RTEMS 6.1-rc4
Data Structures | Data Fields
rtems_bdbuf_buffer Struct Reference
#include <bdbuf.h>
struct  rtems_bdbuf_avl_node
rtems_chain_node link
struct rtems_bdbuf_buffer::rtems_bdbuf_avl_node avl
rtems_disk_devicedd
rtems_blkdev_bnum block
unsigned char * buffer
rtems_bdbuf_buf_state state
uint32_t waiters
rtems_bdbuf_groupgroup
uint32_t hold_timer
int references
void * user
To manage buffers we using buffer descriptors (BD). A BD holds a buffer plus a range of other information related to managing the buffer in the cache. To speed-up buffer lookup descriptors are organized in AVL-Tree. The fields 'dd' and 'block' are search keys.
Field Documentation
◆ block
rtems_blkdev_bnum rtems_bdbuf_buffer::block
block number on the device
◆ buffer
unsigned char* rtems_bdbuf_buffer::buffer
Pointer to the buffer memory area
◆ dd
rtems_disk_device* rtems_bdbuf_buffer::dd
disk device
◆ group
rtems_bdbuf_group* rtems_bdbuf_buffer::group
Pointer to the group of BDs this BD is part of.
◆ hold_timer
uint32_t rtems_bdbuf_buffer::hold_timer
Timer to indicate how long a buffer has been held in the cache modified.
◆ link
rtems_chain_node rtems_bdbuf_buffer::link
Link the BD onto a number of lists.
◆ references
int rtems_bdbuf_buffer::references
Allow reference counting by owner.
◆ state
rtems_bdbuf_buf_state rtems_bdbuf_buffer::state
State of the buffer.
◆ user
void* rtems_bdbuf_buffer::user
User data.
◆ waiters
uint32_t rtems_bdbuf_buffer::waiters
The number of threads waiting on this buffer.
