RTEMS 6.1-rc4
Test context for spec:/rtems/task/req/mode test case. More...
rtems_id worker_id
 This member contains the object identifier of the worker task.
rtems_mode runner_mode
 null If this member is contains the initial mode of the runner.
rtems_mode previous_mode_set_value
 This member provides a value for the previous mode set.
rtems_mode current_mode
 This member specifies the task mode in which rtems_task_mode() is called.
uint32_t worker_counter
 This member counts worker activity.
uint32_t worker_counter_before
 This member contains worker counter before the rtems_task_mode() call.
uint32_t worker_counter_after
 This member contains worker counter after the rtems_task_mode() call.
uint32_t signal_counter
 This member counts signal handler activity.
uint32_t signal_counter_before
 This member contains signal counter before the rtems_task_mode() call.
uint32_t signal_counter_after
 This member contains signal counter after the rtems_task_mode() call.
rtems_mode mode_set
 This member specifies the mode_set parameter for rtems_task_mode().
rtems_mode mode_mask
 This member specifies the mode mask mask parameter for rtems_task_mode() for the action.
rtems_modeprevious_mode_set
 This member specifies the previous mode set previous_mode_set parameter for rtems_task_mode().
rtems_status_code status
 This member contains the return status of the rtems_task_mode() call.
struct {
   size_t   pcs [13]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTaskReqMode_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
