RTEMS 6.1-rc4
Test context for spec:/rtems/task/req/set-scheduler test case. More...
rtems_id runner_id
 This member contains the runner task identifier.
rtems_id scheduler_a_id
 This member contains the scheduler A identifier.
rtems_id scheduler_b_id
 This member contains the scheduler B identifier.
rtems_id scheduler_d_id
 This member contains the scheduler D identifier.
rtems_id worker_id [3]
 This member contains the worker task identifiers.
rtems_id mutex_id [2]
 This member contains the mutex identifiers.
bool additional_home_priority
 If this member is true, then the task shall have an additional priority for the home scheduler.
bool second_eligible_scheduler
 If this member is true, then the task shall have a second eligible scheduler.
bool pinned
 If this member is true, then the task shall be pinned to a processor.
bool blocked
 If this member is true, then the task shall be blocked.
bool enqueued
 If this member is true, then the task shall be enqueued on a thread queue.
rtems_id scheduler_to_set_id
 This member specifies the scheduler identifier to set.
bool affinity_supported
 If this member is true, then the affinity of the task shall be supported by the scheduler.
rtems_status_code status
 This member contains the return value of the rtems_task_set_scheduler() call.
rtems_id task_id
 This member specifies if the task_id parameter value.
rtems_id scheduler_id
 This member specifies if the scheduler_id parameter value.
rtems_task_priority priority
 This member specifies if the priority parameter value.
rtems_id new_scheduler
 This member contains the identifier of the new scheduler.
rtems_task_priority new_priority [2]
 This member contains the new priorities of the task.
struct {
   size_t   pci [10]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [10]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTaskReqSetScheduler_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
