peripheral base address. param handle Pointer to lpuart_edma_handle_t structure. param xfer LPUART eDMA transfer structure, see lpuart_transfer_t. retval kStatus_Success if succeed, others fail. retval kStatus_LPUART_RxBusy Previous transfer ongoing. retval kStatus_InvalidArgument Invalid argument.
◆ LPUART_SendEDMA()
status_t LPUART_SendEDMA ( LPUART_Type base,
This function sends data using eDMA. This is a non-blocking function, which returns right away. When all data is sent, the send callback function is called.
Parameters
handleLPUART handle pointer.
xferLPUART eDMA transfer structure. See lpuart_transfer_t.
Return values
kStatus_Successif succeed, others failed.
kStatus_LPUART_TxBusyPrevious transfer on going.
brief Sends data using eDMA.
param base LPUART peripheral base address. param handle LPUART handle pointer. param xfer LPUART eDMA transfer structure. See lpuart_transfer_t. retval kStatus_Success if succeed, others failed. retval kStatus_LPUART_TxBusy Previous transfer on going. retval kStatus_InvalidArgument Invalid argument.
◆ LPUART_TransferAbortReceiveEDMA()
void LPUART_TransferAbortReceiveEDMA ( LPUART_Type base,
This function aborts the received data using eDMA.
Parameters
brief Aborts the received data using eDMA.
◆ LPUART_TransferAbortSendEDMA()
void LPUART_TransferAbortSendEDMA ( LPUART_Type base,
This function aborts the sent data using eDMA.
Parameters
brief Aborts the sent data using eDMA.
◆ LPUART_TransferCreateHandleEDMA()
void LPUART_TransferCreateHandleEDMA ( LPUART_Type base,
void *  userData,
edma_handle_t txEdmaHandle,
edma_handle_t rxEdmaHandle
Note
This function disables all LPUART interrupts.
Parameters
callbackCallback function.
userDataUser data.
txEdmaHandleUser requested DMA handle for TX DMA transfer.
rxEdmaHandleUser requested DMA handle for RX DMA transfer.
brief Initializes the LPUART handle which is used in transactional functions.
note This function disables all LPUART interrupts.
param base LPUART peripheral base address. param handle Pointer to lpuart_edma_handle_t structure. param callback Callback function. param userData User data. param txEdmaHandle User requested DMA handle for TX DMA transfer. param rxEdmaHandle User requested DMA handle for RX DMA transfer.
◆ LPUART_TransferEdmaHandleIRQ()
void LPUART_TransferEdmaHandleIRQ ( LPUART_Type base,
void *  lpuartEdmaHandle
This function handles the LPUART tx complete IRQ request and invoke user callback. It is not set to static so that it can be used in user application.
Note
This function is used as default IRQ handler by double weak mechanism. If user's specific IRQ handler is implemented, make sure this function is invoked in the handler.
Parameters
lpuartEdmaHandleLPUART handle pointer.
brief LPUART eDMA IRQ handle function.
This function handles the LPUART tx complete IRQ request and invoke user callback. It is not set to static so that it can be used in user application. note This function is used as default IRQ handler by double weak mechanism. If user's specific IRQ handler is implemented, make sure this function is invoked in the handler.
param base LPUART peripheral base address. param lpuartEdmaHandle LPUART handle pointer.
◆ LPUART_TransferGetReceiveCountEDMA()
status_t LPUART_TransferGetReceiveCountEDMA ( LPUART_Type base,
uint32_t *  count
This function gets the number of received bytes.
Parameters
countReceive bytes count.
Return values
kStatus_NoTransferInProgressNo receive in progress.
kStatus_InvalidArgumentParameter is invalid.
kStatus_SuccessGet successfully through the parameter count;
brief Gets the number of received bytes.
param base LPUART peripheral base address. param handle LPUART handle pointer. param count Receive bytes count. retval kStatus_NoTransferInProgress No receive in progress. retval kStatus_InvalidArgument Parameter is invalid. retval kStatus_Success Get successfully through the parameter count;
◆ LPUART_TransferGetSendCountEDMA()
status_t LPUART_TransferGetSendCountEDMA ( LPUART_Type base,
uint32_t *  count
This function gets the number of bytes written to the LPUART TX register by DMA.
Parameters
countSend bytes count.
Return values
kStatus_NoTransferInProgressNo send in progress.
brief Gets the number of bytes written to the LPUART TX register.
param base LPUART peripheral base address. param handle LPUART handle pointer. param count Send bytes count. retval kStatus_NoTransferInProgress No send in progress. retval kStatus_InvalidArgument Parameter is invalid. retval kStatus_Success Get successfully through the parameter count;
Variable Documentation
◆ callback
Callback function.
◆ nbytes
eDMA minor byte transfer count initially configured.
◆ rxDataSizeAll
Size of the data to receive.
◆ rxEdmaHandle
edma_handle_t* _lpuart_edma_handle::rxEdmaHandle
The eDMA RX channel used.
◆ rxState
RX transfer state
◆ txDataSizeAll
Size of the data to send out.
◆ txEdmaHandle
edma_handle_t* _lpuart_edma_handle::txEdmaHandle
The eDMA TX channel used.
◆ txState
TX transfer state.
◆ userData
void* _lpuart_edma_handle::userData
LPUART callback function parameter.
