RTEMS 6.1-rc4
Data Structures | Variables
Flexcan_edma_driver
struct  _flexcan_edma_handle
 FlexCAN eDMA handle. More...
flexcan_edma_transfer_callback_t _flexcan_edma_handle::callback
void * _flexcan_edma_handle::userData
edma_handle_t_flexcan_edma_handle::rxFifoEdmaHandle
volatile uint8_t _flexcan_edma_handle::rxFifoState
size_t _flexcan_edma_handle::frameNum
Driver version
typedef struct _flexcan_edma_handle flexcan_edma_handle_t
typedef void(* flexcan_edma_transfer_callback_t) (CAN_Type *base, flexcan_edma_handle_t *handle, status_t status, void *userData)
 FlexCAN transfer callback function.
#define FSL_FLEXCAN_EDMA_DRIVER_VERSION   (MAKE_VERSION(2, 9, 2))
 FlexCAN EDMA driver version.
eDMA transactional
void FLEXCAN_TransferCreateHandleEDMA (CAN_Type *base, flexcan_edma_handle_t *handle, flexcan_edma_transfer_callback_t callback, void *userData, edma_handle_t *rxFifoEdmaHandle)
 Initializes the FlexCAN handle, which is used in transactional functions.
void FLEXCAN_PrepareTransfConfiguration (CAN_Type *base, flexcan_fifo_transfer_t *pFifoXfer, edma_transfer_config_t *pEdmaConfig)
 Prepares the eDMA transfer configuration for FLEXCAN Legacy RX FIFO.
status_t FLEXCAN_StartTransferDatafromRxFIFO (CAN_Type *base, flexcan_edma_handle_t *handle, edma_transfer_config_t *pEdmaConfig)
 Start Transfer Data from the FLEXCAN Legacy Rx FIFO using eDMA.
status_t FLEXCAN_TransferReceiveFifoEDMA (CAN_Type *base, flexcan_edma_handle_t *handle, flexcan_fifo_transfer_t *pFifoXfer)
 Receives the CAN Message from the Legacy Rx FIFO using eDMA.
status_t FLEXCAN_TransferGetReceiveFifoCountEMDA (CAN_Type *base, flexcan_edma_handle_t *handle, size_t *count)
 Gets the Legacy Rx Fifo transfer status during a interrupt non-blocking receive.
void FLEXCAN_TransferAbortReceiveFifoEDMA (CAN_Type *base, flexcan_edma_handle_t *handle)
 Aborts the receive Legacy/Enhanced Rx FIFO process which used eDMA.
◆ FLEXCAN_PrepareTransfConfiguration()
void FLEXCAN_PrepareTransfConfiguration ( CAN_Type base,
flexcan_fifo_transfer_t pFifoXfer,
edma_transfer_config_t pEdmaConfig
This function prepares the eDMA transfer configuration structure according to FLEXCAN Legacy RX FIFO.
Parameters
baseFlexCAN peripheral base address.
pFifoXferFlexCAN Rx FIFO EDMA transfer structure, see flexcan_fifo_transfer_t.
pEdmaConfigThe user configuration structure of type edma_transfer_t.
◆ FLEXCAN_StartTransferDatafromRxFIFO()
status_t FLEXCAN_StartTransferDatafromRxFIFO ( CAN_Type base,
flexcan_edma_handle_t handle,
This function to Update edma transfer confiugration and Start eDMA transfer
Parameters
handlePointer to flexcan_edma_handle_t structure.
Return values
kStatus_Successif succeed, others failed.
kStatus_FLEXCAN_RxFifoBusyPrevious transfer ongoing.
◆ FLEXCAN_TransferAbortReceiveFifoEDMA()
void FLEXCAN_TransferAbortReceiveFifoEDMA ( CAN_Type base,
This function aborts the receive Legacy/Enhanced Rx FIFO process which used eDMA.
Parameters
◆ FLEXCAN_TransferCreateHandleEDMA()
void FLEXCAN_TransferCreateHandleEDMA ( CAN_Type base,
void *  userData,
edma_handle_t rxFifoEdmaHandle
Parameters
callbackThe callback function.
userDataThe parameter of the callback function.
rxFifoEdmaHandleUser-requested DMA handle for Rx FIFO DMA transfer.
◆ FLEXCAN_TransferGetReceiveFifoCountEMDA()
status_t FLEXCAN_TransferGetReceiveFifoCountEMDA ( CAN_Type base,
size_t *  count
Parameters
handleFlexCAN handle pointer.
countNumber of CAN messages receive so far by the non-blocking transaction.
Return values
kStatus_InvalidArgumentcount is Invalid.
kStatus_SuccessSuccessfully return the count.
◆ FLEXCAN_TransferReceiveFifoEDMA()
status_t FLEXCAN_TransferReceiveFifoEDMA ( CAN_Type base,
This function receives the CAN Message using eDMA. This is a non-blocking function, which returns right away. After the CAN Message is received, the receive callback function is called.
Parameters
Return values
Variable Documentation
◆ callback
Callback function.
◆ frameNum
The number of messages that need to be received.
◆ rxFifoEdmaHandle
edma_handle_t* _flexcan_edma_handle::rxFifoEdmaHandle
The EDMA handler for Rx FIFO.
◆ rxFifoState
Rx FIFO transfer state.
◆ userData
void* _flexcan_edma_handle::userData
FlexCAN callback function parameter.
