RTEMS 6.1-rc4
struct | _flexio_uart_dma_handle |
UART DMA handle. More... | |
flexio_uart_dma_transfer_callback_t | _flexio_uart_dma_handle::callback |
void * | _flexio_uart_dma_handle::userData |
size_t | _flexio_uart_dma_handle::txDataSizeAll |
size_t | _flexio_uart_dma_handle::rxDataSizeAll |
dma_handle_t * | _flexio_uart_dma_handle::txDmaHandle |
dma_handle_t * | _flexio_uart_dma_handle::rxDmaHandle |
volatile uint8_t | _flexio_uart_dma_handle::txState |
volatile uint8_t | _flexio_uart_dma_handle::rxState |
Driver version | |
typedef struct _flexio_uart_dma_handle | flexio_uart_dma_handle_t |
typedef void(* | flexio_uart_dma_transfer_callback_t) (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, status_t status, void *userData) |
UART transfer callback function. | |
#define | FSL_FLEXIO_UART_DMA_DRIVER_VERSION (MAKE_VERSION(2, 4, 0)) |
FlexIO UART DMA driver version. | |
void FLEXIO_UART_TransferAbortReceiveDMA | ( | FLEXIO_UART_Type * | base, |
flexio_uart_dma_handle_t * | handle | ||
Aborts the receive data which using DMA.
This function aborts the receive data which using DMA.
base | Pointer to FLEXIO_UART_Type structure |
handle | Pointer to flexio_uart_dma_handle_t structure |
void FLEXIO_UART_TransferAbortSendDMA | ( | FLEXIO_UART_Type * | base, |
Aborts the sent data which using DMA.
This function aborts the sent data which using DMA.
status_t FLEXIO_UART_TransferCreateHandleDMA | ( | FLEXIO_UART_Type * | base, |
flexio_uart_dma_handle_t * | handle, | ||
flexio_uart_dma_transfer_callback_t | callback, | ||
void * | userData, | ||
dma_handle_t * | txDmaHandle, | ||
dma_handle_t * | rxDmaHandle | ||
Initializes the FLEXIO_UART handle which is used in transactional functions.
base | Pointer to FLEXIO_UART_Type structure. |
handle | Pointer to flexio_uart_dma_handle_t structure. |
callback | FlexIO UART callback, NULL means no callback. |
userData | User callback function data. |
txDmaHandle | User requested DMA handle for TX DMA transfer. |
rxDmaHandle | User requested DMA handle for RX DMA transfer. |
kStatus_Success | Successfully create the handle. |
kStatus_OutOfRange | The FlexIO UART DMA type/handle table out of range. |
status_t FLEXIO_UART_TransferGetReceiveCountDMA | ( | FLEXIO_UART_Type * | base, |
size_t * | count | ||
Gets the number of bytes received.
This function gets the number of bytes received.
count | Number of bytes received so far by the non-blocking transaction. |
kStatus_NoTransferInProgress | transfer has finished or no transfer in progress. |
kStatus_Success | Successfully return the count. |
status_t FLEXIO_UART_TransferGetSendCountDMA | ( | FLEXIO_UART_Type * | base, |
Gets the number of bytes sent out.
This function gets the number of bytes sent out.
count | Number of bytes sent so far by the non-blocking transaction. |
status_t FLEXIO_UART_TransferReceiveDMA | ( | FLEXIO_UART_Type * | base, |
flexio_uart_transfer_t * | xfer | ||
Receives data using DMA.
This function receives data using DMA. This is non-blocking function, which returns right away. When all data is received, the receive callback function is called.
xfer | FLEXIO_UART DMA transfer structure, see flexio_uart_transfer_t. |
kStatus_Success | if succeed, others failed. |
kStatus_FLEXIO_UART_RxBusy | Previous transfer on going. |
status_t FLEXIO_UART_TransferSendDMA | ( | FLEXIO_UART_Type * | base, |
Sends data using DMA.
This function send data using DMA. This is non-blocking function, which returns right away. When all data is sent out, the send callback function is called.
kStatus_FLEXIO_UART_TxBusy | Previous transfer on going. |
flexio_uart_dma_transfer_callback_t _flexio_uart_dma_handle::callback |
Callback function.
size_t _flexio_uart_dma_handle::rxDataSizeAll |
Total bytes to be received.
dma_handle_t* _flexio_uart_dma_handle::rxDmaHandle |
The DMA RX channel used.
volatile uint8_t _flexio_uart_dma_handle::rxState |
RX transfer state
size_t _flexio_uart_dma_handle::txDataSizeAll |
Total bytes to be sent.
dma_handle_t* _flexio_uart_dma_handle::txDmaHandle |
The DMA TX channel used.
volatile uint8_t _flexio_uart_dma_handle::txState |
TX transfer state.
void* _flexio_uart_dma_handle::userData |
UART callback function parameter.
